power monitoring on Firefly-RK3288 Reload
17
Posted at 2/6/2017 23:19:17      View:6679 | Replies:4        Print      Only Author   [Copy Link] 1#
Hello,
I would like to purchase Firefly-RK3288 Reload so that I can monitor individual power rails (CPU, GPU and if possible RAM) and check the power consumption of my algorithm using external measuring equipment.
Is it easy to monitor power with external power measuring equipment? I need easy access to power rails. I have some soldering knowledge and know people who can mod the system if required. Please let me know.
Thank you for your time.
super moderator
Rank: 8Rank: 8
Posted at 2/7/2017 10:00:57        Only Author  2#
Hi
yes ,you can monitor these individual power rails.
the CPU and GPU power supply separately.
for instance, monitor the CPU power ,connect your equipment to L26 (the inductor in the following picture).
and the  GPU power is similar.
Posted at 2/7/2017 18:03:45        Only Author  3#
Thank you very much for the reply isle. How about monitoring the power rail for DDR3 memory (RAM)? Will that be possible too?
super moderator
Rank: 8Rank: 8
Posted at 2/8/2017 09:30:42        Only Author  4#
yes ,It is similar too,(L6 in the following picture )
Posted at 2/9/2017 17:45:22        Only Author  5#
Thank you very much for your reply. I will go ahead with buying it.
