Enable Gadget mode and setup Linux
32
Posted at 10/29/2018 16:23:34      View:3895 | Replies:3        Print      Only Author   [Copy Link] 1#
Hi!
Maybe someone can help me?
I need to setup Ubuntu for AIO-3399j board so it acts like Media Device whenever I plug USB3 cable into other PC or device as it is for Android image.
I already tried to activate g_mass_storage, but there is no kernel-headers for this Linux, so modprobe command is not working.
Also lsmod returns empty list.
Can somebody provide me steps how can I do this?
Thanks
Posted at 10/30/2018 09:11:45        Only Author  2#
Setup Linux need to download ubuntu firmware from here
How to flash firmware http://en.t-firefly.com/doc/product/info/id/437.html
Tutorial AIO-3399j
Posted at 10/30/2018 15:22:03        Only Author  3#
leung先森 Posted at 10/30/2018 09:11
How to flash firmware http://en.t-firefly.co ...
Yes that I already did, I configured docker with Ubuntu 16.04 and added all required libraries and cross compiler.
Then I switched to stable branch, because firefly documentation is wrong, they mentioned that they use firefly branch, but I found that kernel version in that branch is older than that in firmware.
I successfully compiled  kernel.img, resource.img with  using  rk3399-firefly-aio.dtb file ( make rk3399-firefly-aio.img -j4), but in documentation they have example with rk3399-firefly-aio-linux.dtb wich is not in kernel repository.
Then I tried to flash each NAND partition, but then my device is not booting anymore:
kernel.img -> kernel partition
resource.img -> resource partition
boot.img -> boot partition
I want enable g_mass_storage or use MTP device, so my ubuntu is detected as media device when I connect AIO 3399j board OTG to PC.
I saw that Raspberry Pi has good documentation for this, so I would appriciate somithing similar for firefly Linux - https://gist.github.com/gbaman/50b6cca61dd1c3f88f41
Can You please give me some hints?
Posted at 10/31/2018 16:55:09        Only Author  4#
istals Posted at 10/30/2018 15:22
Yes that I already did, I configured docker with Ubuntu 16.04 and added all required libraries and ...
1. You need to flash a ubuntu firmware for board. The software of the board is Android7.1 default.
2. Normally , kernel driver update just use kernel.img and resource.img , besides boot.img .
3. Ubuntu cannot support otg adb function , u can use ssh or else net tool to access the board.
