New Topic
Ubuntu Ethernet connection unavailable
135
Posted at 7/13/2017 19:54:59      View:11850 | Replies:26        Print      Only Author   [Copy Link] 1#
I bought the second RK3399 4Gb card and can not configure the network.
On the first board (I bought it 2 month ago), everything was OK.
Initially, there was an android. In the android everything is OK (wifi and ethernet work perfectly), so I think that is software problem or you changed some hardware and didn't update ubuntu image.
I installed Firefly-rk3399_xubuntu1604_201704271809.
WIFI is working. I made all possible tests for the ethernet nearptwork. I found nothing strange.
"ping" and "traceroute" hangs, "arp" show default gateway if i input static ip address in Network Manager
I found that sometimes the MAC address of eth0 changes. Can be on different firmware, but I'm not sure.
I can provide any information you need.
super moderator
Rank: 8Rank: 8
Posted at 7/14/2017 09:39:52        Only Author  2#
Posted at 7/14/2017 19:01:59        Only Author  3#
Thx, for help. I got compilation error when i compiled on the Firefly board. On my Ubuntu desktop compilation success.
OBJCOPY arch/arm64/boot/Image
./scripts/mkkrnlimg: 1: ./scripts/mkkrnlimg: Syntax error: "(" unexpected
arch/arm64/Makefile:144: recipe for target 'kernel.img' failed
make: *** [kernel.img] Error 2
Posted at 7/14/2017 21:51:42        Only Author  4#
I not understand how to change offset of Kernel Partition. I can't update kernel.img by Android Tool. When i unpacked firware I got only that files:
master@server:~/Kernel/image$  img_unpack Firefly-RK3399_Ubuntu16.04_201703181519.img img
rom version: 6.0.1
build time: 2017-03-18 15:20:22
chip: 33333043
checking md5sum....OK
master@server:~/Kernel/image/img$ afptool -unpack update.img update
Check file...OK
------- UNPACK -------
package-file    0x00000800      0x000000FD
RKLoader.bin    0x00001000      0x0003E94E
parameter       0x00040000      0x00000290
trust.img       0x00040800      0x00400000
uboot.img       0x00440800      0x00400000
linux-boot.img  0x00840800      0x01344000
linux-rootfs.img        0x01B84800      0xBDC00000
RESERVED        0x00000000      0x00000000
update-script   0xBF784800      0x000003A5
recover-script  0xBF785000      0x0000010A
How can I update kernel.img on my Firefly board?
super moderator
Rank: 8Rank: 8
Posted at 7/17/2017 09:44:44        Only Author  5#
oh, please unpack the version of  201705111112.img .that is the latest firmware.
Posted at 7/17/2017 18:47:57        Only Author  6#
First of alI I flashed device last firware 201705111112
1. Next I unpacked 201705111112.img
package-file    0x00000800      0x0000013D
rk3399_loader_v1.07.105.bin     0x00001000      0x0003E94E
parameter       0x00040000      0x0000022A
linux-kernel.img        0x00840800      0x01192E4C
linux-resource.img      0x019D3800      0x0003FA00
ubuntu1604arm64-rootfs.img      0x01A13800      0x87AF2000
update-script   0x89505800      0x00000416
recover-script  0x89506000      0x0000010A
UnPack OK!
2.   Changed adresses in android tool at first tab
3. Selected compiled images
        kernel.img
        resource.img
4. Click Run (flashing..ok)
After that Ubuntu can't  start.
Posted at 7/17/2017 18:54:46        Only Author  7#
Other way
I replaced the files: linux-kernel.img, linux-resource.img
with my own and pack new release firware by this link http://wiki.t-firefly.com/index. ... en#Extract_Firmware
After i flashed new firware Ubuntu not load correctly (Black screen).
  1. Welcome to Ubuntu 16.04.2 LTS!
  2. [    1.809040] systemd[1]: Set hostname to <firefly>.
  3. [    1.836811] random: systemd: uninitialized urandom read (16 bytes read, 28 bi                                                     ts of entropy available)
  4. [    1.841980] wifi_platform_bus_enumerate device present 1
  5. [    1.842459] ======== Card detection to detect SDIO card! ========
  6. [    1.842858] random: systemd-cryptse: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
  7. [    1.843928] mmc2:mmc host rescan start!
  8. [    1.850603] random: systemd-sysv-ge: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
  9. [    1.854268] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
  10. [    1.855401] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
  11. [    1.856356] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
  12. [    1.856468] random: systemd-sysv-ge: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
  13. [    1.858484] random: systemd-gpt-aut: uninitialized urandom read (16 bytes rea                                                     d, 29 bits of entropy available)
  14. [    1.876276] vendor storage:20160801 ret = 0
  15. [    2.017199] systemd[1]: Listening on Journal Socket (/dev/log).
  16. [  OK  ] Listening on Journal Socket (/dev/log).
  17. [    2.018617] systemd[1]: Reached target Swap.
  18. [  OK  ] Reached target Swap.
  19. [    2.019412] systemd[1]: Reached target Encrypted Volumes.
  20. [  OK  ] Reached target Encrypted Volumes.
  21. [    2.020374] systemd[1]: Listening on udev Kernel Socket.
  22. [  OK  ] Listening on udev Kernel Socket.
  23. [    2.021337] systemd[1]: Listening on Journal Socket.
  24. [  OK  ] Listening on Journal Socket.
  25. [    2.022516] systemd[1]: Created slice User and Session Slice.
  26. [  OK  ] Created slice User and Session Slice.
  27. [    2.023405] systemd[1]: Started Forward Password Requests to Wall Directory W                                                     atch.
  28. [  OK  ] Started Forward Password Requests to Wall Directory Watch.
  29. [    2.024561] systemd[1]: Listening on udev Control Socket.
  30. [  OK  ] Listening on udev Control Socket.
  31. [    2.025784] systemd[1]: Created slice System Slice.
  32. [  OK  ] Created slice System Slice.
  33. [    2.028195] systemd[1]: Starting Remount Root and Kernel File Systems...
  34.          Starting Remount Root and Kernel File Systems...
  35. [    2.031736] systemd[1]: Starting Create Static Device Nodes in /dev...
  36.          Starting Create Static Device Nodes in /dev...
  37. [    2.035330] systemd[1]: Mounting Debug File System...
  38.          Mounting Debug File System...
  39. [    2.041457] systemd[1]: Starting Load Kernel Modules...
  40.          Starting Load Kernel Modules...
  41. [    2.043389] systemd[1]: Created slice system-serial\x2dgetty.slice.
  42. [  OK  ] Created slice system-serial\x2dgetty.slice.
  43. [    2.051429] systemd[1]: Listening on Syslog Socket.
  44. [  OK  ] Listening on Syslog Socket.
  45. [    2.054111] systemd[1]: Starting Journal Service...
  46.          Starting Journal Service...
  47. [    2.058155] systemd[1]: Reached target Slices.
  48. [  OK  ] Reached target Slices.
  49. [    2.060663] systemd[1]: Starting Set console keymap...
  50.          Starting Set console keymap...
  51. [    2.061467] systemd[1]: Reached target User and Group Name Lookups.
  52. [  OK  ] Reached target User and Group Name Lookups.
  53. [    2.062683] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
  54. [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
  55. [    2.063680] systemd[1]: Reached target Remote File Systems (Pre).
  56. [  OK  ] Reached target Remote File Systems (Pre).
  57. [    2.064971] systemd[1]: Reached target Remote File Systems.
  58. [  OK  ] Reached target Remote File Systems.
  59. [    2.070176] systemd[1]: Mounted Debug File System.
  60. [  OK  ] Mounted Debug File System.
  61. [    2.071854] systemd[1]: Started Remount Root and Kernel File Systems.
  62. [  OK  ] Started Remount Root and Kernel File Systems.
  63. [    2.077937] systemd[1]: Started Create Static Device Nodes in /dev.
  64. [  OK  ] Started Create Static Device Nodes in /dev.
  65. [    2.079573] systemd[1]: systemd-modules-load.service: Main process exited, co                                                     de=exited, status=1/FAILURE
  66. [    2.081167] systemd[1]: Failed to start Load Kernel Modules.
  67. [FAILED] Failed to start Load Kernel Modules.
  68. See 'systemctl status systemd-modules-load.service' for details.
  69. [    2.082321] systemd[1]: systemd-modules-load.service: Unit entered failed sta                                                     te.
  70. [    2.083400] systemd[1]: systemd-modules-load.service: Failed with result 'exi                                                     t-code'.
  71. [    2.098661] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 233
  72. [    2.104801] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
  73. [    2.105349] mmc2: new ultra high speed SDR104 SDIO card at address 0001
  74. [    2.123073] bcmsdh_register: register client driver
  75. [    2.123679] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
  76. [    2.124239] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
  77. [    2.124660] bus num (host idx)=2, slot num (rca)=1
  78. [    2.125102] found adapter info 'DHD generic adapter'
  79. [    2.125579] sdioh_attach: set sd_f2_blocksize 128
  80. [    2.126382] F1 signature read @0x18000000=0x17224356
  81. [    2.130010] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
  82. [    2.131020] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
  83. [    2.131687] wifi_platform_get_mac_addr
  84. [    2.132027] ======== bcm_wlan_get_mac_address ========
  85. [    2.132476] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
  86. [    2.132956] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac addr                                                     ess failed (-1)
  87. [    2.133697] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
  88. [    2.134213] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmwa                                                     re/config.txt
  89. [    2.136037] wl_create_event_handler(): thread:wl_event_handler:c7 started
  90. [    2.136092] tsk Enter, tsk = 0xffffffc0ed241be8
  91. [    2.137234] wl_escan_attach: Enter
  92. [    2.137557] wl_escan_init: Enter
  93. [    2.138094] wl_create_event_handler(): thread:wl_escan_handler:c8 started
  94. [    2.138151] tsk Enter, tsk = 0xffffffc0ed2701b0
  95. [    2.139237] dhd_attach(): thread:dhd_watchdog_thread:c9 started
  96. [    2.139805] dhd_attach(): thread:dhd_dpc:ca started
  97. [    2.139825] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
  98. [    2.140802] dhd_attach(): thread:dhd_rxf:cb started
  99. [    2.141251] dhd_deferred_work_init: work queue initialized
  100. [    2.142799] systemd[1]: Mounting Configuration File System...
  101.          Mounting Configuration File System...
  102. [    2.145355] systemd[1]: Starting Apply Kernel Variables...
  103.          Starting Apply Kernel Variables...
  104. [    2.148122] systemd[1]: Mounting FUSE Control File System...
  105.          Mounting FUSE Control File System...
  106. [    2.151035] systemd[1]: Starting udev Kernel Device Manager...
  107. [    2.151597] Dongle Host Driver, version 1.363.59.144.1 (r)
  108. [    2.152803] Register interface [wlan0]  MAC: ac:83:f3:9e:4a:6e
  109. [    2.152803]
  110. [    2.152853] wl_event_handler: was terminated
  111. [    2.152965] wl_destroy_event_handler(): thread:wl_event_handler:c7 terminated                                                      OK
  112. [    2.152971] dhd_wl_ioctl: returning as busstate=0
  113. [    2.153693] bcmsdh_oob_intr_unregister: Enter
  114. [    2.153695] bcmsdh_oob_intr_unregister: irq is not registered
  115. [    2.153712] dhd_txglom_enable: enable 0
  116. [    2.153716] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
  117. [    2.153717] dhd_conf_set_txglom_params: txglom_bucket_size=0
  118. [    2.153719] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_                                                     txglom=0
  119.          Starting udev Kernel Device Manager...
  120.          Starting Load/Save Random Seed...
  121.          Starting udev Coldplug all Devices...
  122. [  OK  ] Mounted Configuration File System.
  123. [  OK  ] Mounted FUSE Control File System.
  124. [  OK  ] Started Apply Kernel Variables.
  125. [  OK  ] Started Set console keymap.
  126. [  OK  ] Started Load/Save Random Seed.
  127. [  OK  ] Reached target Local File Systems (Pre).
  128. [  OK  ] Reached target Local File Systems.
  129.          Starting LSB: AppArmor initialization...
  130.          Starting Set console font and keymap...
  131.          Starting Tell Plymouth To Write Out Runtime Data...
  132. [  OK  ] Started Journal Service.
  133.          Starting Flush Journal to Persistent Storage...
  134. [  OK  ] Started Tell Plymouth To Write Out Runtime Data.
  135. [  OK  ] Started udev Kernel Device Manager.
  136. [    2.274233] Unable to handle kernel NULL pointer dereference at virtual addre                                                     ss 00000000
  137. [    2.275004] pgd = ffffffc0ed13d000
  138. [    2.275302] [00000000] *pgd=0000000000000000, *pud=0000000000000000
  139. [    2.275854] Internal error: Oops: 86000005 [#1] SMP
  140. [    2.276279] Modules linked in:
  141. [    2.276551] CPU: 5 PID: 241 Comm: udevadm Not tainted 4.4.55 #1
  142. [    2.277065] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (                                                     DT)
  143. [    2.277708] task: ffffffc0ed2d4980 ti: ffffffc0ed310000 task.ti: ffffffc0ed31                                                     0000
  144. [    2.278359] PC is at 0x0
  145. [    2.278585] LR is at _raw_spin_lock+0x20/0x2c
  146. [    2.278964] pc : [<0000000000000000>] lr : [<ffffff8008baaf98>] pstate: a0000                                                     145
  147. [    2.279605] sp : ffffffc0ed313b90
  148. [    2.279893] x29: ffffffc0ed313b90 x28: ffffffc0ed310000
  149. [    2.280359] x27: ffffff8008bc2000 x26: 000000000000004f
  150. [    2.280823] x25: 000000000000011d x24: 0000000000000030
  151. [    2.281289] x23: 0000000000000000 x22: ffffffc0ee5b86c0
  152. [    2.281753] x21: 0000000000000000 x20: 0000000000000000
  153. [    2.282219] x19: ffffffc0ee5b8718 x18: 0000000000000a03
  154. [    2.282683] x17: 0000007fb685b230 x16: ffffff80081a9e6c
  155. [    2.283147] x15: 0000000000000080 x14: 000000ff02010100
  156. [    2.283611] x13: ffffffff00000000 x12: 0000000000000000
  157. [    2.284075] x11: 0000000000040004 x10: 0000000000000000
  158. [    2.284540] x9 : ffffffc0ed8e701c x8 : fefefefefefefeff
  159. [    2.285006] x7 : 00000055c36b6d00 x6 : 0000000000000fe4
  160. [    2.285470] x5 : 0000000000000003 x4 : 0000000000000000
  161. [    2.285935] x3 : ffffff80090e5000 x2 : 00000000000000d6
  162. [    2.286400] x1 : 0000000000000005 x0 : ffffffc0ed2d4980
  163. [    2.286865]
  164. [    2.286865] LR: 0xffffff8008baaf18:
  165. [    2.287296] af18  8b000021 c802fe61 35ffffa2 d5033bbf 17ffffda a94153f3 a9425                                                     bf5 f9401bf7
  166. [    2.288025] af38  a8c67bfd d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e0                                                     3e0 d503201f
  167. [    2.288752] af58  aa1303e0 97d4e008 35000040 14000002 52800020 f9400bf3 a8c27                                                     bfd d65f03c0
  168. [    2.289478] af78  a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 d503201f aa130                                                     3e0 97d4dfa4
  169. [    2.290206] af98  f9400bf3 a8c27bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa000                                                     3f4 aa1e03e0
  170. [    2.290933] afb8  d503201f d53b4233 d50342df aa1403e0 97d4df97 aa1303e0 a9415                                                     3f3 a8c27bfd
  171. [    2.291660] afd8  d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 d5032                                                     01f d50342df
  172. [    2.292386] aff8  aa1303e0 97d4df8a f9400bf3 a8c27bfd d65f03c0 a9be7bfd 91000                                                     3fd f9000bf3
  173. [    2.293115]
  174. [    2.293115] SP: 0xffffffc0ed313b10:
  175. [    2.293546] 3b10  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 00000                                                     11d 00000000
  176. [    2.294272] 3b30  0000004f 00000000 08bc2000 ffffff80 ed310000 ffffffc0 ed313                                                     b90 ffffffc0
  177. [    2.294998] 3b50  08baaf98 ffffff80 ed313b90 ffffffc0 00000000 00000000 a0000                                                     145 00000000
  178. [    2.295725] 3b70  ee5b8718 ffffffc0 00000000 00000000 00000000 00000080 081b1                                                     9e4 ffffff80
  179. [    2.296452] 3b90  ed313bb0 ffffffc0 08392990 ffffff80 ee5b8718 ffffffc0 081b0                                                     8e8 ffffff80
  180. [    2.297179] 3bb0  ed313bd0 ffffffc0 081b0914 ffffff80 ed313cb0 ffffffc0 00000                                                     000 00000000
  181. [    2.297906] 3bd0  ed313c10 ffffffc0 081b0f1c ffffff80 ed313cb0 ffffffc0 ee5b8                                                     6c0 ffffffc0
  182. [    2.298633] 3bf0  ed313e10 ffffffc0 00000003 00000000 ed313e58 ffffffc0 00000                                                     015 00000000
  183. [    2.299360]
  184. [    2.299360] X0: 0xffffffc0ed2d4900:
  185. [    2.299791] 4900  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  186. [    2.300518] 4920  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  187. [    2.301244] 4940  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  188. [    2.301970] 4960  00ff00ff 00ff00ff 00ff00ff 00ff00ff 00ff00ff 00ff00ff 00ff0                                                     0ff 00ff00ff
  189. [    2.302697] 4980  00000000 00000000 ed310000 ffffffc0 00000002 00404100 00000                                                     000 00000000
  190. [    2.303424] 49a0  00000000 00000000 00000001 000000e1 fffb7433 00000000 ef2fd                                                     5c0 ffffffc0
  191. [    2.304151] 49c0  00000005 00000001 00000078 00000078 00000078 00000000 08bc8                                                     548 ffffff80
  192. [    2.304878] 49e0  00000400 00000000 00400000 00000000 00000001 00000000 00000                                                     000 00000000
  193. [    2.305606]
  194. [    2.305606] X3: 0xffffff80090e4f80:
  195. [    2.306037] 4f80  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  196. [    2.306763] 4fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  197. [    2.307489] 4fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  198. [    2.308215] 4fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  199. [    2.308941] 5000  00000e12 00000e12 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  200. [    2.309668] 5020  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  201. [    2.310394] 5040  05600000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  202. [    2.311120] 5060  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  203. [    2.311847]
  204. [    2.311847] X9: 0xffffffc0ed8e6f9c:
  205. [    2.312278] 6f9c  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  206. [    2.313004] 6fbc  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  207. [    2.313730] 6fdc  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  208. [    2.314456] 6ffc  00000000 ed8e701c ffffffc0 c36b6d00 00000055 00000000 00000                                                     000 00000001
  209. [    2.315183] 701c  7379732f 79730000 616c702f 726f6674 65642f6d 65636976 66662                                                     f73 66336638
  210. [    2.315910] 703c  692e3030 756d6d6f 00746500 00000000 65747379 0000006d 6f746                                                     16c 464f0a72
  211. [    2.316637] 705c  4d4f435f 49544150 5f454c42 65723d30 616c7567 2d726f74 65786                                                     966 464f0a64
  212. [    2.317364] 707c  4d4f435f 49544150 5f454c42 0a313d4e 41444f4d 5341494c 3a666                                                     f3d 6363764e
  213. [    2.318092]
  214. [    2.318092] X13: 0xfffffffeffffff80:
  215. [    2.318530] ff80  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  216. [    2.319262] ffa0  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  217. [    2.319991] ffc0  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  218. [    2.320721] ffe0  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  219. [    2.321450] 0000  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  220. [    2.322179] 0020  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  221. [    2.322908] 0040  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  222. [    2.323638] 0060  ******** ******** ******** ******** ******** ******** *****                                                     *** ********
  223. [    2.324367]
  224. [    2.324367] X16: 0xffffff80081a9dec:
  225. [    2.324806] 9dec  aa1e03e0 aa0103f3 d503201f aa1403e0 9100a3a1 97ffff0d 35000                                                     080 9100a3a0
  226. [    2.325533] 9e0c  aa1303e1 97ffff27 93407c00 a94153f3 a8c97bfd d65f03c0 a9b77                                                     bfd 910003fd
  227. [    2.326259] 9e2c  a90153f3 aa0003f4 aa1e03e0 aa0103f3 d503201f aa1403e0 9100a                                                     3a1 97ffff0a
  228. [    2.326985] 9e4c  35000080 9100a3a0 aa1303e1 97ffff15 93407c00 a94153f3 a8c97                                                     bfd d65f03c0
  229. [    2.327711] 9e6c  a9b67bfd 910003fd a90153f3 aa0003f4 aa1e03e0 f90013a1 aa020                                                     3f3 f90017a3
  230. [    2.328438] 9e8c  d503201f f94013a1 2a1403e0 f94017a3 9100e3a2 97fffeb5 35000                                                     080 9100e3a0
  231. [    2.329165] 9eac  aa1303e1 97fffeff 93407c00 a94153f3 a8ca7bfd d65f03c0 a9b77                                                     bfd 910003fd
  232. [    2.329892] 9ecc  a90153f3 aa0003f4 aa1e03e0 aa0103f3 d503201f 2a1403e0 9100a                                                     3a1 97fffe89
  233. [    2.330620]
  234. [    2.330620] X19: 0xffffffc0ee5b8698:
  235. [    2.331058] 8698  ee5ba408 ffffffc0 ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000                                                     000 00000000
  236. [    2.331784] 86b8  00000000 00000000 00200000 00000002 00000000 00000000 00000                                                     000 00000000
  237. [    2.332511] 86d8  ee5b86c0 ffffffc0 00000000 00000001 ee5b86f8 ffffffc0 ed630                                                     000 ffffffc0
  238. [    2.333237] 86f8  0000002f dead4ead ffffffff 00000000 ffffffff ffffffff 00000                                                     000 00000000
  239. [    2.333964] 8718  64af64ae dead4ead 00000005 00000000 ed2d4980 ffffffc0 00000                                                     00a 00000000
  240. [    2.334691] 8738  00000000 00000000 edde2000 ffffffc0 00000000 dead4ead ef0ee                                                     000 ffffffc0
  241. [    2.335417] 8758  ee5b8758 ffffffc0 ee5b8758 ffffffc0 ee5b8768 ffffffc0 ee5b8                                                     768 ffffffc0
  242. [    2.336144] 8778  ee5e2408 ffffffc0 ee5b8840 ffffffc0 00000000 00000000 ed630                                                     148 ffffffc0
  243. [    2.336872]
  244. [    2.336872] X22: 0xffffffc0ee5b8640:
  245. [    2.337311] 8640  00030003 dead4ead ffffffff ffffffc0 ffffffff ffffffff 00000                                                     000 ffffffc0
  246. [    2.338038] 8660  00000000 00000000 ede0b800 ffffffc0 00000000 00000000 00000                                                     000 00000000
  247. [    2.338764] 8680  ee5ba4d0 ffffffc0 ee5b85a8 ffffffc0 eec0e330 ffffffc0 ee5ba                                                     408 ffffffc0
  248. [    2.339491] 86a0  ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000 00000                                                     000 00000000
  249. [    2.340218] 86c0  00200000 00000002 00000000 00000000 00000000 00000000 ee5b8                                                     6c0 ffffffc0
  250. [    2.340945] 86e0  00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0 00000                                                     02f dead4ead
  251. [    2.341672] 8700  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 64af6                                                     4ae dead4ead
  252. [    2.342399] 8720  00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000 00000                                                     000 00000000
  253. [    2.343126]
  254. [    2.343126] X27: 0xffffff8008bc1f80:
  255. [    2.343564] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  256. [    2.344290] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  257. [    2.345015] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  258. [    2.345741] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  259. [    2.346467] 2000  081e9718 ffffff80 081e9fac ffffff80 081ea550 ffffff80 081ea                                                     590 ffffff80
  260. [    2.347194] 2020  081ea6fc ffffff80 081c88f8 ffffff80 081c894c ffffff80 081c8                                                     9a0 ffffff80
  261. [    2.347922] 2040  081c8a38 ffffff80 081c8a80 ffffff80 081c8ac8 ffffff80 081c8                                                     b40 ffffff80
  262. [    2.348649] 2060  081c8b80 ffffff80 081c8bc0 ffffff80 081c8c30 ffffff80 081c8                                                     c6c ffffff80
  263. [    2.349377]
  264. [    2.349377] X28: 0xffffffc0ed30ff80:
  265. [    2.349815] ff80  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  266. [    2.350542] ffa0  00000000 00000000 00000000 00000000 00000000 00000000 00000                                                     000 00000000
  267. [    2.351268] ffc0  ffff0000 ffff0000 00000000 000000c0 ed38ae00 ffffffc0 ed38a                                                     e00 ffffffc0
  268. [    2.351995] ffe0  00000300 00000001 00000000 00000000 00ff00ff 00ff00ff 00ff0                                                     0ff 00ff00ff
  269. [    2.352721] 0000  00000002 00000000 ffffffff ffffffff ed2d4980 ffffffc0 00000                                                     000 00000005
  270. [    2.353448] 0020  57ac6e9d 00000000 c3b0e580 ffffffbd c3b0e540 ffffffbd c3b0e                                                     500 ffffffbd
  271. [    2.354175] 0040  c3b0e4c0 ffffffbd c3b0e480 ffffffbd c3b0e440 ffffffbd c3b0e                                                     400 ffffffbd
  272. [    2.354902] 0060  c3b0e3c0 ffffffbd c3b0e380 ffffffbd c3b0e340 ffffffbd c3b0e                                                     300 ffffffbd
  273. [    2.355629]
  274. [    2.355629] X29: 0xffffffc0ed313b10:
  275. [    2.356068] 3b10  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 00000                                                     11d 00000000
  276. [    2.356794] 3b30  0000004f 00000000 08bc2000 ffffff80 ed310000 ffffffc0 ed313                                                     b90 ffffffc0
  277. [    2.357521] 3b50  08baaf98 ffffff80 ed313b90 ffffffc0 00000000 00000000 a0000                                                     145 00000000
  278. [    2.358248] 3b70  ee5b8718 ffffffc0 00000000 00000000 00000000 00000080 081b1                                                     9e4 ffffff80
  279. [    2.358974] 3b90  ed313bb0 ffffffc0 08392990 ffffff80 ee5b8718 ffffffc0 081b0                                                     8e8 ffffff80
  280. [    2.359701] 3bb0  ed313bd0 ffffffc0 081b0914 ffffff80 ed313cb0 ffffffc0 00000                                                     000 00000000
  281. [    2.360427] 3bd0  ed313c10 ffffffc0 081b0f1c ffffff80 ed313cb0 ffffffc0 ee5b8                                                     6c0 ffffffc0
  282. [    2.361155] 3bf0  ed313e10 ffffffc0 00000003 00000000 ed313e58 ffffffc0 00000                                                     015 00000000
  283. [    2.361881]
  284. [    2.362012] Process udevadm (pid: 241, stack limit = 0xffffffc0ed310020)
  285. [    2.362594] Stack: (0xffffffc0ed313b90 to 0xffffffc0ed314000)
  286. [    2.363093] 3b80:                                   ffffffc0ed313bb0 ffffff80                                                     08392990
  287. [    2.363773] 3ba0: ffffffc0ee5b8718 ffffff80081b08e8 ffffffc0ed313bd0 ffffff80                                                     081b0914
  288. [    2.364452] 3bc0: ffffffc0ed313cb0 0000000000000000 ffffffc0ed313c10 ffffff80                                                     081b0f1c
  289. [    2.365131] 3be0: ffffffc0ed313cb0 ffffffc0ee5b86c0 ffffffc0ed313e10 00000000                                                     00000003
  290. [    2.365810] 3c00: ffffffc0ed313e58 0000000000000015 ffffffc0ed313c30 ffffff80                                                     081b21a8
  291. [    2.366489] 3c20: 0000000000000000 ffffffc0ed313cb0 ffffffc0ed313c70 ffffff80                                                     081b3508
  292. [    2.367168] 3c40: 00000000ffffff9c 0000000000000000 ffffffc0ed8e7000 ffffffc0                                                     ed313e10
  293. [    2.367847] 3c60: 00000000ffffff9c 0000000000000040 ffffffc0ed313d80 ffffff80                                                     081b3670
  294. [    2.368527] 3c80: 0000000000000000 00000000ffffff9c 00000000ffffff9c 00000055                                                     c36b6d00
  295. [    2.369207] 3ca0: ffffffc0ed8e7000 0000000000000000 ffffffc0edaac020 ffffffc0                                                     ee5b86c0
  296. [    2.369886] 3cc0: 000000030637760b ffffffc0ed8e701d 0000000000000000 ffffffc0                                                     ed5a0a20
  297. [    2.370565] 3ce0: ffffffc0ed630000 0000000200001000 00000000000000d6 00000000                                                     00000000
  298. [    2.371244] 3d00: ffffffc0ed313d08 00000000ffffff9c 00000000ffffff9c ffffff80                                                     090ee000
  299. [    2.371924] 3d20: 00000055c36b6d00 0000000000000000 ffffffc0ed313d80 ffffff80                                                     081b3658
  300. [    2.372603] 3d40: 0000000000000000 00000000ffffff9c 00000000ffffff9c 00000055                                                     c36b6d00
  301. [    2.373282] 3d60: ffffffc0ed313e58 ffffffc0ed8e7000 0000000000000000 ffffff9c                                                     00000002
  302. [    2.373961] 3d80: ffffffc0ed313dc0 ffffff80081a99e8 0000000000000000 00000000                                                     ffffffea
  303. [    2.374640] 3da0: ffffffc0ed60f058 00000055c36b6d00 ffffffc0ed313e10 00000000                                                     00000000
  304. [    2.375319] 3dc0: ffffffc0ed313e20 ffffff80081a9ea4 0000007fe41fb2f0 ffffffff                                                     ffffff9c
  305. [    2.375998] 3de0: ffffffffffffffff 0000007fb68a261c 0000000080000000 ffffff80                                                     081ae4c8
  306. [    2.376678] 3e00: ffffffc0ed313eb0 0000000000000100 ffffffc0ed313e30 ffffff80                                                     081a9fdc
  307. [    2.377357] 3e20: 0000000000000000 ffffff80080826f0 0000000000000000 00000055                                                     c36b6cb4
  308. [    2.378036] 3e40: 00000055c36b6d00 0000000000000100 ffffffffffffffff 0000007f                                                     b68a46e8
  309. [    2.378715] 3e60: 0000000060000000 0000000000000015 000000000000011d 00000000                                                     0000004e
  310. [    2.379394] 3e80: ffffff8008bc2000 ffffff80080826f0 0000000000000000 00000000                                                     00000063
  311. [    2.380073] 3ea0: 0000000000000000 00000000e41fb330 ffffffc0edaac020 ffffffc0                                                     ed60f000
  312. [    2.380752] 3ec0: ffffffffffffff9c 00000055c36b6d00 0000007fe41fb2f0 00000000                                                     00000100
  313. [    2.381431] 3ee0: 00000055c36b6d00 0000000000001011 00000055c36b6d01 00000000                                                     00000003
  314. [    2.382110] 3f00: 000000000000004f 0000007fb692a9a0 aa82000000000000 00000000                                                     00040004
  315. [    2.382789] 3f20: 0000000000000000 ffffffff00000000 000000ff02010100 00000000                                                     00000080
  316. [    2.383469] 3f40: 0000007fb692a008 0000007fb685b230 0000000000000a03 00000055                                                     c36b6cb1
  317. [    2.384148] 3f60: 00000055c36b6cb4 00000055c36b7d00 0000000000000000 0000007f                                                     e41fb2f0
  318. [    2.384827] 3f80: 000000000000002f 00000055c36b6d04 00000055c36b6d00 00000055                                                     c36b6d00
  319. [    2.385506] 3fa0: 0000000000000003 0000007fe41fb280 0000007fb68269cc 0000007f                                                     e41fb280
  320. [    2.386185] 3fc0: 0000007fb68a261c 0000000080000000 ffffffffffffff9c 00000000                                                     0000004f
  321. [    2.386864] 3fe0: 0000000000000000 0000000000000000 0000000000000000 00000000                                                     00000000
  322. [    2.387542] Call trace:
  323. [    2.387757] Exception stack(0xffffffc0ed3139c0 to 0xffffffc0ed313af0)
  324. [    2.388316] 39c0: ffffffc0ee5b8718 0000008000000000 ffffffc0ed313b90 00000000                                                     00000000
  325. [    2.388995] 39e0: ffffffc0ed313a00 ffffff8008bab068 ffffffc0ef0ec080 ffffff80                                                     0819cef4
  326. [    2.389674] 3a00: ffffffc0ed313b00 ffffff800819d004 0000000000000140 ffffffc0                                                     ef0e9100
  327. [    2.390353] 3a20: 00000000024000c0 ffffff80081bab68 ffffffc0edde2000 0000007f                                                     e41fb410
  328. [    2.391032] 3a40: 00000055c36b6a50 00000000fffffffe 00000000ffffffea ffffffc0                                                     ed310000
  329. [    2.391711] 3a60: ffffffc0ed2d4980 0000000000000005 00000000000000d6 ffffff80                                                     090e5000
  330. [    2.392390] 3a80: 0000000000000000 0000000000000003 0000000000000fe4 00000055                                                     c36b6d00
  331. [    2.393069] 3aa0: fefefefefefefeff ffffffc0ed8e701c 0000000000000000 00000000                                                     00040004
  332. [    2.393748] 3ac0: 0000000000000000 ffffffff00000000 000000ff02010100 00000000                                                     00000080
  333. [    2.394426] 3ae0: ffffff80081a9e6c 0000007fb685b230
  334. [    2.394850] [<          (null)>]           (null)
  335. [    2.395263] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  336. [    2.395780] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  337. [    2.396234] [<ffffff80081b0f1c>] complete_walk+0x48/0x94
  338. [    2.396696] [<ffffff80081b21a8>] path_lookupat+0xc4/0x120
  339. [    2.397165] [<ffffff80081b3508>] filename_lookup+0x6c/0xc8
  340. [    2.397642] [<ffffff80081b3670>] user_path_at_empty+0x54/0x60
  341. [    2.398142] [<ffffff80081a99e8>] vfs_fstatat+0x74/0xc0
  342. [    2.398589] [<ffffff80081a9ea4>] SyS_newfstatat+0x38/0x58
  343. [    2.399060] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  344. [    2.399522] Code: bad PC value
  345. [    2.399830] ---[ end trace 9960da25090fce5d ]---
  346. [    9.291374] BUG: spinlock lockup suspected on CPU#4, systemctl/250
  347. [    9.291921]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
  348. [    9.292649] CPU: 4 PID: 250 Comm: systemctl Tainted: G      D         4.4.55 #1
  349. [    9.293283] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  350. [    9.293925] Call trace:
  351. [    9.294148] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  352. [    9.294619] [<ffffff8008088368>] show_stack+0x20/0x28
  353. [    9.295061] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  354. [    9.295502] [<ffffff80080e2d88>] spin_dump+0x88/0x94
  355. [    9.295934] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
  356. [    9.296435] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  357. [    9.296905] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  358. [    9.297421] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  359. [    9.297875] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  360. [    9.298359] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  361. [    9.298821] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  362. [    9.299276] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  363. [    9.299737] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  364. [    9.300177] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  365. [    9.306388] BUG: spinlock lockup suspected on CPU#3, systemd-udevd/254
  366. [    9.306973]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
  367. [    9.307658] BUG: spinlock lockup suspected on CPU#1, systemd-udevd/260
  368. [    9.307662]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
  369. [    9.307667] CPU: 1 PID: 260 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
  370. [    9.307669] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  371. [    9.307671] Call trace:
  372. [    9.307678] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  373. [    9.307683] [<ffffff8008088368>] show_stack+0x20/0x28
  374. [    9.307688] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  375. [    9.307692] [<ffffff80080e2d88>] spin_dump+0x88/0x94
  376. [    9.307695] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
  377. [    9.307700] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  378. [    9.307706] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  379. [    9.307711] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  380. [    9.307714] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  381. [    9.307718] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  382. [    9.307721] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  383. [    9.307725] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  384. [    9.307728] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  385. [    9.307732] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  386. [    9.308909] BUG: spinlock lockup suspected on CPU#2, systemd/1
  387. [    9.308913]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
  388. [    9.308917] CPU: 2 PID: 1 Comm: systemd Tainted: G      D         4.4.55 #1
  389. [    9.308918] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  390. [    9.308919] Call trace:
  391. [    9.308923] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  392. [    9.308927] [<ffffff8008088368>] show_stack+0x20/0x28
  393. [    9.308930] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  394. [    9.308934] [<ffffff80080e2d88>] spin_dump+0x88/0x94
  395. [    9.308937] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
  396. [    9.308940] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  397. [    9.308943] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  398. [    9.308946] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  399. [    9.308949] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  400. [    9.308952] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  401. [    9.308955] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  402. [    9.308958] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  403. [    9.308960] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  404. [    9.308963] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  405. [    9.312359] BUG: spinlock lockup suspected on CPU#0, systemd-udevd/261
  406. [    9.312364]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
  407. [    9.312367] CPU: 0 PID: 261 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
  408. [    9.312369] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  409. [    9.312370] Call trace:
  410. [    9.312374] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  411. [    9.312377] [<ffffff8008088368>] show_stack+0x20/0x28
  412. [    9.312381] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  413. [    9.312384] [<ffffff80080e2d88>] spin_dump+0x88/0x94
  414. [    9.312387] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
  415. [    9.312390] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  416. [    9.312393] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  417. [    9.312396] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  418. [    9.312399] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  419. [    9.312402] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  420. [    9.312405] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  421. [    9.312408] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  422. [    9.312410] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  423. [    9.312413] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  424. [    9.335524] CPU: 3 PID: 254 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
  425. [    9.336190] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  426. [    9.336832] Call trace:
  427. [    9.337050] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  428. [    9.337522] [<ffffff8008088368>] show_stack+0x20/0x28
  429. [    9.337964] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  430. [    9.338406] [<ffffff80080e2d88>] spin_dump+0x88/0x94
  431. [    9.338840] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
  432. [    9.339342] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  433. [    9.339815] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  434. [    9.340330] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  435. [    9.340787] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  436. [    9.341274] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  437. [    9.341738] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  438. [    9.342195] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  439. [    9.342659] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  440. [    9.343101] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  441. [    9.426198] BUG: spinlock lockup suspected on CPU#5, systemd-udevd/258
  442. [    9.426768]  lock: 0xffffffc0ee5b8718, .magic: dead4ead, .owner: udevadm/241, .owner_cpu: 5
  443. [    9.427499] CPU: 5 PID: 258 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
  444. [    9.428163] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  445. [    9.428804] Call trace:
  446. [    9.429019] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  447. [    9.429490] [<ffffff8008088368>] show_stack+0x20/0x28
  448. [    9.429929] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  449. [    9.430369] [<ffffff80080e2d88>] spin_dump+0x88/0x94
  450. [    9.430801] [<ffffff80080e2f28>] do_raw_spin_lock+0x104/0x158
  451. [    9.431300] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  452. [    9.431770] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  453. [    9.432284] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  454. [    9.432738] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  455. [    9.433222] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  456. [    9.433684] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  457. [    9.434137] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  458. [    9.434599] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  459. [    9.435038] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  460. [   28.137891] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 23s! [systemd-udevd:261]
  461. [   28.137894] NMI watchdog: BUG: soft lockup - CPU#1 stuck for 23s! [systemd-udevd:260]
  462. [   28.137901] Modules linked in:
  463. [   28.137902]
  464. [   28.137906] CPU: 1 PID: 260 Comm: systemd-udevd Tainted: G      D         4.4.55 #1
  465. [   28.137908] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  466. [   28.137910] task: ffffffc0eb44e200 ti: ffffffc0ed350000 task.ti: ffffffc0ed350000
  467. [   28.137915] PC is at do_raw_spin_lock+0x128/0x158
  468. [   28.137918] LR is at do_raw_spin_lock+0x104/0x158
  469. [   28.137920] pc : [<ffffff80080e2f4c>] lr : [<ffffff80080e2f28>] pstate: 00000145
  470. [   28.137921] sp : ffffffc0ed353b20
  471. [   28.137926] x29: ffffffc0ed353b20 x28: ffffffc0ed350000
  472. [   28.137929] x27: ffffff8008bc2000 x26: 0000000000000038
  473. [   28.137932] x25: 000000000000011d x24: 0000000000000030
  474. [   28.137935] x23: 0000000000000000 x22: ffffffc0ee5b86c0
  475. [   28.137938] x21: 00000000016e3600 x20: 00000000016e3600
  476. [   28.137941] x19: ffffffc0ee5b8718 x18: 0000000000000a03
  477. [   28.137944] x17: 0000007f7bce8230 x16: ffffff80081a4304
  478. [   28.137947] x15: 0000000000000048 x14: 0ffffffffffffffd
  479. [   28.137951] x13: 0000000000000038 x12: 0101010101010101
  480. [   28.137954] x11: ff7f7f7f7f7f7f7f x10: fdff333376ff2f60
  481. [   28.137957] x9 : 7f7f7f7f7f7f7f7f x8 : ffffff8009255e34
  482. [   28.137960] x7 : 0000000000000001 x6 : ffffffc0f7efd060
  483. [   28.137963] x5 : 0000000000000000 x4 : ffffffc0ed353e90
  484. [   28.137966] x3 : ffffffc0ed353fe0 x2 : 00000000000064ae
  485. [   28.137969] x1 : 000000000000001e x0 : 0000000064b064ae
  486. [   28.137972]
  487. [   28.137972] PC: 0xffffff80080e2ecc:
  488. [   28.137981] 2ecc  900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0 f9800271
  489. [   28.137989] 2eec  885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0 d2800020
  490. [   28.137997] 2f0c  910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77 f9800271
  491. [   28.138005] 2f2c  885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf d503205f
  492. [   28.138013] 2f4c  485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5 f9400800
  493. [   28.138021] 2f6c  f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3
  494. [   28.138028] 2f8c  aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021 88007e61
  495. [   28.138036] 2fac  35ffff60 6b1f001f 1a9f17e0 340000c0 d5384101 b9401c22 b9000a62 f9400821
  496. [   28.138038]
  497. [   28.138038] LR: 0xffffff80080e2ea8:
  498. [   28.138047] 2ea8  97ffffbb f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60
  499. [   28.138054] 2ec8  34000480 900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0
  500. [   28.138062] 2ee8  f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0
  501. [   28.138070] 2f08  d2800020 910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77
  502. [   28.138078] 2f28  f9800271 885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf
  503. [   28.138086] 2f48  d503205f 485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5
  504. [   28.138094] 2f68  f9400800 f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3
  505. [   28.138102] 2f88  aa0003f3 aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021
  506. [   28.138104]
  507. [   28.138104] SP: 0xffffffc0ed353aa0:
  508. [   28.138112] 3aa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
  509. [   28.138119] 3ac0  00000038 00000000 08bc2000 ffffff80 ed350000 ffffffc0 ed353b20 ffffffc0
  510. [   28.138127] 3ae0  080e2f28 ffffff80 ed353b20 ffffffc0 080e2f4c ffffff80 00000145 00000000
  511. [   28.138135] 3b00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
  512. [   28.138143] 3b20  ed353b50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
  513. [   28.138151] 3b40  00000000 00000000 081af0e4 ffffff80 ed353b70 ffffffc0 08392990 ffffff80
  514. [   28.138159] 3b60  ee5b8718 ffffffc0 081b08e8 ffffff80 ed353b90 ffffffc0 081b0914 ffffff80
  515. [   28.138167] 3b80  ed353d40 ffffffc0 00000000 00000000 ed353bd0 ffffffc0 081b1dfc ffffff80
  516. [   28.138169]
  517. [   28.138169] X3: 0xffffffc0ed353f60:
  518. [   28.138178] 3f60  5b054210 00000055 00000008 00000000 00000001 00000000 5b08c000 00000055
  519. [   28.138185] 3f80  5b08b000 00000055 ce10cb50 0000007f ce10cb40 0000007f 88a42c70 00000055
  520. [   28.138193] 3fa0  88a3c950 00000055 ce10c7d0 0000007f 7bce0b60 0000007f ce10c7d0 0000007f
  521. [   28.138201] 3fc0  7bd2fa90 0000007f 80000000 00000000 ffffff9c ffffffff 00000038 00000000
  522. [   28.138209] 3fe0  00000000 00000000 00000000 00000000 00ff00ff 00ff00ff 00ff00ff 00ff00ff
  523. [   28.138217] 4000  40646461 7375622f 616c702f 726f6674 72642f6d 72657669 6f722f73 68636b63
  524. [   28.138225] 4020  642d7069 43410070 4e4f4954 6464613d 56454400 48544150 75622f3d 6c702f73
  525. [   28.138233] 4040  6f667461 642f6d72 65766972 722f7372 636b636f 2d706968 53007064 59534255
  526. [   28.138235]
  527. [   28.138235] X4: 0xffffffc0ed353e10:
  528. [   28.138243] 3e10  ed353e80 ffffffc0 081a4340 ffffff80 ffffff9c ffffffff 5b054210 00000055
  529. [   28.138250] 3e30  ffffffff ffffffff 7bd2fa90 0000007f 80000000 00000000 00000015 00000000
  530. [   28.138258] 3e50  ed353e70 ffffffc0 ce10ca80 0000007f ed353e70 ffffffc0 00020000 ffff0000
  531. [   28.138266] 3e70  00000024 00000100 00000001 ffffff80 00000000 00000000 080826f0 ffffff80
  532. [   28.138274] 3e90  00000000 00000000 00000007 00000000 00000000 00000000 ce10ca80 0000007f
  533. [   28.138282] 3eb0  00080000 00000000 00000000 00000000 ffffff9c ffffffff ce10ca80 0000007f
  534. [   28.138289] 3ed0  00080000 00000000 00000000 00000000 00000008 00000000 00080000 00000000
  535. [   28.138297] 3ef0  5b054212 00000055 5b054216 00000055 00000038 00000000 7f7f7f7f 7f7f7f7f
  536. [   28.138299]
  537. [   28.138299] X6: 0xffffffc0f7efcfe0:
  538. [   28.138307] cfe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  539. [   28.138315] d000  edccf940 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
  540. [   28.138322] d020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  541. [   28.138330] d040  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  542. [   28.138337] d060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  543. [   28.138345] d080  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  544. [   28.138353] d0a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  545. [   28.138360] d0c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  546. [   28.138362]
  547. [   28.138362] X8: 0xffffff8009255db4:
  548. [   28.138370] 5db4  302f3037 38303278 2ac8aaf6 00000002 0029003c 82000000 66663c5b 66666666
  549. [   28.138378] 5dd4  38303038 33346131 5d3e3034 53795320 65706f5f 2b74616e 63337830 3478302f
  550. [   28.138386] 5df4  00000038 2ac8b9c6 00000002 002c003c 82000000 66663c5b 66666666 38303038
  551. [   28.138394] 5e14  36323830 5d3e3066 306c6520 6376735f 6b616e5f 302b6465 2f343278 38327830
  552. [   28.138402] 5e34  2adab014 00000002 00320044 06000000 3a475542 69707320 636f6c6e 6f6c206b
  553. [   28.138409] 5e54  70756b63 73757320 74636570 6f206465 5043206e 2c322355 73797320 646d6574
  554. [   28.138417] 5e74  0000312f 2adac12b 00000002 004f0060 06000000 636f6c20 30203a6b 66666678
  555. [   28.138425] 5e94  63666666 35656530 31373862 2e202c38 6967616d 64203a63 34646165 2c646165
  556. [   28.138429]
  557. [   28.138429] X16: 0xffffff80081a4284:
  558. [   28.138437] 4284  2a0403e5 9400f465 2a1503e0 aa1303e1 94007125 aa1403e0 93407eb4 94003bc6
  559. [   28.138444] 42a4  aa1403e0 a94153f3 a9425bf5 a94363f7 a8c77bfd d65f03c0 a9bd7bfd 910003fd
  560. [   28.138452] 42c4  a90153f3 f90013f5 aa0003f5 aa1e03e0 aa0103f4 aa0203f3 d503201f aa1503e1
  561. [   28.138461] 42e4  320f0282 2a1303e3 12800c60 97ffff71 f94013f5 a94153f3 a8c37bfd d65f03c0
  562. [   28.138469] 4304  a9bc7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 f90017a1 f9001ba2 f9001fa3
  563. [   28.138476] 4324  d503201f f9401ba2 2a1303e0 f94017a1 f9401fa3 320f0042 97ffff5e f9400bf3
  564. [   28.138484] 4344  a8c47bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa1e03e0 aa0103f3
  565. [   28.138492] 4364  d503201f 2a1303e2 aa1403e0 52804821 97ffffd2 a94153f3 a8c27bfd d65f03c0
  566. [   28.138495]
  567. [   28.138495] X19: 0xffffffc0ee5b8698:
  568. [   28.138502] 8698  ee5ba408 ffffffc0 ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000
  569. [   28.138510] 86b8  00000000 00000000 00200000 00000002 00000000 00000000 00000000 00000000
  570. [   28.138518] 86d8  ee5b86c0 ffffffc0 00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0
  571. [   28.138526] 86f8  0000002f dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
  572. [   28.138534] 8718  64b564ae dead4ead 00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000
  573. [   28.138542] 8738  00000000 00000000 edde2000 ffffffc0 00000000 dead4ead ef0ee000 ffffffc0
  574. [   28.138549] 8758  ee5b8758 ffffffc0 ee5b8758 ffffffc0 ee5b8768 ffffffc0 ee5b8768 ffffffc0
  575. [   28.138557] 8778  ee5e2408 ffffffc0 ee5b8840 ffffffc0 00000000 00000000 ed630148 ffffffc0
  576. [   28.138560]
  577. [   28.138560] X22: 0xffffffc0ee5b8640:
  578. [   28.138567] 8640  00030003 dead4ead ffffffff ffffffc0 ffffffff ffffffff 00000000 ffffffc0
  579. [   28.138577] 8660  00000000 00000000 ede0b800 ffffffc0 00000000 00000000 00000000 00000000
  580. [   28.138586] 8680  ee5ba4d0 ffffffc0 ee5b85a8 ffffffc0 eec0e330 ffffffc0 ee5ba408 ffffffc0
  581. [   28.138594] 86a0  ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000 00000000 00000000
  582. [   28.138602] 86c0  00200000 00000002 00000000 00000000 00000000 00000000 ee5b86c0 ffffffc0
  583. [   28.138610] 86e0  00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0 0000002f dead4ead
  584. [   28.138619] 8700  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 64b564ae dead4ead
  585. [   28.138626] 8720  00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000 00000000 00000000
  586. [   28.138629]
  587. [   28.138629] X27: 0xffffff8008bc1f80:
  588. [   28.138637] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  589. [   28.138645] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  590. [   28.138652] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  591. [   28.138660] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  592. [   28.138668] 2000  081e9718 ffffff80 081e9fac ffffff80 081ea550 ffffff80 081ea590 ffffff80
  593. [   28.138676] 2020  081ea6fc ffffff80 081c88f8 ffffff80 081c894c ffffff80 081c89a0 ffffff80
  594. [   28.138684] 2040  081c8a38 ffffff80 081c8a80 ffffff80 081c8ac8 ffffff80 081c8b40 ffffff80
  595. [   28.138692] 2060  081c8b80 ffffff80 081c8bc0 ffffff80 081c8c30 ffffff80 081c8c6c ffffff80
  596. [   28.138694]
  597. [   28.138694] X28: 0xffffffc0ed34ff80:
  598. [   28.138702] ff80  00000018 00000000 88a42b48 00000055 00000003 00000000 88a50600 00000055
  599. [   28.138710] ffa0  0000000e 00000000 ce10cc40 0000007f 5b01bd18 00000055 ce10cc40 0000007f
  600. [   28.138718] ffc0  7bd3c240 0000007f 60000000 00000000 00000004 00000000 00000016 00000000
  601. [   28.138725] ffe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  602. [   28.138733] 0000  00000002 00000000 ffffffff ffffffff eb44e200 ffffffc0 00010000 00000001
  603. [   28.138741] 0020  57ac6e9d 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  604. [   28.138748] 0040  00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
  605. [   28.138756] 0060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  606. [   28.138758]
  607. [   28.138758] X29: 0xffffffc0ed353aa0:
  608. [   28.138766] 3aa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
  609. [   28.138773] 3ac0  00000038 00000000 08bc2000 ffffff80 ed350000 ffffffc0 ed353b20 ffffffc0
  610. [   28.138781] 3ae0  080e2f28 ffffff80 ed353b20 ffffffc0 080e2f4c ffffff80 00000145 00000000
  611. [   28.138789] 3b00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
  612. [   28.138797] 3b20  ed353b50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
  613. [   28.138805] 3b40  00000000 00000000 081af0e4 ffffff80 ed353b70 ffffffc0 08392990 ffffff80
  614. [   28.138813] 3b60  ee5b8718 ffffffc0 081b08e8 ffffff80 ed353b90 ffffffc0 081b0914 ffffff80
  615. [   28.138821] 3b80  ed353d40 ffffffc0 00000000 00000000 ed353bd0 ffffffc0 081b1dfc ffffff80
  616. [   28.138821]
  617. [   28.138826] Kernel panic - not syncing: softlockup: hung tasks
  618. [   28.138830] CPU4: stopping
  619. [   28.138833] CPU: 4 PID: 250 Comm: systemctl Tainted: G      D      L  4.4.55 #1
  620. [   28.138834] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  621. [   28.138835] Call trace:
  622. [   28.138837] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  623. [   28.138839] [<ffffff8008088368>] show_stack+0x20/0x28
  624. [   28.138841] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  625. [   28.138844] [<ffffff800808d944>] handle_IPI+0x134/0x240
  626. [   28.138845] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  627. [   28.138847] Exception stack(0xffffffc0f7f40000 to 0xffffffc0f7f40130)
  628. [   28.138849] 0000: ffffffc0eb4639f0 0000008000000000 ffffffc0eb463b20 ffffff80080e2f4c
  629. [   28.138851] 0020: 0000000000000145 0000000000000030 ffffffc0f7f3c060 0000000000000000
  630. [   28.138853] 0040: ffffffc0eb463b20 ffffffc0eb4639f0 0000000000000000 0000000000000000
  631. [   28.138854] 0060: ffffffc0ed2d5ea0 0000000000000000 0000000000000000 0000000000000000
  632. [   28.138856] 0080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  633. [   28.138858] 00a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  634. [   28.138859] 00c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  635. [   28.138861] 00e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  636. [   28.138862] 0100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  637. [   28.138864] 0120: 0000000000000000 0000000000000000
  638. [   28.138866] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  639. [   28.138868] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
  640. [   28.138869] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  641. [   28.138871] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  642. [   28.138873] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  643. [   28.138875] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  644. [   28.138876] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  645. [   28.138878] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  646. [   28.138880] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  647. [   28.138881] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  648. [   28.138883] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  649. [   28.138884] CPU5: stopping
  650. [   28.138887] CPU: 5 PID: 258 Comm: systemd-udevd Tainted: G      D      L  4.4.55 #1
  651. [   28.138888] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  652. [   28.138888] Call trace:
  653. [   28.138891] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  654. [   28.138893] [<ffffff8008088368>] show_stack+0x20/0x28
  655. [   28.138895] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  656. [   28.138897] [<ffffff800808d944>] handle_IPI+0x134/0x240
  657. [   28.138898] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  658. [   28.138900] Exception stack(0xffffffc0f7f55000 to 0xffffffc0f7f55130)
  659. [   28.138902] 5000: ffffffc0eb4b39f0 0000008000000000 ffffffc0eb4b3b20 ffffff80080e2f4c
  660. [   28.138904] 5020: 0000000000000145 0000000000000030 ffffffc0f7f51060 0000000000000000
  661. [   28.138905] 5040: ffffffc0eb4b3b20 ffffffc0eb4b39f0 0000000000000000 0000000000000000
  662. [   28.138907] 5060: ffffffc0eb44dea0 0000000000000000 0000000000000000 0000000000000000
  663. [   28.138908] 5080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  664. [   28.138910] 50a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  665. [   28.138911] 50c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  666. [   28.138913] 50e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  667. [   28.138915] 5100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  668. [   28.138916] 5120: 0000000000000000 0000000000000000
  669. [   28.138917] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  670. [   28.138919] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
  671. [   28.138921] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  672. [   28.138923] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  673. [   28.138925] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  674. [   28.138927] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  675. [   28.138929] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  676. [   28.138930] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  677. [   28.138932] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  678. [   28.138933] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  679. [   28.138935] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  680. [   28.138938] CPU2: stopping
  681. [   28.138943] CPU: 2 PID: 1 Comm: systemd Tainted: G      D      L  4.4.55 #1
  682. [   28.138945] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  683. [   28.138945] Call trace:
  684. [   28.138950] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  685. [   28.138953] [<ffffff8008088368>] show_stack+0x20/0x28
  686. [   28.138957] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  687. [   28.138961] [<ffffff800808d944>] handle_IPI+0x134/0x240
  688. [   28.138964] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  689. [   28.138967] Exception stack(0xffffffc0f7f16000 to 0xffffffc0f7f16130)
  690. [   28.138971] 6000: ffffffc0ef1179f0 0000008000000000 ffffffc0ef117b20 ffffff80080e2f4c
  691. [   28.138974] 6020: 0000000000000145 0000000000000030 ffffffc0f7f12060 0000000000000000
  692. [   28.138978] 6040: ffffffc0ef117b20 ffffffc0ef1179f0 0000000000000000 0000000000000000
  693. [   28.138980] 6060: ffffffc0ef2088e0 0000000000000000 0000000000000000 0000000000000000
  694. [   28.138984] 6080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  695. [   28.138987] 60a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  696. [   28.138990] 60c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  697. [   28.138992] 60e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  698. [   28.138995] 6100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  699. [   28.138998] 6120: 0000000000000000 0000000000000000
  700. [   28.139001] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  701. [   28.139004] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
  702. [   28.139007] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  703. [   28.139011] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  704. [   28.139013] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  705. [   28.139017] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  706. [   28.139020] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  707. [   28.139022] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  708. [   28.139025] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  709. [   28.139028] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  710. [   28.139031] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  711. [   28.139033] CPU3: stopping
  712. [   28.139037] CPU: 3 PID: 254 Comm: systemd-udevd Tainted: G      D      L  4.4.55 #1
  713. [   28.139038] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  714. [   28.139039] Call trace:
  715. [   28.139043] [<ffffff8008088190>] dump_backtrace+0x0/0x1b8
  716. [   28.139047] [<ffffff8008088368>] show_stack+0x20/0x28
  717. [   28.139050] [<ffffff8008386eb8>] dump_stack+0x8c/0xac
  718. [   28.139053] [<ffffff800808d944>] handle_IPI+0x134/0x240
  719. [   28.139056] [<ffffff8008080e60>] gic_handle_irq+0x130/0x188
  720. [   28.139059] Exception stack(0xffffffc0f7f2b000 to 0xffffffc0f7f2b130)
  721. [   28.139062] b000: ffffffc0ed3179f0 0000008000000000 ffffffc0ed317b20 ffffff80080e2f4c
  722. [   28.139066] b020: 0000000000000145 0000000000000030 ffffffc0f7f27060 0000000000000000
  723. [   28.139069] b040: ffffffc0ed317b20 ffffffc0ed3179f0 0000000000000000 0000000000000000
  724. [   28.139072] b060: ffffffc0eb44ada0 0000000000000000 0000000000000000 0000000000000000
  725. [   28.139075] b080: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  726. [   28.139078] b0a0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  727. [   28.139081] b0c0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  728. [   28.139084] b0e0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  729. [   28.139087] b100: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
  730. [   28.139089] b120: 0000000000000000 0000000000000000
  731. [   28.139092] [<ffffff8008081fb4>] el1_irq+0xb4/0x140
  732. [   28.139095] [<ffffff80080e2f4c>] do_raw_spin_lock+0x128/0x158
  733. [   28.139098] [<ffffff8008baaf98>] _raw_spin_lock+0x20/0x2c
  734. [   28.139102] [<ffffff8008392990>] lockref_get_not_dead+0x14/0x44
  735. [   28.139105] [<ffffff80081b0914>] unlazy_walk+0xc0/0x16c
  736. [   28.139108] [<ffffff80081b1dfc>] link_path_walk+0x240/0x4a0
  737. [   28.139111] [<ffffff80081b2718>] path_openat+0x2b0/0xc5c
  738. [   28.139114] [<ffffff80081b3e14>] do_filp_open+0x48/0x94
  739. [   28.139117] [<ffffff80081a4224>] do_sys_open+0x170/0x208
  740. [   28.139119] [<ffffff80081a4340>] SyS_openat+0x3c/0x48
  741. [   28.139122] [<ffffff80080826f0>] el0_svc_naked+0x24/0x28
  742. [   28.294977] Modules linked in:
  743. [   28.295246]
  744. [   28.295381] CPU: 0 PID: 261 Comm: systemd-udevd Tainted: G      D      L  4.4.55 #1
  745. [   28.296046] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
  746. [   28.296690] task: ffffffc0eb44ee40 ti: ffffffc0eb4c8000 task.ti: ffffffc0eb4c8000
  747. [   28.297342] PC is at do_raw_spin_lock+0x128/0x158
  748. [   28.297753] LR is at do_raw_spin_lock+0x104/0x158
  749. [   28.298164] pc : [<ffffff80080e2f4c>] lr : [<ffffff80080e2f28>] pstate: 00000145
  750. [   28.298807] sp : ffffffc0eb4cbb20
  751. [   28.299097] x29: ffffffc0eb4cbb20 x28: ffffffc0eb4c8000
  752. [   28.299564] x27: ffffff8008bc2000 x26: 0000000000000038
  753. [   28.300031] x25: 000000000000011d x24: 0000000000000030
  754. [   28.300498] x23: 0000000000000000 x22: ffffffc0ee5b86c0
  755. [   28.300965] x21: 00000000016e3600 x20: 00000000016e3600
  756. [   28.301432] x19: ffffffc0ee5b8718 x18: 0000000000000a03
  757. [   28.301899] x17: 0000007f7bce8230 x16: ffffff80081a4304
  758. [   28.302365] x15: 0000000000000058 x14: 0ffffffffffffffd
  759. [   28.302832] x13: 0000000000000038 x12: 0101010101010101
  760. [   28.303298] x11: 7f7f7f7f7f7f7f7f x10: 52ff333376ff2f60
  761. [   28.303766] x9 : 7f7f7f7f7f7f7f7f x8 : ffffff80092567cc
  762. [   28.304232] x7 : 0000000000000000 x6 : ffffffc0f7ee8060
  763. [   28.304699] x5 : 0000000000000000 x4 : ffffffc0eb4cbe90
  764. [   28.305167] x3 : ffffffc0eb4cbfe0 x2 : 00000000000064ae
  765. [   28.305633] x1 : 000000000000001c x0 : 0000000064b264ae
  766. [   28.306100]
  767. [   28.306100] PC: 0xffffff80080e2ecc:
  768. [   28.306533] 2ecc  900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0 f9800271
  769. [   28.307267] 2eec  885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0 d2800020
  770. [   28.308000] 2f0c  910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77 f9800271
  771. [   28.308734] 2f2c  885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf d503205f
  772. [   28.309467] 2f4c  485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5 f9400800
  773. [   28.310200] 2f6c  f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3 aa0003f3
  774. [   28.310934] 2f8c  aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021 88007e61
  775. [   28.311668] 2fac  35ffff60 6b1f001f 1a9f17e0 340000c0 d5384101 b9401c22 b9000a62 f9400821
  776. [   28.312402]
  777. [   28.312402] LR: 0xffffff80080e2ea8:
  778. [   28.312835] 2ea8  97ffffbb f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60
  779. [   28.313568] 2ec8  34000480 900080a0 d2807d14 d2800015 f946dc00 9b147c14 eb1402bf 540001a0
  780. [   28.314302] 2ee8  f9800271 885ffe61 4ac14020 35000080 11404021 88007e61 35ffff60 340002a0
  781. [   28.315035] 2f08  d2800020 910006b5 940a8a4c 17fffff3 d0006ac1 aa1303e0 9116c821 97ffff77
  782. [   28.315770] 2f28  f9800271 885ffe60 11404001 88027e61 35ffffa2 4ac04001 340000c1 d50320bf
  783. [   28.316504] 2f48  d503205f 485ffe62 4a404041 35ffffa1 d5384100 b9401c01 b9000a61 f94013f5
  784. [   28.317237] 2f68  f9400800 f9000a60 a94153f3 a8c37bfd d65f03c0 a9be7bfd 910003fd f9000bf3
  785. [   28.317970] 2f88  aa0003f3 aa1e03e0 d503201f f9800271 885ffe61 4ac14020 35000080 11404021
  786. [   28.318704]
  787. [   28.318704] SP: 0xffffffc0eb4cbaa0:
  788. [   28.319137] baa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
  789. [   28.319870] bac0  00000038 00000000 08bc2000 ffffff80 eb4c8000 ffffffc0 eb4cbb20 ffffffc0
  790. [   28.320604] bae0  080e2f28 ffffff80 eb4cbb20 ffffffc0 080e2f4c ffffff80 00000145 00000000
  791. [   28.321337] bb00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
  792. [   28.322070] bb20  eb4cbb50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
  793. [   28.322803] bb40  00000000 00000000 081af0e4 ffffff80 eb4cbb70 ffffffc0 08392990 ffffff80
  794. [   28.323537] bb60  ee5b8718 ffffffc0 081b08e8 ffffff80 eb4cbb90 ffffffc0 081b0914 ffffff80
  795. [   28.324270] bb80  eb4cbd40 ffffffc0 00000000 00000000 eb4cbbd0 ffffffc0 081b1dfc ffffff80
  796. [   28.325005]
  797. [   28.325005] X3: 0xffffffc0eb4cbf60:
  798. [   28.325439] bf60  5b054210 00000055 00000008 00000000 00000001 00000000 5b08c000 00000055
  799. [   28.326171] bf80  5b08b000 00000055 ce10cb50 0000007f ce10cb40 0000007f 88a52470 00000055
  800. [   28.326905] bfa0  88a42c70 00000055 ce10c7c0 0000007f 7bce0b60 0000007f ce10c7c0 0000007f
  801. [   28.327637] bfc0  7bd2fa90 0000007f 80000000 00000000 ffffff9c ffffffff 00000038 00000000
  802. [   28.328372] bfe0  00000000 00000000 00000000 00000000 91011f39 910046e1 927df320 910006e2
  803. [   28.329105] c000  00000000 00000000 00000000 00000080 eb4d0000 ffffffc0 00000000 00000001
  804. [   28.329838] c020  57ac6e9d 00000000 7661652c 72647365 273d706f 65757274 00000027 00000000
  805. [   28.330571] c040  732f2e2e 732f6372 65726168 63612f64 74752d6c 632e6c69 00000000 00000000
  806. [   28.331305]
  807. [   28.331305] X4: 0xffffffc0eb4cbe10:
  808. [   28.331738] be10  eb4cbe80 ffffffc0 081a4340 ffffff80 ffffff9c ffffffff 5b054210 00000055
  809. [   28.332471] be30  ffffffff ffffffff 7bd2fa90 0000007f 80000000 00000000 00000015 00000000
  810. [   28.333204] be50  eb4cbe70 ffffffc0 ce10ca70 0000007f eb4cbe70 ffffffc0 00020000 ffff0000
  811. [   28.333937] be70  00000024 00000100 00000001 ffffff80 00000000 00000000 080826f0 ffffff80
  812. [   28.334670] be90  00000000 00000000 00000007 00000000 00000000 00000000 ce10ca70 0000007f
  813. [   28.335403] beb0  00080000 00000000 00000000 00000000 ffffff9c ffffffff ce10ca70 0000007f
  814. [   28.336136] bed0  00080000 00000000 00000000 00000000 00000008 00000000 00080000 00000000
  815. [   28.336869] bef0  5b054212 00000055 5b054216 00000055 00000038 00000000 7bdb79a0 0000007f
  816. [   28.337603]
  817. [   28.337603] X6: 0xffffffc0f7ee7fe0:
  818. [   28.338035] 7fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  819. [   28.338767] 8000  edccf780 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
  820. [   28.339499] 8020  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  821. [   28.340230] 8040  00005dc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  822. [   28.340962] 8060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  823. [   28.341693] 8080  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  824. [   28.342424] 80a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  825. [   28.343156] 80c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  826. [   28.343888]
  827. [   28.343888] X8: 0xffffff800925674c:
  828. [   28.344321] 674c  302f3037 38303278 2b101c83 00000002 0029003c 82000000 66663c5b 66666666
  829. [   28.345055] 676c  38303038 33346131 5d3e3034 53795320 65706f5f 2b74616e 63337830 3478302f
  830. [   28.345789] 678c  00000038 2b1027e8 00000002 002c003c 82000000 66663c5b 66666666 38303038
  831. [   28.346523] 67ac  36323830 5d3e3066 306c6520 6376735f 6b616e5f 302b6465 2f343278 38327830
  832. [   28.347256] 67cc  2c70cc6f 00000002 00470058 86000000 3a555043 50203320 203a4449 20343532
  833. [   28.347989] 67ec  6d6d6f43 7973203a 6d657473 64752d64 20647665 6e696154 3a646574 20204720
  834. [   28.348722] 680c  20202020 20202044 20202020 2e342020 35352e34 00312320 2c7af45f 00000002
  835. [   28.349456] 682c  00440054 86000000 64726148 65726177 6d616e20 52203a65 636b636f 20706968
  836. [   28.350192]
  837. [   28.350192] X16: 0xffffff80081a4284:
  838. [   28.350633] 4284  2a0403e5 9400f465 2a1503e0 aa1303e1 94007125 aa1403e0 93407eb4 94003bc6
  839. [   28.351367] 42a4  aa1403e0 a94153f3 a9425bf5 a94363f7 a8c77bfd d65f03c0 a9bd7bfd 910003fd
  840. [   28.352101] 42c4  a90153f3 f90013f5 aa0003f5 aa1e03e0 aa0103f4 aa0203f3 d503201f aa1503e1
  841. [   28.352835] 42e4  320f0282 2a1303e3 12800c60 97ffff71 f94013f5 a94153f3 a8c37bfd d65f03c0
  842. [   28.353568] 4304  a9bc7bfd 910003fd f9000bf3 aa0003f3 aa1e03e0 f90017a1 f9001ba2 f9001fa3
  843. [   28.354302] 4324  d503201f f9401ba2 2a1303e0 f94017a1 f9401fa3 320f0042 97ffff5e f9400bf3
  844. [   28.355035] 4344  a8c47bfd d65f03c0 a9be7bfd 910003fd a90153f3 aa0003f4 aa1e03e0 aa0103f3
  845. [   28.355770] 4364  d503201f 2a1303e2 aa1403e0 52804821 97ffffd2 a94153f3 a8c27bfd d65f03c0
  846. [   28.356505]
  847. [   28.356505] X19: 0xffffffc0ee5b8698:
  848. [   28.356946] 8698  ee5ba408 ffffffc0 ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000
  849. [   28.357678] 86b8  00000000 00000000 00200000 00000002 00000000 00000000 00000000 00000000
  850. [   28.358410] 86d8  ee5b86c0 ffffffc0 00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0
  851. [   28.359143] 86f8  0000002f dead4ead ffffffff 00000000 ffffffff ffffffff 00000000 00000000
  852. [   28.359877] 8718  64b564ae dead4ead 00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000
  853. [   28.360609] 8738  00000000 00000000 edde2000 ffffffc0 00000000 dead4ead ef0ee000 ffffffc0
  854. [   28.361342] 8758  ee5b8758 ffffffc0 ee5b8758 ffffffc0 ee5b8768 ffffffc0 ee5b8768 ffffffc0
  855. [   28.362076] 8778  ee5e2408 ffffffc0 ee5b8840 ffffffc0 00000000 00000000 ed630148 ffffffc0
  856. [   28.362812]
  857. [   28.362812] X22: 0xffffffc0ee5b8640:
  858. [   28.363252] 8640  00030003 dead4ead ffffffff ffffffc0 ffffffff ffffffff 00000000 ffffffc0
  859. [   28.363986] 8660  00000000 00000000 ede0b800 ffffffc0 00000000 00000000 00000000 00000000
  860. [   28.364719] 8680  ee5ba4d0 ffffffc0 ee5b85a8 ffffffc0 eec0e330 ffffffc0 ee5ba408 ffffffc0
  861. [   28.365453] 86a0  ee5b86a0 ffffffc0 ee5b86a0 ffffffc0 00000000 00000000 00000000 00000000
  862. [   28.366186] 86c0  00200000 00000002 00000000 00000000 00000000 00000000 ee5b86c0 ffffffc0
  863. [   28.366919] 86e0  00000000 00000001 ee5b86f8 ffffffc0 ed630000 ffffffc0 0000002f dead4ead
  864. [   28.367653] 8700  ffffffff 00000000 ffffffff ffffffff 00000000 00000000 64b564ae dead4ead
  865. [   28.368386] 8720  00000005 00000000 ed2d4980 ffffffc0 0000000a 00000000 00000000 00000000
  866. [   28.369121]
  867. [   28.369121] X27: 0xffffff8008bc1f80:
  868. [   28.369561] 1f80  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  869. [   28.370293] 1fa0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  870. [   28.371025] 1fc0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  871. [   28.371757] 1fe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  872. [   28.372489] 2000  081e9718 ffffff80 081e9fac ffffff80 081ea550 ffffff80 081ea590 ffffff80
  873. [   28.373223] 2020  081ea6fc ffffff80 081c88f8 ffffff80 081c894c ffffff80 081c89a0 ffffff80
  874. [   28.373956] 2040  081c8a38 ffffff80 081c8a80 ffffff80 081c8ac8 ffffff80 081c8b40 ffffff80
  875. [   28.374689] 2060  081c8b80 ffffff80 081c8bc0 ffffff80 081c8c30 ffffff80 081c8c6c ffffff80
  876. [   28.375423]
  877. [   28.375423] X28: 0xffffffc0eb4c7f80:
  878. [   28.375864] 7f80  eb4aa738 ffffffc0 eda823c8 ffffffc0 00000001 00000000 eb4c7f98 ffffffc0
  879. [   28.376597] 7fa0  eb4c7f98 ffffffc0 00000000 00000000 08be2a98 ffffff80 00000000 00000000
  880. [   28.377330] 7fc0  ed2cb680 ffffffc0 00000000 00000000 97fefb94 35000420 3940f282 b9403a80
  881. [   28.378063] 7fe0  121e7842 f9400e81 3900f282 a900fe9f f900129f 17ffff3f 12800bc0 17ffff4b
  882. [   28.378796] 8000  00000002 00000000 ffffffff ffffffff eb44ee40 ffffffc0 00010000 00000000
  883. [   28.379530] 8020  57ac6e9d 00000000 17ffffd5 00000000 a9ad7bfd 910003fd a90153f3 900001d3
  884. [   28.380262] 8040  f90013f5 a91093a3 a9119ba5 f90097a7 f9440263 3d8023a0 3d8027a1 3d802ba2
  885. [   28.380995] 8060  f9400064 f9003fa4 d2800004 3d802fa3 3d8033a4 3d8037a5 3d803ba6 3d803fa7
  886. [   28.381730]
  887. [   28.381730] X29: 0xffffffc0eb4cbaa0:
  888. [   28.382171] baa0  ee5b86c0 ffffffc0 00000000 00000000 00000030 00000000 0000011d 00000000
  889. [   28.382903] bac0  00000038 00000000 08bc2000 ffffff80 eb4c8000 ffffffc0 eb4cbb20 ffffffc0
  890. [   28.383636] bae0  080e2f28 ffffff80 eb4cbb20 ffffffc0 080e2f4c ffffff80 00000145 00000000
  891. [   28.384370] bb00  ee5b8718 ffffffc0 016e3600 00000000 00000000 00000080 08e3c5b2 ffffff80
  892. [   28.385102] bb20  eb4cbb50 ffffffc0 08baaf98 ffffff80 ee5b8718 ffffffc0 00000000 00000000
  893. [   28.385835] bb40  00000000 00000000 081af0e4 ffffff80 eb4cbb70 ffffffc0 08392990 ffffff80
  894. [   28.386568] bb60  ee5b8718 ffffffc0 081b08e8 ffffff80 eb4cbb90 ffffffc0 081b0914 ffffff80
  895. [   28.387301] bb80  eb4cbd40 ffffffc0 00000000 00000000 eb4cbbd0 ffffffc0 081b1dfc ffffff80
  896. [   28.388035]
  897. [   29.305496] SMP: failed to stop secondary CPUs
  898. [   29.305887] CRU:
  899. [   29.306058] 00000000: 0000003f 00001101 80000000 00000108 00000007 00007f00 00000000 00000000
  900. [   29.306804] 00000020: 00000053 00001101 80000000 00000108 00000007 00007f00 00000000 00000000
  901. [   29.307551] 00000040: 00000037 00001201 8000031f 00000108 00000007 00007f00 00000000 00000000
  902. [   29.308297] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
  903. [   29.309043] 00000080: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
  904. [   29.309789] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
  905. [   29.310535] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
  906. [   29.311281] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  907. [   29.312027] 00000100: 00000100 00000707 00000140 00006909 00000083 00008581 00008320 00000141
  908. [   29.312773] 00000120: 00000181 00008181 00000141 00000141 00004141 00008362 00003185 00000107
  909. [   29.313519] 00000140: 0000041d 00000300 00004a87 00000113 00009381 00008387 00001103 00001087
  910. [   29.314265] 00000160: 00008247 00000187 00001743 0000001f 00000380 00000380 00000380 00000000
  911. [   29.315011] 00000180: 00006380 00009200 00000200 00000200 00000200 00000200 00003f3f 00000081
  912. [   29.315757] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000005 00000381
  913. [   29.316503] 000001c0: 00000381 00000001 00000003 00000087 00000087 00000141 00000141 00008181
  914. [   29.317249] 000001e0: 0000833f 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
  915. [   29.317995] 00000200: 000000cf 000000cf 00000000 00000000 00000000 00000000 00000000 00000000
  916. [   29.318740] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  917. [   29.319486] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  918. [   29.320231] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  919. [   29.320978] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
  920. [   29.321724] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
  921. [   29.322469] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  922. [   29.323215] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  923. [   29.323961] 00000300: 00000080 00000080 00000202 0000006b 00000c30 00000000 0000001c 000001c0
  924. [   29.324707] 00000320: 0000fff8 0000f0ff 0000f0ff 0000c1b0 0000004a 0000e233 00000000 00000000
  925. [   29.325453] 00000340: 00000505 00000505 00001000 00000000 00000e04 00000000 0000cfeb 00003f00
  926. [   29.326199] 00000360: 0000ef60 00000020 00000ffe 000001f0 000000cc 00000f86 00000d0a 000001b8
  927. [   29.326945] 00000380: 00002010 00000000 00000028 00000000 00000000 00000000 00000000 00000000
  928. [   29.327691] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  929. [   29.328436] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  930. [   29.329181] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  931. [   29.329927] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  932. [   29.330672] 00000420: 00000000 00004070 00000000 00000014 00000000 00000000 00000000 00000000
  933. [   29.331419] 00000440: 00000000 00000000 00000000 00000000 00001000 00000000 00000000 00000000
  934. [   29.332164] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  935. [   29.332910] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  936. [   29.333656] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  937. [   29.334402] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  938. [   29.335147] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  939. [   29.335893] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 00000000 00000000
  940. [   29.336639] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  941. [   29.337384] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  942. [   29.338130] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  943. [   29.338874] 00000580: 00000004 00000000 00000004 0000098c 00000004
  944. [   29.339411] PMU CRU:
  945. [   29.339611] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
  946. [   29.340359] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  947. [   29.341106] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  948. [   29.341854] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  949. [   29.342602] 00000080: 0000070d 00001986 00000d0d 0000000d 000002dc 00000200 0bb8ea60 0bb8ea60
  950. [   29.343349] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  951. [   29.344097] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  952. [   29.344844] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
  953. [   29.345591] 00000100: 00000efc 0000fb80 0000000f 00000000 00000024 00000000 00000000 00000000
  954. [   29.346336] 00000120: 00000000 00000180 00000000 00000000 00000000
  955. [   29.346875] Kernel Offset: disabled
  956. [   29.347180] Memory Limit: none
  957. [   29.347456] rockchip-thermal ff260000.tsadc: channal 0: temperature(31 C)
  958. [   29.348047] THERMAL REGS:
  959. [   29.348283] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 00000000 00000000
  960. [   29.349030] 00000020: 00000213 0000020b 00000000 00000000 0000024e 00000000 00000000 00000000
  961. [   29.349777] 00000040: 00000279 00000279 00000000 00000000 00000000 00000000 00000000 00000000
  962. [   29.350523] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000
  963. [   29.351265] 00000080: 00000000 00000000
  964. [   29.351603] ---[ end Kernel panic - not syncing: softlockup: hung tasks
Copy the code
Posted at 7/17/2017 19:13:25        Only Author  8#
I make Lower Format before flashing and Ubuntu loaded, network worked some time and hang.   After reboot I got black screen again and permanently lit blue LED.  Where can I download worked firware?
super moderator
Rank: 8Rank: 8
Posted at 7/18/2017 10:06:44        Only Author  9#
please flash these images with the tool "upgrade_tool" in linux
http://wiki.t-firefly.com/index. ... lash_image/en#Linux
Posted at 7/18/2017 19:14:24        Only Author  10#
No effect. Ubuntu stop before loading
Mounting Fuse Control File System...
I think my kernel is too fresh for the other firmware images.
Please, make a new version of firware with network fix or give me yours kernel.img and resource.img for test.
Return to List
123
