RK3288 + ov13850 camera module => RAW
142
Rank: 8Rank: 8
Posted at 12/13/2015 23:51:49      View:5420 | Replies:9        Print      Only Author   [Copy Link] 1#
Hi,
Is there a way to retrieve RAW images from the camera module using android 5.1?
many thanks,
vip
Rank: 6Rank: 6
Posted at 12/18/2015 09:10:02        Only Author  2#
have a look at  : hardware/rockchip/camera/CameraHal/
Rank: 8Rank: 8
Posted at 12/18/2015 19:07:10        Only Author  3#
Is this the path to the driver sources or a location on where I can find a temporary raw file?
vip
Rank: 6Rank: 6
Posted at 12/19/2015 11:26:15        Only Author  4#
grep the “raw” keyword, you can find out and analys it by youself
Posted at 9/26/2017 00:24:25        Only Author  5#
Hi.
Like Macdam, I'm also looking for RAW format.
As a java/android developer, i'm not satisfied by Zhansb reply.
calling camera1 api  :
  1. camera.getParameters().getSupportedPictureFormats()
Copy the code
returns only one value ==> 256 which is the JPEG format as documented in android SDK (https://developer.android.com/re ... cs/ImageFormat.html)
Is there any plan to support RAW/YUV format ?
Is there any workaround to get this format?
Posted at 10/27/2017 06:21:16        Only Author  6#
I was able to get a "raw" (YUV422)  picture with android 5.1 running on a rk3288.
The Camera.takePicture() method takes a callback for raw as second parameter.
  1. camera.takePicture ( shutterCallback, rawCallback, jpegCallback );
Copy the code
This callback will return a null byteArray, unless you explicitly add a buffer for raw image .
  1. addRawImageCallbackBuffer.invoke(camera, bytes);
Copy the code
Surprisingly,  the method is public but not exported, so you cannot call it directly.
The pseudo-code below demonstrate how to call it by reflection.
  1. ...
  2. byte[] bytes = new byte[100000000]);
  3. android.hardware.Camera  camera = Camera.Open();
  4. ...
  5.    try {
  6.         final Method addRawImageCallbackBuffer =
  7.                 camera.getClass()
  8.                        .getDeclaredMethod("addRawImageCallbackBuffer",
  9.                                           byte[].class);
  10.         addRawImageCallbackBuffer.invoke(camera0, bytes);
  11.     } catch (Exception e) {
  12.         Log.e("RNG", "Error", e);
  13.     }
  14. ...
  15. camera.takePicture ( shutterCallback, rawCallback, jpegCallback );
  16. ...
Copy the code
For reference : https://stackoverflow.com/questi ... and-raw-takepicture
Posted at 11/3/2017 00:17:23        Only Author  7#
I have similar need for raw preview format. Currently preview only support NV21 and Yv12.
