New Topic
Question about I2S audio output
107
Posted at 12/8/2014 14:33:02      View:15687 | Replies:9        Print      Only Author   [Copy Link] 1#
The Firefly RK3288's PCM mode works well, but I want to use I2S audio output with ALSA. I don't know how to configure ES8323 I2S output mode. Please let me know the configuration for the I2S audio output.
Thanks.
Posted at 12/9/2014 09:28:56        Only Author  2#
en,,,I am also not goot at this.
You can try to view RKDocs,Good luck!
super moderator
Rank: 8Rank: 8
Posted at 12/9/2014 11:08:00        Only Author  3#
│ Symbol: SND_RK_SOC_ES8323 [=y]        │
  │ Type  : tristate        │
  │ Prompt: SoC I2S Audio support for rockchip - ES8323        │
  │   Location:        │
  │     -> Device Drivers        │
  │       -> Sound card support (SOUND [=y])        │
  │         -> Advanced Linux Sound Architecture (SND [=y])        │
  │ (1)       -> ALSA for SoC audio support (SND_SOC [=y])        │
  │   Defined at sound/soc/rockchip/Kconfig:54        │
  │   Depends on: SOUND [=y] && !M68K && !UML && SND [=y] && SND_SOC [=y] && SND_RK_SOC [=y]                                               │
  │   Selects: SND_RK_SOC_I2S [=y] && SND_SOC_ES8323 [=y]
Posted at 12/9/2014 12:20:38        Only Author  4#
As you know default kernel image that Firefly provides is ES8323 PCM output. In the kernel compile configuration, there are two options "SoC I2S Audio support for rockchip -ES8323" and "Soc I2S Audio Support for rockchip - ES8323 for PCM modem". So you suggest that I should compile "SoC I2S Audio support for rockchip - ES8323" option. Is it right? Default kernel device driver in ALSA always provide PCM output and that's why I was wondering about using I2S mode.
super moderator
Rank: 8Rank: 8
Posted at 12/9/2014 17:55:49        Only Author  5#
Yes!
i use the i2s mode and it works well 。
Posted at 12/12/2014 23:49:50        Only Author  6#
I compiled kernel with "SoC I2S Audio support for rockchip -ES8323" option. But I can't see the I2S driver in Unbuntu. When I list with "aplay -l" command, I see the following devices. There is no I2S driver for ES8323.  Could you help me how to setup I2S?
**** List of PLAYBACK Hardware Devices ****
card 0: RKES8323 [RK_ES8323], device 0: ES8323 PCM ES8323 HiFi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: RKHDMISPDIF [RK-HDMI-SPDIF], device 0: SPDIF PCM Playback rk-hdmi-spdif-hifi-0 []
  Subdevices: 1/1
super moderator
Rank: 8Rank: 8
Posted at 12/13/2014 10:29:23        Only Author  7#
As I know , the ES8323 PCM mode & I2S mode are the different serial audio data interface.
it is just a  transport type between MCU and Audio codec .
you can check  it on the document of  ES8323_DS.pdf which can be downloaded on our website.
and here :
"The device provides four formats of serial audio data interface to the input of the DAC or output from the ADC through LRCK, SCLK and SDIN/SDOUT pins. The four formats are I2S, left justified, right justified and DSP/PCM mode."
here is the figure of the I2S mode format:
and the pcm mode :
and both of them are delivered  the PCM DATA .
So ,I guees  the “PCM”  from the "aplay -l" command  means the “PCM DATA”, not the  interface。
however, I'm not very sure about it .please tell me if I was wrong.
Posted at 12/17/2014 10:11:04        Only Author  8#
I try to connect my PCM5102 DAC through I2S into Firefly Rk3288's GPIO6 I2S pin. But I still can't connect I2S device from GPIO6 I2S at Firefly. Stereo output at Firefly is working but I want a i2s output from Firefly. When I see "/proc/i2s_reg", there is no register values, so I think i2s device driver is not loaded. I2S device driver file which is "kernel/sound/soc/rockchip/rk30_i2s.c" is compiled, but I think it is not loaded. How can I output i2s signal from GPIO6 at Firefly to my PCM5102 I2S device?
super moderator
Rank: 8Rank: 8
Posted at 12/18/2014 15:20:43        Only Author  9#
hi , the firefly board use the es8323 as  default Aduio DAC , it's also connect to the I2S0(GPIO6). so.you would do nothing to get I2S out from I2S0(GPIO6).
Posted at 3/12/2015 20:51:00        Only Author  10#
Hi,
In the datasheet of RK3288 it says that PCM and I2S cannot be used together. I think somehow you should disable the built in from the kernel and run through I2S. As far as I see it is 8ch I2S with outs and ins.
Well can you check lsmod?
Regards.
Return to List
12
