Station OS - Season No.12 Release
391
super moderator
Rank: 8Rank: 8
Posted at 7/24/2018 14:27:32      View:9210 | Replies:6        Print      Only Author   [Copy Link] 1#
▍Release Time
Station OS v1.2.7 - 2018.07.24 Release
▍Station OS Download
Note:【Station OS】 only supports "Firefly-RK3399" "ROC-RK3328-CC" now.
▍Update Notes
Video Player :
1. Modify the subtitle UI.
2. Add caption source selection in the caption setting option
3. Prompt the user when the playback video is not supported.
4. Added save play mode selection.
Settings :
1. Added volume control settings.
2. Fixed network and Bluetooth status confusion
MediaStation :
1. Fixed an issue where opening Device Manager crashed after adding DLNA device
2. Added support for SMB devices
File picker :
1. Add smb support
2. Optimize some operations and interfaces
3. Optimize file scanning of newly inserted storage devices
Emulations :
1. Add a display function to control the recommended game in the settings
2. Add APP new version check and download update function
3. Add simulator core information display
4. Add update warehouse function
5. Fix a bug that stuck when the search interface exited
6. Fix bugs that may be messy when the game is downloaded
7. Fixed a bug that prevented the uninstalled game from being uninstalled
8. Optimize part of the interface
9. Optimize the game scanning process
10. Limit rom simultaneous downloads to 3 (too many downloads will cause download errors)
File Manager :
1. Modify the interface UI
2. Modify the shared folder name of DLNA
Firmware Programming
Firefly-RK3399:
1. Firmware Programming:Firefly-RK3399 firmware programming >>
ROC-RK3328-CC:
1. One-Key Proramming Tool:Firefly SDCard Installer >>
2. Firmware Programming:ROC-RK3328-CC firmware programming >>
▍Station Hot Posts Collection
Posted at 7/27/2018 00:07:51        Only Author  2#
The link provided for the RK3328 board is the same as the RK3399 image, will this image work on an RK3328 board?
Posted at 7/29/2018 13:22:48        Only Author  3#
@Kenn, As mentioned by @slaeyer, v1.2.7 seems to be available only for RK339. The SDInstaller tool also does not show v1.2.7 for RK3328. Pls confirm whether RK339 image can also be used for RK3328. Thank you.
super moderator
Rank: 8Rank: 8
Posted at 7/31/2018 15:58:53        Only Author  4#
slaeyer Posted at 7/27/2018 00:07
The link provided for the RK3328 board is the same as the RK3399 image, will this image work on an R ...
Hello, Station OS for ROC-RK3328-CC v1.27 has been released, because the development of Station OS is based on Firefly-RK3399, so the release of Station OS for ROC-RK3328-CC will be a little later.
super moderator
Rank: 8Rank: 8
Posted at 7/31/2018 15:59:10        Only Author  5#
AdmiralSpock Posted at 7/29/2018 13:22
@Kenn, As mentioned by @slaeyer, v1.2.7 seems to be available only for RK339. The SDInstaller tool a ...
Posted at 8/6/2018 14:37:01        Only Author  6#
@Kenn, I ran into these blocker issues with v1.2.7  that did not let me proceed:
1. The system would not recognize my external Hard disk. I tried with both Seagate as well as WD 2TB HDD (does not have external power) connected to the USB 3.0 port. Due to this I could not try actually playing any media.
2. HDMI-CEC feature is not implemented in the Android core. Due to this, the TV remote cannot be used to interact with the Station OS. Had to test with USB mouse but this is not a usable option for me as I sit far away from the TV and Renegade box.
3. Kodi, even in Expert mode, does not support audio pass-through. So I doubt that, even if I manage to play some media, Atmos 7.1 audio will be supported.
So, overall, I was not able to use this build as a Media Center (and I am not into Retro gaming). I will look out for fixes for above mentioned issues in the 'Update Notes' of upcoming builds. Thanks!
super moderator
Rank: 8Rank: 8
Posted at 8/14/2018 14:51:10        Only Author  7#
AdmiralSpock Posted at 8/6/2018 14:37
1. The system woul ...
Thank you for your feedback, we will work hard to solve the above problems.
