New Topic
Inform: Insert an SD .. when open camera
93
Posted at 3/29/2017 18:54:32      View:4642 | Replies:12        Print      Only Author   [Copy Link] 1#
Hi everyone,
I just build Lollipop with date: 2017-02-22, when i open camera, it show "Insert an SD card ..."then i can't change parameters or camera/video mode.
Can you give me how to fix it?
Thanks
super moderator
Rank: 8Rank: 8
Posted at 4/6/2017 10:30:08        Only Author  2#
Hi ,does the latest official firmware have the same issue?
Posted at 4/8/2017 16:04:04        Only Author  3#
Hi isle, that's exactly lastest firmware.
super moderator
Rank: 8Rank: 8
Posted at 4/10/2017 09:44:32        Only Author  4#
No , I mean  the firmware you download from the baidupan or google driver.
not the firmware you made by yourself.
Posted at 5/6/2017 09:52:31        Only Author  5#
Hi isle,
Source is firefly-rk3288_android5.1_git_20170224.tar.gz then i builded by myseft.
Posted at 5/6/2017 10:02:02        Only Author  6#
Hi all,
I found that it's not camera problem. There are error in Lollipop system: it can not access any kind memory.
Who can show me fix it?
Thanks
super moderator
Rank: 8Rank: 8
Posted at 5/11/2017 09:27:50        Only Author  7#
Hi ,
so ,you mean ,when use the official firmware ,there is no such issue.
But when you build a firmware by the source code, It has.
have you add something in your source code?
Posted at 5/11/2017 14:14:03        Only Author  8#
Hi, isle
No, i build source code without any modification.I chose kernel for normal or Reload also have same storage issue.
super moderator
Rank: 8Rank: 8
Posted at 5/12/2017 10:46:31        Only Author  9#
Hi
   my colleague has just  checked . build the source code with no modification  have no such issue.
    Could you please show us your kernel log?
Posted at 5/12/2017 18:14:27        Only Author  10#
Hi isle,
How to get kernal log?
Thanks.
Return to List
12
