Technical briefing for Firefly-RK3288: Updates firmware and codes (15/07/2016)
385
super moderator
Rank: 8Rank: 8
Posted at 7/18/2016 10:16:05      View:8036 | Replies:6        Print      Only Author   [Copy Link] 1#
Android5.1 update:
1.update loader version 2.30.10
2.update camerahal driver
3.fix pcba test some issue
4.add dual screen patch and multiwindow patch
5.fix some application feature
6.update media play library
7.system optimization and stability
Ubuntu update:
1.support nfs
2.add kernel headers
3.open uart1 and uart3
Please refer to  the Download Android SDK on wiki, and upgrade to the latest tag: Firefly-RK3288-Reload_Android5.1_201603151017
You can download the latest firmware from the following links:
   Android Firmware from google drive
   Ubuntu Firmware from google drive
   DualBoot(Android&Ubuntu) Firmware from google drive
Posted at 8/16/2016 22:09:21        Only Author  2#
Hi Wico,
Downloaded images from https://drive.google.com/drive/f ... gAqAeXlaa29rRF82dzA and used upgrade_tool to flash the this image.
Flashed successfully
$ upgrade_tool uf Firefly-RK3288_DualBoot_201607151016.img
Loading firmware...
Support Type:RK32        FW Ver:5.0.00        FW Time:2016-07-15 10:16:28
Loader ver:2.30        Loader Time:2016-07-15 09:57:34
Upgrade firmware ok.
But board does not boot.
U-Boot 2014.10-RK3288-10 (Jul 15 2016 - 09:57:27)
CPU: rk3288
cpu version = 0
CPU's clock information:
    arm pll = 600000000HZ
    periph pll = 300000000HZ
    ddr pll = 200000000HZ
    codec pll = 594000000HZ
Board:  Rockchip platform Board
DRAM:  Found dram banks: 1
Adding bank:0000000000000000(0000000080000000)
128 MiB
G
rebooted it couple of times and still board stuck at uboot.
Any idea what could be the issue?
Thanks
Posted at 8/16/2016 22:59:30        Only Author  3#
Tried on other hardware and it worked. Meaning I could flash Image from https://drive.google.com/drive/f ... gAqAeXlaa29rRF82dzA and board boots to android without any issue.
But I could not halt booting at uboot prompt. Looks like uboot delay is made 0.
Can this delay be increased ?
Does the bootloader with this image support fastboot ?
I can flash standard android Image?
could you also provide me refer to uboot code? do we have rk3288 support in mainline uboot?
Thanks,
Posted at 11/8/2016 05:52:57        Only Author  4#
We don't have any possibility to use fireasy apk anymore on android 5.1?? Somebody knows any possibility to use this app?
Cheers
super moderator
Rank: 8Rank: 8
Posted at 11/11/2016 09:52:47        Only Author  5#
It can be run on android5.1 .
Did you have any problem?
Posted at 11/26/2016 21:42:54        Only Author  6#
I tested two versions of fireasy apk v1.0 and v1.1
in this version 5.1:
Rk3288_box_userdebug5.1.1 LMY49F ENG guanzl.20160912.143552 test-keys
You have tested in this version?
I love fireasy so can confirm if this version have it working?
super moderator
Rank: 8Rank: 8
Posted at 11/28/2016 14:47:34        Only Author  7#
Yes, the firmware   you mentioned can run  fireasy apk rightly.
