ExFat Filesystem Support?
254
Posted at 12/28/2016 15:06:36      View:5693 | Replies:4        Print      Only Author   [Copy Link] 1#
Hi
Can Firefly Team add ExFat filesystem support to Firefly devices?
Lots of 1080p/4K videos are over 4GB in size and then Fat32 can't be used any more.
super moderator
Rank: 8Rank: 8
Posted at 12/29/2016 14:42:30        Only Author  2#
No ,We can't offer it unless your have solved the issue of copyright.
Posted at 1/6/2017 14:03:10        Only Author  3#
https://github.com/relan/exfat
that is the open source version of exfat for linux/unix/bsd ect.
it uses the FUSE filesystem driver and has actually been around in mainstream linux distro's for quite some time so I'm not sure what copyright issues you are referring to, could you please explain?
super moderator
Rank: 8Rank: 8
Posted at 1/7/2017 09:38:12        Only Author  4#
the exFAT is  belong to miscrsoft, if you haven't bought the rights,you can't add it in your android devices.
Posted at 1/8/2017 18:22:15        Only Author  5#
well perhaps it would be a good idea to add the FUSE support into the kernel so people who need different filesystem support can then install the required FUSE modules in the userspace?
