Network PCIe Card not detected in rk3399
32
Posted at 4/16/2018 19:03:57
Dear,
I am using the firefly RK-3399 board which has Mini PCIe connector on it.
A PCIe Network card is inserted into Mini PCIe slot using a "Mini PCI-E to PCI-E Express 1X Extension Cord Adapter Card with USB Riser Card"
For some reason the PCIe card is not detected in the firefly board when checked using "lspci" command. lspci command shows nothing.
Could you please throw some points which can help us to identify why the card is not detected?
Setup Details:
Extension Cord Adapter purchased from AMAZON: http://a.co/b5k9Oju
If you have ever came across issue with the Riser cards, please suggest us the suitable Mini PCIe to PCIe extension cord.
Waiting for your technical suggestion.
Posted at 4/17/2018 09:55:11
this  from RK suggest. the below they had tried.
Marvell wifi 8897
ASmedia PCIEtoSAS ASM1061
Realtek Ethernet 8996
Posted at 4/17/2018 15:31:48
thanks for reply, But this above mentioned HW doesnt have Mini PCIe slot.
I want to know is there any extension cord that is used to connect PCIe card to Mini PCIe slot on Rk3399 board other than "Mini PCI-E to PCI-E Express 1X Extension Cord Adapter Card with USB Riser Card"
Posted at 4/17/2018 16:20:17
WajahathMM Posted at 4/17/2018 15:31
I want to know is there  ...
i have no try that device yet , so i cannot figure out if it work.
Posted at 4/18/2018 09:32:31
some developer have tried the D720201 , a PCIe to 2 usb3.0.
it work fine under the newest ubuntu firmware AIO-3399J_xubuntu1604_20170119.7z
Posted at 4/18/2018 20:05:11
Dear,
Which M2 connector cord was used along with the D720201 to connect to firefly rk3399?
Posted at 4/19/2018 09:12:03
WajahathMM Posted at 4/18/2018 20:05
Dear,
He used the M.2 m-key interface of D720201 on the AIO-3399J . export to 2 usb3.0 port.
Posted at 4/19/2018 12:29:39
Ok. Thanks.
