Can't get into loader mode
2
Posted at 11/24/2014 01:49:37        Only Author  1#
Hi,
I have a Firefly RK3288 board and can't seem to get it into loader
mode.
I'm doing this from Linux, I have the rkflashkit gui running. From
the device being in a powered on state, I've tried both the following
as noted from
http://wiki.t-firefly.com/index.php/Fir ... #Boot_Mode.
  • Keep device power on.
  • Use micro USB OTG cable to connect host and device together.
  • Press and hold RECOVERY key.
  • Shortly press RESET key.
  • Release RECOVERY key.
  • Note:If device still can not be found after pressing "RESET", then try this: long press "PWRKEY" after short pressing of "RESET", before finally releasing "RECOVERY".
As soon as I press the reset key the device powers off, after a few seconds it
powers back on but in normal boot mode.
Any idea's what I'm doing wrong? Does it matter if the JTAG/serial cable is
connected? I've tried it both with and without.
Cheers,
Andrew
Posted at 11/24/2014 02:25:27        Only Author  2#
Err, hang on, I've just tried using the cable from my phone and it seems to
be working!
Posted at 11/25/2014 14:09:58        Only Author  3#
you can try the following steps:
1.make sure you have installed the driver.
2. Keep device power off
3.Use micro USB OTG cable to connect host and device together.
4.Press and hold RECOVERY key.
5.power on the device
Until discover the device on your computer,then you can Release RECOVERY key.
Posted at 12/1/2014 17:33:52        Only Author  4#
Short remark:
From RK3188 I learned that it might take some seconds (3...5) until the Loader has started the USB and connected the driver on the PC side. So releasing the button to early may result in the Loader is going to power off again.?
So a general rule should be:
Press RECOVERY, power on or press and release?RESET, take a deep breath, wait another few seconds and then release RECOVERY.
If you're still not sure if the Loader has connected to your Linux box:
Call "tail -f /var/log/kern.log" and you can see if the device does register.
Astralix, Crewrktablets
Posted at 12/3/2014 00:54:33        Only Author  5#
Thanks for the replies...
I was trying to connect a USB OTG adaptor to the USB OTG port. No, No, No.
Cheers,
Andrew
Posted at 2/10/2026 23:49:04        Only Author  6#
경쟁율이 치열한 IT업계에서 아무런 목표없이 아무런 희망없이 무미건조한 생활을 하고 계시나요? 다른 사람들이 모두 취득하고 있는 자격증에 관심도 없는 분은 치열한 경쟁속에서 살아남기 어렵습니다. Cisco인증 300-835시험패스가 힘들다한들Fast2test덤프만 있으면 어려운 시험도 쉬워질수 밖에 없습니다. Cisco인증 300-835덤프에 있는 문제만 잘 이해하고 습득하신다면Cisco인증 300-835시험을 패스하여 자격증을 취득해 자신의 경쟁율을 업그레이드하여 경쟁시대에서 안전감을 보유할수 있습니다.
Posted at 4/19/2026 13:51:39        Only Author  7#
This article has truly inspired me, thank you for sharing it! Get free CAS-005 exam registration to improve your IT knowledge. Wishing you all the best!
