how to set the hostname on android
142
Rank: 8Rank: 8
Posted at 9/7/2015 03:56:13      View:3973 | Replies:5        Print      Only Author   [Copy Link] 1#
Hi,
I can't find any solution to set the hostname on android
I've tried to add the value in the /system/build.prop file but since I've done
"mount -o remount,rw /system" the RK3288 doesn't boot anymore, kernel stars but not the android layer
any help is more than welcomed
Thx
Mathieu
Posted at 9/7/2015 17:13:16        Only Author  2#
Which hostname do you want to change?
Please attach a screenshot.
Rank: 8Rank: 8
Posted at 9/8/2015 17:48:52        Only Author  3#
Hi
I net the value net.hostname to be set so that I can adresss our 192 Firefly plugged on the network using our local DNS
Posted at 9/11/2015 11:07:02        Only Author  4#
In /init.rc, there's the hostname setting:
on boot
# basic network init
    ifup lo
    hostname localhost
    domainname localdomain
But I doubt that you want to modify that file.
You can also use busybox to set hostname:
   busybox hostname  myname
Also, there's /system/etc/hosts, which has the list the ip and hostname.
Rank: 8Rank: 8
Posted at 9/25/2015 23:45:06        Only Author  5#
is /init.r the right place to do a ifuo etho in dhcp mode?
/system/etc/hosts is read only fs, I already tryied do to a remount rw of fs /system but it lead to the system failure and the I never succeed to repair the firefly installation which starts the kernel but not the android layer.
what I need it to set this value on system boot
[net.hostname]: [android-6a369c298c876691]
