New Topic
Need help with display setup
55
Posted at 9/22/2016 19:17:33        Only Author  11#
Unfortunately, I have only 1 firefly board. HDMI was working with another firmware, just could not set correct resolution. Do you think HDMI input is damaged somehow now? I will try to flash older firmware to test the behavior today evening and will post the result.
Posted at 9/24/2016 05:04:26        Only Author  12#
I have flashed firmware "Firefly-RK3288_MainlineKernel-Ubuntu14.04_201503191033". In this case HDMI is working, but I am not able to set correct (800 x 480) resolution. Here is Xorg.0.log:
  1. [    10.539]
  2. X.Org X Server 1.15.1
  3. Release Date: 2014-04-13
  4. [    10.539] X Protocol Version 11, Revision 0
  5. [    10.539] Build Operating System: Linux 3.2.0-60-highbank armv7l Ubuntu
  6. [    10.539] Current Operating System: Linux firefly 4.0.0-rc1+ #58 SMP Wed Mar 18 17:40:36 CST 2015 armv7l
  7. [    10.539] Kernel command line: console=ttyS2,115200 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init  mtdparts=rk29xxnand:0x00008000@0x00002000(kernel),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x00001000@0x00014000(backup),-@0x00015000(linuxroot) storagemedia=emmc loader.timestamp=2015-03-18_16:19:34 androidboot.mode=emmc
  8. [    10.539] Build Date: 30 July 2014  12:24:34AM
  9. [    10.539] xorg-server 2:1.15.1-0ubuntu2.1 (For technical support please see http://www.ubuntu.com/support)
  10. [    10.539] Current version of pixman: 0.30.2
  11. [    10.539]         Before reporting problems, check http://wiki.x.org
  12.         to make sure that you have the latest version.
  13. [    10.539] Markers: (--) probed, (**) from config file, (==) default setting,
  14.         (++) from command line, (!!) notice, (II) informational,
  15.         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
  16. [    10.540] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan  1 00:00:10 1970
  17. [    10.559] (==) Using config file: "/etc/X11/xorg.conf"
  18. [    10.559] (==) Using config directory: "/etc/X11/xorg.conf.d"
  19. [    10.559] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
  20. [    10.576] (==) No Layout section.  Using the first Screen section.
  21. [    10.576] (**) |-->Screen "Default Screen" (0)
  22. [    10.576] (**) |   |-->Monitor "<default monitor>"
  23. [    10.577] (==) No device specified for screen "Default Screen".
  24.         Using the first device section listed.
  25. [    10.577] (**) |   |-->Device "Default Device"
  26. [    10.577] (==) No monitor specified for screen "Default Screen".
  27.         Using a default monitor configuration.
  28. [    10.577] (==) Automatically adding devices
  29. [    10.577] (==) Automatically enabling devices
  30. [    10.577] (==) Automatically adding GPU devices
  31. [    10.603] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
  32. [    10.603]         Entry deleted from font path.
  33. [    10.604] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
  34. [    10.604]         Entry deleted from font path.
  35. [    10.604] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
  36. [    10.604]         Entry deleted from font path.
  37. [    10.604] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
  38. [    10.604]         Entry deleted from font path.
  39. [    10.604] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
  40. [    10.604]         Entry deleted from font path.
  41. [    10.604] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
  42. [    10.604]         Entry deleted from font path.
  43. [    10.604] (==) FontPath set to:
  44.         /usr/share/fonts/X11/misc,
  45.         built-ins
  46. [    10.604] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
  47. [    10.604] (II) The server relies on udev to provide the list of input devices.
  48.         If no devices become available, reconfigure udev or disable AutoAddDevices.
  49. [    10.604] (II) Loader magic: 0xb6f86f10
  50. [    10.604] (II) Module ABI versions:
  51. [    10.604]         X.Org ANSI C Emulation: 0.4
  52. [    10.604]         X.Org Video Driver: 15.0
  53. [    10.604]         X.Org XInput driver : 20.0
  54. [    10.604]         X.Org Server Extension : 8.0
  55. [    10.606] (II) xfree86: Adding drm device (/dev/dri/card0)
  56. [    10.606] Initializing built-in extension Generic Event Extension
  57. [    10.606] Initializing built-in extension SHAPE
  58. [    10.607] Initializing built-in extension MIT-SHM
  59. [    10.607] Initializing built-in extension XInputExtension
  60. [    10.607] Initializing built-in extension XTEST
  61. [    10.607] Initializing built-in extension BIG-REQUESTS
  62. [    10.607] Initializing built-in extension SYNC
  63. [    10.607] Initializing built-in extension XKEYBOARD
  64. [    10.607] Initializing built-in extension XC-MISC
  65. [    10.607] Initializing built-in extension SECURITY
  66. [    10.607] Initializing built-in extension XINERAMA
  67. [    10.607] Initializing built-in extension XFIXES
  68. [    10.607] Initializing built-in extension RENDER
  69. [    10.607] Initializing built-in extension RANDR
  70. [    10.607] Initializing built-in extension COMPOSITE
  71. [    10.607] Initializing built-in extension DAMAGE
  72. [    10.607] Initializing built-in extension MIT-SCREEN-SAVER
  73. [    10.607] Initializing built-in extension DOUBLE-BUFFER
  74. [    10.607] Initializing built-in extension RECORD
  75. [    10.607] Initializing built-in extension DPMS
  76. [    10.607] Initializing built-in extension Present
  77. [    10.607] Initializing built-in extension DRI3
  78. [    10.607] Initializing built-in extension X-Resource
  79. [    10.608] Initializing built-in extension XVideo
  80. [    10.608] Initializing built-in extension XVideo-MotionCompensation
  81. [    10.608] Initializing built-in extension SELinux
  82. [    10.608] Initializing built-in extension XFree86-VidModeExtension
  83. [    10.608] Initializing built-in extension XFree86-DGA
  84. [    10.608] Initializing built-in extension XFree86-DRI
  85. [    10.608] Initializing built-in extension DRI2
  86. [    10.608] (II) LoadModule: "glx"
  87. [    10.614] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
  88. [    10.690] (II) Module glx: vendor="X.Org Foundation"
  89. [    10.690]         compiled for 1.15.1, module version = 1.0.0
  90. [    10.690]         ABI class: X.Org Server Extension, version 8.0
  91. [    10.690] (==) AIGLX enabled
  92. [    10.690] Loading extension GLX
  93. [    10.690] (II) LoadModule: "fbdev"
  94. [    10.693] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
  95. [    10.695] (II) Module fbdev: vendor="X.Org Foundation"
  96. [    10.695]         compiled for 1.15.0, module version = 0.4.4
  97. [    10.695]         Module class: X.Org Video Driver
  98. [    10.695]         ABI class: X.Org Video Driver, version 15.0
  99. [    10.695] (II) FBDEV: driver for framebuffer: fbdev
  100. [    10.695] (++) using VT number 7
  101. [    10.736] (WW) Falling back to old probe method for fbdev
  102. [    10.736] (II) Loading sub module "fbdevhw"
  103. [    10.736] (II) LoadModule: "fbdevhw"
  104. [    10.737] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
  105. [    10.739] (II) Module fbdevhw: vendor="X.Org Foundation"
  106. [    10.739]         compiled for 1.15.1, module version = 0.0.2
  107. [    10.739]         ABI class: X.Org Video Driver, version 15.0
  108. [    10.739] (II) FBDEV(0): using default device
  109. [    10.739] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
  110. [    10.739] (II) FBDEV(0): Creating default Display subsection in Screen section
  111.         "Default Screen" for depth/fbbpp 24/32
  112. [    10.739] (**) FBDEV(0): Depth 24, (--) framebuffer bpp 32
  113. [    10.739] (==) FBDEV(0): RGB weight 888
  114. [    10.739] (==) FBDEV(0): Default visual is TrueColor
  115. [    10.739] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
  116. [    10.740] (II) FBDEV(0): hardware:  (video memory: 8100kB)
  117. [    10.740] (II) FBDEV(0): checking modes against framebuffer device...
  118. [    10.740] (II) FBDEV(0): checking modes against monitor...
  119. [    10.740] (--) FBDEV(0): Virtual size is 1920x1080 (pitch 1920)
  120. [    10.740] (**) FBDEV(0):  Built-in mode "current"
  121. [    10.740] (==) FBDEV(0): DPI set to (96, 96)
  122. [    10.740] (II) Loading sub module "fb"
  123. [    10.740] (II) LoadModule: "fb"
  124. [    10.740] (II) Loading /usr/lib/xorg/modules/libfb.so
  125. [    10.765] (II) Module fb: vendor="X.Org Foundation"
  126. [    10.765]         compiled for 1.15.1, module version = 1.0.0
  127. [    10.765]         ABI class: X.Org ANSI C Emulation, version 0.4
  128. [    10.765] (**) FBDEV(0): using shadow framebuffer
  129. [    10.765] (II) Loading sub module "shadow"
  130. [    10.765] (II) LoadModule: "shadow"
  131. [    10.766] (II) Loading /usr/lib/xorg/modules/libshadow.so
  132. [    10.768] (II) Module shadow: vendor="X.Org Foundation"
  133. [    10.768]         compiled for 1.15.1, module version = 1.1.0
  134. [    10.768]         ABI class: X.Org ANSI C Emulation, version 0.4
  135. [    10.768] (==) Depth 24 pixmap format is 32 bpp
  136. [    10.865] (==) FBDEV(0): Backing store enabled
  137. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  138. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  139. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  140. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  141. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  142. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  143. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  144. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  145. [    10.866] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  146. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  147. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  148. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  149. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  150. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  151. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  152. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  153. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  154. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  155. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  156. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  157. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  158. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  159. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  160. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  161. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  162. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  163. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  164. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  165. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  166. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  167. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  168. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  169. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  170. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  171. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  172. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  173. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  174. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  175. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  176. [    10.867] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  177. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  178. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  179. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  180. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  181. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  182. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  183. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  184. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  185. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  186. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  187. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  188. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  189. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  190. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  191. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  192. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  193. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  194. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  195. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  196. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  197. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  198. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  199. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  200. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  201. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  202. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  203. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  204. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  205. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  206. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  207. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  208. [    10.868] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  209. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  210. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  211. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  212. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  213. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  214. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  215. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  216. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  217. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  218. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  219. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  220. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  221. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  222. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  223. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  224. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  225. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  226. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  227. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  228. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  229. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  230. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  231. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  232. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  233. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  234. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  235. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  236. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  237. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  238. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  239. [    10.869] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  240. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  241. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  242. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  243. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  244. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  245. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  246. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  247. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  248. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  249. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  250. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  251. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  252. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  253. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  254. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  255. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  256. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  257. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  258. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  259. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  260. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  261. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  262. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  263. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  264. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  265. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  266. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  267. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  268. [    10.870] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  269. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  270. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  271. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  272. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  273. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  274. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  275. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  276. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  277. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  278. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  279. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  280. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  281. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  282. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  283. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  284. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  285. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  286. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  287. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  288. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  289. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  290. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  291. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  292. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  293. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  294. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  295. [    10.871] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  296. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  297. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  298. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  299. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  300. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  301. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  302. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  303. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  304. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  305. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  306. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  307. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  308. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  309. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  310. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  311. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  312. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  313. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  314. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  315. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  316. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  317. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  318. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  319. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  320. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  321. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  322. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  323. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  324. [    10.872] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  325. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  326. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  327. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  328. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  329. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  330. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  331. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  332. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  333. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  334. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  335. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  336. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  337. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  338. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  339. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  340. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  341. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  342. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  343. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  344. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  345. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  346. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  347. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  348. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  349. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  350. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  351. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  352. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  353. [    10.873] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  354. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  355. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  356. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  357. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  358. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  359. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  360. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  361. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  362. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  363. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  364. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  365. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  366. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  367. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  368. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  369. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  370. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  371. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  372. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  373. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  374. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  375. [    10.874] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
  376. [    10.874] (==) FBDEV(0): DPMS enabled
  377. [    10.875] (==) RandR enabled
  378. [    10.895] (II) SELinux: Disabled on system
  379. [    10.897] (II) AIGLX: Screen 0 is not DRI2 capable
  380. [    10.898] (EE) AIGLX: reverting to software rendering
  381. [    10.899] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
  382. [    10.899] (EE) GLX: could not load software renderer
  383. [    10.899] (II) GLX: no usable GL providers found for screen 0
  384. [    10.979] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
  385. [    10.994] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/platform/display-subsystem/drm/card0
  386. [    10.994] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
  387. [    10.996] (II) config/udev: Adding input device   Mini Keyboard (/dev/input/event2)
  388. [    10.996] (**)   Mini Keyboard: Applying InputClass "evdev keyboard catchall"
  389. [    10.996] (II) LoadModule: "evdev"
  390. [    10.997] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
  391. [    11.015] (II) Module evdev: vendor="X.Org Foundation"
  392. [    11.016]         compiled for 1.15.1, module version = 2.9.1
  393. [    11.016]         Module class: X.Org XInput Driver
  394. [    11.016]         ABI class: X.Org XInput driver, version 20.0
  395. [    11.016] (II) Using input driver 'evdev' for '  Mini Keyboard'
  396. [    11.016] (**)   Mini Keyboard: always reports core events
  397. [    11.016] (**) evdev:   Mini Keyboard: Device: "/dev/input/event2"
  398. [    11.016] (--) evdev:   Mini Keyboard: Vendor 0x1997 Product 0x2433
  399. [    11.016] (--) evdev:   Mini Keyboard: Found keys
  400. [    11.016] (II) evdev:   Mini Keyboard: Configuring as keyboard
  401. [    11.016] (**) evdev:   Mini Keyboard: YAxisMapping: buttons 4 and 5
  402. [    11.016] (**) evdev:   Mini Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
  403. [    11.016] (**) Option "config_info" "udev:/sys/devices/platform/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1997:2433.0001/input/input2/event2"
  404. [    11.017] (II) XINPUT: Adding extended input device "  Mini Keyboard" (type: KEYBOARD, id 6)
  405. [    11.017] (**) Option "xkb_rules" "evdev"
  406. [    11.017] (**) Option "xkb_model" "pc105"
  407. [    11.017] (**) Option "xkb_layout" "us"
  408. [    11.024] (II) config/udev: Adding input device   Mini Keyboard (/dev/input/event3)
  409. [    11.024] (**)   Mini Keyboard: Applying InputClass "evdev pointer catchall"
  410. [    11.024] (**)   Mini Keyboard: Applying InputClass "evdev keyboard catchall"
  411. [    11.024] (II) Using input driver 'evdev' for '  Mini Keyboard'
  412. [    11.024] (**)   Mini Keyboard: always reports core events
  413. [    11.024] (**) evdev:   Mini Keyboard: Device: "/dev/input/event3"
  414. [    11.025] (--) evdev:   Mini Keyboard: Vendor 0x1997 Product 0x2433
  415. [    11.025] (--) evdev:   Mini Keyboard: Found 9 mouse buttons
  416. [    11.025] (--) evdev:   Mini Keyboard: Found scroll wheel(s)
  417. [    11.025] (--) evdev:   Mini Keyboard: Found relative axes
  418. [    11.025] (--) evdev:   Mini Keyboard: Found x and y relative axes
  419. [    11.025] (--) evdev:   Mini Keyboard: Found absolute axes
  420. [    11.025] (II) evdev:   Mini Keyboard: Forcing absolute x/y axes to exist.
  421. [    11.025] (--) evdev:   Mini Keyboard: Found keys
  422. [    11.025] (II) evdev:   Mini Keyboard: Configuring as mouse
  423. [    11.025] (II) evdev:   Mini Keyboard: Configuring as keyboard
  424. [    11.025] (II) evdev:   Mini Keyboard: Adding scrollwheel support
  425. [    11.025] (**) evdev:   Mini Keyboard: YAxisMapping: buttons 4 and 5
  426. [    11.025] (**) evdev:   Mini Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
  427. [    11.025] (**) Option "config_info" "udev:/sys/devices/platform/ff540000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:1997:2433.0002/input/input3/event3"
  428. [    11.025] (II) XINPUT: Adding extended input device "  Mini Keyboard" (type: KEYBOARD, id 7)
  429. [    11.025] (**) Option "xkb_rules" "evdev"
  430. [    11.025] (**) Option "xkb_model" "pc105"
  431. [    11.025] (**) Option "xkb_layout" "us"
  432. [    11.026] (II) evdev:   Mini Keyboard: initialized for relative axes.
  433. [    11.026] (WW) evdev:   Mini Keyboard: ignoring absolute axes.
  434. [    11.026] (**)   Mini Keyboard: (accel) keeping acceleration scheme 1
  435. [    11.027] (**)   Mini Keyboard: (accel) acceleration profile 0
  436. [    11.027] (**)   Mini Keyboard: (accel) acceleration factor: 2.000
  437. [    11.027] (**)   Mini Keyboard: (accel) acceleration threshold: 4
  438. [    11.030] (II) config/udev: Adding input device   Mini Keyboard (/dev/input/mouse1)
  439. [    11.031] (II) No input driver specified, ignoring this device.
  440. [    11.031] (II) This device may have been added with another device file.
  441. [    11.032] (II) config/udev: Adding input device gpio-keys (/dev/input/event4)
  442. [    11.032] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
  443. [    11.032] (II) Using input driver 'evdev' for 'gpio-keys'
  444. [    11.032] (**) gpio-keys: always reports core events
  445. [    11.032] (**) evdev: gpio-keys: Device: "/dev/input/event4"
  446. [    11.032] (--) evdev: gpio-keys: Vendor 0x1 Product 0x1
  447. [    11.032] (--) evdev: gpio-keys: Found keys
  448. [    11.032] (II) evdev: gpio-keys: Configuring as keyboard
  449. [    11.032] (**) evdev: gpio-keys: YAxisMapping: buttons 4 and 5
  450. [    11.032] (**) evdev: gpio-keys: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
  451. [    11.032] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input4/event4"
  452. [    11.032] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 8)
  453. [    11.032] (**) Option "xkb_rules" "evdev"
  454. [    11.032] (**) Option "xkb_model" "pc105"
  455. [    11.033] (**) Option "xkb_layout" "us"
  456. [    11.037] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event0)
  457. [    11.038] (**) gpio_ir_recv: Applying InputClass "evdev keyboard catchall"
  458. [    11.038] (II) Using input driver 'evdev' for 'gpio_ir_recv'
  459. [    11.038] (**) gpio_ir_recv: always reports core events
  460. [    11.038] (**) evdev: gpio_ir_recv: Device: "/dev/input/event0"
  461. [    11.038] (--) evdev: gpio_ir_recv: Vendor 0x1 Product 0x1
  462. [    11.038] (--) evdev: gpio_ir_recv: Found keys
  463. [    11.038] (II) evdev: gpio_ir_recv: Configuring as keyboard
  464. [    11.038] (**) evdev: gpio_ir_recv: YAxisMapping: buttons 4 and 5
  465. [    11.038] (**) evdev: gpio_ir_recv: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
  466. [    11.038] (**) Option "config_info" "udev:/sys/devices/platform/ir-receiver/rc/rc0/input0/event0"
  467. [    11.038] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 9)
  468. [    11.038] (**) Option "xkb_rules" "evdev"
  469. [    11.038] (**) Option "xkb_model" "pc105"
  470. [    11.038] (**) Option "xkb_layout" "us"
  471. [    11.040] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (gpio-rc-recv) (/dev/input/event1)
  472. [    11.041] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev pointer catchall"
  473. [    11.042] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): Applying InputClass "evdev keyboard catchall"
  474. [    11.042] (II) Using input driver 'evdev' for 'MCE IR Keyboard/Mouse (gpio-rc-recv)'
  475. [    11.042] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): always reports core events
  476. [    11.042] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Device: "/dev/input/event1"
  477. [    11.042] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Vendor 0 Product 0
  478. [    11.042] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found 3 mouse buttons
  479. [    11.042] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found relative axes
  480. [    11.042] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found x and y relative axes
  481. [    11.042] (--) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Found keys
  482. [    11.042] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as mouse
  483. [    11.042] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): Configuring as keyboard
  484. [    11.042] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): YAxisMapping: buttons 4 and 5
  485. [    11.042] (**) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
  486. [    11.042] (**) Option "config_info" "udev:/sys/devices/virtual/input/input1/event1"
  487. [    11.042] (II) XINPUT: Adding extended input device "MCE IR Keyboard/Mouse (gpio-rc-recv)" (type: KEYBOARD, id 10)
  488. [    11.042] (**) Option "xkb_rules" "evdev"
  489. [    11.042] (**) Option "xkb_model" "pc105"
  490. [    11.043] (**) Option "xkb_layout" "us"
  491. [    11.043] (II) evdev: MCE IR Keyboard/Mouse (gpio-rc-recv): initialized for relative axes.
  492. [    11.044] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) keeping acceleration scheme 1
  493. [    11.044] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration profile 0
  494. [    11.044] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration factor: 2.000
  495. [    11.044] (**) MCE IR Keyboard/Mouse (gpio-rc-recv): (accel) acceleration threshold: 4
  496. [    11.045] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (gpio-rc-recv) (/dev/input/mouse0)
  497. [    11.045] (II) No input driver specified, ignoring this device.
  498. [    11.045] (II) This device may have been added with another device file.
Copy the code
super moderator
Rank: 8Rank: 8
Posted at 9/24/2016 09:44:25        Only Author  13#
Hi
try this fireware : https://drive.google.com/open?id=0B7HO8lbGgAqAemxZUThVdWlqU2M
and post  the X11 & kernel log .
Posted at 9/25/2016 04:31:28        Only Author  14#
I have flashed the firmware you suggested.
Here is the Xorg log:
http://pastebin.com/UfdLeNcf
Here is kernel log (cant paste it into pastebin, as it is too big):
https://dl.dropboxusercontent.com/u/40102812/kern.log
In this firmware HDMI output could be set to correct resolution using xrandr. VGA was set to resolution 800x480 by default, so no need for me to change it. Dual display is not working. If you were using HDMI during boot up, you will have to reboot to be able to use VGA. Opposite is the same... if is using VGA during boot up, you would have to reboot if you plan to use HDMI at some point.
super moderator
Rank: 8Rank: 8
Posted at 9/26/2016 10:55:52        Only Author  15#
hi :
your HDMI monitor haven't support 800X480  . so  the dual display can't work.
the two monitor must have  the same resolution
已有 1评分Money +5 Contribution +5 Pack up reason
Alexander + 5 + 5
View all ratings
Posted at 9/27/2016 04:36:40        Only Author  16#
It is same monitor, It has a module with several inputs, including HDMI and VGA. Also, when I connect it via VGA i can see boot messages, but when it is connected via HDMI, screen remains black until desktop is showing up.
Well, at least I can set right values for each mode separately. Thats good. Thank you! Can you, please, explain me how why it was not working on previous firmwires? What exactly have you changed? Will this firmware work with older kernel (where WiFi is functional)?
super moderator
Rank: 8Rank: 8
Posted at 9/27/2016 10:11:25        Only Author  17#
Hi
we used the kernel 3.14 instead of 3.10.  because the front one use the DRM display driver.
and then update the ubuntu to 16.04 .
if you want change the kernel , pls get this one :
https://github.com/T-Firefly/firefly-3.14-kernel/commits/master
the wifi problem has been solved.
Posted at 9/27/2016 15:50:55        Only Author  18#
Thank you very much! If that are the only changes, I will try to play around the kernel to fix the rest problems.
Posted at 1/10/2026 11:34:23        Only Author  19#
This article is impressive beyond words, thank you for sharing it. Free access to the Test 350-801 assessment questions now. Wishing you all the best of luck!
Posted at 1/18/2026 05:21:52        Only Author  20#
It was an article full of wisdom and insights. The New practice questions ISO-IEC-27001-Lead-Implementer ppt exam is coming up soon – hope I pass with ease!
Return to List
123
