Is this problem kernel configuration?
Posted at 2/8/2018 10:50:29
Hi all.
I am trying to build my custom dual boot image.
I built u-boot, kernel and android5.1 and flashed RK3288UbootLoader.bin, boot.img, system.img.
Before I execute the script "lollipop/mkimage.sh", I modified two lines.
TARGET="withoutkernel" -> TARGET="ota"
PARAMETER=FFTools/parameter/rk3288-3.10-uboot-android.parameter.txt -> PARAMETER=FFTools/parameter/rk3288-3.10-uboot-dual.parameter.txt
But the kernel seemed to that can't load android image.
My kernel log as below.
DDR Version 1.00 20160530
In
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel b: DDR3 200MHz
Memory OK
Memory OK
OUT
U-Boot 2014.10-RK3288-10 (Feb 08 2018 - 10:51:58)
CPU: rk3288
cpu version = 0
CPU's clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
Board: Rockchip platform Board
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000080000000)
128 MiB
GIC CPU mask = 0x00000001
remotectl v0.1
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
Using default environment
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
pmic:act8846
can't find dts node for pwm1
DCDC vdd_logic has been used, pwm regulator not init it.
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2018-02-08#2.30
empty serial no.
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
read logo on state from dts [0]
no fuel gauge found
checkKey
vbus = 1
Hit any key to stop autoboot: 3 2 1 0
Secure Boot state: 0
kernel @ 0x02000000 (0x006f70d8)
ramdisk @ 0x05bf0000 (0x00146474)
bootrk: do_bootm_linux...
Loading Device Tree to 05600000, end 0561c06a ... OK
Add bank:0000000000000000, 0000000080000000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x500
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.0 (gykim@gykim) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #29 SMP PREEMPT Tue Feb 6 15:09:48 KST 2018
[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
[ 0.000000] hdmi init vic is -1
[ 0.000000] ion heap(drm): base(0) size(0) align(0)
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1fb6000 s13312 r8192 d15360 u36864
[ 0.000000] Kernel command line: vmalloc=496M console=tty0 console=ttyS2 earlyprintk androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00620000@0x0059C000(linuxroot),-@0x00BBC000(user) storagemedia=emmc loader.timestamp=2018-02-08_10:51:58 hdmi.vic=-1 tve.format=-1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 2048MB = 2048MB total
[ 0.000000] Memory: 2025816k/2025816k available, 71336k reserved, 1556480K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0c3f6c0 (12510 kB)
[ 0.000000] .init : 0xc0c40000 - 0xc0c9a400 ( 361 kB)
[ 0.000000] .data : 0xc0c9c000 - 0xc0e37040 (1645 kB)
[ 0.000000] .bss : 0xc0e37040 - 0xc0f5bd9c (1172 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:12
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:10
[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.499093] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.499124] pid_max: default: 32768 minimum: 301
[ 0.499245] Security Framework initialized
[ 0.499269] SELinux: Initializing.
[ 0.499349] Mount-cache hash table entries: 512
[ 0.500004] Initializing cgroup subsys debug
[ 0.500027] Initializing cgroup subsys memory
[ 0.500061] Initializing cgroup subsys freezer
[ 0.500099] CPU: Testing write buffer coherency: ok
[ 0.500427] /cpus/cpu@0 missing clock-frequency property
[ 0.500452] /cpus/cpu@1 missing clock-frequency property
[ 0.500470] /cpus/cpu@2 missing clock-frequency property
[ 0.500487] /cpus/cpu@3 missing clock-frequency property
[ 0.500550] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.500609] Setting up static identity map for 0xc08dbae0 - 0xc08dbb38
[ 0.502922] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17f5 (version 3.1)
[ 0.576617] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.596276] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.615985] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.616086] Brought up 4 CPUs
[ 0.616150] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.616168] CPU: All CPU(s) started in SVC mode.
[ 0.616907] devtmpfs: initialized
[ 0.621688] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.622796] pinctrl core: initialized pinctrl subsystem
[ 0.623060] regulator-dummy: no parameters
[ 0.637022] NET: Registered protocol family 16
[ 0.639022] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.639422] ion_snapshot: 0x1e9e8000 map to 0xe0907000 and copy to 0xc0f3454c (version 0.1)
[ 0.639660] Registered FIQ tty driver
[ 0.640049] fiq-debugger is disabled in device tree
[ 0.653059] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.653090] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.653666] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.679937] bio: create slab <bio-0> at 0
[ 0.680435] Rockchip hdmi driver version 2.0
[ 0.680435] .
[ 0.681587] SCSI subsystem initialized
[ 0.681759] usbcore: registered new interface driver usbfs
[ 0.681819] usbcore: registered new interface driver hub
[ 0.681916] usbcore: registered new device driver usb
[ 0.686607] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.687272] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.687731] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.687992] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.688438] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.688567] media: Linux media interface: v0.10
[ 0.688616] Linux video capture interface: v2.00
[ 0.688687] pps_core: LinuxPPS API ver. 1 registered
[ 0.688705] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.688739] PTP clock support registered
[ 0.688805] i2c-core: driver [bq24296] using legacy suspend method
[ 0.688825] i2c-core: driver [bq24296] using legacy resume method
[ 0.689641] Rockchip ion module is successfully loaded (v1.1)
[ 0.689810] Advanced Linux Sound Architecture Driver Initialized.
[ 0.690220] Bluetooth: Core ver 2.16
[ 0.690286] NET: Registered protocol family 31
[ 0.690305] Bluetooth: HCI device and connection manager initialized
[ 0.690331] Bluetooth: HCI socket layer initialized
[ 0.690351] Bluetooth: L2CAP socket layer initialized
[ 0.690386] Bluetooth: SCO socket layer initialized
[ 0.690624] cfg80211: Calling CRDA to update world regulatory domain
[ 0.694890] act_dcdc1: 1200 mV
[ 0.697870] vccio: 3300 mV
[ 0.699723] vdd_logic: 700 <--> 1500 mV at 1100 mV
[ 0.702665] act_dcdc4: 2000 mV
[ 0.703895] vccio_sd: 1800 <--> 3300 mV at 3300 mV
[ 0.706197] act_ldo2: 1050 mV
[ 0.708498] act_ldo3: 3300 mV
[ 0.710794] act_ldo4: 3300 mV
[ 0.713095] act_ldo5: 3300 mV
[ 0.715430] act_ldo6: 1100 mV
[ 0.717735] vcc_18: 1800 mV
[ 0.720025] act_ldo8: 1850 mV
[ 0.724760] vdd_arm: 712 <--> 1500 mV at 1000 mV
[ 0.729441] vdd_gpu: 712 <--> 1500 mV at 1000 mV
[ 0.731606] rk808: probe of 0-001b failed with error -11
[ 0.731689] i2c-core: driver [rk818] using legacy suspend method
[ 0.731709] i2c-core: driver [rk818] using legacy resume method
[ 0.733640] Switching to clocksource arch_sys_counter
[ 0.757433] rga: Module initialized.
[ 0.758166] rga2 ff920000.rga: rga ion client create success!
[ 0.758338] rga: Driver loaded succesfully
[ 0.758537] fb disp policy is box
[ 0.758604] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.758626] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.758968] rk-screen rk_screen.8: rockchip screen probe success
[ 0.759210] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.759575] rk32-edp ff970000.edp: screen is not edp!
[ 0.759603] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.760084] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0
[ 0.760323] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.760643] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.760818] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.760998] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.761283] vop ver:3007236,unsupport output color:1
[ 0.761423] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.761456] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.778148] alloc_buffer:ion_phy_addr=0x7f000000
[ 0.789095] fb0:phy:7f000000>>vir:e0971000>>len:0x1000000
[ 0.789123] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 0.789325] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1
[ 0.789348] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.789589] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.789919] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.790100] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.790281] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.790512] unknow screen type: 0
[ 0.790532] vop ver:3007236,unsupport output color:1
[ 0.790589] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:60
[ 0.790611] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.790630] fb4:phy:7f000000>>vir:e0971000>>len:0x1000000
[ 0.790650] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 0.801214] tc358749_hdmiin_probe!
[ 0.860495] tc358749_hdmiin_probe OK!
[ 0.861011] NET: Registered protocol family 2
[ 0.861722] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.861811] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.861893] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.861962] TCP: reno registered
[ 0.861984] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.862016] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.862219] NET: Registered protocol family 1
[ 0.862502] RPC: Registered named UNIX socket transport module.
[ 0.862525] RPC: Registered udp transport module.
[ 0.862541] RPC: Registered tcp transport module.
[ 0.862557] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.863170] Unpacking initramfs...
[ 0.932508] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 0.933470] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.934034] vcodec_service: probe device ff9a0000.vpu_service
[ 0.934249] vcodec_service: No reset resource define
[ 0.934387] vcodec_service: ff9a0000.vpu_service: power on
[ 0.934481] vcodec_service: probe device ff9a0000.vpu_service
[ 0.934507] vcodec_service: checking hw id 4831
[ 0.935054] vcodec_service: ff9a0000.vpu_service: power off...
[ 0.935108] vcodec_service: done
[ 0.935128] vcodec_service: init success
[ 0.935195] vcodec_service: probe device ff9c0000.hevc_service
[ 0.935530] vcodec_service: ff9c0000.hevc_service: power on
[ 0.935601] vcodec_service: probe device ff9c0000.hevc_service
[ 0.935626] vcodec_service: checking hw id 6867
[ 0.935883] vcodec_service: ff9c0000.hevc_service: power off...
[ 0.935929] vcodec_service: done
[ 0.935947] vcodec_service: init success
[ 0.936224] rknand: probe of ff400000.nandc failed with error -1
[ 0.937571] audit: initializing netlink socket (disabled)
[ 0.937652] type=2000 audit(0.430:1): initialized
[ 0.943199] NFS: Registering the id_resolver key type
[ 0.943268] Key type id_resolver registered
[ 0.943286] Key type id_legacy registered
[ 0.943313] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.943870] fuse init (API version 7.22)
[ 0.944260] msgmni has been set to 951
[ 0.946107] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.946141] io scheduler noop registered
[ 0.946157] io scheduler deadline registered
[ 0.946254] io scheduler cfq registered (default)
[ 0.947477] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.949066] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.949097] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.950490] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.950520] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.950828] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 0.950859] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 0.950901] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 0.951346] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.951551] serial ff180000.serial: membase e1972000
[ 0.951725] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.951900] serial ff190000.serial: membase e197e000
[ 0.952049] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.953450] console [ttyS2] enabled
[ 0.953628] serial ff690000.serial: membase fed60000
[ 0.953826] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.954050] serial ff1b0000.serial: membase e1992000
[ 0.956854] loop: module loaded
[ 0.957238] zram: Created 1 device(s) ...
[ 0.957333] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.957356] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.957383] mpu_init: Probe name mpu6050B1
[ 0.957545] ak8963_mod_init: Probe name ak8963_mod
[ 0.958257] SCSI Media Changer driver v0.25
[ 0.958588] tun: Universal TUN/TAP device driver, 1.6
[ 0.958611] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.959309] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.959338] stmmac_probe_config_dt: clock input/output? (input).
[ 0.959360] stmmac_probe_config_dt: TX delay(0x30).
[ 0.959379] stmmac_probe_config_dt: RX delay(0x20).
[ 0.959436] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.959455] stmmc_pltfr_init:
[ 0.959470] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.959501] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.959521] stmmc_pltfr_init: init for RGMII
[ 0.959539] tx delay=0x30
[ 0.959539] rx delay=0x20
[ 0.959565] tx delay=0x30
[ 0.959565] rx delay=0x20
[ 0.960073] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.960095] Normal descriptors
[ 0.960110] Ring mode enabled
[ 0.960125] DMA HW capability register supported
[ 0.960143] RX Checksum Offload Engine supported (type 2)
[ 0.960164] TX Checksum insertion supported
[ 0.960180] Wake-Up On Lan supported
[ 0.960234] Enable RX Mitigation via HW Watchdog Timer
[ 0.960693] PPP generic driver version 2.4.2
[ 0.960846] PPP BSD Compression module registered
[ 0.960875] PPP Deflate Compression module registered
[ 0.960907] PPP MPPE Compression module registered
[ 0.960927] NET: Registered protocol family 24
[ 0.960973] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.961002rnia.
[ 0.961198] usbcore: registered new interface driver catc
[ 0.961250] usbcore: registered new interface driver kaweth
[ 0.961272] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.961324] usbcore: registered new interface driver pegasus
[ 0.961372] usbcore: registered new interface driver rtl8150
[ 0.961421] usbcore: registered new interface driver r8152
[ 0.961440] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.961525] usbcore: registered new interface driver hso
[ 0.961578] usbcore: registered new interface driver asix
[ 0.961628] usbcore: registered new interface driver ax88179_178a
[ 0.961677] usbcore: registered new interface driver cdc_ether
[ 0.961724] usbcore: registered new interface driver cdc_eem
[ 0.961772] usbcore: registered new interface driver dm9601
[ 0.961819] usbcore: registered new interface driver dm9620
[ 0.961881] usbcore: registered new interface driver smsc75xx
[ 0.961938] usbcore: registered new interface driver smsc95xx
[ 0.961986] usbcore: registered new interface driver gl620a
[ 0.962034] usbcore: registered new interface driver net1080
[ 0.962081] usbcore: registered new interface driver plusb
[ 0.962130] usbcore: registered new interface driver rndis_host
[ 0.962182] usbcore: registered new interfaerface driver zaurus
[ 0.962280] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.962356] usbcore: registered new interface driver int51x1
[ 0.962406] usbcore: registered new interface driver kalmia
[ 0.962454] usbcore: registered new interface driver ipheth
[ 0.962505] usbcore: registered new interface driver sierra_net
[ 0.962560] usbcore: registered new interface driver cx82310_eth
[ 0.962618] usbcore: registered new interface driver cdc_ncm
[ 0.962668] usbcore: registered new interface driver qmi_wwan
[ 0.962716] usbcore: registered new interface driver cdc_mbim
[ 0.962738] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.965195] EHCI: ehci_rk_probe e1a40000 e1a40010
[ 0.965222] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.965263] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.965636] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.979734] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.979830] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.979857] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.979884] usb usb1: Product: EHCI Host Controller
[ 0.979905] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.979925] usb usb1: SerialNumber: ff500000.usb
[ 0.980374] hub 1-0:1.0: USB hub found
[ 0.980407] hub 1-0:1.0: 1 port detected
[ 0.980587] EHCI: ehci_rk_probe ok
[ 0.980701] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.981002] usbcore: registered new interface driver cdc_acm
[ 0.981025] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.981094] usbcore: registered new interface driver usblp
[ 0.981152] usbcore: registered new interface driver cdc_wdm
[ 0.981229] usbcore: registered new interface driver usb-storage
[ 0.981280] usbcore: registered new interface driver ums-alauda
[ 0.981328] usbcore: registered new interface driver ums-cypress
[ 0.981377] usbcore: registered new interface driver ums-datafab
[ 0.981425] usbcore: registered new interface driver ums_eneub6250
[ 0.981474] usbcore: registered new interface driver ums-freecom
[ 0.981523] usbcore: registered new interface driver ums-isd200
[ 0.981576] usbcore: registered new interface driver ums-jumpshot
[ 0.981626] usbcore: registered new interface driver ums-karma
[ 0.981676] usbcore: registered new interface driver ums-onetouch
[ 0.981726] usbcore: registered new interface driver ums-sddr09
[ 0.981775] usbcore: registered new interface driver ums-sddr55
[ 0.981825] usbcore: registered new interface driver ums-usbat
[ 0.981928] usbcore: registered new interface driver usbserial
[ 0.981979] usbcore: registered new interface driver usbserial_generic
[ 0.982022] usbserial: USB Serial support registered for generic
[ 0.982079] usbcore: registered new interface driver option
[ 0.982122] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.982227] usbcore: registered new interface driver trancevibrator
[ 0.982250] usb20_otg: version 3.10a 21-DEC-2012
[ 0.983044] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.983084] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.983129] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.983198] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.983224] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.983251] usb usb2: Product: DWC OTG Controller
[ 0.983271] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.983293] usb usb2: SerialNumber: ff580000.usb
[ 0.983709] hub 2-0:1.0: USB hub found
[ 0.983742] hub 2-0:1.0: 1 port detected
[ 0.984059] usb20_host: version 3.10a 21-DEC-2012
[ 0.986765] usb20_host ff540000.usb: DWC OTG Controller
[ 0.986803] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.986845] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.987001] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.987028] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.987053] usb usb3: Product: DWC OTG Controller
[ 0.987073] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.987094] usb usb3: SerialNumber: ff540000.usb
[ 0.987486] hub 3-0:1.0: USB hub found
[ 0.987516] hub 3-0:1.0: 1 port detected
[ 0.988216] usbcore: registered new interface driver xpad
[ 0.988287] usbcore: registered new interface driver usb_acecad
[ 0.988350] usbcore: registered new interface driver aiptek
[ 0.988407] usbcore: registered new interface driver gtco
[ 0.988465] usbcore: registered new interface driver hanwang
[ 0.988520] usbcore: registered new interface driver kbtab
[ 0.988584] usbcore: registered new interface driver wacom
[ 0.989119] .. rk pwm remotectl v1.1 init
[ 0.989373] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 0.994455] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 0.995085] i2c /dev entries driver
[ 0.995785] IR NEC protocol handler initialized
[ 0.995809] IR RC5(x) protocol handler initialized
[ 0.995827] IR RC6 protocol handler initialized
[ 0.995844] IR JVC protocol handler initialized
[ 0.995862] IR Sony protocol handler initialized
[ 0.995879] IR RC5 (streamzap) protocol handler initialized
[ 0.995898] IR SANYO protocol handler initialized
[ 0.995915] IR MCE Keyboard/mouse protocol handler initialized
[ 0.996082] usbcore: registered new interface driver uvcvideo
[ 0.996104] USB Video Class driver (1.1.1)
[ 0.999660] i2c-core: driver [bq27320] using legacy suspend method
[ 0.999690] i2c-core: driver [bq27320] using legacy resume method
[ 1.058443] tsadc ff280000.tsadc: initialized
[ 1.058819] device-mapper: uevent: version 1.0.3
[ 1.059086] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.059395] Bluetooth: HCI UART driver ver 2.2
[ 1.059419] Bluetooth: HCI H4 protocol initialized
[ 1.059439] Bluetooth: HCILL protocol initialized
[ 1.059457] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.059479] rtk_btusb: Register usb char device interface for BT driver
[ 1.059682] usbcore: registered new interface driver rtk_btusb
[ 1.060350] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.064672] cpuidle: using governor ladder
[ 1.064695] cpuidle: using governor menu
[ 1.064740] Synopsys Designware Multimedia Card Interface Driver
[ 1.064761] MHSC version = Ver 2.00 2015-06-10
[ 1.065089] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.065142] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.065472] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.097867] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.097904] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.098252] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.098313] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.099014] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.099738] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.129958] mmc0: BKOPS_EN bit is not set
[ 1.134115] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.134169] [mmc0] tuning regsbase addr 0x218.
[ 1.134736] [mmc0] Data transmission error !!!! MINTSTS: [0x00002000]
[ 1.134752] [mmc0] host was already tuning, Don't need to retry tune again ignore 0.
[ 1.134780] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 1.134816] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.134868] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.135106] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-180 (17 len)
[ 1.135125] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len)
[ 1.135143] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-180 (17 len)
[ 1.135159] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90
[ 1.135209] mmc0: new HS200 MMC card at address 0001
[ 1.135498] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
[ 1.135621] mmcblk0rpmb: mmc0:0001 AGND3R partition 3 4.00 MiB
[ 1.135932] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 1.135950] misc: 0x000800000 -- 0x000c00000 (4 MB)
[ 1.135965] resource: 0x000c00000 -- 0x001c00000 (16 MB)
[ 1.135980] kernel: 0x001c00000 -- 0x002c00000 (16 MB)
[ 1.135993] boot: 0x002c00000 -- 0x004c00000 (32 MB)
[ 1.136007] recovery: 0x004c00000 -- 0x006c00000 (32 MB)
[ 1.136021] backup: 0x006c00000 -- 0x00a000000 (52 MB)
[ 1.136034] cache: 0x00a000000 -- 0x012000000 (128 MB)
[ 1.136049] kpanic: 0x012000000 -- 0x012400000 (4 MB)
[ 1.136062] system: 0x012400000 -- 0x072400000 (1536 MB)
[ 1.136076] metadata: 0x072400000 -- 0x073400000 (16 MB)
[ 1.136090] baseparamer: 0x073400000 -- 0x073800000 (4 MB)
[ 1.136104] userdata: 0x073800000 -- 0x0b3800000 (1024 MB)
[ 1.136117] linuxroot: 0x0b3800000 -- 0x177800000 (3136 MB)
[ 1.136132] user: 0x177800000 -- 0x3a3a00000 (8898 MB)
[ 1.136170] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15[ 1.137202] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.137232] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.137554] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.137599] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.137855] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
1358..dw_mci_set_ios: no card. [mmc1]
[ 1.176556] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.176580] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.176868] leds-gpio leds.27: pins are not configured from the driver
[ 1.177143] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.178599] usbcore: registered new interface driver usbhid
[ 1.178618] usbhid: USB HID core driver
[ 1.178741] ashmem: initialized
[ 1.178860] logger: created 256K log 'log_main'
[ 1.178959] logger: created 256K log 'log_events'
[ 1.179058] logger: created 256K log 'log_radio'
[ 1.179164] logger: created 256K log 'log_system'
[ 1.180245] input: rk29-keypad as /devices/ff100000.adc/key.30/input/input1
[ 1.181087] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.181119] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.181136] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.181157] ES8323 2-0010: Error applying setting, reverse things back
[ 1.182398] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.816481] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux
[ 1.816506] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux
[ 1.816523] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux
[ 1.816538] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux
[ 1.816554] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux
[ 1.816569] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux
[ 1.816585] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux
[ 1.816599] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux
[ 1.816615] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux
[ 1.816629] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux
[ 1.816645] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux
[ 1.816659] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux
[ 1.816675] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux
[ 1.816689] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux
[ 1.816706] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux
[ 1.816720] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux
[ 1.816735] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux
[ 1.816751] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux
[ 1.816767] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux
[ 1.816781] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux
[ 1.816797] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux
[ 1.816811] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux
[ 1.816827] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux
[ 1.816842] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux
[ 1.816858] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux
[ 1.816873] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux
[ 1.816889] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux
[ 1.816904] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux
[ 1.816919] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux
[ 1.816933] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux
[ 1.816949] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux
[ 1.816963] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux
[ 1.816995] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux
[ 1.817010] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux
[ 1.817026] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux
[ 1.817040] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux
[ 1.817056] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux
[ 1.817071] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux
[ 1.817087] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux
[ 1.817101] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux
[ 1.817117] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux
[ 1.817131] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux
[ 1.817147] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux
[ 1.817162] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux
[ 1.817311] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.817329] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.817344] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.817359] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.817385] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.823716] rockchip-es8323 rockchip-es8323.26: ES8323 HiFi <-> ff890000.rockchip-i2s mapping ok
[ 1.824111] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.26/sound/card0/input2
[ 1.824536] u32 classifier
[ 1.824548] Actions configured
[ 1.824562] Netfilter messages via NETLINK v0.30.
[ 1.824617] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.824900] ctnetlink v0.93: registering with nfnetlink.
[ 1.824965] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.824977] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.825205] xt_time: kernel timezone is -0000
[ 1.825384] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.825520] arp_tables: (C) 2002 David S. Miller
[ 1.825555] TCP: cubic registered
[ 1.825565] Initializing XFRM netlink socket
[ 1.825742] NET: Registered protocol family 10
[ 1.826248] mip6: Mobile IPv6
[ 1.826277] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.826389] sit: IPv6 over IPv4 tunneling driver
[ 1.826674] NET: Registered protocol family 17
[ 1.826703] NET: Registered protocol family 15
[ 1.826752] Bridge firewalling registered
[ 1.826767] Ebtables v2.0 registered
[ 1.826924] Bluetooth: RFCOMM TTY layer initialized
[ 1.826951] Bluetooth: RFCOMM socket layer initialized
[ 1.826962] Bluetooth: RFCOMM ver 1.11
[ 1.826972] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.826982] Bluetooth: BNEP filters: protocol multicast
[ 1.826994] Bluetooth: BNEP socket layer initialized
[ 1.827005] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.827018] Bluetooth: HIDP socket layer initialized
[ 1.827073] l2tp_core: L2TP core driver, V2.0
[ 1.827089] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.827100] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.827298] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.827312] [WLAN_RFKILL]: can't find rockchip,grf property
[ 1.827324] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.827336] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.827349] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.827363] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.827388] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.827414] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.827428] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.827457] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.827472] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.827512] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.827638] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.827663] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 270.
[ 1.827683] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.827702] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.827721] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.827771] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.827864] [BT_RFKILL]: ** disable irq
[ 1.827939] [BT_RFKILL]: ap6335 device registered.
[ 1.827995] Key type dns_resolver registered
[ 1.829216] Registering SWP/SWPB emulation handler
[ 1.829581] ddrfreq: verion 1.2 20140526
[ 1.829598] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 492MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 1.829613] ddrfreq: auto-freq=0
[ 1.829621] ddrfreq: auto-freq-table[0] 240MHz
[ 1.829630] ddrfreq: auto-freq-table[1] 324MHz
[ 1.829638] ddrfreq: auto-freq-table[2] 456MHz
[ 1.829647] ddrfreq: auto-freq-table[3] 528MHz
[ 1.842697] act_ldo3: operation not allowed
[ 1.842710] rgb2hdmi_probe: turn on ldo3 done.
[ 1.842959] act_ldo4: operation not allowed
[ 1.842969] rgb2hdmi_probe: turn on ldo done.
[ 1.843222] act_ldo2: operation not allowed
[ 1.843232] rgb2hdmi_probe: turn on ldo2 done.
[ 1.843477] act_ldo8: operation not allowed
[ 1.843487] rgb2hdmi_probe: turn on ldo done.
[ 1.843612] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.091630] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.091685] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[ 2.091751] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.347474] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.347493] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[ 2.347538] regulator-dummy: disabling
[ 2.347829] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.347911] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.347919] file system registered
[ 2.347928] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.347938] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.348436] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.348451] android_usb gadget: Number of LUNs=2
[ 2.348463] lun0: LUN: removable file: (no medium)
[ 2.348472] lun1: LUN: removable file: (no medium)
[ 2.348612] android_usb gadget: android_usb ready
[ 2.348692] sensor_init: Probe name sensors
[ 2.349237] rtc_hym8563 0-0051: setting system clock to 2011-01-04 12:14:24 UTC (1294143264)
[ 2.355297] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi <-> ff880000.rockchip-spdif mapping ok
[ 2.356466] usbcore: registered new interface driver snd-usb-audio
[ 2.356478] ALSA device list:
[ 2.356487] #0: RK_ES8323
[ 2.356494] #1: RK-SPDIF-CARD
[ 2.356922] Freeing unused kernel memory: 360K (c0c40000 - c0c9a000)
[ 2.455730] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.557467] type=1403 audit(1294143264.700:2): policy loaded auid=4294967295 ses=4294967295
[ 2.585411] init: invalid gid 'trace'
[ 2.662390] mmc2:mmc host rescan start!
[ 2.703824] init: /dev/hw_random not found
[ 2.703895] keychord: using input dev ff680000.pwm for fevent
[ 2.703914] keychord: using input dev rk29-keypad for fevent
[ 2.708460] init: /dev/hw_random not found
[ 2.709316] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.710132] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.712634] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.716285] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.716382] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.717017] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.721617] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.721666] e2fsck: system: clean, 1891/85440 files, 116327/393216 blocks
[ 2.725204] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.725277] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.731723] EXT4-fs (mmcblk0p8): recovery complete
[ 2.732019] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.732078] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.732399] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.735801] EXT4-fs (mmcblk0p11): recovery complete
[ 2.735822] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.735877] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.736467] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.740444] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.740485] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.744371] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.744462] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.744520] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.745464] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.745516] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.745791] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.746171] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.762715] EXT4-fs (mmcblk0p13): 2 orphan inodes deleted
[ 2.762739] EXT4-fs (mmcblk0p13): recovery complete
[ 2.765289] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.765377] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.766212] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.770828] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.770874] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 572/65536 files, 10585/262144 blocks
[ 2.774710] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.774785] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.774817] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.789014] arm_release_ver of this mali_ko is 'r6p0-02rel0', rk_ko_ver is '13', built at '09:15:10', on 'Oct 22 2015'.
[ 2.789107] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.789188] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.789207] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.789224] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.789242] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.789348] turn on mali power
[ 2.789368] kbase_platform_rk_init,register_reboot_notifier
[ 2.789417] hrtimer: interrupt took 11958 ns
[ 2.789534] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.791778] mali ffa30000.gpu: Probed as mali0
[ 2.792809] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 2.793437] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 2.794056] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 2.794833] zram0: detected capacity change from 0 to 533413888
[ 2.841420] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.867403] EXT4-fs (mmcblk0p13): Unrecognized mount option "background_gc=on" or missing value
[ 2.875302] drmboot: module license 'unspecified' taints kernel.
[ 2.875335] Disabling lock debugging due to kernel taint
[ 2.877659] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 2.877732] bat_cap: oldcap_path no exist
[ 2.877910] binder: 151:151 transaction failed 29189, size 0-0
[ 2.878460] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 2.882787] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[ 2.882827] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[ 2.883078] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[ 2.883652] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.883677] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.883703] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.883719] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.883749] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.883765] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.883785] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.883801] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.914156] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.915675] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.917204] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.919970] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.943854] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[ 2.948580] logd.auditd: start
[ 2.957046] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
[ 2.957519] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
[ 2.957588] EHCI: rk_ehci_hcd_enable, disable host controller
[ 2.958875] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 2.967308] init: Warning! Service daemonsu needs a SELinux domain defined; please fix!
[ 2.967610] init: cannot find '/system/bin/akmd', disabling 'akmd'
[ 2.968537] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.969374] android_usb: already disabled
[ 2.979451] read descriptors
[ 2.979472] read strings
[ 2.979492] mtp_bind_config
[ 2.982577] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.994550] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.994589] mmc2: new high speed SDIO card at address 0001
[ 3.014642] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.014662] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.014675] [WLAN_RFKILL]: This mac address is not valid, ignored...
[ 3.039662] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.144526] [WLAN_RFKILL]: wifi shut off power.
[ 3.144553] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.144564] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.252765] rk_fb_switch_screen: wait update_regs_wait timeout
[ 3.252803] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[ 3.587336] usb 3-1: new high-speed ==================USB device number 2 using usb20_host
[ 3.659580] rockchip_ion_cma: Fail to allocate(3f5000) buffer
[ 3.667608] rockchip_ion_cma: Fail to allocate(1000) buffer
[ 3.682292] rk3288-lcdc lcdc0: blank mode:0
[ 3.784468] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.784497] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.784512] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.785727] hub 3-1:1.0: USB hub found
[ 3.785826] hub 3-1:1.0: 4 ports detected
[ 3.863767] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 3.864031] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 3.864307] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 4.059784] usb 3-1.2: new low-speed ==================USB device number 3 using usb20_host
[ 4.101619] binder: release 156:188 transaction 33 in, still active
[ 4.101645] binder: send failed reply for transaction 33 to 322:322
[ 4.104793] init: untracked pid 405 killed by signal 9
[ 4.161310] usb 3-1.2: New USB device found, idVendor=2188, idProduct=0ae1
[ 4.161330] usb 3-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.161344] usb 3-1.2: Product: USB OPTICAL MOUSE
[ 4.164625] input: USB OPTICAL MOUSE as /devices/ff540000.usb/usb3/3-1/3-1.2/3-1.2:1.0/input/input3
[ 4.164890] hid-generic 0003:2188:0AE1.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE ] on usb-ff540000.usb-1.2/input0
[ 4.236821] usb 3-1.4: new high-speed ==================USB device number 4 using usb20_host
[ 4.336243] usb 3-1.4: New USB device found, idVendor=114d, idProduct=8451
[ 4.336263] usb 3-1.4: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 4.336277] usb 3-1.4: Manufacturer: Alpha Imaging Tech. Corp.
[ 4.337032] uvcvideo: Found UVC 1.00 device <unnamed> (114d:8451)
[ 4.337959] input: UVC Camera (114d:8451) as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input4
shell@firefly:/ $ [ 8.263985] rockchip_ion_cma: Fail to allocate(3f5000) buffer
[ 8.266636] rockchip_ion_cma: Fail to allocate(1000) buffer
[ 8.283689] rk3288-lcdc lcdc0: blank mode:0
[ 8.753682] binder: release 411:416 transaction 96 in, still active
[ 8.753712] binder: send failed reply for transaction 96 to 445:478
[ 8.756246] binder: undelivered death notification, 00000000b88908c0
[ 8.757407] init: untracked pid 595 killed by signal 9
[ 8.871420] [otg id chg] last id -1 current id 1
[ 10.030716] android_work: sent uevent USB_STATE=CONNECTED
[ 10.119463] android_usb gadget: high-speed config #1: android
[ 10.125178] android_work: sent uevent USB_STATE=CONFIGURED
[ 12.796364] rockchip_ion_cma: Fail to allocate(3f5000) buffer
[ 12.804461] rockchip_ion_cma: Fail to allocate(1000) buffer
[ 12.819452] rk3288-lcdc lcdc0: blank mode:0
[ 13.358749] binder: release 600:607 transaction 119 in, still active
[ 13.358783] binder: send failed reply for transaction 119 to 629:629
[ 13.371497] init: untracked pid 687 killed by signal 9
[ 17.546689] rockchip_ion_cma: Fail to allocate(3f5000) buffer
[ 17.552818] rockchip_ion_cma: Fail to allocate(1000) buffer
[ 17.589017] rk3288-lcdc lcdc0: blank mode:0
[ 18.456934] binder: release 696:703 transaction 145 in, still active
[ 18.456980] binder: send failed reply for transaction 145 to 726:726
[ 18.467911] init: untracked pid 789 killed by signal 9
[ 22.586326] rockchip_ion_cma: Fail to allocate(3f5000) buffer
[ 22.588953] rockchip_ion_cma: Fail to allocate(1000) buffer
[ 22.600829] rk3288-lcdc lcdc0: blank mode:0
I need your help.
Thanks.
