[Linux] Error in Installing Drivers in RK 3399-PC
89
【Linux】 Error in Installing Drivers in RK 3399-PC
Posted at 8/12/2019 19:05:06      View:8568 | Replies:5        Print      Only Author   [Copy Link] 1#
I am trying to install PCIe drivers but couldn't install due to missing files. I have used "ROC-RK3399-PC-MEZZ-M2-POE-UBUNTU18.04-GPT-SDBOOT-20190625-1605.img" file for bootup. But it displays the error shown below while installing the drivers.  Could anyone suggest a way to add these files?
  1. ./arch/arm64/include/asm/opcodes.h:5:10: fatal error: ../../arm/include/asm/opcodes.h: No such file or directory
  2. #include <../../arm/include/asm/opcodes.h>
  3.           ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
  4. compilation terminated.
Copy the code
vip
Rank: 6Rank: 6
Posted at 8/13/2019 11:38:05        Only Author  2#
Hi Srikrishna, how do you install the driver?
Do you compile the driver directly on the board?
Then you need to download the full kernel source code
to the board for convenience. The Firefly root filesystem
currently does not contain the kernel headers.
Posted at 8/21/2019 17:21:16        Only Author  3#
I have now successfully installed PCIe drivers but display goes blank after reboot. When I uninstall the driver the display shows up. I am able to use the console mode but not the display mode. Here is the log:
  1. [    0.000000] Booting Linux on physical CPU 0x0
  2. [    0.000000] Initializing cgroup subsys cpuset
  3. [    0.000000] Initializing cgroup subsys cpu
  4. [    0.000000] Initializing cgroup subsys cpuacct
  5. [    0.000000] Linux version 4.4.167 (daijh@tchip14) (firefly-merged-20190124-oldrkbin: 2f18cc87774957059d9f1d6282ca47f6d6f3ce40) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #152 SMP Tue Jun 25 15:15:26 CST 2019
  6. [    0.000000] Boot CPU: AArch64 Processor [410fd034]
  7. [    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
  8. [    0.000000] bootconsole [uart0] enabled
  9. [    0.000000] On node 0 totalpages: 1007616
  10. [    0.000000]   DMA zone: 15864 pages used for memmap
  11. [    0.000000]   DMA zone: 0 pages reserved
  12. [    0.000000]   DMA zone: 1007616 pages, LIFO batch:31
  13. [    0.000000] psci: probing for conduit method from DT.
  14. [    0.000000] psci: PSCIv1.0 detected in firmware.
  15. [    0.000000] psci: Using standard PSCI v0.2 function IDs
  16. [    0.000000] psci: Trusted OS migration not required
  17. [    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ec9000 s46120 r8192 d31704 u86016
  18. [    0.000000] pcpu-alloc: s46120 r8192 d31704 u86016 alloc=21*4096
  19. [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
  20. [    0.000000] Detected VIPT I-cache on CPU0
  21. [    0.000000] CPU features: enabling workaround for ARM erratum 845719
  22. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 991752
  23. [    0.000000] Kernel command line: storagemedia=sd androidboot.mode=sd androidboot.slot_suffix= androidboot.serialno=db88e99c900a6478  rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 systemd.gpt_auto=0
  24. [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  25. [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
  26. [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
  27. [    0.000000] software IO TLB [mem 0xf7e81000-0xf7ec1000] (0MB) mapped at [ffffffc0f7e81000-ffffffc0f7ec0fff]
  28. [    0.000000] Memory: 3937416K/4030464K available (10238K kernel code, 1542K rwdata, 4164K rodata, 1088K init, 1953K bss, 93048K reserved, 0K cma-reserved)
  29. [    0.000000] Virtual kernel memory layout:
  30.                    modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  31.                    vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
  32.                      .init : 0xffffff8008ea0000 - 0xffffff8008fb0000   (  1088 KB)
  33.                      .text : 0xffffff8008080000 - 0xffffff8008a80000   ( 10240 KB)
  34.                    .rodata : 0xffffff8008a80000 - 0xffffff8008ea0000   (  4224 KB)
  35.                      .data : 0xffffff8008fb0000 - 0xffffff8009131808   (  1543 KB)
  36.                    vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
  37.                              0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
  38.                    fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
  39.                    PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
  40.                    memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
  41. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
  42. [    0.000000] Hierarchical RCU implementation.
  43. [    0.000000]  Build-time adjustment of leaf fanout to 64.
  44. [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
  45. [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
  46. [    0.000000] NR_IRQS:64 nr_irqs:64 0
  47. [    0.000000] GIC: Using split EOI/Deactivate mode
  48. [    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
  49. [    0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
  50. [    0.000000] ITS: using cache flushing for cmd queue
  51. [    0.000000] GIC: using LPI property table @0x000000000a210000
  52. [    0.000000] ITS: Allocated 1792 chunks for LPIs
  53. [    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
  54. [    0.000000] CPU0: using LPI pending table @0x000000000a220000
  55. [    0.000000] GIC: using cache flushing for LPI property table
  56. [    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
  57. [    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
  58. [    0.000000] rockchip_mmc_get_phase: invalid clk rate
  59. [    0.000000] rockchip_mmc_get_phase: invalid clk rate
  60. [    0.000000] rockchip_mmc_get_phase: invalid clk rate
  61. [    0.000000] rockchip_mmc_get_phase: invalid clk rate
  62. [    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
  63. [    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
  64. [    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
  65. [    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
  66. [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  67. [    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  68. [    0.002293] Console: colour dummy device 80x25
  69. [    0.002736] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
  70. [    0.003724] pid_max: default: 32768 minimum: 301
  71. [    0.004253] Security Framework initialized
  72. [    0.004719] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
  73. [    0.005360] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
  74. [    0.006829] Initializing cgroup subsys devices
  75. [    0.007278] Initializing cgroup subsys freezer
  76. [    0.007727] ftrace: allocating 39061 entries in 153 pages
  77. [    0.108878] sched-energy: Sched-energy-costs installed from DT
  78. [    0.109448] CPU0: update cpu_capacity 401
  79. [    0.109895] ASID allocator initialised with 32768 entries
  80. [    0.113603] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
  81. [    0.115008] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
  82. [    0.117317] Detected VIPT I-cache on CPU1
  83. [    0.117351] CPU1: found redistributor 1 region 0:0x00000000fef20000
  84. [    0.117381] CPU1: using LPI pending table @0x00000000f2ca0000
  85. [    0.117424] CPU1: update cpu_capacity 401
  86. [    0.117428] CPU1: Booted secondary processor [410fd034]
  87. [    0.117981] Detected VIPT I-cache on CPU2
  88. [    0.118002] CPU2: found redistributor 2 region 0:0x00000000fef40000
  89. [    0.118029] CPU2: using LPI pending table @0x00000000f2cd0000
  90. [    0.118055] CPU2: update cpu_capacity 401
  91. [    0.118058] CPU2: Booted secondary processor [410fd034]
  92. [    0.118589] Detected VIPT I-cache on CPU3
  93. [    0.118608] CPU3: found redistributor 3 region 0:0x00000000fef60000
  94. [    0.118636] CPU3: using LPI pending table @0x00000000f2d20000
  95. [    0.118662] CPU3: update cpu_capacity 401
  96. [    0.118665] CPU3: Booted secondary processor [410fd034]
  97. [    0.119219] Detected PIPT I-cache on CPU4
  98. [    0.119245] CPU4: found redistributor 100 region 0:0x00000000fef80000
  99. [    0.119283] CPU4: using LPI pending table @0x00000000f2d50000
  100. [    0.119321] CPU4: update cpu_capacity 1024
  101. [    0.119325] CPU4: Booted secondary processor [410fd082]
  102. [    0.119880] Detected PIPT I-cache on CPU5
  103. [    0.119898] CPU5: found redistributor 101 region 0:0x00000000fefa0000
  104. [    0.119934] CPU5: using LPI pending table @0x00000000f2d80000
  105. [    0.119962] CPU5: update cpu_capacity 1024
  106. [    0.119965] CPU5: Booted secondary processor [410fd082]
  107. [    0.120052] Brought up 6 CPUs
  108. [    0.132419] SMP: Total of 6 processors activated.
  109. [    0.132870] CPU features: detected feature: GIC system register CPU interface
  110. [    0.133559] CPU features: detected feature: 32-bit EL0 Support
  111. [    0.134119] CPU: All CPU(s) started at EL2
  112. [    0.134550] alternatives: patching kernel code
  113. [    0.136382] devtmpfs: initialized
  114. [    0.154604] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
  115. [    0.155531] futex hash table entries: 2048 (order: 5, 131072 bytes)
  116. [    0.156591] pinctrl core: initialized pinctrl subsystem
  117. [    0.157301] regulator-dummy: no parameters
  118. [    0.157854] NET: Registered protocol family 16
  119. [    0.163583] cpuidle: using governor ladder
  120. [    0.167591] cpuidle: using governor menu
  121. [    0.167976] Registered FIQ tty driver
  122. [    0.168563] vdso: 2 pages (1 code @ ffffff8008a86000, 1 data @ ffffff8008fb4000)
  123. [    0.169310] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  124. [    0.170100] DMA: preallocated 256 KiB pool for atomic allocations
  125. [    0.187186] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
  126. [    0.187268] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
  127. [    0.187339] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
  128. [    0.187410] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
  129. [    0.187479] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
  130. [    0.197333] console [ttyFIQ0] enabled
  131. [    0.198016] bootconsole [uart0] disabled
  132. [    0.198912] Registered fiq debugger ttyFIQ0
  133. [    0.213521] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vccadc-ref[0]'
  134. [    0.213546] vcc1v8_sys: 1800 mV
  135. [    0.213712] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV
  136. [    0.213766] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]'
  137. [    0.213782] vcc3v3_sys: 3300 mV
  138. [    0.213938] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
  139. [    0.214171] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-host-regulator[0]' - status (0)
  140. [    0.214223] vcc5v0_host: no parameters
  141. [    0.214369] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
  142. [    0.214518] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_hub_en-regulator[0]' - status (0)
  143. [    0.214556] vcc_hub_en: no parameters
  144. [    0.214718] reg-fixed-voltage vcc_hub_en-regulator: vcc_hub_en supplying 0uV
  145. [    0.214862] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-wifi[0]' - status (0)
  146. [    0.214905] vcc_wifi: 5000 mV
  147. [    0.215059] reg-fixed-voltage vcc-wifi: vcc_wifi supplying 5000000uV
  148. [    0.215187] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-pcie[0]' - status (0)
  149. [    0.215227] vcc_pcie: 5000 mV
  150. [    0.215387] reg-fixed-voltage vcc-pcie: vcc_pcie supplying 5000000uV
  151. [    0.215533] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-sd[0]' - status (0)
  152. [    0.215571] vcc_sd: 3300 mV
  153. [    0.215723] reg-fixed-voltage vcc-sd: vcc_sd supplying 3300000uV
  154. [    0.215779] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-sys[0]'
  155. [    0.215795] vcc5v0_sys: 5000 mV
  156. [    0.215952] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
  157. [    0.216002] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
  158. [    0.216017] vcc_phy: no parameters
  159. [    0.216163] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
  160. [    0.216293] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-lcd-regulator[0]' - status (0)
  161. [    0.216332] vcc_lcd: no parameters
  162. [    0.216497] reg-fixed-voltage vcc-lcd-regulator: vcc_lcd supplying 0uV
  163. [    0.216640] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_mipi[0]' - status (0)
  164. [    0.216676] vcc_mipi: no parameters
  165. [    0.216834] reg-fixed-voltage vcc_mipi: vcc_mipi supplying 0uV
  166. [    0.216902] rockchip-pinctrl pinctrl: pin gpio1-17 already requested by vcc-pcie; cannot claim for dvdd-1v2
  167. [    0.217769] rockchip-pinctrl pinctrl: pin-49 (dvdd-1v2) status -22
  168. [    0.218321] rockchip-pinctrl pinctrl: could not request pin 49 (gpio1-17) from group cif-pwr  on device rockchip-pinctrl
  169. [    0.219284] reg-fixed-voltage dvdd-1v2: Error applying setting, reverse things back
  170. [    0.220010] of_get_named_gpiod_flags: parsed 'gpio' property of node '/dvdd-1v2[0]' - status (0)
  171. [    0.220046] dvdd_1v2: no parameters
  172. [    0.220201] reg-fixed-voltage dvdd-1v2: dvdd_1v2 supplying 0uV
  173. [    0.220883] iommu: Adding device ff650000.vpu_service to group 0
  174. [    0.221508] iommu: Adding device ff660000.rkvdec to group 1
  175. [    0.222102] iommu: Adding device ff8f0000.vop to group 2
  176. [    0.222664] iommu: Adding device ff900000.vop to group 3
  177. [    0.223217] iommu: Adding device ff910000.rkisp1 to group 4
  178. [    0.223804] iommu: Adding device ff920000.rkisp1 to group 5
  179. [    0.224799] rk_iommu ff650800.iommu: can't get sclk
  180. [    0.225507] rk_iommu ff660480.iommu: can't get sclk
  181. [    0.226158] rk_iommu ff8f3f00.iommu: can't get sclk
  182. [    0.226753] rk_iommu ff903f00.iommu: can't get sclk
  183. [    0.227363] rk_iommu ff914000.iommu: can't get sclk
  184. [    0.227961] rk_iommu ff924000.iommu: can't get sclk
  185. [    0.228767] SCSI subsystem initialized
  186. [    0.229293] libata version 3.00 loaded.
  187. [    0.229508] usbcore: registered new interface driver usbfs
  188. [    0.230039] usbcore: registered new interface driver hub
  189. [    0.230609] usbcore: registered new device driver usb
  190. [    0.231114] media: Linux media interface: v0.10
  191. [    0.231553] Linux video capture interface: v2.00
  192. [    0.232033] pps_core: LinuxPPS API ver. 1 registered
  193. [    0.232477] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  194. [    0.233302] PTP clock support registered
  195. [    0.234883] Advanced Linux Sound Architecture Driver Initialized.
  196. [    0.235914] Bluetooth: Core ver 2.21
  197. [    0.236254] NET: Registered protocol family 31
  198. [    0.236661] Bluetooth: HCI device and connection manager initialized
  199. [    0.237227] Bluetooth: HCI socket layer initialized
  200. [    0.237669] Bluetooth: L2CAP socket layer initialized
  201. [    0.238132] Bluetooth: SCO socket layer initialized
  202. [    0.239202] rockchip-cpuinfo cpuinfo: Serial         : db88e99c900a6478
  203. [    0.240310] clocksource: Switched to clocksource arch_sys_counter
  204. [    0.290037] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
  205. [    0.290956] NET: Registered protocol family 2
  206. [    0.291794] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
  207. [    0.292697] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
  208. [    0.294246] TCP: Hash tables configured (established 32768 bind 32768)
  209. [    0.294954] UDP hash table entries: 2048 (order: 5, 196608 bytes)
  210. [    0.295678] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
  211. [    0.296650] NET: Registered protocol family 1
  212. [    0.297348] RPC: Registered named UNIX socket transport module.
  213. [    0.297875] RPC: Registered udp transport module.
  214. [    0.298295] RPC: Registered tcp transport module.
  215. [    0.298726] RPC: Registered tcp NFSv4.1 backchannel transport module.
  216. [    0.299320] PCI: CLS 0 bytes, default 64
  217. [    0.300427] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  218. [    0.301229] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
  219. [    0.305079] Initialise system trusted keyring
  220. [    0.313470] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  221. [    0.314734] NFS: Registering the id_resolver key type
  222. [    0.315196] Key type id_resolver registered
  223. [    0.315586] Key type id_legacy registered
  224. [    0.316160] fuse init (API version 7.23)
  225. [    0.316855] SGI XFS with security attributes, no debug enabled
  226. [    0.322265] NET: Registered protocol family 38
  227. [    0.322707] Key type asymmetric registered
  228. [    0.323078] Asymmetric key parser 'x509' registered
  229. [    0.323679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  230. [    0.324352] io scheduler noop registered
  231. [    0.324710] io scheduler deadline registered
  232. [    0.325205] io scheduler cfq registered (default)
  233. [    0.327953] rockchip-mipi-dphy-rx ff770000.syscon:mipi-dphy-rx0: invalid resource
  234. [    0.329392] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply from device tree
  235. [    0.329404] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
  236. [    0.330406] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply from device tree
  237. [    0.330421] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply property in node /power-management@ff310000/power-controller failed
  238. [    0.330869] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply from device tree
  239. [    0.330883] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply property in node /power-management@ff310000/power-controller failed
  240. [    0.331237] phy phy-pcie-phy.1: Looking up phy-supply from device tree
  241. [    0.331247] phy phy-pcie-phy.1: Looking up phy-supply property in node /pcie-phy failed
  242. [    0.333342] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
  243. [    0.333353] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
  244. [    0.333383] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
  245. [    0.333630] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
  246. [    0.333642] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed
  247. [    0.333661] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
  248. [    0.334224] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
  249. [    0.334234] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
  250. [    0.334248] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
  251. [    0.334821] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
  252. [    0.334831] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
  253. [    0.334846] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
  254. [    0.335416] rockchip-pcie f8000000.pcie: missing "memory-region" property
  255. [    0.336019] PCI host bridge /pcie@f8000000 ranges:
  256. [    0.336461]   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
  257. [    0.336920]    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
  258. [    0.381151] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
  259. [    0.381753] pci_bus 0000:00: root bus resource [bus 00-1f]
  260. [    0.382247] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
  261. [    0.382867] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
  262. [    0.383742] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
  263. [    0.383845] pci 0000:00:00.0: supports D1
  264. [    0.383854] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
  265. [    0.384097] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
  266. [    0.384929] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-1f] (conflicts with (null) [bus 00-1f])
  267. [    0.384971] pci 0000:01:00.0: [1cd7:0052] type 00 class 0x040000
  268. [    0.385025] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0003ffff]
  269. [    0.385158] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot
  270. [    0.387349] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
  271. [    0.387383] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff]
  272. [    0.387984] pci 0000:01:00.0: BAR 0: assigned [mem 0xfa000000-0xfa03ffff]
  273. [    0.388598] pci 0000:00:00.0: PCI bridge to [bus 01]
  274. [    0.389048] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
  275. [    0.389706] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
  276. [    0.390474] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
  277. [    0.391093] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
  278. [    0.391684] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
  279. [    0.391790] aer 0000:00:00.0:pcie02: service driver aer loaded
  280. [    0.392340] pwm-backlight backlight: GPIO lookup for consumer enable
  281. [    0.392349] pwm-backlight backlight: using device tree for GPIO lookup
  282. [    0.392359] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
  283. [    0.392368] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
  284. [    0.392376] pwm-backlight backlight: using lookup tables for GPIO lookup
  285. [    0.392385] pwm-backlight backlight: lookup for GPIO enable failed
  286. [    0.392396] pwm-backlight backlight: Looking up power-supply from device tree
  287. [    0.392405] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
  288. [    0.392419] backlight supply power not found, using dummy regulator
  289. [    0.393487] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree
  290. [    0.393499] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
  291. [    0.393515] rk-vcodec ff650000.vpu_service: no regulator for vcodec
  292. [    0.394381] rk-vcodec ff650000.vpu_service: probe device
  293. [    0.395059] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
  294. [    0.396265] rk-vcodec ff650000.vpu_service: could not find power_model node
  295. [    0.396902] rk-vcodec ff650000.vpu_service: init success
  296. [    0.397602] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree
  297. [    0.397613] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
  298. [    0.397630] rk-vcodec ff660000.rkvdec: no regulator for vcodec
  299. [    0.398628] rk-vcodec ff660000.rkvdec: probe device
  300. [    0.399244] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
  301. [    0.400217] rk-vcodec ff660000.rkvdec: could not find power_model node
  302. [    0.400806] rk-vcodec ff660000.rkvdec: init success
  303. [    0.402768] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
  304. [    0.403449] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
  305. [    0.405709] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
  306. [    0.406390] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
  307. [    0.408448] pwm-regulator vdd-log: GPIO lookup for consumer enable
  308. [    0.408457] pwm-regulator vdd-log: using device tree for GPIO lookup
  309. [    0.408468] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]'
  310. [    0.408477] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]'
  311. [    0.408485] pwm-regulator vdd-log: using lookup tables for GPIO lookup
  312. [    0.408493] pwm-regulator vdd-log: lookup for GPIO enable failed
  313. [    0.408534] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  314. [    0.408544] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  315. [    0.408569] vdd_log: 800 <--> 1100 mV at 1007 mV
  316. [    0.408731] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  317. [    0.408741] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  318. [    0.408796] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  319. [    0.408806] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  320. [    0.409248] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
  321. [    0.410473] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
  322. [    0.411627] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
  323. [    0.412580] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
  324. [    0.413190] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer  on device rockchip-pinctrl
  325. [    0.414190] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
  326. [    0.415030] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
  327. [    0.417025] [drm] Initialized drm 1.1.0 20060810
  328. [    0.421605] [drm] Rockchip DRM driver version: v1.0.1
  329. [    0.424363] mali ff9a0000.gpu: Looking up mali-supply from device tree
  330. [    0.424388] mali ff9a0000.gpu: Failed to get regulator
  331. [    0.424846] mali ff9a0000.gpu: Power control initialization failed
  332. [    0.425443] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply from device tree
  333. [    0.425455] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@ff310000/power-controller failed
  334. [    0.425774] Unable to detect cache hierarchy for CPU 0
  335. [    0.427018] brd: module loaded
  336. [    0.432430] loop: module loaded
  337. [    0.433232] zram: Added device: zram0
  338. [    0.433914] lkdtm: No crash points registered, enable through debugfs
  339. [    0.436101] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
  340. [    0.436707] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
  341. [    0.437292] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
  342. [    0.438713] register spi return v = :0
  343. [    0.439899] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
  344. [    0.439992] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
  345. [    0.440628] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
  346. [    0.441133] rk_gmac-dwmac fe300000.ethernet: RX delay(0x13).
  347. [    0.441660] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
  348. [    0.442394] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
  349. [    0.443013] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
  350. [    0.448565] rk_gmac-dwmac fe300000.ethernet: init for RGMII
  351. [    0.449174] stmmac - user ID: 0x10, Synopsys ID: 0x35
  352. [    0.449628]  Ring mode enabled
  353. [    0.449899]  DMA HW capability register supported
  354. [    0.450296]  Normal descriptors
  355. [    0.450610]  RX Checksum Offload Engine supported (type 2)
  356. [    0.451098]  TX Checksum insertion supported
  357. [    0.451480]  Wake-Up On Lan supported
  358. [    0.451839]  Enable RX Mitigation via HW Watchdog Timer
  359. [    0.452417] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0)
  360. [    0.517752] libphy: stmmac: probed
  361. [    0.518070] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
  362. [    0.518663] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
  363. [    0.521480] usbcore: registered new interface driver rndis_wlan
  364. [    0.522168] Rockchip WiFi SYS interface (V1.00) ...
  365. [    0.522719] usbcore: registered new interface driver rtl8150
  366. [    0.523263] usbcore: registered new interface driver r8152
  367. [    0.523820] usbcore: registered new interface driver asix
  368. [    0.524360] usbcore: registered new interface driver ax88179_178a
  369. [    0.524941] usbcore: registered new interface driver cdc_ether
  370. [    0.525511] usbcore: registered new interface driver rndis_host
  371. [    0.526113] usbcore: registered new interface driver cdc_ncm
  372. [    0.526670] usbcore: registered new interface driver qmi_wwan
  373. [    0.527229] usbcore: registered new interface driver cdc_mbim
  374. [    0.529728] rockchip-dwc3 usb0: failed to get drvdata dwc3
  375. [    0.530354] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply from device tree
  376. [    0.530370] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply property in node /power-management@ff310000/power-controller failed
  377. [    0.531603] rockchip-dwc3 usb1: failed to get drvdata dwc3
  378. [    0.533598] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  379. [    0.534195] ehci-pci: EHCI PCI platform driver
  380. [    0.534700] ehci-platform: EHCI generic platform driver
  381. [    0.536118] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  382. [    0.536700] ohci-platform: OHCI generic platform driver
  383. [    0.538573] usbcore: registered new interface driver cdc_acm
  384. [    0.539074] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
  385. [    0.539843] usbcore: registered new interface driver cdc_wdm
  386. [    0.540407] usbcore: registered new interface driver uas
  387. [    0.540937] usbcore: registered new interface driver usb-storage
  388. [    0.541581] usbcore: registered new interface driver usbserial
  389. [    0.542132] usbcore: registered new interface driver usbserial_generic
  390. [    0.542758] usbserial: USB Serial support registered for generic
  391. [    0.543348] usbcore: registered new interface driver ch341
  392. [    0.543865] usbserial: USB Serial support registered for ch341-uart
  393. [    0.544477] usbcore: registered new interface driver cp210x
  394. [    0.544995] usbserial: USB Serial support registered for cp210x
  395. [    0.545573] usbcore: registered new interface driver ftdi_sio
  396. [    0.546114] usbserial: USB Serial support registered for FTDI USB Serial Device
  397. [    0.546823] usbcore: registered new interface driver keyspan
  398. [    0.547368] usbserial: USB Serial support registered for Keyspan - (without firmware)
  399. [    0.548090] usbserial: USB Serial support registered for Keyspan 1 port adapter
  400. [    0.548781] usbserial: USB Serial support registered for Keyspan 2 port adapter
  401. [    0.549471] usbserial: USB Serial support registered for Keyspan 4 port adapter
  402. [    0.550160] usbcore: registered new interface driver option
  403. [    0.550694] usbserial: USB Serial support registered for GSM modem (1-port)
  404. [    0.551368] usbcore: registered new interface driver oti6858
  405. [    0.551900] usbserial: USB Serial support registered for oti6858
  406. [    0.552491] usbcore: registered new interface driver pl2303
  407. [    0.553009] usbserial: USB Serial support registered for pl2303
  408. [    0.553588] usbcore: registered new interface driver qcserial
  409. [    0.554128] usbserial: USB Serial support registered for Qualcomm USB modem
  410. [    0.554799] usbcore: registered new interface driver sierra
  411. [    0.555337] usbserial: USB Serial support registered for Sierra USB modem
  412. [    0.557340] usbcore: registered new interface driver usbtouchscreen
  413. [    0.558129] .. rk pwm remotectl v1.1 init
  414. [    0.558743] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
  415. [    0.559838] sensor_register_slave:mma8452,id=17
  416. [    0.560244] sensor_register_slave:lis3dh,id=7
  417. [    0.560653] sensor_register_slave:mma7660,id=18
  418. [    0.561057] sensor_register_slave:lsm303d,id=22
  419. [    0.561468] sensor_register_slave:gs_mc3230,id=23
  420. [    0.561888] [Gsensor]   gsensor_init
  421. [    0.562210] sensor_register_slave:mpu6880_acc,id=24
  422. [    0.562656] sensor_register_slave:mpu6500_acc,id=25
  423. [    0.563094] sensor_register_slave:lsm330_acc,id=26
  424. [    0.563527] sensor_register_slave:akm8975,id=30
  425. [    0.563930] sensor_register_slave:akm8963,id=31
  426. [    0.564341] sensor_register_slave:l3g4200d,id=45
  427. [    0.564754] sensor_register_slave:l3g20d,id=46
  428. [    0.565157] sensor_register_slave:ewtsa,id=47
  429. [    0.565556] sensor_register_slave:lsm330_gyro,id=51
  430. [    0.565993] sensor_register_slave:cm3217,id=53
  431. [    0.566403] sensor_register_slave:cm3218,id=54
  432. [    0.567340] i2c /dev entries driver
  433. [    0.568525] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
  434. [    0.568535] fan53555-regulator 0-0040: using device tree for GPIO lookup
  435. [    0.568566] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr827@40[0]' - status (0)
  436. [    0.568957] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
  437. [    0.569592] fan53555-regulator 0-0040: Looking up vin-supply from device tree
  438. [    0.569654] fan53555-reg: supplied by vcc5v0_sys
  439. [    0.570068] vcc5v0_sys: could not add device link regulator.14 err -2
  440. [    0.571207] vdd_cpu_b: 712 <--> 1500 mV at 800 mV
  441. [    0.571587] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  442. [    0.571600] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  443. [    0.571835] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
  444. [    0.571844] fan53555-regulator 0-0041: using device tree for GPIO lookup
  445. [    0.571874] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr828@41[0]' - status (0)
  446. [    0.572219] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
  447. [    0.572853] fan53555-regulator 0-0041: Looking up vin-supply from device tree
  448. [    0.572897] fan53555-reg: supplied by vcc5v0_sys
  449. [    0.573321] vcc5v0_sys: could not add device link regulator.15 err -2
  450. [    0.574466] vdd_gpu: 712 <--> 1500 mV at 800 mV
  451. [    0.574824] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  452. [    0.574835] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  453. [    0.575518] rk808 0-001b: Pmic Chip id: 0x0
  454. [    0.578581] rk808 0-001b: GPIO lookup for consumer dvs
  455. [    0.578590] rk808 0-001b: using device tree for GPIO lookup
  456. [    0.578601] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[0]'
  457. [    0.578611] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
  458. [    0.578618] rk808 0-001b: using lookup tables for GPIO lookup
  459. [    0.578627] rk808 0-001b: lookup for GPIO dvs failed
  460. [    0.578635] rk808-regulator rk808-regulator: there is no dvs0 gpio
  461. [    0.579184] rk808 0-001b: GPIO lookup for consumer dvs
  462. [    0.579191] rk808 0-001b: using device tree for GPIO lookup
  463. [    0.579199] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[1]'
  464. [    0.579208] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[1]'
  465. [    0.579215] rk808 0-001b: using lookup tables for GPIO lookup
  466. [    0.579222] rk808 0-001b: lookup for GPIO dvs failed
  467. [    0.579229] rk808-regulator rk808-regulator: there is no dvs1 gpio
  468. [    0.579833] rk808 0-001b: Looking up vcc1-supply from device tree
  469. [    0.579894] DCDC_REG1: supplied by vcc3v3_sys
  470. [    0.580284] vcc3v3_sys: could not add device link regulator.16 err -2
  471. [    0.580745] vdd_center: 750 <--> 1350 mV at 900 mV
  472. [    0.580968] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  473. [    0.580979] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  474. [    0.581030] rk808 0-001b: Looking up vcc2-supply from device tree
  475. [    0.581070] DCDC_REG2: supplied by vcc3v3_sys
  476. [    0.581476] vcc3v3_sys: could not add device link regulator.17 err -2
  477. [    0.581772] vdd_cpu_l: 750 <--> 1350 mV at 800 mV
  478. [    0.581981] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  479. [    0.581992] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  480. [    0.582039] rk808 0-001b: Looking up vcc3-supply from device tree
  481. [    0.582079] DCDC_REG3: supplied by vcc3v3_sys
  482. [    0.582484] vcc3v3_sys: could not add device link regulator.18 err -2
  483. [    0.582514] vcc_ddr: at 3300 mV
  484. [    0.582691] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  485. [    0.582702] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  486. [    0.582753] rk808 0-001b: Looking up vcc4-supply from device tree
  487. [    0.582792] DCDC_REG4: supplied by vcc3v3_sys
  488. [    0.583181] vcc3v3_sys: could not add device link regulator.19 err -2
  489. [    0.583375] vcc_1v8: 1800 mV
  490. [    0.583578] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  491. [    0.583589] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  492. [    0.583641] rk808 0-001b: Looking up vcc6-supply from device tree
  493. [    0.583680] LDO_REG1: supplied by vcc3v3_sys
  494. [    0.584058] vcc3v3_sys: could not add device link regulator.20 err -2
  495. [    0.584895] vcca1v8_codec: 1800 mV
  496. [    0.585106] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  497. [    0.585117] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  498. [    0.585171] rk808 0-001b: Looking up vcc6-supply from device tree
  499. [    0.585209] LDO_REG2: supplied by vcc3v3_sys
  500. [    0.585605] vcc3v3_sys: could not add device link regulator.21 err -2
  501. [    0.586314] vcc1v8_hdmi: 1800 mV
  502. [    0.586523] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  503. [    0.586533] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  504. [    0.586589] rk808 0-001b: Looking up vcc7-supply from device tree
  505. [    0.586628] LDO_REG3: supplied by vcc3v3_sys
  506. [    0.587006] vcc3v3_sys: could not add device link regulator.22 err -2
  507. [    0.587705] vcc1v8_pmu: 1800 mV
  508. [    0.587915] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  509. [    0.587925] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  510. [    0.587985] rk808 0-001b: Looking up vcc9-supply from device tree
  511. [    0.588022] LDO_REG4: supplied by vcc3v3_sys
  512. [    0.588416] vcc3v3_sys: could not add device link regulator.23 err -2
  513. [    0.589119] vccio_sd: 1800 <--> 3000 mV at 3000 mV
  514. [    0.589345] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  515. [    0.589355] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  516. [    0.589416] rk808 0-001b: Looking up vcc9-supply from device tree
  517. [    0.589457] LDO_REG5: supplied by vcc3v3_sys
  518. [    0.589838] vcc3v3_sys: could not add device link regulator.24 err -2
  519. [    0.590533] vcca3v0_codec: 3000 mV
  520. [    0.590733] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  521. [    0.590744] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  522. [    0.590810] rk808 0-001b: Looking up vcc10-supply from device tree
  523. [    0.590850] LDO_REG6: supplied by vcc3v3_sys
  524. [    0.591228] vcc3v3_sys: could not add device link regulator.25 err -2
  525. [    0.591939] vcc_1v5: 1500 mV
  526. [    0.592142] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  527. [    0.592153] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  528. [    0.592219] rk808 0-001b: Looking up vcc7-supply from device tree
  529. [    0.592258] LDO_REG7: supplied by vcc3v3_sys
  530. [    0.592654] vcc3v3_sys: could not add device link regulator.26 err -2
  531. [    0.593351] vcca0v9_hdmi: 900 mV
  532. [    0.593563] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  533. [    0.593573] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  534. [    0.593640] rk808 0-001b: Looking up vcc11-supply from device tree
  535. [    0.593680] LDO_REG8: supplied by vcc3v3_sys
  536. [    0.594058] vcc3v3_sys: could not add device link regulator.27 err -2
  537. [    0.594754] vcc_3v0: 3000 mV
  538. [    0.594971] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  539. [    0.594981] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  540. [    0.595048] rk808 0-001b: Looking up vcc8-supply from device tree
  541. [    0.595086] SWITCH_REG1: supplied by vcc3v3_sys
  542. [    0.595502] vcc3v3_sys: could not add device link regulator.28 err -2
  543. [    0.595531] vcc3v3_s3: at 3300 mV
  544. [    0.595719] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  545. [    0.595729] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  546. [    0.595800] rk808 0-001b: Looking up vcc12-supply from device tree
  547. [    0.595838] SWITCH_REG2: supplied by vcc3v3_sys
  548. [    0.596239] vcc3v3_sys: could not add device link regulator.29 err -2
  549. [    0.596267] vcc3v3_s0: at 3300 mV
  550. [    0.596456] pwm-regulator vdd-log: Looking up pwm-supply from device tree
  551. [    0.596466] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
  552. [    0.599657] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
  553. [    0.600677] of_get_named_gpiod_flags: parsed 'pmic,hold-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]' - status (0)
  554. [    0.600715] of_get_named_gpiod_flags: can't parse 'pmic,stby-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
  555. [    0.600725] rk808 0-001b: Can not read property pmic,stby-gpio
  556. [    0.601267] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80093f6000
  557. [    0.602673] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80093f8000
  558. [    0.603901] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80093fa000
  559. [    0.605268] fusb302 7-0022: GPIO lookup for consumer int-n
  560. [    0.605278] fusb302 7-0022: using device tree for GPIO lookup
  561. [    0.605325] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff160000/fusb30x@22[0]' - status (0)
  562. [    0.605351] fusb302 7-0022: GPIO lookup for consumer vbus-5v
  563. [    0.605358] fusb302 7-0022: using device tree for GPIO lookup
  564. [    0.605367] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
  565. [    0.605376] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
  566. [    0.605383] fusb302 7-0022: using lookup tables for GPIO lookup
  567. [    0.605392] fusb302 7-0022: lookup for GPIO vbus-5v failed
  568. [    0.605400] fusb302 7-0022: GPIO lookup for consumer vbus-other
  569. [    0.605407] fusb302 7-0022: using device tree for GPIO lookup
  570. [    0.605415] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
  571. [    0.605424] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
  572. [    0.605431] fusb302 7-0022: using lookup tables for GPIO lookup
  573. [    0.605438] fusb302 7-0022: lookup for GPIO vbus-other failed
  574. [    0.605446] fusb302 7-0022: GPIO lookup for consumer discharge
  575. [    0.605454] fusb302 7-0022: using device tree for GPIO lookup
  576. [    0.605462] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
  577. [    0.605470] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
  578. [    0.605477] fusb302 7-0022: using lookup tables for GPIO lookup
  579. [    0.605484] fusb302 7-0022: lookup for GPIO discharge failed
  580. [    0.605493] fusb302 7-0022: GPIO lookup for consumer charge-en
  581. [    0.605499] fusb302 7-0022: using device tree for GPIO lookup
  582. [    0.605507] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
  583. [    0.605516] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
  584. [    0.605522] fusb302 7-0022: using lookup tables for GPIO lookup
  585. [    0.605529] fusb302 7-0022: lookup for GPIO charge-en failed
  586. [    0.605697] fusb302 7-0022: Can't get property of role, set role to default DRP
  587. [    0.606513] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
  588. [    0.609785] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
  589. [    0.610710] mp8859 7-0066: GPIO lookup for consumer charge-en
  590. [    0.610719] mp8859 7-0066: using device tree for GPIO lookup
  591. [    0.610727] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/mp8859@66[0]'
  592. [    0.610736] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/mp8859@66[0]'
  593. [    0.610743] mp8859 7-0066: using lookup tables for GPIO lookup
  594. [    0.610751] mp8859 7-0066: lookup for GPIO charge-en failed
  595. [    0.611462] mp8859 7-0066: set mp8859 out 12v ok
  596. [    0.611873] mp8859 7-0066: register ext0 dev0
  597. [    0.612407] mp8859 7-0066: mp8859 probe successful
  598. [    0.612852] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80093fc000
  599. [    0.614318] rockchip-pinctrl pinctrl: pin gpio1-1 already requested by vcc_mipi; cannot claim for 4-0022
  600. [    0.615150] rockchip-pinctrl pinctrl: pin-33 (4-0022) status -22
  601. [    0.615701] rockchip-pinctrl pinctrl: could not request pin 33 (gpio1-1) from group fusb1-int  on device rockchip-pinctrl
  602. [    0.616669] fusb302 4-0022: Error applying setting, reverse things back
  603. [    0.617336] fusb302 4-0022: GPIO lookup for consumer int-n
  604. [    0.617344] fusb302 4-0022: using device tree for GPIO lookup
  605. [    0.617374] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
  606. [    0.617398] fusb302 4-0022: GPIO lookup for consumer vbus-5v
  607. [    0.617406] fusb302 4-0022: using device tree for GPIO lookup
  608. [    0.617432] of_get_named_gpiod_flags: parsed 'vbus-5v-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
  609. [    0.617458] fusb302 4-0022: GPIO lookup for consumer vbus-other
  610. [    0.617465] fusb302 4-0022: using device tree for GPIO lookup
  611. [    0.617475] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
  612. [    0.617483] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
  613. [    0.617491] fusb302 4-0022: using lookup tables for GPIO lookup
  614. [    0.617498] fusb302 4-0022: lookup for GPIO vbus-other failed
  615. [    0.617506] fusb302 4-0022: GPIO lookup for consumer discharge
  616. [    0.617513] fusb302 4-0022: using device tree for GPIO lookup
  617. [    0.617521] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
  618. [    0.617529] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
  619. [    0.617536] fusb302 4-0022: using lookup tables for GPIO lookup
  620. [    0.617543] fusb302 4-0022: lookup for GPIO discharge failed
  621. [    0.617551] fusb302 4-0022: GPIO lookup for consumer charge-en
  622. [    0.617558] fusb302 4-0022: using device tree for GPIO lookup
  623. [    0.617566] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
  624. [    0.617574] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
  625. [    0.617581] fusb302 4-0022: using lookup tables for GPIO lookup
  626. [    0.617588] fusb302 4-0022: lookup for GPIO charge-en failed
  627. [    0.617731] fusb302 4-0022: Can't get property of role, set role to default DRP
  628. [    0.626662] fusb302 4-0022: port 1 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
  629. [    0.627482] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80093fe000
  630. [    0.629282] IR NEC protocol handler initialized
  631. [    0.630534] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.00
  632. [    0.631115] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
  633. [    0.632852] rkisp1 ff910000.rkisp1: GPIO lookup for consumer vsirq
  634. [    0.632862] rkisp1 ff910000.rkisp1: using device tree for GPIO lookup
  635. [    0.632872] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff910000[0]'
  636. [    0.632880] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff910000[0]'
  637. [    0.632888] rkisp1 ff910000.rkisp1: using lookup tables for GPIO lookup
  638. [    0.632896] rkisp1 ff910000.rkisp1: lookup for GPIO vsirq failed
  639. [    0.633214] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.00
  640. [    0.633812] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
  641. [    0.635542] rkisp1 ff920000.rkisp1: GPIO lookup for consumer vsirq
  642. [    0.635552] rkisp1 ff920000.rkisp1: using device tree for GPIO lookup
  643. [    0.635563] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff920000[0]'
  644. [    0.635572] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff920000[0]'
  645. [    0.635579] rkisp1 ff920000.rkisp1: using lookup tables for GPIO lookup
  646. [    0.635588] rkisp1 ff920000.rkisp1: lookup for GPIO vsirq failed
  647. [    0.635848] usbcore: registered new interface driver uvcvideo
  648. [    0.636377] USB Video Class driver (1.1.1)
  649. [    0.636813] cw201x 2-0062: design_capacity missing!
  650. [    0.669270] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
  651. [    0.670241] cw201x 2-0062: cw2015/cw2013 driver v1.2 probe sucess
  652. [    0.671493] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
  653. [    0.671714] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
  654. [    0.671773] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
  655. [    0.671831] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
  656. [    0.671886] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
  657. [    0.673872] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
  658. [    0.674821] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
  659. [    0.676335] Bluetooth: Virtual HCI driver ver 1.5
  660. [    0.676884] Bluetooth: HCI UART driver ver 2.3
  661. [    0.677283] Bluetooth: HCI UART protocol H4 registered
  662. [    0.677751] Bluetooth: HCI UART protocol LL registered
  663. [    0.678207] Bluetooth: HCI UART protocol ATH3K registered
  664. [    0.678752] usbcore: registered new interface driver bfusb
  665. [    0.679286] usbcore: registered new interface driver btusb
  666. [    0.680381] cpu cpu0: bin=1
  667. [    0.680683] cpu cpu0: leakage=21
  668. [    0.681024] cpu cpu0: Looking up cpu-supply from device tree
  669. [    0.693716] cpu cpu0: temp=63125, pvtm=148332 (146880 + 1452)
  670. [    0.694458] cpu cpu0: pvtm-volt-sel=1
  671. [    0.694841] cpu cpu0: bin-scale=34
  672. [    0.695479] cpu cpu4: bin=1
  673. [    0.695778] cpu cpu4: leakage=37
  674. [    0.696089] cpu cpu4: Looking up cpu-supply from device tree
  675. [    0.708930] cpu cpu4: temp=63125, pvtm=155285 (154515 + 770)
  676. [    0.710578] cpu cpu4: pvtm-volt-sel=2
  677. [    0.710952] cpu cpu4: bin-scale=17
  678. [    0.711555] cpu cpu0: Looking up cpu-supply from device tree
  679. [    0.711830] cpu cpu0: Looking up cpu-supply from device tree
  680. [    0.712432] cpu cpu0: avs=0, target-scale=34
  681. [    0.712882] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
  682. [    0.714136] cpu cpu4: Looking up cpu-supply from device tree
  683. [    0.714797] cpu cpu4: avs=0, target-scale=17
  684. [    0.715246] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
  685. [    0.717283] sdhci: Secure Digital Host Controller Interface driver
  686. [    0.717848] sdhci: Copyright(c) Pierre Ossman
  687. [    0.718239] Synopsys Designware Multimedia Card Interface Driver
  688. [    0.719721] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
  689. [    0.720406] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
  690. [    0.721012] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
  691. [    0.721566] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
  692. [    0.722452] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
  693. [    0.722463] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
  694. [    0.722496] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
  695. [    0.722506] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
  696. [    0.722529] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
  697. [    0.723078] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
  698. [    0.723646] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
  699. [    0.723653] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
  700. [    0.723664] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
  701. [    0.723673] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
  702. [    0.723681] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
  703. [    0.723689] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
  704. [    0.723915] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply from device tree
  705. [    0.723927] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply property in node /power-management@ff310000/power-controller failed
  706. [    0.724610] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
  707. [    0.725271] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
  708. [    0.725889] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
  709. [    0.726445] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
  710. [    0.727321] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
  711. [    0.728035] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
  712. [    0.728132] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
  713. [    0.728203] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
  714. [    0.728211] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
  715. [    0.728221] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]'
  716. [    0.728230] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]'
  717. [    0.728238] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
  718. [    0.728246] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
  719. [    0.728255] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
  720. [    0.728263] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
  721. [    0.728271] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]'
  722. [    0.728280] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]'
  723. [    0.728288] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
  724. [    0.728295] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
  725. [    0.728476] vccio_sd: unsupportable voltage range: 3300000-3000000uV
  726. [    0.729050] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
  727. [    0.729719] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
  728. [    0.741372] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  729. [    0.747567] fusb302 7-0022: CC connected in CC1 as UFP
  730. [    0.752452] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
  731. [    0.753729] sdhci-pltfm: SDHCI platform and OF driver helper
  732. [    0.755319] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
  733. [    0.755331] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
  734. [    0.755346] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]'
  735. [    0.755358] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]'
  736. [    0.755369] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
  737. [    0.755380] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
  738. [    0.756525] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
  739. [    0.756540] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
  740. [    0.756608] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
  741. [    0.756628] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
  742. [    0.756653] sdhci-arasan fe330000.sdhci: No vmmc regulator found
  743. [    0.757196] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
  744. [    0.784345] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
  745. [    0.786355] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/power[0]' - status (0)
  746. [    0.786613] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/user[0]' - status (0)
  747. [    0.786994] hidraw: raw HID events driver (C) Jiri Kosina
  748. [    0.788136] usbcore: registered new interface driver usbhid
  749. [    0.788664] usbhid: USB HID core driver
  750. [    0.789231] inv_mpu_iio: inv_mpu_init:746
  751. [    0.792225] rockchip-dmc dmc: unable to get devfreq-event device : dfi
  752. [    0.797738] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
  753. [    0.799899] usbcore: registered new interface driver snd-usb-audio
  754. [    0.806251] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
  755. [    0.806949] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
  756. [    0.807842] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
  757. [    0.809058] ip_tables: (C) 2000-2006 Netfilter Core Team
  758. [    0.809686] Initializing XFRM netlink socket
  759. [    0.810725] NET: Registered protocol family 10
  760. [    0.812686] NET: Registered protocol family 17
  761. [    0.813109] NET: Registered protocol family 15
  762. [    0.814118] Bluetooth: RFCOMM socket layer initialized
  763. [    0.814630] Bluetooth: RFCOMM ver 1.11
  764. [    0.814993] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  765. [    0.815536] Bluetooth: HIDP socket layer initialized
  766. [    0.816037] [WLAN_RFKILL]: Enter rfkill_wlan_init
  767. [    0.816808] [WLAN_RFKILL]: Enter rfkill_wlan_probe
  768. [    0.817270] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
  769. [    0.817887] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
  770. [    0.818524] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
  771. [    0.819182] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
  772. [    0.819190] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
  773. [    0.819198] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
  774. [    0.819238] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
  775. [    0.819245] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
  776. [    0.820050] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
  777. [    0.820823] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
  778. [    0.821312] [WLAN_RFKILL]: Exit rfkill_wlan_probe
  779. [    0.821822] [BT_RFKILL]: Enter rfkill_rk_init
  780. [    0.822685] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0)
  781. [    0.822693] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
  782. [    0.823551] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]'
  783. [    0.823573] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0)
  784. [    0.823578] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
  785. [    0.824287] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0)
  786. [    0.824292] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
  787. [    0.825009] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0)
  788. [    0.825014] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
  789. [    0.825739] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
  790. [    0.826382] [BT_RFKILL]: Request irq for bt wakeup host
  791. [    0.826888] [BT_RFKILL]: ** disable irq
  792. [    0.827352] [BT_RFKILL]: bt_default device registered.
  793. [    0.827869] Key type dns_resolver registered
  794. [    0.828464] sensor_register_slave:mpu6880_gyro,id=50
  795. [    0.829700] ov13850 1-0036: GPIO lookup for consumer reset
  796. [    0.829713] ov13850 1-0036: using device tree for GPIO lookup
  797. [    0.829752] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
  798. [    0.829810] ov13850 1-0036: Looking up avdd-supply from device tree
  799. [    0.830018] ov13850 1-0036: Looking up dovdd-supply from device tree
  800. [    0.830118] ov13850 1-0036: Looking up dvdd-supply from device tree
  801. [    0.830545] ov13850 1-0036: GPIO lookup for consumer pwdn
  802. [    0.830556] ov13850 1-0036: using device tree for GPIO lookup
  803. [    0.830595] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
  804. [    0.832866] ov13850 1-0036: write SCCB_ID failed
  805. [    0.833519] ov13850: probe of 1-0036 failed with error -5
  806. [    0.834450] ov13850 1-0046: GPIO lookup for consumer reset
  807. [    0.834461] ov13850 1-0046: using device tree for GPIO lookup
  808. [    0.834498] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
  809. [    0.834538] ov13850 1-0046: Looking up avdd-supply from device tree
  810. [    0.834677] ov13850 1-0046: Looking up dovdd-supply from device tree
  811. [    0.834806] ov13850 1-0046: Looking up dvdd-supply from device tree
  812. [    0.835200] ov13850 1-0046: GPIO lookup for consumer pwdn
  813. [    0.835211] ov13850 1-0046: using device tree for GPIO lookup
  814. [    0.835250] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
  815. [    0.837199] ov13850 1-0046: write SCCB_ID failed
  816. [    0.837889] ov13850: probe of 1-0046 failed with error -5
  817. [    0.839203] Registered cp15_barrier emulation handler
  818. [    0.839791] Registered setend emulation handler
  819. [    0.841768] Loading compiled-in X.509 certificates
  820. [    0.843078] rga2: Module initialized.
  821. [    0.844031] phy phy-ff770000.syscon:usb2-phy@e450.2: Looking up phy-supply from device tree
  822. [    0.844121] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e450.2 err -2
  823. [    0.844550] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply from device tree
  824. [    0.844562] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
  825. [    0.844925] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply from device tree
  826. [    0.844936] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
  827. [    0.844957] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
  828. [    0.846342] phy phy-ff770000.syscon:usb2-phy@e460.4: Looking up phy-supply from device tree
  829. [    0.846404] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e460.4 err -2
  830. [    0.846742] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up phy-supply from device tree
  831. [    0.846753] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
  832. [    0.847030] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up vbus-supply from device tree
  833. [    0.847039] phy phy-ff770000.syscon:usb2-phy@e460.5: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
  834. [    0.847059] phy phy-ff770000.syscon:usb2-phy@e460.5: Failed to get VBUS supply regulator
  835. [    0.848392] phy phy-ff7c0000.phy.6: Looking up phy-supply from device tree
  836. [    0.848402] phy phy-ff7c0000.phy.6: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
  837. [    0.848461] mp8859 7-0066: mp8859 get notify
  838. [    0.848518] phy phy-ff7c0000.phy.7: Looking up phy-supply from device tree
  839. [    0.848523] phy phy-ff7c0000.phy.7: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
  840. [    0.848862] mp8859 7-0066: mp8859 get ufp 1 dp 0
  841. [    0.848922] phy phy-ff800000.phy.8: Looking up phy-supply from device tree
  842. [    0.848927] phy phy-ff800000.phy.8: Looking up phy-supply property in node /phy@ff800000/dp-port failed
  843. [    0.849010] phy phy-ff800000.phy.9: Looking up phy-supply from device tree
  844. [    0.849015] phy phy-ff800000.phy.9: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
  845. [    0.849550] rockchip-drm display-subsystem: defer getting devfreq
  846. [    0.850365] rockchip-vop ff900000.vop: missing rockchip,grf property
  847. [    0.850375] mp8859 7-0066: set mp8859 out 12v ok
  848. [    0.851582] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008b251e8)
  849. [    0.852337] rockchip-vop ff8f0000.vop: missing rockchip,grf property
  850. [    0.853048] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008b251e8)
  851. [    0.854119] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
  852. [    0.854734] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
  853. [    0.855517] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
  854. [    0.858139] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008b19fd8)
  855. [    0.859325] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
  856. [    0.860184] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
  857. [    0.860994] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff8008b1aff8)
  858. [    0.861700] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  859. [    0.862279] [drm] No driver support for vblank timestamp query.
  860. [    0.918437] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
  861. [    0.919349] vccio_sd: ramp_delay not set
  862. [    0.919378] rockchip-iodomain ff770000.syscon:io-domains: Setting to 1800000 done
  863. [    0.945830] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
  864. [    1.154948] dwmmc_rockchip fe320000.dwmmc: Successfully tuned phase to 116
  865. [    1.154983] mmc0: new ultra high speed SDR50 SDXC card at address aaaa
  866. [    1.156534] mmcblk0: mmc0:aaaa SL128 119 GiB
  867. [    1.187805] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1280x720p50, type: 11
  868. [    1.190291]  mmcblk0: p1 p2 p3 p4 p5
  869. [    1.221833] Freeing drm_logo memory: 616K
  870. [    1.298125] Console: switching to colour frame buffer device 160x45
  871. [    1.344925] rockchip-drm display-subsystem: fb0:  frame buffer device
  872. [    1.352139] mali ff9a0000.gpu: Looking up mali-supply from device tree
  873. [    1.352448] mali ff9a0000.gpu: leakage=28
  874. [    1.352827] mali ff9a0000.gpu: Looking up mali-supply from device tree
  875. [    1.352850] vdd_gpu: could not add device link ff9a0000.gpu err -17
  876. [    1.352861] vdd_gpu: Failed to create debugfs directory
  877. [    1.366031] mali ff9a0000.gpu: temp=62500, pvtm=126167 (125915 + 252)
  878. [    1.370158] mali ff9a0000.gpu: pvtm-volt-sel=2
  879. [    1.371478] fusb302 7-0022: 0000 max vol cur 0 0
  880. [    1.371911] fusb302 7-0022: max vol cur 15000 3000
  881. [    1.372991] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
  882. [    1.374146] mali ff9a0000.gpu: Protected mode not available
  883. [    1.376001] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
  884. [    1.376743] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
  885. [    1.377946] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
  886. [    1.380826] mali ff9a0000.gpu: Probed as mali0
  887. [    1.387066] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
  888. [    1.388055] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
  889. [    1.388890] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
  890. [    1.389711] xhci-hcd xhci-hcd.10.auto: irq 232, io mem 0xfe800000
  891. [    1.390458] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  892. [    1.391060] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  893. [    1.391701] usb usb1: Product: xHCI Host Controller
  894. [    1.392131] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
  895. [    1.392638] usb usb1: SerialNumber: xhci-hcd.10.auto
  896. [    1.393815] hub 1-0:1.0: USB hub found
  897. [    1.394173] hub 1-0:1.0: 1 port detected
  898. [    1.394784] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
  899. [    1.395521] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 2
  900. [    1.396250] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  901. [    1.397049] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
  902. [    1.397659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  903. [    1.398293] usb usb2: Product: xHCI Host Controller
  904. [    1.398729] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
  905. [    1.399215] usb usb2: SerialNumber: xhci-hcd.10.auto
  906. [    1.400342] hub 2-0:1.0: USB hub found
  907. [    1.400697] hub 2-0:1.0: 1 port detected
  908. [    1.402295] xhci-hcd xhci-hcd.10.auto: remove, state 1
  909. [    1.402801] usb usb2: USB disconnect, device number 1
  910. [    1.427577] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
  911. [    1.428241] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
  912. [    1.428961] xhci-hcd xhci-hcd.10.auto: USB bus 2 deregistered
  913. [    1.429838] xhci-hcd xhci-hcd.10.auto: remove, state 1
  914. [    1.430370] usb usb1: USB disconnect, device number 1
  915. [    1.431577] xhci-hcd xhci-hcd.10.auto: USB bus 1 deregistered
  916. [    1.489235] fusb302 7-0022: PD connected as UFP, fetching 5V
  917. [    1.570806] random: nonblocking pool is initialized
  918. [    1.590676] mp8859 7-0066: mp8859 get notify
  919. [    1.591081] mp8859 7-0066: mp8859 get ufp 1 dp 1
  920. [    1.594291] mp8859 7-0066: set mp8859 out 12v ok
  921. [    1.612701] phy phy-ff770000.syscon:usb2-phy@e450.3: charger = USB_DCP_CHARGER
  922. [    1.618631] rockchip-dwc3 usb0: USB peripheral connected
  923. [    1.621100] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
  924. [    1.621978] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 1
  925. [    1.622923] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
  926. [    1.623800] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe900000
  927. [    1.624741] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  928. [    1.625382] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  929. [    1.626025] usb usb1: Product: xHCI Host Controller
  930. [    1.626488] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
  931. [    1.626984] usb usb1: SerialNumber: xhci-hcd.11.auto
  932. [    1.628402] hub 1-0:1.0: USB hub found
  933. [    1.628789] hub 1-0:1.0: 1 port detected
  934. [    1.629715] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
  935. [    1.630498] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 2
  936. [    1.631289] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  937. [    1.632203] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
  938. [    1.632833] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  939. [    1.633489] usb usb2: Product: xHCI Host Controller
  940. [    1.633936] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
  941. [    1.634446] usb usb2: SerialNumber: xhci-hcd.11.auto
  942. [    1.635803] hub 2-0:1.0: USB hub found
  943. [    1.636185] hub 2-0:1.0: 1 port detected
  944. [    1.637391] xhci-hcd xhci-hcd.11.auto: remove, state 1
  945. [    1.637875] usb usb2: USB disconnect, device number 1
  946. [    1.639216] xhci-hcd xhci-hcd.11.auto: USB bus 2 deregistered
  947. [    1.639979] xhci-hcd xhci-hcd.11.auto: remove, state 1
  948. [    1.640512] usb usb1: USB disconnect, device number 1
  949. [    1.641508] xhci-hcd xhci-hcd.11.auto: USB bus 1 deregistered
  950. [    1.644474] ehci-platform fe380000.usb: EHCI Host Controller
  951. [    1.645544] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
  952. [    1.646524] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
  953. [    1.652383] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
  954. [    1.653436] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  955. [    1.654055] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  956. [    1.654735] usb usb1: Product: EHCI Host Controller
  957. [    1.655186] usb usb1: Manufacturer: Linux 4.4.167 ehci_hcd
  958. [    1.655709] usb usb1: SerialNumber: fe380000.usb
  959. [    1.657643] hub 1-0:1.0: USB hub found
  960. [    1.658047] hub 1-0:1.0: 1 port detected
  961. [    1.664127] ehci-platform fe3c0000.usb: EHCI Host Controller
  962. [    1.665640] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
  963. [    1.666737] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
  964. [    1.673404] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
  965. [    1.674532] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  966. [    1.675153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  967. [    1.675833] usb usb2: Product: EHCI Host Controller
  968. [    1.676284] usb usb2: Manufacturer: Linux 4.4.167 ehci_hcd
  969. [    1.676812] usb usb2: SerialNumber: fe3c0000.usb
  970. [    1.678534] hub 2-0:1.0: USB hub found
  971. [    1.678989] hub 2-0:1.0: 1 port detected
  972. [    1.681640] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
  973. [    1.683223] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
  974. [    1.684386] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
  975. [    1.739842] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
  976. [    1.740494] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  977. [    1.741144] usb usb3: Product: Generic Platform OHCI controller
  978. [    1.741709] usb usb3: Manufacturer: Linux 4.4.167 ohci_hcd
  979. [    1.742206] usb usb3: SerialNumber: fe3a0000.usb
  980. [    1.744296] hub 3-0:1.0: USB hub found
  981. [    1.744785] hub 3-0:1.0: 1 port detected
  982. [    1.747394] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
  983. [    1.748779] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
  984. [    1.749771] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
  985. [    1.805808] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  986. [    1.806448] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  987. [    1.807103] usb usb4: Product: Generic Platform OHCI controller
  988. [    1.807653] usb usb4: Manufacturer: Linux 4.4.167 ohci_hcd
  989. [    1.808150] usb usb4: SerialNumber: fe3e0000.usb
  990. [    1.809975] hub 4-0:1.0: USB hub found
  991. [    1.810456] hub 4-0:1.0: 1 port detected
  992. [    1.812776] input: adc-keys as /devices/platform/adc-keys/input/input1
  993. [    1.816375] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
  994. [    1.817112] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
  995. [    1.817802] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
  996. [    1.818399] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
  997. [    1.819360] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
  998. [    1.819389] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
  999. [    1.819479] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
  1000. [    1.819507] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
  1001. [    1.819555] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
  1002. [    1.820145] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
  1003. [    1.820767] dwmmc_rockchip fe310000.dwmmc: GPIO lookup for consumer wp
  1004. [    1.820789] dwmmc_rockchip fe310000.dwmmc: using device tree for GPIO lookup
  1005. [    1.820815] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe310000[0]'
  1006. [    1.820838] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe310000[0]'
  1007. [    1.820859] dwmmc_rockchip fe310000.dwmmc: using lookup tables for GPIO lookup
  1008. [    1.820882] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
  1009. [    1.821478] platform sdio-pwrseq: GPIO lookup for consumer reset
  1010. [    1.821500] platform sdio-pwrseq: using device tree for GPIO lookup
  1011. [    1.821570] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
  1012. [    1.821672] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
  1013. [    1.833516] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
  1014. [    1.845786] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
  1015. [    1.847530] rockchip-dmc dmc: Looking up center-supply from device tree
  1016. [    1.848158] rockchip-dmc dmc: Failed to get leakage
  1017. [    1.848749] rockchip-dmc dmc: Looking up center-supply from device tree
  1018. [    1.848821] vdd_center: could not add device link dmc err -17
  1019. [    1.848850] vdd_center: Failed to create debugfs directory
  1020. [    1.848876] rockchip-dmc dmc: Failed to get pvtm
  1021. [    1.850054] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
  1022. [    1.850703] rockchip-dmc dmc: failed to get vop pn to msch rl
  1023. [    1.851777] rockchip-dmc dmc: could not find power_model node
  1024. [    1.853636] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
  1025. [    1.853661] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
  1026. [    1.854967] asoc-simple-card hdmi-sound: i2s-hifi <-> ff8a0000.i2s mapping ok
  1027. [    1.860122] rockchip-cdndp-sound dp-sound: spdif-hifi <-> ff870000.spdif mapping ok
  1028. [    1.861162] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
  1029. [    1.861578] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
  1030. [    1.864629] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card1/input2
  1031. [    1.867774] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0)
  1032. [    1.867875] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
  1033. [    1.868415] input: gpio-keys as /devices/platform/gpio-keys/input/input3
  1034. [    1.869707] ==gsl_ts_init==
  1035. [    1.870102] ret=0
  1036. [    1.870892] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply from device tree
  1037. [    1.870925] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply property in node /power-management@ff310000/power-controller failed
  1038. [    1.871052] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply from device tree
  1039. [    1.871081] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@ff310000/power-controller failed
  1040. [    1.871184] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply from device tree
  1041. [    1.871213] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply property in node /power-management@ff310000/power-controller failed
  1042. [    1.872132] rk808-rtc rk808-rtc: setting system clock to 2019-08-20 05:04:41 UTC (1566277481)
  1043. [    1.873473] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
  1044. [    1.911142] vcc_mipi: disabling
  1045. [    1.911473] dvdd_1v2: disabling
  1046. [    1.911801] ret 1024
  1047. [    1.912404] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
  1048. [    1.912585] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply from device tree
  1049. [    1.912605] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply property in node /power-management@ff310000/power-controller failed
  1050. [    1.912750] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply from device tree
  1051. [    1.912765] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply property in node /power-management@ff310000/power-controller failed
  1052. [    1.912878] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply from device tree
  1053. [    1.912892] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vopl-supply property in node /power-management@ff310000/power-controller failed
  1054. [    1.912995] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply from device tree
  1055. [    1.913008] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply property in node /power-management@ff310000/power-controller failed
  1056. [    1.913098] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree
  1057. [    1.913111] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed
  1058. [    1.913224] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '14:46:49', on 'Jun 24 2019'.
  1059. [    1.913956] Mali: Mali device driver loaded
  1060. [    1.915333] rockchip-pinctrl pinctrl: unsupported driver strength 20
  1061. [    1.915343] rockchip-pinctrl pinctrl: pin_config_set op failed for pin 122
  1062. [    1.915352] usb-ext-charge usb-charge: Error applying setting, reverse things back
  1063. [    1.915447] usb-ext-charge usb-charge: GPIO lookup for consumer charge-en
  1064. [    1.915457] usb-ext-charge usb-charge: using device tree for GPIO lookup
  1065. [    1.915505] of_get_named_gpiod_flags: parsed 'charge-en-gpios' property of node '/usb-charge[0]' - status (0)
  1066. [    1.915546] usb-ext-charge usb-charge: GPIO lookup for consumer cur-ctl
  1067. [    1.915554] usb-ext-charge usb-charge: using device tree for GPIO lookup
  1068. [    1.915600] of_get_named_gpiod_flags: parsed 'cur-ctl-gpios' property of node '/usb-charge[0]' - status (0)
  1069. [    1.915638] usb-ext-charge usb-charge: GPIO lookup for consumer poe-state
  1070. [    1.915646] usb-ext-charge usb-charge: using device tree for GPIO lookup
  1071. [    1.915689] of_get_named_gpiod_flags: parsed 'poe-state-gpios' property of node '/usb-charge[0]' - status (0)
  1072. [    1.915717] usb-ext-charge usb-charge: GPIO lookup for consumer cap-led
  1073. [    1.915725] usb-ext-charge usb-charge: using device tree for GPIO lookup
  1074. [    1.915737] of_get_named_gpiod_flags: can't parse 'cap-led-gpios' property of node '/usb-charge[0]'
  1075. [    1.915747] of_get_named_gpiod_flags: can't parse 'cap-led-gpio' property of node '/usb-charge[0]'
  1076. [    1.915755] usb-ext-charge usb-charge: using lookup tables for GPIO lookup
  1077. [    1.915765] usb-ext-charge usb-charge: lookup for GPIO cap-led failed
  1078. [    1.915808] of_get_named_gpiod_flags: parsed 'bat-int' property of node '/usb-charge[0]' - status (0)
  1079. [    1.916365] usb-ext-charge usb-charge: register ext0 dev0
  1080. [    1.916378] usb-ext-charge usb-charge: uec get notify
  1081. [    1.916390] usb-ext-charge usb-charge: uec get ufp 1 pd 1
  1082. [    1.916402] usb-ext-charge usb-charge:  usb status 2 battery_online 0 poe_online 0
  1083. [    1.916424] usb-ext-charge usb-charge: probe success
  1084. [    1.917233] ALSA device list:
  1085. [    1.917239]   #0: rockchip,hdmi
  1086. [    1.917244]   #1: rockchip-cdndp-sound
  1087. [    1.961516] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
  1088. [    1.981410] usb 2-1: new high-speed USB device number 2 using ehci-platform
  1089. [    2.096450] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
  1090. [    2.097136] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  1091. [    2.097850] usb 2-1: Product: USB 2.0 Hub [MTT]
  1092. [    2.100001] hub 2-1:1.0: USB hub found
  1093. [    2.100625] hub 2-1:1.0: 4 ports detected
  1094. [    2.180416] usb 3-1: new low-speed USB device number 2 using ohci-platform
  1095. [    2.368424] usb 3-1: New USB device found, idVendor=03f0, idProduct=1198
  1096. [    2.369030] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1097. [    2.369694] usb 3-1: Product: HP USB 1000dpi Laser Mouse
  1098. [    2.370175] usb 3-1: Manufacturer: HP
  1099. [    2.378583] usb 2-1.4: new low-speed USB device number 3 using ehci-platform
  1100. [    2.380464] input: HP HP USB 1000dpi Laser Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:03F0:1198.0001/input/input4
  1101. [    2.432761] hid-generic 0003:03F0:1198.0001: input,hidraw0: USB HID v2.00 Mouse [HP HP USB 1000dpi Laser Mouse] on usb-fe3a0000.usb-1/input0
  1102. [    2.433622] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
  1103. [    2.433676] VFS: Mounted root (ext4 filesystem) on device 179:5.
  1104. [    2.441495] hid-generic 0003:03F0:1198.0002: hiddev0,hidraw1: USB HID v2.00 Device [HP HP USB 1000dpi Laser Mouse] on usb-fe3a0000.usb-1/input1
  1105. [    2.443006] devtmpfs: mounted
  1106. [    2.443742] Freeing unused kernel memory: 1088K
  1107. [    2.473186] usb 2-1.4: New USB device found, idVendor=413c, idProduct=2003
  1108. [    2.473853] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1109. [    2.474528] usb 2-1.4: Product: Dell USB Keyboard
  1110. [    2.474955] usb 2-1.4: Manufacturer: Dell
  1111. [    2.483595] input: Dell Dell USB Keyboard as /devices/platform/fe3c0000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:413C:2003.0003/input/input5
  1112. [    2.536817] hid-generic 0003:413C:2003.0003: input,hidraw2: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-fe3c0000.usb-1.4/input0
  1113. [    3.173508] cgroup: cgroup2: unknown option "nsdelegate"
  1114. [    3.212676] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1115. [    3.216108] systemd[1]: Detected architecture arm64.
  1116. [    3.242147] systemd[1]: Set hostname to <firefly>.
  1117. [    3.793529] systemd[1]: File /lib/systemd/system/systemd-udevd.service:34 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
  1118. [    3.795101] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
  1119. [    3.835397] vendor storage:20160801 ret = -1
  1120. [    3.885539] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
  1121. [    3.886273] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
  1122. [    4.460912] systemd[1]: Created slice User and Session Slice.
  1123. [    4.462438] systemd[1]: Reached target Swap.
  1124. [    4.463758] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1125. [    4.464992] systemd[1]: Reached target User and Group Name Lookups.
  1126. [    4.466445] systemd[1]: Reached target Remote File Systems.
  1127. [    4.468608] systemd[1]: Created slice System Slice.
  1128. [    4.470922] systemd[1]: Created slice system-serial\x2dgetty.slice.
  1129. [    4.529365] systemd[1]: Listening on udev Control Socket.
  1130. [    4.530459] systemd[1]: Reached target Slices.
  1131. [    4.531693] systemd[1]: Listening on udev Kernel Socket.
  1132. [    4.533461] systemd[1]: Listening on Journal Socket.
  1133. [    4.541024] systemd[1]: Starting Set the console keyboard layout...
  1134. [    4.548672] systemd[1]: Mounting Kernel Debug File System...
  1135. [    4.557857] systemd[1]: Starting Remount Root and Kernel File Systems...
  1136. [    4.584038] systemd[1]: Starting Load Kernel Modules...
  1137. [    4.587185] systemd[1]: Listening on Syslog Socket.
  1138. [    4.593616] systemd[1]: Starting udev Coldplug all Devices...
  1139. [    4.595495] systemd[1]: Listening on Journal Socket (/dev/log).
  1140. [    4.607084] systemd[1]: Starting Journal Service...
  1141. [    4.611475] systemd[1]: Starting Create Static Device Nodes in /dev...
  1142. [    4.657090] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
  1143. [    4.661023] systemd[1]: Started Remount Root and Kernel File Systems.
  1144. [    4.667967] systemd[1]: Started Load Kernel Modules.
  1145. [    4.678653] systemd[1]: Mounting Kernel Configuration File System...
  1146. [    4.686719] systemd[1]: Starting Apply Kernel Variables...
  1147. [    4.691382] systemd[1]: Mounting FUSE Control File System...
  1148. [    4.724005] systemd[1]: Starting Load/Save Random Seed...
  1149. [    4.788360] systemd[1]: Started Load/Save Random Seed.
  1150. [    4.804362] systemd[1]: Mounted Kernel Debug File System.
  1151. [    4.805567] systemd[1]: Mounted Kernel Configuration File System.
  1152. [    4.806872] systemd[1]: Mounted FUSE Control File System.
  1153. [    4.813586] systemd[1]: Started Apply Kernel Variables.
  1154. [    4.871852] systemd[1]: Started Create Static Device Nodes in /dev.
  1155. [    4.874321] systemd[1]: Starting udev Kernel Device Manager...
  1156. [    4.964237] systemd[1]: Started udev Coldplug all Devices.
  1157. [    5.009674] systemd[1]: Started Set the console keyboard layout.
  1158. [    5.010065] systemd[1]: Reached target Local File Systems (Pre).
  1159. [    5.010234] systemd[1]: Reached target Local File Systems.
  1160. [    5.012370] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
  1161. [    5.014529] systemd[1]: Starting Set console font and keymap...
  1162. [    5.026214] systemd[1]: Started Journal Service.
  1163. [    5.056693] systemd-journald[193]: Received request to flush runtime journal from PID 1
  1164. [    5.935477] usb-ext-charge usb-charge: adc value = 3
  1165. [    5.935498] usb-ext-charge usb-charge:  usb status 2 battery_online 1 poe_online 0
  1166. [    6.096806] MWEcoCapture: loading out-of-tree module taints kernel.
  1167. [    6.098888] Eco Capture 0000:01:00.0: enabling device (0000 -> 0002)
  1168. [    6.646352] Eco Capture: V4L2 device registered as video8
  1169. [    7.011929] cfg80211: World regulatory domain updated:
  1170. [    7.011955] cfg80211:  DFS Master region: unset
  1171. [    7.011965] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
  1172. [    7.011981] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
  1173. [    7.011997] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
  1174. [    7.012011] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
  1175. [    7.012026] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
  1176. [    7.012041] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
  1177. [    7.012056] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
  1178. [    7.012069] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
  1179. [    7.012116] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
  1180. [    7.964395] [BT_RFKILL]: ENABLE UART_RTS
  1181. [    8.074112] [BT_RFKILL]: DISABLE UART_RTS
  1182. [    8.074263] [BT_RFKILL]: bt turn on power
  1183. [    8.939360] file system registered
  1184. [    8.950629] ttyS0 - failed to request DMA, use interrupt mode
  1185. [    9.388430] read descriptors
  1186. [    9.388457] read strings
  1187. [   10.087824] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
  1188. [   10.914217] tty_port_close_start: tty->count = 1 port count = 2.
  1189. [   13.369743] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
  1190. [   13.369777] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  1191. [   40.007465] usb-ext-charge usb-charge: adc value = 4
  1192. [   40.007497] usb-ext-charge usb-charge:  usb status 2 battery_online 0 poe_online 0
Copy the code
vip
Rank: 6Rank: 6
Posted at 8/23/2019 09:21:55        Only Author  4#
  1. [    0.216834] reg-fixed-voltage vcc_mipi: vcc_mipi supplying 0uV
  2. [    0.216902] rockchip-pinctrl pinctrl: pin gpio1-17 already requested by vcc-pcie; cannot claim for dvdd-1v2
  3. [    0.217769] rockchip-pinctrl pinctrl: pin-49 (dvdd-1v2) status -22
  4. [    0.218321] rockchip-pinctrl pinctrl: could not request pin 49 (gpio1-17) from group cif-pwr  on device rockchip-pinctrl
  5. [    0.219284] reg-fixed-voltage dvdd-1v2: Error applying setting, reverse things back
  6. [    0.220010] of_get_named_gpiod_flags: parsed 'gpio' property of node '/dvdd-1v2[0]' - status (0)
  7. [    0.220046] dvdd_1v2: no parameters
  8. [    0.220201] reg-fixed-voltage dvdd-1v2: dvdd_1v2 supplying 0uV
Copy the code
Some regulators have conflict GPIOs, please check your PCIe dts node.
Posted at 8/29/2019 04:17:41        Only Author  5#
penguin Posted at 8/23/2019 09:21
Could you provide instructions on how to check PCIe dts node?
vip
Rank: 6Rank: 6
Posted at 9/3/2019 17:40:46        Only Author  6#
Please check the log quoted before. You have to inspect the GPIOs used in PCIe dts node and dvdd-1v2 regulator node carefully.
