New Topic
Ubuntu for Firefly Updating
1821
super moderator
Rank: 8Rank: 8
Posted at 10/18/2016 16:20:12      View:13501 | Replies:12        Print      Only Author   [Copy Link] 1#
New firmware for firefly ubuntu has coming.
1: the kernel update to 4.4
   our github: https://github.com/T-Firefly/kernel_4.4
2 : VAAPI support
Download:
baidupan :http://pan.baidu.com/s/1gfsi9FH
google driver : https://drive.google.com/open?id=0B7HO8lbGgAqAR0dneVh0cXEtcDQ
Posted at 10/19/2016 13:16:15        Only Author  2#
will this be uploaded to google drive?
what version of mali and display drivers are used?
glmark2 scores?
super moderator
Rank: 8Rank: 8
Posted at 10/19/2016 15:25:10        Only Author  3#
the version of mali driver is r9p0 .
the score of glmark2-es2 is lower the before ,because use a new display driver.
Posted at 10/21/2016 02:08:52        Only Author  4#
isle Posted at 10/19/2016 15:25
the score of glmark2-es2 is lower the before ,because use a ne ...
Actually i am new to this linux development...
i have build Android and flash the image in RK3288 board but now i want to run ubuntu in rk3288 board....
How can i get the source for ubuntu, build it and flash it....
Thank you in advance...
super moderator
Rank: 8Rank: 8
Posted at 10/21/2016 09:28:06        Only Author  5#
Posted at 10/25/2016 05:16:34        Only Author  6#
Thanks,  Isle,
I could u-boot, kernel compile(4.4), make root file system.
Would you also upload two files to github for "firefly-reload" user?
1) rk3288-firefly_reload_linux_defconfig    for reload
2) rk3288-filrefly_reload.dtsi   for reload
I hope to see CAMERA(MIPI or DVP) driver and HDMI-IN(TC358743) driver as well.
Thanks.
super moderator
Rank: 8Rank: 8
Posted at 10/25/2016 11:14:32        Only Author  7#
Hi
1   we haven't support reload board yet,
2   we are working on the camera support.
Posted at 12/2/2016 18:39:49        Only Author  8#
Is there any way to get the VAAPI support working with Chromium? Also, why is there a reference to a server on your local network in /etc/apt/apt.conf so apt doesn't work?
super moderator
Rank: 8Rank: 8
Posted at 12/5/2016 09:44:42        Only Author  9#
Hi wouter
   1  I don't know  whether the VAAPI can use be uesd in  chromuim or not  . but I will have a try later.
    2  Yes ,please remove /etc/apt/apt.conf,that is my fault . I should delete it when the firmware was  build .
     we  build a proxy server to accelerate the speed when we use the "apt" command.
Posted at 1/1/2017 02:26:53        Only Author  10#
Hi,
I flashed this image, and the OpenGL works, but I can't get Wifi working - is there any image that has working wifi and OpenGL? I can't seem to find any.
Return to List
12
