Technical briefing for Firefly-RK3399 Android7.1 Updates firmware and Codes
385
super moderator
Rank: 8Rank: 8
Posted at 5/24/2017 15:00:59
Android7.1 update
1. Support HDMI, DP dual display, support different features
2. support tf card, remote control, headphones, microphone, spdif, Gigabit Ethernet, wifi, Bluetooth, mipi camera, dvp camera, PCIe SSD / SATA, 7.85eDP display, usb3.0, 4G module.
USB3.0 test speed
USB3.0 theoretical value can reach 500M / s, using high-speed USB3.0 storage disk to test as a example
read speed 270.3M/
write speed 329.0M/s
UI:
Android7.1 AnTuTu score  is higher higher 10,000 points than Android6.0 system version
please log in Baidu Pan to download Android SDKand upgrade to the latest commitc77e39c Init the Firefly-RK3399 7.1 SDK
gitlab    git@gitlab.com:TeeFirefly/FireNow-Nougat.git
Update codes:
git pull gitlab firefly-rk3399:firefly-rk3399
Download the latest firmware:
Google Drive
JDK Installation
  1. sudo add-apt-repository ppa:openjdk-r/ppa
  2. sudo apt-get update
  3. sudo apt-get install openjdk-8-jdk</font>
Copy the code
Default compilation HDMI+DP
  1. ./FFTo</font></font>ols/make.sh -j8
  2. ./FFTools/mkupdate/mkupdate.sh</font>
Copy the code
Compile EDP7.85
  1. ./FFTools/make.sh -j8 -d rk3399-firefly-edp -l rk3399_firefly_edp_box-userdebug
  2. ./FFTools/mkupdate/mkupdate.sh -l rk3399_firefly_edp_box-userdebug</font>
Copy the code
Website: http://www.t-firefly.com
Wiki: http://wiki.t-firefly.com
Community: http://developer.t-firefly.com
Buy: https://t-firefly.taobao.com/
Technical Group (QQ): 431139193 | 586343230
Posted at 5/26/2017 09:45:14
I used Android 7.1 img file.
There is no menu about mobile network in setup menu.
I hope that I can see new firmware with eDP and good working mobile network (NO ROAMING AT HOME) version ASAP.
Thx.
Posted at 6/8/2017 00:07:59
First off, thanks for sharing the code.
To id2ego (and others), I've got a build for eDP from the FireNow-Nougat repository. 7.85" touchscreen working well, haven't tried the 4G module yet. Could probably put this image somewhere people can get it from. Cheers.
Posted at 6/12/2017 21:30:41
exyn Posted at 6/8/2017 00:07
To id2ego (and others), I've got a build for eDP from the ...
Thx. I had already used the image.
But, It's same problem that can't use mobile networks.
Anyway...
May I ask you something?
http://bbs.t-firefly.com/forum.p ... &extra=page%3D1
If you can solve this problem, please let me know.
Thx.
