New Topic
Firefly-RK3399 slarm64 (aarch64 unofficial slackware)
1175
vip
Rank: 6Rank: 6
Posted at 7/17/2017 00:21:40      View:29793 | Replies:37        Print      Only Author   [Copy Link] 1#
info: http://fail.pp.ua/board/75
first release only flash to MMC
howto:
1. download all http://dl.fail.pp.ua/slackware/firefly-rk3399/legacy/
2. download rkdeveloptool upgrade_tool
3. unpack Linux_Upgrade_Tool_v1.21.zip, upgrade_tool must be at the root of the image
4. place the board in Loader Mode
5. execute script ./flash_mmc.sh
super moderator
Rank: 8Rank: 8
Posted at 7/18/2017 10:36:25        Only Author  2#
vip
Rank: 6Rank: 6
Posted at 7/30/2017 23:25:05        Only Author  3#
Added acceleration for X.Org
mpv --vo xv plays 1080p, on the CPU load to 35%
donation   slarm64
vip
Rank: 6Rank: 6
Posted at 8/6/2017 22:29:44        Only Author  4#
release flash to SDCARD
1. The bootloader of the system is written to the image
2. mainline u-boot - U-Boot 2017.09-rc1-00110-gfe84c48eeb-dirty (Aug 06 2017 - 15:29:44 +0300)
howto:
2. /dev/mmcblk0 - уour memory card
     dd if=slack-current-miniroot_24Jul17-4.4.71-firefly_rk3399-build-20170806.img of=/dev/mmcblk0 bs=1M
     dd if=slack-current-xfce_24Jul17-4.4.71-firefly_rk3399-build-20170806.img of=/dev/mmcblk0 bs=1M
donation   slarm64
Posted at 8/11/2017 17:13:59        Only Author  5#
Good, thanks for sharing
2Wan
hardcore
Rank: 8Rank: 8
Posted at 8/20/2017 06:48:08        Only Author  6#
thanks
vip
Rank: 6Rank: 6
Posted at 8/22/2017 00:53:49        Only Author  7#
0. images from sdcard
1. update kernel 4.4.77
2 To flash a new loader, you need to convert the board into a maskrom
   boot from eMMC and clean boot sector: dd=/dev/zero of=/dev/mmcblk1 bs=32767 count=1
   flash uboot to mmc:  ./rkdeveloptool db rk3399_loader_v1.08.106.bin
                                     ./rkdeveloptool wl 0x40 idbloader.img
                                     ./rkdeveloptool wl 0x4000 uboot.img
                                     ./rkdeveloptool wl 0x6000 trust.img
3. after flash uboot transfer sd -> mmc, run setup after booting
donation   slarm64
Posted at 8/26/2017 09:34:08        Only Author  8#
hi, can't find flash_mmc.sh script where is it located?
cheers .
vip
Rank: 6Rank: 6
Posted at 8/27/2017 02:22:53        Only Author  9#
hi nadsat,
flash_mmc.sh is unnecessary, ш corrected the instruction.
for transfer to eMMC you need to run setup or setup.sh after booting from SD
And flash the loader as described above
donation   slarm64
Posted at 8/27/2017 03:20:42        Only Author  10#
thanks !!!
Return to List
1234
