Wi-Fi Access Point mode using hostapd
19
Posted at 7/20/2015 19:47:50      View:8739 | Replies:5        Print      Only Author   [Copy Link] 1#
Hi,
does the Firefly-RK3288 support access point mode? I'm trying to set up hostapd on Ubuntu but I've not been able to make it work. Anyone managed to do it?
Thanks!
vip
Rank: 6Rank: 6
Posted at 7/21/2015 11:48:11        Only Author  2#
some one have support it, but it is chinese:
http://developer.t-firefly.com/thread-1684-1-1.html
Posted at 7/21/2015 12:00:29        Only Author  3#
Actually, this is a YES.
Here is the link (but in Chinese, use Google translate):
Posted at 7/21/2015 16:24:29        Only Author  4#
Thanks, I'll try to understand what's in there... :-)
Posted at 7/21/2015 16:56:59        Only Author  5#
Thanks, I've followed the instructions on the link you posted and I can confirm it works. It is a pain to bring everything down and upload a new firmware, but better than nothing. :-)
Posted at 7/31/2015 19:54:48        Only Author  6#
Hi,
after some testing I've managed to make it work. No need to rewrite the firmware, just need to change the "op_mode" and restart wifi. At the moment, the only way I've found to restart the wifi is to use rfkill or nmcli:
  1. sudo nmcli radio wifi off
  2. sudo su -c "echo 2 > /sys/module/bcmdhd/parameters/op_mode"
  3. sudo nmcli radio wifi on
Copy the code
Now I'm facing the problem that while in AP mode, network manager can't scan the network anymore (nmcli dev wifi rescan). When it tries, I see this error in dmesg:
  1. CFG80211-ERROR) __wl_cfg80211_scan : Invalid Scan Command at SoftAP mode
  2. CFG80211-ERROR) wl_cfg80211_scan : scan error (-22)
Copy the code
The error seems to imply that scan can't be done, but using iwlist it seems to work instead (iwlist wlan0 scan), even if the kernel complains:
  1. bcmsdh_sdmmc mmc2:0001:2 wlan0: (WE) : Wireless Event (cmd=0x8B19) too big (65303)
  2. CFG80211-ERROR) wl_notify_scan_status : scan is not ready
Copy the code
Any idea or suggestion? Thanks!
