My Firefly is dead
2
Posted at 12/23/2014 15:25:28
Went to switch it on this morning and it is completely dead.
Hooked it up to my PC but it isn't being recognised there either.
Checked the status of the ac unit and that is fine.
Posted at 12/23/2014 17:57:21
What had you done to it?
Try attach a serial adapter to it and see if anything comes out.
Posted at 12/23/2014 20:22:12
I just started it up as usual.
Tried a serial adapter but getting?absolutely nothing.
Posted at 12/23/2014 22:05:32
If the on board flash is trashed connect a micro usb cable from the otg port to a PC as the device may be in MaskRom Mode.?Then use something like RKAndroidTool, RKBatchTool?to see if the device is detected.
Posted at 12/24/2014 01:04:36
I tried to see if it was in maskrom mode and used all of the available tools but none see the firefly in any way, shape or form.
Posted at 12/24/2014 15:18:20
Please use a?multimeter to measure the voltages described in the attached picture, and post the result.
(The full?component reference file is at
http://www.t-firefly.com/download/firef ... 30_pos.pdf
Posted at 12/31/2014 02:46:31
Took it to a local sparky, who ran the multimeter tests over it and found no life whatsoever.
vip
Rank: 6Rank: 6
Posted at 2/26/2015 16:50:57
Re: My Firefly is dead
if no power and no log, you should check you hardware.
