Power Connector Size?
15
Posted at 12/18/2014 09:23:15        Only Author  11#
Echoa:
The Firefly is internally protected at the dc plug with a 3 Amp fusible link.? So if pull over 3 amps on the board?you will be?learning?how to solder a new power plug on the board.? Look at the schematics third page power supply upper right hand corner.
Ah ok, ty for the info
4amp shouldnt be a problem do you think? could you link me the 3amp you used?
edit: Nevermind found one
Posted at 12/18/2014 09:49:34        Only Author  12#
For anyone in the States looking for a 5v 3amp Power supply here is one
http://tinyurl.com/otmztok
and a usb adapter for it
http://www.adafruit.com/products/988
Outside US Aliexpress has them
http://tinyurl.com/note2uc
im not sure where to get the usb plug anywhere but adafruit though
Posted at 12/18/2014 16:44:05        Only Author  13#
so, is it right a power adapter with a standard 1.7x4.0 mm dc plug in line?
http://www.ebay.it/itm/360674178616
Please....
Posted at 12/19/2014 04:03:04        Only Author  14#
That was the size of the plug I ordered from EBAY with my new power supply and it worked perfectly.? Are you sure you need this or are you ordering your first one.? As I have mentioned I am not a normal user of the power for a normal user and the 2.5 amp if you have one should be fine.? Me I power everything from the board and with my pins in and pins out at times looks like noodle soup.
Posted at 12/19/2014 04:48:55        Only Author  15#
Im going to be attempting some heavy overclocking and using it as a micro console and media machine so itll see some decent loads so i want to make sure i dont have any power issues. Right now the highest i have is a 2.1amp which will have to work till i can order the 3amp plug.?
Return to List
12
High mode
B Color Image Link Quote Code Smilies |Upload
