Fan speed under ubuntu rk3399
37
Posted at 4/10/2017 19:48:42      View:4401 | Replies:5        Print      Only Author   [Copy Link] 1#
Good day!
Fan spins constanly with high speed without any needs.
So maybe there is a value to adjust RPMs?
Roman
super moderator
Rank: 8Rank: 8
Posted at 4/11/2017 09:30:28        Only Author  2#
sorry, can't be,
hardware  limitation.
or you could modify  like this:
http://developer.t-firefly.com/f ... hlight=%B7%E7%C9%C8
Posted at 4/21/2017 06:28:54        Only Author  3#
I found it frustratingly loud too.  I did some testing, and the board is perfectly working even with very heavy processing with the fan connector unplugged.  The speed of the A72 cores slows considerably, the net effect being a few tens of percent slowdown, which to me is still perfectly workable.  There is a dedicated heatsink in the store that might do better, but so far whenever I've looked it's been out of stock.  Hopefully there will be more soon.
Posted at 4/21/2017 06:30:16        Only Author  4#
For more details on the testing: http://bbs.t-firefly.com/forum.p ... &extra=page%3D2
Posted at 5/24/2017 19:07:28        Only Author  5#
isle Posted at 4/11/2017 09:30
sorry, can't be,
It would be a huge help if i could read chinese but sadly i can't. think you can translate?
Posted at 7/16/2017 23:56:22        Only Author  6#
sorry, can't be,
hello isle,
Is it possible to post the information of your link also in english. Just for my understanding, the Fan turns always on max. rpm (Android and Linux) at  least on my board. Is the line where it is connected not regulated at all? I dont understand the comment hardware limitation. The SOC has temp sensors so it should be no big deal to read them and regulate the fans rpm based on a temperature profile.
Thax for helping
