Posted at 3/19/2018 19:40:30
This is still unsolved. I am using the original gitlab 7.1.2, last commit is 6ef1ea24af
I build and flash:
sudo upgrade_tool di -b rockdev/Image-rk3399_firefly_box/boot.img
sudo upgrade_tool di -k rockdev/Image-rk3399_firefly_box/kernel.img
sudo upgrade_tool di -s rockdev/Image-rk3399_firefly_box/system.img
sudo upgrade_tool di -r rockdev/Image-rk3399_firefly_box/recovery.img
sudo upgrade_tool di -m rockdev/Image-rk3399_firefly_box/misc.img
sudo upgrade_tool di resource rockdev/Image-rk3399_firefly_box/resource.img
sudo upgrade_tool di -p rockdev/Image-rk3399_firefly_box/parameter.txt
sudo upgrade_tool ul ./u-boot/rk3399_loader_v1.08.109.bin
sudo upgrade_tool di trust rockdev/Image-rk3399_firefly_box/trust.img
Now the device does not boot unless I pull out the HDMI cable. It crashes in u-boot:
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=1121
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
"Synchronous Abort" handler, esr 0x96000004
/Tony |
