will you plz replace the big blue VGA connector with usb ?
2
Posted at 12/11/2014 15:05:48      View:5564 | Replies:5        Print      Only Author   [Copy Link] 1#
that's all the mods need
Posted at 12/12/2014 10:37:34        Only Author  2#
You'd like two more USB ports?
Posted at 12/12/2014 16:59:27        Only Author  3#
that'll be awsome!
Posted at 12/13/2014 11:08:40        Only Author  4#
The VGA connector has its important usage. There're still many VGA displays around.
You have some options to get more USB ports. The first one, of couse, is using an external USB hub.
The second option, is DIY your board. If you look at the back of the USB port, you'll find eight copper pads in two lines.
And yes, you can solder a double deck usb port with wires on it.
If you're interested at the second option, we can provide the detail.
Posted at 3/9/2015 16:36:39        Only Author  5#
Re: will you plz replace the big blue VGA connector with usb ?
        Hi,
        can you provide the detail?
This user has been deleted
Posted at 5/2/2015 10:04:59        Only Author  6#
Tip: the author has been banned or deleted automatically shield
Posted at 5/2/2015 16:48:27        Only Author  7#
High mode
B Color Image Link Quote Code Smilies |Upload
