[Android] Does rk3328 support hdmi 800x480-60p resolution?
135
【Android】 Does rk3328 support hdmi 800x480-60p resolution?
Posted at 3/3/2020 17:41:05      View:4628 | Replies:4        Print      Only Author   [Copy Link] 1#
I want to use an 800x480p LCD with the hdmi interface of core-rk3328-jd4.
The LCD is odroid-c2 compatible.
In aio-3288j, the value of /sys/class/display/HDMI/modes is 'auto' and the mode value is recognized as '1280x720p-60' but only 800x480 is displayed on the screen.
core-rk3328-jd4 does not recognize it, and nothing appears on the screen.
How can I use this LCD with core-rk3328-jd4?
Posted at 3/12/2020 15:27:14        Only Author  2#
Added pixel-rate of 800x480 LCD to 'kernel/driver/phy/rockchip/phy-rockchip-inno-hdmi-phy.c'.
Add '{ 29230000,  29230000, 1,  90, 2, 2, 2, 12, 2, 2, 2, 0, 0},' to the pre_pll_config list, the screen will appear on the 800x400 LCD.
What does each pre_pll_config item (pixclock, tmdsclock, prediv, fbdiv, tmds_div_a, ..., pclk_div_a, ...) mean?
Is the problem caused by incorrect pre_pll_config item values?
Posted at 8/18/2021 11:09:39        Only Author  3#
Posted at 8/18/2021 11:11:39        Only Author  4#
Posted at 8/18/2021 11:22:26        Only Author  5#
testki144 Posted at 3/12/2020 15:27
Add ' ...
Hope to useful
