New Topic
Windows 10 and Fireduino
42
Posted at 2/7/2017 18:38:33        Only Author  11#
How to update the firmware ? The manual says changed Blink - where can I get it ?
There is only a normal Blink , not changed find !
Posted at 2/7/2017 18:40:11        Only Author  12#
Posted at 5/12/2017 22:17:02        Only Author  13#
Hello everyone :-)
I have also a problem to install Fireduino on windows 10.
I'm using a MacbookPro 2015 15inch with bootcamp (Windows 10 Pro N)
1) When I connect the Fireduino (it goes on since I can see the little blu and green blinks)
But I'm not able to see it on the device manager.
Like there : http://wiki.t-firefly.com/index. ... driver_installation
There is no Other devices / Unknown device
Even with the driver signature enforcement trick, I can't see the Fireduino.
Maybe I missed soemthing, or maybe there is a way to install the driver manually by putting the files at the right place ?
2) Also on the Arduino IDE link on this link : http://wiki.t-firefly.com/index.php/Fireduino/Install_IDE/en
I don't see any "Additional Boards Managers URLs...
Thanks for your attention.
cheers.
Posted at 6/9/2017 00:30:10        Only Author  14#
Don't get the "Fireduino USB to serial port device driver installation" step.
I can just see my device as Rocksub.
I forgot to write about the last post, but I got it to work yeah :-)
Still have the last step "Fireduino USB to serial port device driver installation" that doesn't install but the fireduino seems to work anyways.
It was really idiot, I just don't really understood what was the step 1. and 2.
So basically... Don't forget to do that :
1. Press the UPGRADE key and hold.
2. Short press the RESET button,the PC finds unknown equipment
The UPGRADE bottom is next to the card reader and the RESET button next to the AC input.
Of course don't forget to enable test mode via the windows command prompt by typing "bcdedit /set testsigning on".
Restart, and you should see on your desktop a little white text on the corner down right
"Test Mode
Windows 10 Pro N
Build ......"
And then follow the steps of the link :http://wiki.t-firefly.com/index.php/Fireduino/Install_Driver/en#Development_board_driver_installation...
For the "Fireduino USB to serial port device driver installation" if you have a solution tell me :-)
Regards
satolas
Posted at 1/19/2026 14:12:33        Only Author  15#
What an enlightening and motivating read, thank you for sharing! Boost your IT abilities with free Free AP-226 updates. Wishing you the best of luck!
Posted at 2/1/2026 02:55:57        Only Author  16#
Your article was truly insightful, I’m sincerely thankful. Best of luck to everyone taking the exam! Free H19-338-ENU valid exam cram materials materials are here!
Posted at 3/7/2026 21:57:33        Only Author  17#
I’m grateful for your article, it truly stood out to me. Free Valid test cram Advanced-Administrator sheet file exam papers are shared! Best wishes for your exams!
Return to List
12
