New Topic
firefly rk 3399 .Boot Mode of MaskRom mode
84
Posted at 4/6/2017 20:03:20      View:10871 | Replies:18        Print      Only Author   [Copy Link] 1#
I updated image in mini box but it deleted by mistake . When i installed again .It does not work .Can you help me in this matter . It looks only blank screen .Kindly reply me.i will wait
super moderator
Rank: 8Rank: 8
Posted at 4/7/2017 09:20:53        Only Author  2#
not quiet sure about your problem ? Could you please give more information?
what "mini box" is ?
Posted at 4/9/2017 05:03:23        Only Author  3#
hi sir,i mean to say.i updated image in my mini box .when it switch on tv screen .it looks like this picture.i think there is no driver active in mini box.that is my first experience to  use it.kindly help me in this matter.if you have any doubt about problem .i will clarify
rk3399
rk3399
Posted at 4/9/2017 05:16:04        Only Author  4#
Posted at 4/9/2017 06:35:40        Only Author  5#
Which image did u flash to the board? Can you give filename?
Posted at 4/9/2017 09:03:19        Only Author  6#
What image did you flash? can I get the filename?
Posted at 4/9/2017 16:43:34        Only Author  7#
andriod .6.  first i downdload image from firefly then i use andriod tool window and flash .
Posted at 4/9/2017 18:06:25        Only Author  8#
LOG FIL
10:00:10 038        Layer<1-1-3-5>:Test Device Start
10:00:10 038        Layer<1-1-3-5>:Test Device Success
10:00:10 038        Layer<1-1-3-5>:Check Chip Start
10:00:10 054        Layer<1-1-3-5>: Check Chip Success
10:00:10 054        Layer<1-1-3-5>:Get FlashInfo Start
10:00:10 054        <LAYER 1-1-3-5> INFO:FlashInfo: 00 F0 D1 01 00 04 04 00 28 00 01
10:00:10 054        <LAYER 1-1-3-5> INFO:GetFlashInfo-->Emmc storage.
10:00:10 069        Layer<1-1-3-5>:Get FlashInfo Success
10:00:10 085        Layer<1-1-3-5>repare IDB Start
10:00:10 085        <LAYER 1-1-3-5> INFO:CS(1)                (14910MB)                (SAMSUNG)
10:00:10 101        Layer<1-1-3-5>repare IDB Success
10:00:10 101        Layer<1-1-3-5>ownload IDB Start
10:00:11 351        Layer<1-1-3-5>ownload IDB Success
10:00:11 366        Layer<1-1-3-5>:Reset Device Start
10:00:12 379        Layer<1-1-3-5>:Reset Device Success
10:00:12 379        Layer<1-1-3-5>:Wait For Loader Start
10:00:12 942        Layer<1-1-3-5>:Wait For Loader Success
10:00:12 957        Layer<1-1-3-5>:Test Device Start
10:00:12 957        Layer<1-1-3-5>:Test Device Success
10:00:12 957        Layer<1-1-3-5>ownload Firmware Start
10:00:12 973        <LAYER 1-1-3-5> INFO:Start download image,total=701358048
10:00:13 020        <LAYER 1-1-3-5> INFO:Start to download trust,offset=0x4000,size=4194304
10:00:13 207        <LAYER 1-1-3-5> INFO:Start to download uboot,offset=0x2000,size=4194304
10:00:13 395        <LAYER 1-1-3-5> INFO:Start to download misc,offset=0x6000,size=49152
10:00:13 426        <LAYER 1-1-3-5> INFO:Start to download resource,offset=0x8000,size=201216
10:00:13 442        <LAYER 1-1-3-5> INFO:Start to download kernel,offset=0x10000,size=17123180
10:00:14 317        <LAYER 1-1-3-5> INFO:Start to download boot,offset=0x1a000,size=1354740
10:00:14 395        <LAYER 1-1-3-5> INFO:Start to download recovery,offset=0x2a000,size=21725184
10:00:15 442        <LAYER 1-1-3-5> INFO:Start to download system,offset=0xb2000,size=652509184
10:01:10 684        Layer<1-1-3-5>ownload Firmware Success
10:01:10 684        Layer<1-1-3-5>:Reset Device Start
10:01:11 713        Layer<1-1-3-5>:Reset Device Success
Posted at 4/10/2017 04:54:45        Only Author  9#
Use this one, compiled last night.
http://InfinityCommunicationsGat ... ndroid6.0_170409.7z (Personal Server, Slow Download)
https://drive.google.com/drive/f ... UWpUa1U?usp=sharing (Google Drive, Fast)
https://mega.nz/#F!RdZ0gQIT!aG1anG13CWlxOb5Gont8pQ (MEGA, Fast)
Posted at 4/11/2017 01:37:38        Only Author  10#
hi my friends ,my mini pc not work .all detail about this is written below .plz
DDR Version 1.07 20161103
In
Channel 0: DDR3, 666MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: DDR3, 666MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x32817281, stride = 0x9
OUT
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1847
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 62373
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 77478
LoaderFlag2: 0x0
NOTICE:  BL31: v1.2(debug):e1a1ee4
NOTICE:  BL31: Built : 14:38:26, Sep 29 2016
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    plat_rockchip_pmu_init(1202): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
<hit enter to activate fiq debugger>
[    0.167792] console [ttyFIQ0] enabled
[[    0.167792] console [ttyFIQ0] enabled
[    0.168368] bootconsole [uart0] disabled
[    0.169584] Registered fiq debugger ttyFIQ0
[    0.205682] Rockchip hdmi driver version 2.0
[    0.205748] ACPI: Interpreter disabled.
[    0.208437] vgaarb: loaded
[    0.208727] SCSI subsystem initialized
[    0.209247] usbcore: registered new interface driver usbfs
[    0.209318] usbcore: registered new interface driver hub
[    0.209421] usbcore: registered new device driver usb
[    0.210093] media: Linux media interface: v0.10
[    0.210145] Linux video capture interface: v2.00
[    0.210320] pps_core: LinuxPPS API ver. 1 registered
[    0.210331] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.210360] PTP clock support registered
[    0.210813] rockchip ion: success to create - cma-heap
[    0.210839] rockchip ion: success to create - system-heap
[    0.211365] Advanced Linux Sound Architecture Driver Initialized.
[    0.211994] Bluetooth: Core ver 2.21
[    0.212032] NET: Registered protocol family 31
[    0.212043] Bluetooth: HCI device and connection manager initialized
[    0.212060] Bluetooth: HCI socket layer initialized
[    0.212075] Bluetooth: L2CAP socket layer initialized
[    0.212109] Bluetooth: SCO socket layer initialized
[    0.214085] clocksource: Switched to clocksource arch_sys_counter
[    0.270369] fb disp policy is box
[    0.270405] uboot-logo-on:1
[    0.270449] rk-fb rockchip-fb: rk fb ion client create success!
[    0.270665] logo: base=0x7dc00000, size=0x1000000, offset=0x0
[    0.270679] rk-fb rockchip-fb: rockchip framebuffer driver probe
[    0.271208] rk-screen screen: rockchip screen probe success
[    0.272855] rk322x-lcdc ff900000.vop-rk-fb: vop_dev->regs=0xffffff8009308000
[    0.273015] rk322x-lcdc vop0: can't find power_ctr node for lcdc0
[    0.273300] graphics fb0: rockchip framebuffer registerd:fb0
[    0.273716] graphics fb1: rockchip framebuffer registerd:fb1
[    0.273915] graphics fb2: rockchip framebuffer registerd:fb2
[    0.274132] graphics fb3: rockchip framebuffer registerd:fb3
[    0.274328] graphics fb4: rockchip framebuffer registerd:fb4
[    0.274445] rk322x-lcdc vop0: failed to get clk source
[    0.274459] rk322x-lcdc vop0: failed to get clk source
[    0.276302] rk322x-lcdc vop0: lcdc0: dclk:148500000>>fps:60
[    0.276314] rk322x-lcdc vop0: dsp lut table is null
[    0.276324] rk322x-lcdc vop0: cabc lut table is null
[    0.298367] alloc_buffer:ion_phy_addr=0x10000000
[    0.303742] fb0:phy:10000000>>vir:ffffff8009481000>>len:0x1800000
[    0.307834] rk_iommu ff903f00.vopb-mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x73cbd000
[    0.307867] rk322x-lcdc vop0: lcdc0 probe ok, iommu enabled
[    0.308155] rk322x-lcdc ff8f0000.vop-rk-fb: vop_dev->regs=0xffffff8009338000
[    0.308239] rk322x-lcdc vop1: can't find power_ctr node for lcdc1
[    0.308251] rk_fb_trsm_ops_get: unsupported transmitter: 0!
[    0.308520] graphics fb5: rockchip framebuffer registerd:fb5
[    0.308859] graphics fb6: rockchip framebuffer registerd:fb6
[    0.309051] graphics fb7: rockchip framebuffer registerd:fb7
[    0.309239] graphics fb8: rockchip framebuffer registerd:fb8
[    0.309431] graphics fb9: rockchip framebuffer registerd:fb9
[    0.309443] rk322x-lcdc vop1: lcdc1 probe ok, iommu enabled
[    0.309760] pnp: PnP ACPI: disabled
[    0.311138] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.311355] NET: Registered protocol family 2
[    0.311787] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.311886] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.312009] TCP: Hash tables configured (established 16384 bind 16384)
[    0.312077] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.312105] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.312247] NET: Registered protocol family 1
[    0.312694] Trying to unpack rootfs image as initramfs...
[    0.516285] Freeing initrd memory: 4456K (ffffffc005bf0000 - ffffffc00604a000)
[    0.516803] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.516889] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.519241] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.519351] audit: initializing netlink subsys (disabled)
[    0.519409] audit: type=2000 audit(0.516:1): initialized
[    0.528660] VFS: Disk quotas dquot_6.6.0
[    0.528781] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.530196] fuse init (API version 7.23)
[    0.534439] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.534470] io scheduler noop registered
[    0.534639] io scheduler cfq registered (default)
[    0.539431] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.539458] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.539475] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.066086] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    1.066146] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    1.066806] rga2 ff680000.rga: rga ion client create success!
[    1.067324] rga: Driver loaded succesfully
[    1.068060] hdmi phy_table not exist
[    1.068510] reset hdmi
[    1.068649] rockchip-hdmiv2 ff940000.hdmi-rk-fb: rockchip hdmiv2 probe success.
[    1.069102] iep: failed to find iep power down clock source.
[    1.069390] IEP Power ON
[    1.069421] iep ion client create success!
[    1.069631] rk_iommu ff670800.iep-mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x73cb9000
[    1.069644] IEP Power OFF
[    1.069664] IEP Driver loaded succesfully
[    1.069741] Module initialized.
[    1.070085] vcodec_service: No core reset resource define
[    1.070149] vcodec ff650000.vpu_service: do not have pd_video
[    1.070171] vcodec_service: probe device ff650000.vpu_service
[    1.070186] vcodec_service: ff650000.vpu_service: power on
[    1.070209] vcodec_service: checking hw id 0
[    1.070796] vcodec_service: ff650000.vpu_service: power off...
[    1.070822] vcodec_service: done
[    1.070833] vcodec_service: init success
[    1.071062] vcodec_service: No core reset resource define
[    1.071182] vcodec ff660000.rkvdec: do not have pd_video
[    1.071202] vcodec_service: probe device ff660000.rkvdec
[    1.071216] vcodec_service: ff660000.rkvdec: power on
[    1.071241] vcodec_service: checking hw id 6876
[    1.071703] vcodec_service: ff660000.rkvdec: power off...
[    1.071727] vcodec_service: done
[    1.071738] vcodec_service: init success
[    1.077527] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.077547] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.078906] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.078923] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.079785] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    1.081247] console [ttyS0] disabled
[    1.081289] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[    1.081752] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[    1.082270] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.082613] [drm] Initialized drm 1.1.0 20060810
[    1.084708] mali ff9a0000.gpu: Failed to get regulator
[    1.084722] mali ff9a0000.gpu: Power control initialization failed
[    1.085015] Unable to detect cache hierarchy from DT for CPU 0
[    1.097359] brd: module loaded
[    1.101894] loop: module loaded
[    1.102423] zram: Added device: zram0
[    1.102863] SCSI Media Changer driver v0.25
[    1.103454] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[    1.103478] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[    1.103493] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx  on device rockchip-pinctrl
[    1.103509] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[    1.103650] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    1.103663] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    1.104543] tun: Universal TUN/TAP device driver, 1.6
[    1.104554] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.105489] rk_gmac-dwmac fe300000.eth: clock input or output? (input).
[    1.105506] rk_gmac-dwmac fe300000.eth: TX delay(0x28).
[    1.105518] rk_gmac-dwmac fe300000.eth: RX delay(0x11).
[    1.105703] rk_gmac-dwmac fe300000.eth: clock input from PHY
[    1.105714] rk_gmac-dwmac fe300000.eth: init for RGMII
[    1.110793] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.110803]  Ring mode enabled
[    1.110811]  DMA HW capability register supported
[    1.110819]  Normal descriptors
[    1.110829]  RX Checksum Offload Engine supported (type 2)
[    1.110837]  TX Checksum insertion supported
[    1.110845]  Wake-Up On Lan supported
[    1.110886]  Enable RX Mitigation via HW Watchdog Timer
[    1.183744] libphy: stmmac: probed
[    1.183763] eth0: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.183775] eth0: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.184357] PPP generic driver version 2.4.2
[    1.184510] PPP BSD Compression module registered
[    1.184525] PPP Deflate Compression module registered
[    1.184551] PPP MPPE Compression module registered
[    1.184568] NET: Registered protocol family 24
[    1.184609] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.184621] CSLIP: code copyright 1989 Regents of the University of California.
[    1.184642] Rockchip WiFi SYS interface (V1.00) ...
[    1.184720] usbcore: registered new interface driver catc
[    1.184763] usbcore: registered new interface driver kaweth
[    1.184778] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.184814] usbcore: registered new interface driver pegasus
[    1.184853] usbcore: registered new interface driver rtl8150
[    1.184892] usbcore: registered new interface driver r8152
[    1.184906] hso: drivers/net/usb/hso.c: Option Wireless
[    1.184959] usbcore: registered new interface driver hso
[    1.185008] usbcore: registered new interface driver asix
[    1.185047] usbcore: registered new interface driver ax88179_178a
[    1.185087] usbcore: registered new interface driver cdc_ether
[    1.185126] usbcore: registered new interface driver cdc_eem
[    1.185164] usbcore: registered new interface driver dm9601
[    1.185217] usbcore: registered new interface driver smsc75xx
[    1.185265] usbcore: registered new interface driver smsc95xx
[    1.185303] usbcore: registered new interface driver gl620a
[    1.185342] usbcore: registered new interface driver net1080
[    1.185381] usbcore: registered new interface driver plusb
[    1.185422] usbcore: registered new interface driver rndis_host
[    1.185462] usbcore: registered new interface driver cdc_subset
[    1.185501] usbcore: registered new interface driver zaurus
[    1.185544] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.185598] usbcore: registered new interface driver int51x1
[    1.185637] usbcore: registered new interface driver kalmia
[    1.185679] usbcore: registered new interface driver ipheth
[    1.185722] usbcore: registered new interface driver sierra_net
[    1.185762] usbcore: registered new interface driver cx82310_eth
[    1.185810] usbcore: registered new interface driver cdc_ncm
[    1.185851] usbcore: registered new interface driver qmi_wwan
[    1.185894] usbcore: registered new interface driver cdc_mbim
[    1.187039] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    1.190791] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.190810] ehci-pci: EHCI PCI platform driver
[    1.190868] ehci-platform: EHCI generic platform driver
[    1.191366] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.191394] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[    1.191541] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.202092] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.202216] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.202230] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.202243] usb usb1: Product: EHCI Host Controller
[    1.202255] usb usb1: Manufacturer: Linux 4.4.16 ehci_hcd
[    1.202266] usb usb1: SerialNumber: fe3c0000.usb
[    1.202726] hub 1-0:1.0: USB hub found
[    1.202757] hub 1-0:1.0: 1 port detected
[    1.203251] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.203277] ohci-pci: OHCI PCI platform driver
[    1.203332] ohci-platform: OHCI generic platform driver
[    1.203817] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.203843] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[    1.203968] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    1.262210] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.262230] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.262244] usb usb2: Product: Generic Platform OHCI controller
[    1.262256] usb usb2: Manufacturer: Linux 4.4.16 ohci_hcd
[    1.262267] usb usb2: SerialNumber: fe3e0000.usb
[    1.262680] hub 2-0:1.0: USB hub found
[    1.262712] hub 2-0:1.0: 1 port detected
[    1.263480] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.263503] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3
[    1.263722] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[    1.263768] xhci-hcd xhci-hcd.0.auto: irq 233, io mem 0xfe900000
[    1.263880] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.263894] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.263907] usb usb3: Product: xHCI Host Controller
[    1.263918] usb usb3: Manufacturer: Linux 4.4.16 xhci-hcd
[    1.263929] usb usb3: SerialNumber: xhci-hcd.0.auto
[    1.264346] hub 3-0:1.0: USB hub found
[    1.264377] hub 3-0:1.0: 1 port detected
[    1.264617] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.264635] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    1.264692] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.264776] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    1.264790] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.264802] usb usb4: Product: xHCI Host Controller
[    1.264812] usb usb4: Manufacturer: Linux 4.4.16 xhci-hcd
[    1.264823] usb usb4: SerialNumber: xhci-hcd.0.auto
[    1.265212] hub 4-0:1.0: USB hub found
[    1.265241] hub 4-0:1.0: 1 port detected
[    1.265577] usbcore: registered new interface driver cdc_acm
[    1.265588] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.265655] usbcore: registered new interface driver usblp
[    1.265704] usbcore: registered new interface driver cdc_wdm
[    1.265792] usbcore: registered new interface driver usb-storage
[    1.265838] usbcore: registered new interface driver ums-alauda
[    1.265881] usbcore: registered new interface driver ums-cypress
[    1.265924] usbcore: registered new interface driver ums-datafab
[    1.265967] usbcore: registered new interface driver ums_eneub6250
[    1.266010] usbcore: registered new interface driver ums-freecom
[    1.266054] usbcore: registered new interface driver ums-isd200
[    1.266128] usbcore: registered new interface driver ums-jumpshot
[    1.266172] usbcore: registered new interface driver ums-karma
[    1.266218] usbcore: registered new interface driver ums-onetouch
[    1.266262] usbcore: registered new interface driver ums-sddr09
[    1.266304] usbcore: registered new interface driver ums-sddr55
[    1.266347] usbcore: registered new interface driver ums-usbat
[    1.266434] usbcore: registered new interface driver usbserial
[    1.266473] usbcore: registered new interface driver usbserial_generic
[    1.266503] usbserial: USB Serial support registered for generic
[    1.266552] usbcore: registered new interface driver option
[    1.266582] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.266735] usbcore: registered new interface driver trancevibrator
[    1.266751] usb20_otg: version 3.10a 21-DEC-2012
[    1.266976] usb20_host: version 3.10a 21-DEC-2012
[    1.271387] usbcore: registered new interface driver xpad
[    1.271440] usbcore: registered new interface driver usb_acecad
[    1.271488] usbcore: registered new interface driver aiptek
[    1.271536] usbcore: registered new interface driver gtco
[    1.271582] usbcore: registered new interface driver hanwang
[    1.271632] usbcore: registered new interface driver kbtab
[    1.271646] ==gsl_ts_init==
[    1.271677] ret=0
[    1.278376] .. rk pwm remotectl v1.1 init
[    1.278604] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    1.278994] sensor_register_slave:mma8452,id=17
[    1.279010] sensor_register_slave:lis3dh,id=7
[    1.279024] sensor_register_slave:mma7660,id=18
[    1.279038] sensor_register_slave:lsm303d,id=22
[    1.279052] sensor_register_slave:mpu6880_acc,id=24
[    1.279066] sensor_register_slave:mpu6500_acc,id=25
[    1.279080] sensor_register_slave:lsm330_acc,id=26
[    1.279094] sensor_register_slave:akm8975,id=28
[    1.279108] sensor_register_slave:akm8963,id=29
[    1.279121] sensor_register_slave:l3g4200d,id=43
[    1.279135] sensor_register_slave:l3g20d,id=44
[    1.279148] sensor_register_slave:ewtsa,id=45
[    1.279162] sensor_register_slave:lsm330_gyro,id=48
[    1.279176] sensor_register_slave:cm3217,id=50
[    1.279190] sensor_register_slave:cm3218,id=51
[    1.279822] i2c /dev entries driver
[    1.280782] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.282051] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.286631] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.286682] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.297351] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    1.297849] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800ae26000
[    1.298397] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800ae28000
[    1.307303] fusb302 4-0022: port 0 probe success
[    1.307336] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800ae2a000
[    1.308155] IR NEC protocol handler initialized
[    1.308169] IR RC5(x/sz) protocol handler initialized
[    1.308181] IR RC6 protocol handler initialized
[    1.308193] IR JVC protocol handler initialized
[    1.308205] IR Sony protocol handler initialized
[    1.308217] IR SANYO protocol handler initialized
[    1.308228] IR Sharp protocol handler initialized
[    1.308240] IR MCE Keyboard/mouse protocol handler initialized
[    1.308252] IR XMP protocol handler initialized
[    1.308360] usbcore: registered new interface driver uvcvideo
[    1.308380] USB Video Class driver (1.1.1)
[    1.308397] CamSys driver version: v0.33.5, CamSys head file version: v0.13.0
[    1.309542] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[    1.309542]
[    1.309560] E:camsys_soc_init(51): camsys_soc_init exit!
[    1.309630] D1:camsys_mipiphy_probe_cb(205): ff910000.isp mipi phy0 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.309630]
[    1.309653] D1:camsys_mipiphy_probe_cb(205): ff910000.isp mipi phy1 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.309653]
[    1.309715] D1:camsys_mipiphy_probe_cb(274): rk_cru_base=0xffffff800ae2c000
[    1.309746] D1:camsys_mipiphy_probe_cb(278): rk_grf_base=0xffffff800b100000
[    1.310363] D1:camsys_platform_probe(1527): ff910000.isp memory:
[    1.310378] D1:camsys_platform_probe(1543):  Register memory (phy: 0xff910000 vir: 0xffffff800ae60000 size: 0x10000)
[    1.310393] D1:camsys_platform_probe(1535):  I2c memory (phy: 0x5d46000 vir: 0xffffffc005d46000 size: 0x1000)
[    1.310406] D1:camsys_init_ext_fsh_module(20): init external flash module
[    1.310416] D1:camsys_platform_probe(1557): Probe ff910000.isp device success
[    1.311613] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[    1.311613]
[    1.311630] E:camsys_soc_init(51): camsys_soc_init exit!
[    1.311679] D1:camsys_mipiphy_probe_cb(205): ff920000.isp mipi phy0 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.311679]
[    1.311703] D1:camsys_mipiphy_probe_cb(205): ff920000.isp mipi phy1 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.311703]
[    1.311749] D1:camsys_mipiphy_probe_cb(274): rk_cru_base=0xffffff800ae2e000
[    1.311777] D1:camsys_mipiphy_probe_cb(278): rk_grf_base=0xffffff800b140000
[    1.312335] D1:camsys_platform_probe(1527): ff920000.isp memory:
[    1.312348] D1:camsys_platform_probe(1543):  Register memory (phy: 0xff920000 vir: 0xffffff800b120000 size: 0x10000)
[    1.312362] D1:camsys_platform_probe(1535):  I2c memory (phy: 0x5d72000 vir: 0xffffffc005d72000 size: 0x1000)
[    1.312375] D1:camsys_init_ext_fsh_module(20): init external flash module
[    1.312386] D1:camsys_platform_probe(1557): Probe ff920000.isp device success
[    1.312760] __power_supply_register: Expected proper parent device for 'test_ac'
[    1.312885] __power_supply_register: Expected proper parent device for 'test_battery'
[    1.313126] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    1.313224] __power_supply_register: Expected proper parent device for 'test_usb'
[    1.313815] vcc1v8_dvp: supplied by vcc3v3_sys
[    1.313931] vcca1v8_codec: supplied by vcc3v3_sys
[    1.314029] vcc_sd: supplied by vcc3v3_sys
[    1.314171] vcc_3v0: supplied by vcc3v3_sys
[    1.315448] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    1.315952] device-mapper: uevent: version 1.0.3
[    1.316226] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.316350] Bluetooth: HCI UART driver ver 2.3
[    1.316363] Bluetooth: HCI UART protocol H4 registered
[    1.316373] Bluetooth: HCI UART protocol LL registered
[    1.316733] vdd_cpu_l: supplied by vcc3v3_sys
[    1.317712] vdd_cpu_b: supplied by vcc5v0_sys
[    1.319251] sdhci: Secure Digital Host Controller Interface driver
[    1.319263] sdhci: Copyright(c) Pierre Ossman
[    1.319277] Synopsys Designware Multimedia Card Interface Driver
[    1.320078] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.320162] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.320182] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.320232] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.320299] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    1.320311] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    1.321040] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    1.321084] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    1.321101] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    1.321141] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    1.321247] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    1.321484] rockchip-iodomain io-domains: Setting to 3300000 done
[    1.321737] rockchip-iodomain io-domains: Setting to 3300000 done
[    1.334184] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.351230] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    1.351512] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.353151] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    1.353172] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    1.380973] fusb302 4-0022: CC connected in 1 as UFP
[    1.388195] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.392854] hidraw: raw HID events driver (C) Jiri Kosina
[    1.397095] usbcore: registered new interface driver usbhid
[    1.397112] usbhid: USB HID core driver
[    1.397250] inv_mpu_iio: inv_mpu_init:747
[    1.398194] ashmem: initialized
[    1.399550] ff100000.saradc supply vref not found, using dummy regulator
[    1.400909] rknandbase v1.1 2016-01-08
[    1.401336] usbcore: registered new interface driver snd-usb-audio
[    1.416699] u32 classifier
[    1.416718]     Actions configured
[    1.416769] Netfilter messages via NETLINK v0.30.
[    1.416839] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.417210] ctnetlink v0.93: registering with nfnetlink.
[    1.417979] xt_time: kernel timezone is -0000
[    1.419201] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.419486] arp_tables: (C) 2002 David S. Miller
[    1.420139] Initializing XFRM netlink socket
[    1.421008] NET: Registered protocol family 10
[    1.422824] mip6: Mobile IPv6
[    1.422893] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.425173] sit: IPv6 over IPv4 tunneling driver
[    1.426048] NET: Registered protocol family 17
[    1.426143] NET: Registered protocol family 15
[    1.426214] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.427966] Bridge firewalling registered
[    1.427998] Ebtables v2.0 registered
[    1.428381] Bluetooth: RFCOMM TTY layer initialized
[    1.428420] Bluetooth: RFCOMM socket layer initialized
[    1.428471] Bluetooth: RFCOMM ver 1.11
[    1.428528] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.428548] Bluetooth: BNEP filters: protocol multicast
[    1.428577] Bluetooth: BNEP socket layer initialized
[    1.428607] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.428659] mmc1: MAN_BKOPS_EN bit is not set
[    1.428714] Bluetooth: HIDP socket layer initialized
[    1.428779] l2tp_core: L2TP core driver, V2.0
[    1.428820] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    1.428850] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.429297] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    1.429391] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    1.429413] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    1.429434] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    1.429575] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    1.429599] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    1.429621] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    1.429719] [BT_RFKILL]: Enter rfkill_rk_init
[    1.431467] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    1.431548] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[    1.431607] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    1.431665] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    1.432422] [BT_RFKILL]: Request irq for bt wakeup host
[    1.432518] [BT_RFKILL]: ** disable irq
[    1.432544] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    1.432792] [BT_RFKILL]: bt_default device registered.
[    1.433103] sensor_register_slave:mpu6880_gyro,id=47
[    1.434415] Registered cp15_barrier emulation handler
[    1.434531] Registered setend emulation handler
[    1.434662] schedtune: init normalization constants...
[    1.434690] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    1.434715] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    1.434737] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    1.434759] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    1.434780] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    1.434803] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    1.434824] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    1.434845] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    1.434865] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    1.434888] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    1.434908] schedtune: verify normalization constants...
[    1.434928] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    1.434948] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    1.434966] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    1.434985] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    1.435003] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    1.435022] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    1.436012] registered taskstats version 1
[    1.440097] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[    1.441833] Freeing logo memory: 16384K (ffffffc07dc00000 - ffffffc07ec00000)
[    1.444975] mmcblk1: mmc1:0001 AJNB4R 14.6 GiB
[    1.449332] mmcblk1boot0: mmc1:0001 AJNB4R partition 1 4.00 MiB
[    1.449642] mmcblk1boot1: mmc1:0001 AJNB4R partition 2 4.00 MiB
[    1.450566] vdd_gpu: supplied by vcc5v0_sys
[    1.450942] mmcblk1rpmb: mmc1:0001 AJNB4R partition 3 4.00 MiB
[    1.451579]  parameter: 0x000000000 -- 0x000400000 (4 MB)
[    1.451607]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    1.451630]      trust: 0x000800000 -- 0x000c00000 (4 MB)
[    1.451651]       misc: 0x000c00000 -- 0x001000000 (4 MB)
[    1.451671]   resource: 0x001000000 -- 0x002000000 (16 MB)
[    1.451692]     kernel: 0x002000000 -- 0x003000000 (16 MB)
[    1.451712]       boot: 0x003000000 -- 0x005000000 (32 MB)
[    1.451731]   recovery: 0x005000000 -- 0x007000000 (32 MB)
[    1.451752]     backup: 0x007000000 -- 0x00e000000 (112 MB)
[    1.451773]      cache: 0x00e000000 -- 0x016000000 (128 MB)
[    1.451794]     system: 0x016000000 -- 0x056000000 (1024 MB)
[    1.451814]   metadata: 0x056000000 -- 0x057000000 (16 MB)
[    1.451835] baseparamer: 0x057000000 -- 0x057400000 (4 MB)
[    1.451856]   userdata: 0x057400000 -- 0x3a3a00000 (13510 MB)
[    1.451916]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    1.452292] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    1.453267] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 265; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    1.457984] mali ff9a0000.gpu: Probed as mali0
[    1.461955] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    1.461986] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 5
[    1.462239] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[    1.462295] xhci-hcd xhci-hcd.2.auto: irq 232, io mem 0xfe800000
[    1.462450] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    1.462463] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.462474] usb usb5: Product: xHCI Host Controller
[    1.462485] usb usb5: Manufacturer: Linux 4.4.16 xhci-hcd
[    1.462495] usb usb5: SerialNumber: xhci-hcd.2.auto
[    1.463029] hub 5-0:1.0: USB hub found
[    1.463063] hub 5-0:1.0: 1 port detected
[    1.463365] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    1.463384] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 6
[    1.463449] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.463547] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    1.463560] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.463571] usb usb6: Product: xHCI Host Controller
[    1.463581] usb usb6: Manufacturer: Linux 4.4.16 xhci-hcd
[    1.463591] usb usb6: SerialNumber: xhci-hcd.2.auto
[    1.464058] hub 6-0:1.0: USB hub found
[    1.464088] hub 6-0:1.0: 1 port detected
[    1.465655] xhci-hcd xhci-hcd.2.auto: remove, state 1
[    1.465684] usb usb6: USB disconnect, device number 1
[    1.489596] xhci-hcd xhci-hcd.2.auto: Host not halted after 16000 microseconds.
[    1.489618] xhci-hcd xhci-hcd.2.auto: Host controller not halted, aborting reset.
[    1.489782] xhci-hcd xhci-hcd.2.auto: USB bus 6 deregistered
[    1.489800] xhci-hcd xhci-hcd.2.auto: remove, state 1
[    1.489821] usb usb5: USB disconnect, device number 1
[    1.490564] xhci-hcd xhci-hcd.2.auto: USB bus 5 deregistered
[    1.491156] ehci-platform fe380000.usb: EHCI Host Controller
[    1.491181] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[    1.491377] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    1.514294] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    1.526100] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.526262] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    1.526463] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.526499] usb usb5: Product: EHCI Host Controller
[    1.526525] usb usb5: Manufacturer: Linux 4.4.16 ehci_hcd
[    1.526549] usb usb5: SerialNumber: fe380000.usb
[    1.527609] hub 5-0:1.0: USB hub found
[    1.527679] hub 5-0:1.0: 1 port detected
[    1.528881] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.528932] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[    1.529179] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    1.586721] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    1.586761] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.586791] usb usb6: Product: Generic Platform OHCI controller
[    1.586815] usb usb6: Manufacturer: Linux 4.4.16 ohci_hcd
[    1.586840] usb usb6: SerialNumber: fe3a0000.usb
[    1.587880] hub 6-0:1.0: USB hub found
[    1.587947] hub 6-0:1.0: 1 port detected
[    1.589680] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.589796] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.589831] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.589894] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.589992] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    1.590014] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    1.590508] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    1.606304] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.622351] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    1.623954] asoc-simple-card hdmi-sound: dw-hdmi-hifi <-> ff8a0000.i2s mapping ok
[    1.639252] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[    1.648322] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[    1.652287] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[    1.655615] otg_wakelock_init: No USB transceiver found
[    1.655691] dhd_module_init: in
[    1.655718] ======== bcm_wlan_set_plat_data ========
[    1.655740] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    1.655771] host_oob_irq: 62
[    1.655789] host_oob_irq_flags=0x4
[    1.655805] sensor_init: Probe name sensors
[    1.655820] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[    1.655841] dhd_wifi_platform_load: Enter
[    1.655884] Power-up adapter 'DHD generic adapter'
[    1.655957] wifi_platform_set_power = 1
[    1.655974] ======== PULL WL_REG_ON HIGH! ========
[    1.655994] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    1.656014] [WLAN_RFKILL]: wifi turn on power. -1
[    1.657322] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:53:18 UTC (1358499198)
[    1.660574] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[    1.660612] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.660641] usb 1-1: Product: USB 2.0 Hub [MTT]
[    1.661983] hub 1-1:1.0: USB hub found
[    1.662240] hub 1-1:1.0: 7 ports detected
[    1.671470] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.673178] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.674861] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.677844] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.685392] sdhci-arasan fe330000.sdhci: data error (-84)
[    1.685444] sdhci-arasan fe330000.sdhci: failed (-84) to handle RPMB request
u▒   1.693768]
[    1.743869] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
Return to List
12
