[Android] FireFly 3568j built Android image fails on emulator
91
【Android】 FireFly 3568j built Android image fails on emulator
Posted at 3/24/2023 14:17:48      View:944 | Replies:2        Print      Only Author   [Copy Link] 1#
I have two questions.
1. How do I run the image AIO-3568J_Android11_HDMI_230202.img in qemu on x86-64 Ubuntu from command line? Can I integrate this VM in Android studio?
2. I am trying to build and run the  FireFly 3568 image on the emulator.
source build/envsetup.shlunch rk3568_firefly_aioj-userdebugmake installcleanmake -j8
I run
./emulator
The emulator window is being drawed OK, but the guest system doesn't seem to start: no output on the console, the device windows is black. What can be wrong?
P.S. The filename and dl address apply to the first question, the log and the picture attached - to the 2nd.
emu_run_log.tar.gz
5.47 KB, Down times: 1
Posted at 3/24/2023 15:45:10        Only Author  2#
1. How to build Android image?
----> see https://wiki.t-firefly.com/en/Core-3568J/prepare_compile_android.html,  https://wiki.t-firefly.com/en/Co ... d11.0_firmware.html
2. AIO-3568J_Android11_HDMI_230202.img do not support in qemu on x86-64 Ubuntu from command line
Posted at 3/24/2023 17:27:09        Only Author  3#
I performed the build just like it described in the manual, in Ubuntu 18.04 podman container. Have spent a lot of time...
