Posted at 10/17/2016 23:07:32
Hi all,
I am working on getting rk3288 reload board running with kernel 4.4 (rockchip repository). Everything is going well but I have a problem with USB:
[ 3.431863] usb 1-1.3.2: Product: USB Optical Mouse
[ 3.436737] usb 1-1.3.2: Manufacturer: Logitech
[ 3.443943] input: Logitech USB Optical Mouse as
/devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:046D:C077.0001/input/input0
[ 3.457352] hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID
v1.11 Mouse [Logitech USB Optical Mouse] on
usb-ff540000.usb-1.3.2/input0
[ 4.588211] usb usb1-port1: disabled by hub (EMI?), re-enabling...
[ 4.595848] usb 1-1: USB disconnect, device number 2
[ 4.602261] usb 1-1.3: USB disconnect, device number 3
[ 4.608815] usb 1-1.3.1: USB disconnect, device number 4
[ 4.615884] usb 1-1.3.2: USB disconnect, device number 5
[ 6.058190] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 7.318273] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 8.568319] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 9.828165] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 9.835164] usb usb1-port1: unable to enumerate USB device
Does anyone know how to solve this problem? I am just attaching a powered hub and a mouse, if I attach the mouse directly to one of the usb ports on the reload board it's the same result, and if I try another mouse it's also the same.
Thanks
Bert
