【Android】
Board can not enter Android OS
Posted at 5/24/2018 16:55:00
U-Boot 2014.10-RK3399-06-02507-g99e11be-dirty (Dec 18 2017 - 12:28:55)
CPU: rk3399
cpu version = 0
CPU's clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Board: Rockchip platform Board
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(00000000ffe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
SdmmcInit = 0 20
storage init OK!
Using default environment
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
usb bc: can find node by path: /dwc-control-usb/usb_bc
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=66
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2017-12-18#1.09
empty serial no.
reboot normal.
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
failed to find panel driver
read logo on state from dts [1]
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 3 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x012b2808)
ramdisk @ 0x05bf0000 (0x007af3d4)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000005600000, end 0000000005614a1e ... OK
Add bank:0000000000200000, 0000000008200000
Add bank:0000000009400000, 00000000eec00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Initializing cgroup subsys schedtune
[ 0.000000] Linux version 4.4.83 (zxy@ZIG-HP-Z228) (gcc version 4.9 20150123 (prerelease) (GCC) ) #2 SMP PREEMPT Thu May 24 14:55:26 CST 2018
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] hdmi init vic is -1
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef7000 s45696 r8192 d32128 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 995336
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00546000@0x000B4000(system),0x00008000@0x005FA000(metadata),0x00002000@0x00602000(baseparamer),-@0x00604000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-12-18_12:28:55 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB [mem 0xf6eaf000-0xf6eef000] (0MB) mapped at [ffffffc0f6eaf000-ffffffc0f6eeefff]
[ 0.000000] Memory: 3926484K/4044800K available (11582K kernel code, 1354K rwdata, 5316K rodata, 832K init, 1079K bss, 101932K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff8009110000 - 0xffffff80091e0000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bd0000 ( 11584 KB)
[ 0.000000] .rodata : 0xffffff8008bd0000 - 0xffffff8009110000 ( 5376 KB)
[ 0.000000] .data : 0xffffff80091e0000 - 0xffffff8009332808 ( 1355 KB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[ 0.000000] ITS: allocated 65536 Devices @f2000000 (psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x00000000f2080000
[ 0.000000] ITS: Allocated 1792 chunks for LPIs
[ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2090000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.009833] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.021116] pid_max: default: 32768 minimum: 301
[ 0.026269] Security Framework initialized
[ 0.030809] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.038173] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.046798] Initializing cgroup subsys freezer
[ 0.051694] Initializing cgroup subsys debug
[ 0.057213] sched-energy: Sched-energy-costs installed from DT
[ 0.063636] CPU0: update cpu_capacity 401
[ 0.068091] ASID allocator initialised with 65536 entries
[ 0.090902] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.100969] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.124631] Detected VIPT I-cache on CPU1
[ 0.124662] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.124698] CPU1: using LPI pending table @0x00000000f2200000
[ 0.124741] CPU1: update cpu_capacity 401
[ 0.124744] CPU1: Booted secondary processor [410fd034]
[ 0.134628] Detected VIPT I-cache on CPU2
[ 0.134647] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.134679] CPU2: using LPI pending table @0x00000000f2230000
[ 0.134706] CPU2: update cpu_capacity 401
[ 0.134710] CPU2: Booted secondary processor [410fd034]
[ 0.144666] Detected VIPT I-cache on CPU3
[ 0.144684] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.144716] CPU3: using LPI pending table @0x00000000f2270000
[ 0.144743] CPU3: update cpu_capacity 401
[ 0.144745] CPU3: Booted secondary processor [410fd034]
[ 0.154714] Detected PIPT I-cache on CPU4
[ 0.154741] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.154779] CPU4: using LPI pending table @0x00000000f22b0000
[ 0.154820] CPU4: update cpu_capacity 1024
[ 0.154823] CPU4: Booted secondary processor [410fd082]
[ 0.164734] Detected PIPT I-cache on CPU5
[ 0.164752] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.164788] CPU5: using LPI pending table @0x00000000f22e0000
[ 0.164815] CPU5: update cpu_capacity 1024
[ 0.164818] CPU5: Booted secondary processor [410fd082]
[ 0.164898] Brought up 6 CPUs
[ 0.307366] SMP: Total of 6 processors activated.
[ 0.312537] CPU features: detected feature: GIC system register CPU interface
[ 0.320380] CPU: All CPU(s) started at EL2
[ 0.324917] alternatives: patching kernel code
[ 0.332320] devtmpfs: initialized
[ 0.349130] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.359873] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.367463] pinctrl core: initialized pinctrl subsystem
[ 0.374559] Failed to find legacy iommu devices
[ 0.379893] NET: Registered protocol family 16
[ 0.385184] schedtune: init normalization constants...
[ 0.390844] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.398026] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.405209] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.412390] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.419568] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.426749] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.433928] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.441107] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.448288] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.455469] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.463895] schedtune: verify normalization constants...
[ 0.469737] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.475865] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.481992] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.488121] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.494247] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.500373] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.506500] schedtune: configured to support 5 boost groups
[ 0.525993] cpuidle: using governor ladder
[ 0.543870] cpuidle: using governor menu
[ 0.548220] Registered FIQ tty driver
[ 0.552614] vdso: 2 pages (1 code @ ffffff8008bd6000, 1 data @ ffffff80091e4000)
[ 0.560775] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.568944] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.612370] console [pstore0] enabled
[ 0.616591] pstore: Registered ramoops as persistent store backend
[ 0.623401] ramoops: attached 0xf0000@0x110000, ecc: 0/0
<hit enter to activate fiq debugger>
[ 0.631665] console [ttyFIQ0] enabled
[[ 0.631665] console [ttyFIQ0] enabled
[ 0.638930] bootconsole [uart0] disabled
[ 0.650947] Registered fiq debugger ttyFIQ0
[ 0.688511] Rockchip hdmi driver version 2.0
[ 0.690767] iommu: Adding device ff650000.vpu_service to group 0
[ 0.690840] iommu: Adding device ff660000.rkvdec to group 1
[ 0.690926] iommu: Adding device ff670000.iep to group 2
[ 0.691019] iommu: Adding device ff8f0000.vop to group 3
[ 0.691094] iommu: Adding device ff900000.vop to group 4
[ 0.691193] iommu: Adding device ff910000.isp to group 5
[ 0.691271] iommu: Adding device ff920000.isp to group 6
[ 0.691934] rk_iommu ff670800.iommu: can't get aclk
[ 0.691950] rk_iommu ff670800.iommu: can't get hclk
[ 0.692784] SCSI subsystem initialized
[ 0.692974] usbcore: registered new interface driver usbfs
[ 0.693030] usbcore: registered new interface driver hub
[ 0.693107] usbcore: registered new device driver usb
[ 0.693460] media: Linux media interface: v0.10
[ 0.693498] Linux video capture interface: v2.00
[ 0.693630] pps_core: LinuxPPS API ver. 1 registered
[ 0.693642] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.693670] PTP clock support registered
[ 0.695089] Advanced Linux Sound Architecture Driver Initialized.
[ 0.695541] Bluetooth: Core ver 2.21
[ 0.695571] NET: Registered protocol family 31
[ 0.695581] Bluetooth: HCI device and connection manager initialized
[ 0.695599] Bluetooth: HCI socket layer initialized
[ 0.695616] Bluetooth: L2CAP socket layer initialized
[ 0.695641] Bluetooth: SCO socket layer initialized
[ 0.698232] rockchip-cpuinfo cpuinfo: Serial : 0000000000000000
[ 0.698747] clocksource: Switched to clocksource arch_sys_counter
[ 0.733343] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.733560] NET: Registered protocol family 2
[ 0.733959] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.734145] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.734372] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.734453] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.734499] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.734676] NET: Registered protocol family 1
[ 0.735124] Trying to unpack rootfs image as initramfs...
[ 1.070512] Freeing initrd memory: 7868K
[ 1.071085] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.071178] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.076656] audit: initializing netlink subsys (disabled)
[ 1.076715] audit: type=2000 audit(0.953:1): initialized
[ 1.084957] VFS: Disk quotas dquot_6.6.0
[ 1.085079] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.086458] fuse init (API version 7.23)
[ 1.087062]
[ 1.087062] TEE Core Framework initialization (ver 1:0.1)
[ 1.087088] TEE armv7 Driver initialization
[ 1.087394] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 1.087411] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 1.087563] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[ 1.108481] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.108506] io scheduler noop registered
[ 1.108668] io scheduler cfq registered (default)
[ 1.109977] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 1.114094] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.114116] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.114134] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.635497] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.635689] rockchip-pcie: probe of f8000000.pcie failed with error 昄Lj
[ 1.637153] iep: failed to find iep power down clock source.
[ 1.637739] IEP Power ON
[ 1.637949] IEP Power OFF
[ 1.638056] IEP Driver loaded succesfully
[ 1.638250] Module initialized.
[ 1.638827] rk-vcodec ff650000.vpu_service: probe device
[ 1.638872] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f18b6810
[ 1.639052] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.639114] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.639586] rk-vcodec ff650000.vpu_service: init success
[ 1.640104] rk-vcodec ff660000.rkvdec: probe device
[ 1.640148] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f18b7010
[ 1.640303] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.640363] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.640690] rk-vcodec ff660000.rkvdec: init success
[ 1.642529] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.642550] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.644413] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.644432] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.646050] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.648016] console [ttyS0] disabled
[ 1.648077] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 1.648835] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.649548] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.649926] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.654154] mali ff9a0000.gpu: Failed to get regulator
[ 1.654172] mali ff9a0000.gpu: Power control initialization failed
[ 1.654406] Unable to detect cache hierarchy from DT for CPU 0
[ 1.674926] brd: module loaded
[ 1.679426] loop: module loaded
[ 1.679912] zram: Added device: zram0
[ 1.680456] SCSI Media Changer driver v0.25
[ 1.680915] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 1.680936] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 1.680952] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 1.680969] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 1.681101] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.681118] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.681710] tun: Universal TUN/TAP device driver, 1.6
[ 1.681724] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.682679] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.682699] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.682714] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.682746] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.682916] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.687935] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.688011] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.688022] Ring mode enabled
[ 1.688031] DMA HW capability register supported
[ 1.688041] Normal descriptors
[ 1.688052] RX Checksum Offload Engine supported (type 2)
[ 1.688062] TX Checksum insertion supported
[ 1.688070] Wake-Up On Lan supported
[ 1.688111] Enable RX Mitigation via HW Watchdog Timer
[ 1.753156] libphy: stmmac: probed
[ 1.753171] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.753184] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.753894] PPP generic driver version 2.4.2
[ 1.754046] PPP BSD Compression module registered
[ 1.754065] PPP Deflate Compression module registered
[ 1.754095] PPP MPPE Compression module registered
[ 1.754118] NET: Registered protocol family 24
[ 1.754166] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.754180] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.754203] Rockchip WiFi SYS interface (V1.00) ...
[ 1.754284] usbcore: registered new interface driver catc
[ 1.754331] usbcore: registered new interface driver kaweth
[ 1.754349] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.754391] usbcore: registered new interface driver pegasus
[ 1.754437] usbcore: registered new interface driver rtl8150
[ 1.754481] usbcore: registered new interface driver r8152
[ 1.754499] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.754560] usbcore: registered new interface driver hso
[ 1.754610] usbcore: registered new interface driver asix
[ 1.754658] usbcore: registered new interface driver ax88179_178a
[ 1.754703] usbcore: registered new interface driver cdc_ether
[ 1.754747] usbcore: registered new interface driver cdc_eem
[ 1.754790] usbcore: registered new interface driver dm9601
[ 1.754844] usbcore: registered new interface driver smsc75xx
[ 1.754900] usbcore: registered new interface driver smsc95xx
[ 1.754944] usbcore: registered new interface driver gl620a
[ 1.754988] usbcore: registered new interface driver net1080
[ 1.755031] usbcore: registered new interface driver plusb
[ 1.755075] usbcore: registered new interface driver rndis_host
[ 1.755122] usbcore: registered new interface driver cdc_subset
[ 1.755166] usbcore: registered new interface driver zaurus
[ 1.755210] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.755272] usbcore: registered new interface driver int51x1
[ 1.755316] usbcore: registered new interface driver kalmia
[ 1.755360] usbcore: registered new interface driver ipheth
[ 1.755450] usbcore: registered new interface driver sierra_net
[ 1.755500] usbcore: registered new interface driver cx82310_eth
[ 1.755554] usbcore: registered new interface driver cdc_ncm
[ 1.755601] usbcore: registered new interface driver qmi_wwan
[ 1.755647] usbcore: registered new interface driver cdc_mbim
[ 1.756755] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.759795] rockchip-typec-phy ff800000.phy: mode = 0, id = 0
[ 1.759817] rockchip-typec-phy ff800000.phy: new_mode = 2
[ 1.759830] rockchip-typec-phy ff800000.phy: tcphy->mode = 0, new_mode = 2
[ 1.762408] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.763396] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.763418] ehci-pci: EHCI PCI platform driver
[ 1.763502] ehci-platform: EHCI generic platform driver
[ 1.767535] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.767569] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.767721] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.775443] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.775577] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.775594] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.775609] usb usb1: Product: EHCI Host Controller
[ 1.775621] usb usb1: Manufacturer: Linux 4.4.83 ehci_hcd
[ 1.775633] usb usb1: SerialNumber: fe3c0000.usb
[ 1.776063] hub 1-0:1.0: USB hub found
[ 1.776097] hub 1-0:1.0: 1 port detected
[ 1.776587] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.776618] ohci-platform: OHCI generic platform driver
[ 1.777072] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.777098] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.777206] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.832895] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.832913] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.832928] usb usb2: Product: Generic Platform OHCI controller
[ 1.832941] usb usb2: Manufacturer: Linux 4.4.83 ohci_hcd
[ 1.832953] usb usb2: SerialNumber: fe3e0000.usb
[ 1.833355] hub 2-0:1.0: USB hub found
[ 1.833389] hub 2-0:1.0: 1 port detected
[ 1.834150] usbcore: registered new interface driver cdc_acm
[ 1.834164] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.834225] usbcore: registered new interface driver usblp
[ 1.834271] usbcore: registered new interface driver cdc_wdm
[ 1.834317] usbcore: registered new interface driver uas
[ 1.834392] usbcore: registered new interface driver usb-storage
[ 1.834433] usbcore: registered new interface driver ums-alauda
[ 1.834473] usbcore: registered new interface driver ums-cypress
[ 1.834513] usbcore: registered new interface driver ums-datafab
[ 1.834553] usbcore: registered new interface driver ums_eneub6250
[ 1.834593] usbcore: registered new interface driver ums-freecom
[ 1.834633] usbcore: registered new interface driver ums-isd200
[ 1.834672] usbcore: registered new interface driver ums-jumpshot
[ 1.834715] usbcore: registered new interface driver ums-karma
[ 1.834755] usbcore: registered new interface driver ums-onetouch
[ 1.834796] usbcore: registered new interface driver ums-sddr09
[ 1.834836] usbcore: registered new interface driver ums-sddr55
[ 1.834875] usbcore: registered new interface driver ums-usbat
[ 1.834951] usbcore: registered new interface driver usbserial
[ 1.834988] usbcore: registered new interface driver usbserial_generic
[ 1.835022] usbserial: USB Serial support registered for generic
[ 1.835065] usbcore: registered new interface driver option
[ 1.835095] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.835194] usbcore: registered new interface driver trancevibrator
[ 1.835210] usb20_otg: version 3.10a 21-DEC-2012
[ 1.835365] usb20_host: version 3.10a 21-DEC-2012
[ 1.839133] usbcore: registered new interface driver xpad
[ 1.839182] usbcore: registered new interface driver usb_acecad
[ 1.839229] usbcore: registered new interface driver aiptek
[ 1.839275] usbcore: registered new interface driver gtco
[ 1.839322] usbcore: registered new interface driver hanwang
[ 1.839367] usbcore: registered new interface driver kbtab
[ 1.839403] Successfully added driver ft5x0x_ts
[ 1.839692] .. rk pwm remotectl v1.1 init
[ 1.839908] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.840152] remotectl-pwm ff420030.pwm: Missing psci property in the DT.
[ 1.840260] sensor_register_slave:mma8452,id=17
[ 1.840276] sensor_register_slave:lis3dh,id=7
[ 1.840291] sensor_register_slave:mma7660,id=18
[ 1.840305] sensor_register_slave:lsm303d,id=22
[ 1.840318] sensor_register_slave:gs_mc3230,id=23
[ 1.840328] [Gsensor] gsensor_init
[ 1.840341] sensor_register_slave:mpu6880_acc,id=24
[ 1.840355] sensor_register_slave:mpu6500_acc,id=25
[ 1.840370] sensor_register_slave:lsm330_acc,id=26
[ 1.840384] sensor_register_slave:akm8975,id=28
[ 1.840398] sensor_register_slave:akm8963,id=29
[ 1.840413] sensor_register_slave:l3g4200d,id=43
[ 1.840426] sensor_register_slave:l3g20d,id=44
[ 1.840440] sensor_register_slave:ewtsa,id=45
[ 1.840454] sensor_register_slave:lsm330_gyro,id=48
[ 1.840468] sensor_register_slave:cm3217,id=50
[ 1.840482] sensor_register_slave:cm3218,id=51
[ 1.841063] i2c /dev entries driver
[ 1.842161] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.842224] fan53555-reg: supplied by vcc5v0_sys
[ 1.844218] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.844267] fan53555-reg: supplied by vcc5v0_sys
[ 1.846326] rk808 0-001b: Pmic Chip id: 0x0
[ 1.849014] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.849067] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.849145] DCDC_REG1: supplied by vcc3v3_sys
[ 1.849815] DCDC_REG2: supplied by vcc3v3_sys
[ 1.850295] DCDC_REG3: supplied by vcc3v3_sys
[ 1.850489] DCDC_REG4: supplied by vcc3v3_sys
[ 1.850864] LDO_REG1: supplied by vcc3v3_sys
[ 1.851881] LDO_REG2: supplied by vcc3v3_sys
[ 1.852760] LDO_REG3: supplied by vcc3v3_sys
[ 1.853645] LDO_REG4: supplied by vcc3v3_sys
[ 1.854545] LDO_REG5: supplied by vcc3v3_sys
[ 1.855459] LDO_REG6: supplied by vcc3v3_sys
[ 1.856349] LDO_REG7: supplied by vcc3v3_sys
[ 1.857242] LDO_REG8: supplied by vcc3v3_sys
[ 1.858120] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.858327] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.861594] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.862016] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096fc000
[ 1.862152] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.862173] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.862188] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.862205] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.862561] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80096fe000
[ 1.875763] fusb302 4-0022: port 0 probe success
[ 1.875899] ft5x0x_ts############################
[ 1.875910] ft5x0x_ts_probe-373
[ 1.941847] fusb302 4-0022: CC connected in 0 as UFP
[ 2.082105] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 2.085764] input: ft5x0x_ts as /devices/virtual/input/input1
[ 2.206019] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.206039] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.206054] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.206673] hub 1-1:1.0: USB hub found
[ 2.206765] hub 1-1:1.0: 7 ports detected
[ 2.238931] ft5x0x_ts 4-0038: fft5x0x_i2c_Read: i2c read error.
[ 2.238946] [FTS]####### Firmware version = 0x8b
[ 2.239118] ft5x0x_ts 4-0038: fft5x0x_i2c_Read: i2c read error.
[ 2.239131] [FTS]####### report rate is 1390Hz.
[ 2.239302] ft5x0x_ts 4-0038: fft5x0x_i2c_Read: i2c read error.
[ 2.239317] #######ft5x0x_ts_probe ok !!!!483
[ 2.239343] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009742000
[ 2.240259] IR NEC protocol handler initialized
[ 2.240276] IR RC5(x/sz) protocol handler initialized
[ 2.240293] IR RC6 protocol handler initialized
[ 2.240309] IR JVC protocol handler initialized
[ 2.240325] IR Sony protocol handler initialized
[ 2.240341] IR SANYO protocol handler initialized
[ 2.240357] IR Sharp protocol handler initialized
[ 2.240373] IR MCE Keyboard/mouse protocol handler initialized
[ 2.240390] IR XMP protocol handler initialized
[ 2.240477] usbcore: registered new interface driver uvcvideo
[ 2.240488] USB Video Class driver (1.1.1)
[ 2.240508] CamSys driver version: v0.34.5, CamSys head file version: v0.13.0
[ 2.244529] __power_supply_register: Expected proper parent device for 'test_ac'
[ 2.244656] __power_supply_register: Expected proper parent device for 'test_battery'
[ 2.244898] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.244999] __power_supply_register: Expected proper parent device for 'test_usb'
[ 2.247098] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.247647] device-mapper: uevent: version 1.0.3
[ 2.247900] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.251356] Bluetooth: HCI UART driver ver 2.3
[ 2.251370] Bluetooth: HCI UART protocol H4 registered
[ 2.251382] Bluetooth: HCI UART protocol LL registered
[ 2.251396] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.251407] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.251419] rtk_btusb: Register usb char device interface for BT driver
[ 2.251604] usbcore: registered new interface driver rtk_btusb
[ 2.255113] sdhci: Secure Digital Host Controller Interface driver
[ 2.255127] sdhci: Copyright(c) Pierre Ossman
[ 2.255139] Synopsys Designware Multimedia Card Interface Driver
[ 2.255823] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.255909] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.255928] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.255971] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.256002] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.256042] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.256053] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.256644] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.256686] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.256703] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.256736] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.256755] dwmmc_rockchip fe320000.dwmmc: 'cl__bionic_open_tzmad' par: couoperty was nddep arenycat ted.z
[ 2.256n 8loo21] dwmmc_rockachip fe3200
[ 2St.2art5ing recoveroc (pid 183) on Thu n Mayf 24f0770000.sy con:i
d# obmaootimode = emmic
ns: S 0e /mntt/interna30_sd vdfat /dev/block/platform/fe330000.sdhci/by-name/usersl
ot 01 /) mnt=/externa00_sd vflota reqt /dev/blo,k actual 400000
2div = 0)
[ t2.283 /202d] dwmmc_rockchip foe3rm/20fe003300.000d.sdhcmc/by -name/system ializ0d
[ 3 /cache ext4 418/] sdhci-pltfm: SDHCI rm/fe330000.d OF dsdhci/helper
[ 2.2
9 4 70] sedhcitadata exte330000b.sdhci: Notvmrm/fmc regulatohcir /byf-namue/metada a 20.284 5 /data f2fs /arev/block/plat.forhcm/i: feNo 3vqmm30000.sdhci/foy-name/us erdata 61] m0c1: 6S /cust ext4 /roldelerv on /block/platform/fe3300000.sd00.sbdy-nahci] using
7D /cMA
tom[ ex t4 2 .312d822] hidraw: raworm/fe330000.sdhcri/ (Cby) J-iri Kosina
[ 0
2.38148 /misc cemmc /dev/bleockre/pldatf nm/fee330000.sdhci/ dy-name/misc 0
2.314909] usb/dev/block/platfeorm /fe330000.sdhci2.by-name/uboot 0_i
io: inv_mpu_init:7c6
[ lock/p1lat87fo] armshm/em: fe330000.sdh
i/[ by -n2.3a18725me/charge0.0
adc s11upp /ly rvref not foummnc /dd, usoickng atduformmm/fye33 reguladhci/b y-name/resourc2e 0
12 3] raknandbase mv1c /.dev/1 2016-latfo11-08
[ 2s320hci8/by-20] usbcaormete:er 0
ergis1tered new interfa/dcev/block/platfod-m/fe330000.sdhci2/b.32y4447] u32 class0i
[ 14 /r 2eco.very e44mc / de v/Actbions configatfured
[ 2.3dh24497] Netfieltervmessag
e 15 /backup emm vc 0.3/d0.
16 2.324548] nform/f_conntrack cive/byr-namse/backup.00 (
ilock /platf933] ctrm/fe330000.sdhrecgistering with nfnet
s: ( C) 2000-2006 Nedev/belock/platforeammk tplatfnorm/fe330000.s
[ 2.3316h93ci/rpy-nbame/f: (C) 2
19 /2 David S. killer
[ 2
.3
449I:InternalSD_gROOFR: /mnt/iknt soecket
[ sd I:2.332826] NET: T: /istmeren t/external_sdamirely a10
[ cmdline4038] mip6: Mobile IPv6
[ 2.b33oo406t-6] rip6_ctables:
IC) 2000-2006mentfs floter Core Team
c 2.336742] sit=== start void d tmpCmdArggs(invet, r
[ 2.337139] NET
Rargev[0g istered proetocrly.famargvily 17
[ _2.337
(v5] NET: Registeied pro2tocosl dcafrd iamily 15
[ 2c337197]
emrimc_dpoint is /mdeatic filmtering v
arp/i p/ip6tables h
bstaege is []epreason is [(nuall)e]
your scripts to load br_netfilter if you need this.
[ 2.338207] Bridge firewalling registered
[ 2.338219] Ebtables v2.0 registered
[ 2.338571] Bluetooth: RFCOMM TTY layer initialized
[ 2.338589] Bluetooth: RFCOMM socket layer initialized
[ 2.338614] Bluetooth: RFCOMM ver 1.11
[ 2.338632] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.338642] Bluetooth: BNEP filters: protocol multicast
[ 2.338655] Bluetooth: BNEP socket layer initialized
[ 2.338667] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.338680] Bluetooth: HIDP socket layer initialized
[ 2.338706] l2tp_core: L2TP core driver, V2.0
[ 2.338723] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.338775] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.339012] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.339065] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.339076] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.339086] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.339135] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 1003, flags = 0.
[ 2.339146] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.339157] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.339200] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.339458] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 1083.
[ 2.339492] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 1009.
[ 2.339519] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 1090.
[ 2.339545] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 1004.
[ 2.339829] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.339879] [BT_RFKILL]: ** disable irq
[ 2.339992] [BT_RFKILL]: bt_default device registered.
[ 2.340300] sensor_register_slave:mpu6880_gyro,id=47
[ 2.340728] Registered cp15_barrier emulation handler
[ 2.340862] Registered setend emulation handler
[ 2.341568] registered taskstats version 1
[ 2.342169] rockchip ion idev is NULL
[ 2.342183] rga2 ff680000.rga: rga ion client create success!
[ 2.342437] rga: Driver loaded successfully ver:3.02
[ 2.342567] pvtm list NULL
[ 2.347283] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 2.349675] rockchip-vop ff900000.vop: failed to get vop register byname
[ 2.349730] rockchip-vop ff900000.vop: invalid resource
[ 2.349744] rockchip-vop ff900000.vop: failed to get vop lut registers
[ 2.349757] rockchip-vop ff900000.vop: invalid resource
[ 2.349770] rockchip-vop ff900000.vop: failed to get vop cabc lut registers
[ 2.350020] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 2.350062] rockchip-vop ff8f0000.vop: failed to get vop register byname
[ 2.350090] rockchip-vop ff8f0000.vop: invalid resource
[ 2.350103] rockchip-vop ff8f0000.vop: failed to get vop lut registers
[ 2.350115] rockchip-vop ff8f0000.vop: invalid resource
[ 2.350127] rockchip-vop ff8f0000.vop: failed to get vop cabc lut registers
[ 2.350317] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 2.350867] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.350967] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.351058] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.352529] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 2.353211] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 2.353232] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.353245] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 2.353911] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.356212] mmc1: MAN_BKOPS_EN bit is not set
[ 2.368035] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.371901] mmcblk1: mmc1:0001 BJNB4R 29.1 GiB
[ 2.375653] mmcblk1boot0: mmc1:0001 BJNB4R partition 1 4.00 MiB
[ 2.375996] mmcblk1boot1: mmc1:0001 BJNB4R partition 2 4.00 MiB
[ 2.379767] mmcblk1rpmb: mmc1:0001 BJNB4R partition 3 4.00 MiB
[ 2.380188] parameter: 0x000000000 -- 0x000400000 (4 MB)
[ 2.380201] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 2.380212] trust: 0x000800000 -- 0x000c00000 (4 MB)
[ 2.380223] misc: 0x000c00000 -- 0x001000000 (4 MB)
[ 2.380233] resource: 0x001000000 -- 0x002000000 (16 MB)
[ 2.380243] kernel: 0x002000000 -- 0x003800000 (24 MB)
[ 2.380252] boot: 0x003800000 -- 0x005800000 (32 MB)
[ 2.380261] recovery: 0x005800000 -- 0x007800000 (32 MB)
[ 2.380271] backup: 0x007800000 -- 0x00e800000 (112 MB)
[ 2.380280] cache: 0x00e800000 -- 0x016800000 (128 MB)
[ 2.380290] system: 0x016800000 -- 0x0bf400000 (2700 MB)
[ 2.380299] metadata: 0x0bf400000 -- 0x0c0400000 (16 MB)
[ 2.380309] baseparamer: 0x0c0400000 -- 0x0c0800000 (4 MB)
[ 2.380318] userdata: 0x0c0800000 -- 0x747800000 (26736 MB)
[ 2.380359] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.485473] usb 1-1.1: new low-speed USB device number 3 using ehci-platform
[ 2.585527] usb 1-1.1: New USB device found, idVendor=04f3, idProduct=0235
[ 2.585557] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.585572] usb 1-1.1: Product: OM
[ 2.590533] input: OM as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:04F3:0235.0001/input/input2
[ 2.590962] hid-generic 0003:04F3:0235.0001: input,hidraw0: USB HID v1.11 Mouse [OM] on usb-fe3c0000.usb-1.1/input0
[ 2.820738] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.835956] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.837069] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.837615] mali ff9a0000.gpu: Probed as mali0
[ 2.841415] rockchip-typec-phy ff7c0000.phy: ufp = 1, dfp = 0, dp = 0
[ 2.841438] rockchip-typec-phy ff7c0000.phy: new_mode = 1
[ 2.841452] rockchip-typec-phy ff7c0000.phy: tcphy->mode = 0, new_mode = 1
[ 2.843958] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.843994] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 2.844378] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 2.844455] xhci-hcd xhci-hcd.10.auto: irq 232, io mem 0xfe800000
[ 2.844714] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.844731] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.844747] usb usb3: Product: xHCI Host Controller
[ 2.844759] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.844787] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 2.845644] hub 3-0:1.0: USB hub found
[ 2.845726] hub 3-0:1.0: 1 port detected
[ 2.846193] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.846217] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.846341] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.846506] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.846555] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.846574] usb usb4: Product: xHCI Host Controller
[ 2.846587] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.846600] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.847415] hub 4-0:1.0: USB hub found
[ 2.847458] hub 4-0:1.0: 1 port detected
[ 2.848230] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.848289] usb usb4: USB disconnect, device number 1
[ 2.849002] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 2.849037] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.849079] usb usb3: USB disconnect, device number 1
[ 2.849821] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 2.850127] rockchip-dwc3 usb@fe800000: USB peripheral not support!
[ 2.854234] rockchip-typec-phy ff800000.phy: mode = 0, id = 0
[ 2.854257] rockchip-typec-phy ff800000.phy: new_mode = 2
[ 2.854271] rockchip-typec-phy ff800000.phy: tcphy->mode = 0, new_mode = 2
[ 2.856886] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.856919] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.857286] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 2.857385] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe900000
[ 2.857634] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.857652] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.857667] usb usb3: Product: xHCI Host Controller
[ 2.857679] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.857726] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.858497] hub 3-0:1.0: USB hub found
[ 2.858540] hub 3-0:1.0: 1 port detected
[ 2.859067] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.859104] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.859222] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.859410] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.859442] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.859470] usb usb4: Product: xHCI Host Controller
[ 2.859487] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.859501] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 2.860253] hub 4-0:1.0: USB hub found
[ 2.860292] hub 4-0:1.0: 1 port detected
[ 2.860679] vendor storage:20160801 ret = 0
[ 2.864871] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.864903] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 2.865188] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.872322] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.872554] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.872572] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.872587] usb usb5: Product: EHCI Host Controller
[ 2.872600] usb usb5: Manufacturer: Linux 4.4.83 ehci_hcd
[ 2.872613] usb usb5: SerialNumber: fe380000.usb
[ 2.873289] hub 5-0:1.0: USB hub found
[ 2.873331] hub 5-0:1.0: 1 port detected
[ 2.874357] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.874390] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 2.874607] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.929671] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.929689] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.929704] usb usb6: Product: Generic Platform OHCI controller
[ 2.929717] usb usb6: Manufacturer: Linux 4.4.83 ohci_hcd
[ 2.929730] usb usb6: SerialNumber: fe3a0000.usb
[ 2.930382] hub 6-0:1.0: USB hub found
[ 2.930424] hub 6-0:1.0: 1 port detected
[ 2.931890] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.932003] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.932024] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.932061] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.932115] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.932177] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.932190] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.932565] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.945528] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.959094] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.964182] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[ 2.967331] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 2.967361] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to add ELD: -16
[ 2.968002] rk-hdmi-dp-sound hdmi-dp-sound: multicodec <-> ff8a0000.i2s mapping ok
[ 2.968060] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 2.969977]
[ 2.969989] =======================================================
[ 2.969999] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.970009] =======================================================
[ 2.970018] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 2.970030] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.970040] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.970048] RTL871X: module init start
[ 2.970056] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 2.970171] usbcore: registered new interface driver rtl8188eu
[ 2.970182] RTL871X: module init ret=0
[ 2.970197] otg_wakelock_init: No USB transceiver found
[ 2.970271] sensor_init: Probe name sensors
[ 2.970283] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.970324] dhd_module_init: in Dongle Host Driver, version 1.363.59.144.10 (r)
[ 2.970336] ======== dhd_wlan_init_plat_data ========
[ 2.970345] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 2.970353] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 2.970363] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.970373] dhd_wlan_init_gpio: host_oob_irq: 73
[ 2.970382] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 2.970390] dhd_wifi_platform_load: Enter
[ 2.970410] Power-up adapter 'DHD generic adapter'
[ 2.970439] wifi_platform_set_power = 1
[ 2.970447] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.970456] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.970464] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.971025] rk808-rtc rk808-rtc: setting system clock to 2018-05-24 07:39:10 UTC (1527147550)
[ 2.972363] It doesn't contain Rogue gpu
[ 2.991620] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-8fefd62', rk_ko_ver is '5', built at '14:47:26', on 'May 24 2018'.
[ 2.991992] Mali: Mali device driver loaded
[ 2.993763] input: rk29-keypad as /devices/platform/rockchip-key/input/input3
[ 2.994693] ALSA device list:
[ 2.994705] #0: ROCKCHIP,SPDIF
[ 2.994714] #1: rk-hdmi-dp-sound
[ 2.995191] Freeing unused kernel memory: 832K
[ 2.998998] init: init first stage started!
[ 2.999987] init: init second stage started!
[ 3.001923] init: Setting ro.rk.soc=rk3399
[ 3.001996] init: OK,EMMC DRIVERS INIT OK
[ 3.002022] init: property_set("ro.boot.mode", "emmc") failed
[ 3.002138] init: property_set("ro.hardware", "rk30board") failed
[ 3.002186] init: Running restorecon...
[ 3.002281] init: waitpid failed: No child processes
[ 3.002779] init: property_set("ro.board.platform", "rk3399") failed
[ 3.003083] init: property_set("ro.factory.hasGPS", "false") failed
[ 3.003248] init: property_set("ro.boot.noril", "true") failed
[ 3.003390] init: property_set("ro.rk.screenshot_enable", "true") failed
[ 3.003482] init: (Loading properties from /default.prop took 0.00s.)
[ 3.004010] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.004176] init: could not import file '/init.bootmode.emmc.rc' from '/init.rc': No such file or directory
c' 3.004216] init: could not import f ' erasinge_t.ext: en_US (88 from '/init.r
[ 3.004241] init : ( Pars ing /init.rcd_ ttexoot: ken_US (16s6 x 38 @ 1170).004334] init: Starting service 'ueventd'...
[ 3.004718]r _teitnit: Starting service 1'heal
thd'...
[ 3.005185] init: Waiting for /dev/.coldboot_done...
[ 3.005608] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.007223] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.007841] ueventd: ueventd started!
[ 3.007980] healthd: BatteryCurrentNowPath not found
[ 3.008001] healthd: BatteryCycleCountPath not found
[ 3.008459] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.008958] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.009082] ueventd: invalid gid 'trace'
[ 3.009393] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.009831] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.010097] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.063663] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.064524] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.065350] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 3.066250] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 3.146105] ueventd: Coldboot took 0.14s.
[ 3.146426] init: Waiting for /dev/.coldboot_done took 0.14s.
[ 3.146534] init: /dev/hw_random not found
[ 3.148192] init: /dev/hw_random not found
[ 3.149088] file system registered
[ 3.150660] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': Permission denied
[ 3.150736] init: write_file: Unable to open '/sys/class/android_usb/android0/idVendor': Permission denied
[ 3.150804] init: write_file: Unable to open '/sys/class/android_usb/android0/idProduct': Permission denied
[ 3.150867] init: write_file: Unable to open '/sys/class/android_usb/android0/f_ffs/aliases': No such file or directory
[ 3.150934] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': Permission denied
[ 3.151011] init: write_file: Unable to open '/sys/class/android_usb/android0/iManufacturer': Permission denied
[ 3.151083] init: write_file: Unable to open '/sys/class/android_usb/android0/iProduct': Permission denied
[ 3.151126] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[ 3.151151] init: write: cannot expand '${ro.serialno}'
[ 3.151577] init: finit_module for "/drmboot.ko" failed: Exec format errorinit: (Loading properties from /system/build.prop took 0.00s.)
[ 3.151740] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 3.151788] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 3.151968] fs_mgr: Warning: unknown flag resize
[ 3.152175] init: /recovery not specified in fstab
[ 3.152977] init: Starting service 'recovery'...
[ 3.153624] init: Starting service 'adbd'...
[ 3.154357] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': Permission denied
[ 3.154455] init: Starting service 'console'...
[ 3.155367] init: setsockcreatecon("") failed: Invalid argument
[ 3.172488] wifi_platform_bus_enumerate device present 1
[ 3.172501] ======== Card detection to detect SDIO card! ========
[ 3.172513] mmc2:mmc host rescan start!
[ 3.308939] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 253
[ 3.312140] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.312182] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 3.329240] bcmsdh_register: register client driver
[ 3.329498] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.329589] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.329603] bus num (host idx)=2, slot num (rca)=1
[ 3.329614] found adapter info 'DHD generic adapter'
[ 3.329660] sdioh_attach: set sd_f2_blocksize 256
[ 3.329992] F1 signature read @0x18000000=0x17224356
[ 3.333335] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 3.333788] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.333882] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 3.334760] wl_create_event_handler(): thread:wl_event_handler:ba started
[ 3.334843] tsk Enter, tsk = 0xffffffc0f0ac1a90
[ 3.335079] dhd_attach(): thread:dhd_watchdog_thread:bb started
[ 3.335170] dhd_attach(): thread:dhd_dpc:bc started
[ 3.335325] dhd_attach(): thread:dhd_rxf:bd started
[ 3.335344] dhd_deferred_work_init: work queue initialized
[ 3.343500] Dongle Host Driver, version 1.363.59.144.10 (r)
[ 3.344255] Register interface [wlan0] MAC: ac:83:f3:9e:4d:5e
[ 3.344255]
[ 3.344355] wl_event_handler: was terminated
[ 3.344385] wl_destroy_event_handler(): thread:wl_event_handler:ba terminated OK
[ 3.344401] dhd_wl_ioctl: re tur ning installin0g
[ 3en_.3443453] bcmsdh_oob_intr_unregister: Enter
[ 3.344463] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.344482] dhd_txglom_enable: enable 0
[ 3.344493] dhd_conf_set_txglom_params: swtxglom=0, txglom_exbot=0ot, modetxglmom_bu
parro.dalvik.vm.nativee.b=0, defe"05]- dhd_-wipe_all"x
]alvik.vm.isa,.arus_.variant=cortex-3.53.a1857
d dhald_cvonf_set_txglom_pam.features=defau,lt
daltvik.vm.isah.arm64.variant=cortex-aax=
vik. vm.isa.ar45m629]4 dhd_conf_set_txglou_pa
ms:dalvik.mvm.usejitt==tr0ue
daltvik.vm.heatmpsioze_fi=5x=01
3da445lv40] sdioh_srof.threshold=500
xgldom_modeik. vm.deto cot-Xpms=64m
d3.344550]. dhvmd_b.us_devreset-Xtmx=512m
N daOFFlDvik.vm.heapmaxf3re44606
widafilvi_pk.latvmfor.m_set_powenfrree= = 0
dal vi 3.k344617] ========ar PUtsLL iWL_REG_ON(
8] da[WlvLANik_RF.KILLm]: rocktprofilesw=truepodawlviker: 0
[ t3.hr3ead446
lvierda.k .vm.heapgrFKwthli wifmit=192mff
k.vm.stack-tra4ce-f4751] dhd_madule_init: xExi
dalevik.vm.image- 3de.34x6296] fs_mgr: Wa
3.35lvikn.vm.image-g ex2ozat-Xmx=64m
da76lvi9k.vm] fs_mgre Warninhrgeads=2
udanknlvowni fla.g resize
r[ge t 4.733764] Freeing.drm
dogalvo ikme.vmmo.imragey:dex 2oat660K
[ 4
r84o.c5onfi757] fusb302 .-0022: PDt disablled
r o.c onfig.ringtone=Rings_S (mymcblknth_04.oggmoruno.cteonfdig.a filesystem lert=Alarm_Classa c.ogg
rpts: (null)
[ c5ation_sound=pixi dust.ogg
1p12): mounted firint=Android/rkh33 ordered data mode. OHpts: (null)
514:userdebug/test-keys
pm.dexopt.boot=verify-profile
pm.dexopt.ab-ota=speed-profile
pm.dexopt.install=interpret-only
pm.dexopt.core-app=speed
pm.dexopt.bg-dexopt=speed-profile
pm.dexopt.first-boot=interpret-only
pm.dexopt.shared-apk=speed
pm.dexopt.nsys-library=speed
pm.dexopt.forced-dexopt=speed
ro.rk.soc=rk3399
ro.rk.bt_enable=true
ro.rk.systembar.tabletUI=false
ro.rk.systembar.voiceicon=true
ro.rk.MassStorage=false
ro.rk.hdmi_enable=true
ro.rk.flash_enable=true
ro.rk.homepage_base=http://www.baidu.com
ro.rk.def_brightness=200
ro.rk.screenoff_time=2147483647
ro.rk.screenshot_enable=false
ro.rk.LowBatteryBrightness=true
ro.rk.install_non_market_apps=false
ro.sf.hwrotation=0
ro.sf.lcd_density=240
ro.sf.fakerotation=false
ro.adb.secure=0
ro.com.google.gmsversion=7.1_r3
ro.com.android.dataroaming=true
ro.boot.mode=emmc
ro.boot.noril=false
ro.boot.console=ttyFIQ0
ro.boot.selinux=permissive
ro.boot.baseband=N/A
ro.boot.hardware=rk30board
ro.hwui.path_cache_size=32
ro.hwui.layer_cache_size=48
ro.hwui.texture_cache_size=72
ro.hwui.disable_scissor_opt=true
ro.hwui.gradient_cache_size=1
ro.hwui.r_buffer_cache_size=8
ro.hwui.drop_shadow_cache_size=6
ro.hwui.text_large_cache_width=2048
ro.hwui.text_small_cache_width=1024
ro.hwui.text_large_cache_height=1024
ro.hwui.text_small_cache_height=1024
ro.hwui.texture_cache_flushrate=0.4
ro.wifi.channels=
ro.allow.mock.location=0
ro.audio.monitorOrientation=true
ro.board.platform=rk3399
ro.build.id=NHG47K
ro.build.date=Thu May 24 15:14:24 CST 2018
ro.build.date.utc=1527146064
ro.build.host=ZIG-HP-Z228
ro.build.tags=test-keys
ro.build.type=userdebug
ro.build.user=zxy
ro.build.flavor=rk3399-userdebug
ro.build.display.id=rk3399-userdebug 7.1.2 NHG47K eng.zxy.20180524.151424 test-keys
ro.build.product=rk3399
ro.build.version.sdk=25
ro.build.version.base_os=
ro.build.version.release=7.1.2
ro.build.version.codename=REL
ro.build.version.incremental=eng.zxy.20180524.151424
ro.build.version.preview_sdk=0
ro.build.version.all_codenames=REL
ro.build.version.security_patch=2017-04-05
ro.build.description=rk3399-userdebug 7.1.2 NHG47K eng.zxy.20180524.151424 test-keys
ro.build.characteristics=tablet
ro.rksdk.version=RK30_ANDROID7.1.2-SDK-v1.00.00
ro.udisk.visible=true
ro.secure=1
ro.target.product=tablet
ro.tether.denied=false
ro.zygote=zygote64_32
ro.carrier=unknown
ro.default.size=100
ro.factory.tool=0
ro.factory.hasGPS=true
ro.factory.hasUMS=false
ro.factory.without_battery=false
ro.factory.storage_suppntfs=true
ro.product.cpu.abi=arm64-v8a
ro.product.cpu.abilist=arm64-v8a,armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=arm64-v8a
ro.product.name=rk3399
ro.product.board=rk30sdk
ro.product.brand=Android
ro.product.model=rk3399
ro.product.device=rk3399
ro.product.locale=en-US
ro.product.usbfactory=rockchip_usb
ro.product.manufacturer=rockchip
ro.product.first_api_level=25
ro.baseband=N/A
ro.bootmode=emmc
ro.hardware=rk30board
ro.opengles.version=196610
ro.revision=0
ro.safemode.disabled=true
ro.bootimage.build.date=Thu May 24 15:14:24 CST 2018
ro.bootimage.build.date.utc=1527146064
ro.bootimage.build.fingerprint=Android/rk3399/rk3399:7.1.2/NHG47K/zxy05241514:userdebug/test-keys
ro.bootloader=unknown
ro.debuggable=1
ro.lockscreen.disable.default=true
ro.setupwizard.mode=OPTIONAL
ro.enable_boot_charger_mode=0
sf.power.control=8847360
init.svc.adbd=running
init.svc.console=running
init.svc.healthd=running
init.svc.ueventd=running
init.svc.recovery=running
rild.libpath=/system/lib6[ 5.6erence-ri]l.sop widpfi.i minterface=wlaity
wifi.supplicant_scan_interval=15
camera2.portability.force_api=1
persist.tegra.nvmmlite=1
persist.enable.3g.dongle=true
testing.mediascanner.skiplist=/mnt/shell/emulated/Android/
keyguard.no_require_sim=true
ExternalSD_ROOT=/mnt/external_sd
InternalSD_ROOT=/mnt/internal_sd
UserVolumeLabel=RockChip
security.perf_harden=1
debug.nfc.se=false
debug.nfc.fw_download=false
debug.atrace.tags.enableflags=0
net.bt.name=Android
net.change=net.bt.name
sys.hwc.device.primary=HDMI-A
sys.hwc.compose_policy=6
sys.usb.controller=fe800000.dwc3
sys.dump.binder_stats.anr=1
sys.dump.binder_stats.uiwdt=1
sys.rkadb.root=0
sys.status.hidebar_enable=false
sys.display.timeline=0
sys.dropbox.max_size_kb=4096
sys.wallpaper.rgb565=0
sys.resolution.changed=false
persist.sys.ui.hw=true
persist.sys.usb.config=mtp,adb
persist.sys.dalvik.vm.lib.2=libart.so
persist.sys.timezone=Asia/Shanghai
persist.sys.strictmode.visual=false
persist.sys.framebuffer.main=1200x825
persist.sys.root_access=1
ro.ril.ecclist=112,911
ril.function.dataonly=1
sys.usb.config=adb
sys.usb.configfs=1
Supported API: 3
-- Wiping data...
Formatting /data...
F2FS-tools: mkfs.f2fs Ver: 1.7.0 (2016-07-28)
Info: Debug level = 0
Info: Label =
Info: Trim is disabled
Info: Segments per section = 1
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 54755328 (26736 MB)
Info: zone aligned segment0 blkaddr: 512
Info: format vers42ion] wirth
P "anLindux ovme:r sion 4..4f.283fs zuxy@ZIG-aHized urandom verd i(o1n6 4.9 201501, 923 (pbrereiltease) (GCop) ) #2 SMP )
REEMPT Thu May 24 14:55:26 CST 2018"
Info: Overprovision ratio = 1.230%
Info: Overprovision segments = 331 (GC reserved = 170)
Info: format successful
Formatting /cache...
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Journal blocks: 1024
Label:
Blocks: 32768
Block groups: 1
Reserved block group size: 7
Created filesystem with 11/8192 inodes and 1550/32768 blocks
[ 11.932311] random: nonblocking pool is initialized
[ 13.232205] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: (null)
Data wipe complete.
begin to wipe frp partion!
I:format_volume for: fs_type:emmc blk_device:/dev/block/platform/fe330000.sdhci/by-name/frp mount_point:/frp
E:format_volume: failed to open /dev/block/platform/fe330000.sdhci/by-name/frp
wiping frp failed!
I:Saving locale "en_US"
[ 13.296445] fs_mgr: Warning: unknown flag resize
Join led thread error!
Rebooting...
[ 13.324430] sysrq: SysRq : Emergency Remount R/O
[ 13.325261] EXT4-fs (mmcblk1p12): re-mounted. Opts: (null)
[ 13.325319] Emergency Remount complete
[ 13.369024] read descriptors
[ 13.369074] read descriptors
[ 13.369087] read strings
[ 13.425311] cpu4 limit freq=816000 min=816000 max=816000
[ 13.425515] cpu0 limit freq=816000 min=816000 max=816000
[ 13.426420] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 294; [Func] : kbase_platform_rk_shutdown(); to make vdd_gpu enabled for turning off pd_gpu in pm_framework.
[ 13.458980] rk-vcodec ff660000.rkvdec: vcodec shutdown
[ 13.465291] rk-vcodec ff650000.vpu_service: vcodec shutdown
[ 13.472047] reboot: Restarting system with command ''
Z籒隈>拖}?駷拖}|?^瀩"XK掆湖嬯?Z敫蔌隍J妺*鷠?}廳7摿dj}燑x?O!b*薣|?躌>}雙碘糐駘p0
U-Boot 2014.10-RK3399-06-02507-g99e11be-dirty (Dec 18 2017 - 12:28:55)
CPU: rk3399
cpu version = 0
CPU's clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Board: Rockchip platform Board
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(00000000ffe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
SdmmcInit = 0 20
storage init OK!
Using default environment
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
usb bc: can find node by path: /dwc-control-usb/usb_bc
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=66
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2017-12-18#1.09
empty serial no.
reboot normal.
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
failed to find panel driver
read logo on state from dts [1]
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 4 color_output 3 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
rockchip_panel_enable: failed to find panel prepare funcs
checkKey
vbus = 1
Hit any key to stop autoboot: 0
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x012b2808)
ramdisk @ 0x05bf0000 (0x001ad6f8)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000005600000, end 0000000005614a1e ... OK
Add bank:0000000000200000, 0000000008200000
Add bank:0000000009400000, 00000000eec00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Initializing cgroup subsys schedtune
[ 0.000000] Linux version 4.4.83 (zxy@ZIG-HP-Z228) (gcc version 4.9 20150123 (prerelease) (GCC) ) #2 SMP PREEMPT Thu May 24 14:55:26 CST 2018
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] hdmi init vic is -1
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef7000 s45696 r8192 d32128 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 995336
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00546000@0x000B4000(system),0x00008000@0x005FA000(metadata),0x00002000@0x00602000(baseparamer),-@0x00604000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-12-18_12:28:55 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB [mem 0xf6eaf000-0xf6eef000] (0MB) mapped at [ffffffc0f6eaf000-ffffffc0f6eeefff]
[ 0.000000] Memory: 3932636K/4044800K available (11582K kernel code, 1354K rwdata, 5316K rodata, 832K init, 1079K bss, 95780K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff8009110000 - 0xffffff80091e0000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bd0000 ( 11584 KB)
[ 0.000000] .rodata : 0xffffff8008bd0000 - 0xffffff8009110000 ( 5376 KB)
[ 0.000000] .data : 0xffffff80091e0000 - 0xffffff8009332808 ( 1355 KB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[ 0.000000] ITS: allocated 65536 Devices @f2000000 (psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x00000000f2080000
[ 0.000000] ITS: Allocated 1792 chunks for LPIs
[ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2090000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.009822] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.021104] pid_max: default: 32768 minimum: 301
[ 0.026255] Security Framework initialized
[ 0.030796] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.038163] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.046783] Initializing cgroup subsys freezer
[ 0.051678] Initializing cgroup subsys debug
[ 0.057206] sched-energy: Sched-energy-costs installed from DT
[ 0.063630] CPU0: update cpu_capacity 401
[ 0.068083] ASID allocator initialised with 65536 entries
[ 0.090893] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.100936] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.124598] Detected VIPT I-cache on CPU1
[ 0.124629] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.124665] CPU1: using LPI pending table @0x00000000f2200000
[ 0.124707] CPU1: update cpu_capacity 401
[ 0.124710] CPU1: Booted secondary processor [410fd034]
[ 0.134592] Detected VIPT I-cache on CPU2
[ 0.134611] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.134643] CPU2: using LPI pending table @0x00000000f2230000
[ 0.134670] CPU2: update cpu_capacity 401
[ 0.134673] CPU2: Booted secondary processor [410fd034]
[ 0.144631] Detected VIPT I-cache on CPU3
[ 0.144650] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.144682] CPU3: using LPI pending table @0x00000000f2270000
[ 0.144708] CPU3: update cpu_capacity 401
[ 0.144711] CPU3: Booted secondary processor [410fd034]
[ 0.154680] Detected PIPT I-cache on CPU4
[ 0.154707] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.154746] CPU4: using LPI pending table @0x00000000f22b0000
[ 0.154787] CPU4: update cpu_capacity 1024
[ 0.154789] CPU4: Booted secondary processor [410fd082]
[ 0.164700] Detected PIPT I-cache on CPU5
[ 0.164717] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.164753] CPU5: using LPI pending table @0x00000000f22e0000
[ 0.164780] CPU5: update cpu_capacity 1024
[ 0.164783] CPU5: Booted secondary processor [410fd082]
[ 0.164864] Brought up 6 CPUs
[ 0.307336] SMP: Total of 6 processors activated.
[ 0.312507] CPU features: detected feature: GIC system register CPU interface
[ 0.320351] CPU: All CPU(s) started at EL2
[ 0.324888] alternatives: patching kernel code
[ 0.332286] devtmpfs: initialized
[ 0.349130] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.359875] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.367465] pinctrl core: initialized pinctrl subsystem
[ 0.374562] Failed to find legacy iommu devices
[ 0.379899] NET: Registered protocol family 16
[ 0.385176] schedtune: init normalization constants...
[ 0.390833] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.398016] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.405197] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.412377] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.419557] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.426738] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.433916] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.441095] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.448276] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.455455] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.463881] schedtune: verify normalization constants...
[ 0.469725] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.475853] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.481979] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.488107] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.494235] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.500361] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.506488] schedtune: configured to support 5 boost groups
[ 0.525982] cpuidle: using governor ladder
[ 0.543856] cpuidle: using governor menu
[ 0.548207] Registered FIQ tty driver
[ 0.552595] vdso: 2 pages (1 code @ ffffff8008bd6000, 1 data @ ffffff80091e4000)
[ 0.560757] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.568924] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.596436] console [pstore0] enabled
[ 0.600653] pstore: Registered ramoops as persistent store backend
[ 0.607464] ramoops: attached 0xf0000@0x110000, ecc: 0/0
<hit enter to activate fiq debugger>
[ 0.615700] console [ttyFIQ0] enabled
[[ 0.615700] console [ttyFIQ0] enabled
[ 0.622962] bootconsole [uart0] disabled
[ 0.634983] Registered fiq debugger ttyFIQ0
[ 0.672541] Rockchip hdmi driver version 2.0
[ 0.674833] iommu: Adding device ff650000.vpu_service to group 0
[ 0.674928] iommu: Adding device ff660000.rkvdec to group 1
[ 0.674995] iommu: Adding device ff670000.iep to group 2
[ 0.675089] iommu: Adding device ff8f0000.vop to group 3
[ 0.675167] iommu: Adding device ff900000.vop to group 4
[ 0.675261] iommu: Adding device ff910000.isp to group 5
[ 0.675340] iommu: Adding device ff920000.isp to group 6
[ 0.675995] rk_iommu ff670800.iommu: can't get aclk
[ 0.676012] rk_iommu ff670800.iommu: can't get hclk
[ 0.676847] SCSI subsystem initialized
[ 0.677032] usbcore: registered new interface driver usbfs
[ 0.677089] usbcore: registered new interface driver hub
[ 0.677194] usbcore: registered new device driver usb
[ 0.677551] media: Linux media interface: v0.10
[ 0.677590] Linux video capture interface: v2.00
[ 0.677722] pps_core: LinuxPPS API ver. 1 registered
[ 0.677734] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.677762] PTP clock support registered
[ 0.682394] Advanced Linux Sound Architecture Driver Initialized.
[ 0.682846] Bluetooth: Core ver 2.21
[ 0.682876] NET: Registered protocol family 31
[ 0.682886] Bluetooth: HCI device and connection manager initialized
[ 0.682903] Bluetooth: HCI socket layer initialized
[ 0.682919] Bluetooth: L2CAP socket layer initialized
[ 0.682945] Bluetooth: SCO socket layer initialized
[ 0.685619] rockchip-cpuinfo cpuinfo: Serial : 0000000000000000
[ 0.686124] clocksource: Switched to clocksource arch_sys_counter
[ 0.720726] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.720944] NET: Registered protocol family 2
[ 0.721349] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.721533] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.721759] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.721838] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.721885] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.722061] NET: Registered protocol family 1
[ 0.722512] Trying to unpack rootfs image as initramfs...
[ 0.809939] Freeing initrd memory: 1716K
[ 0.810482] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.810572] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.813313] audit: initializing netlink subsys (disabled)
[ 0.813365] audit: type=2000 audit(0.690:1): initialized
[ 0.818205] VFS: Disk quotas dquot_6.6.0
[ 0.818324] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.819671] fuse init (API version 7.23)
[ 0.820272]
[ 0.820272] TEE Core Framework initialization (ver 1:0.1)
[ 0.820305] TEE armv7 Driver initialization
[ 0.820623] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 0.820639] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 0.820789] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[ 0.824126] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.824152] io scheduler noop registered
[ 0.824316] io scheduler cfq registered (default)
[ 0.825589] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.829731] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.829752] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.829770] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.352873] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.353052] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.354515] iep: failed to find iep power down clock source.
[ 1.355097] IEP Power ON
[ 1.355309] IEP Power OFF
[ 1.355410] IEP Driver loaded succesfully
[ 1.355605] Module initialized.
[ 1.356184] rk-vcodec ff650000.vpu_service: probe device
[ 1.356236] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f18b6810
[ 1.356402] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.356460] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.356864] rk-vcodec ff650000.vpu_service: init success
[ 1.360647] rk-vcodec ff660000.rkvdec: probe device
[ 1.360694] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f18b7010
[ 1.360847] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.360905] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.361185] rk-vcodec ff660000.rkvdec: init success
[ 1.362542] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.362562] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.363922] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.363941] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.365070] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.366559] console [ttyS0] disabled
[ 1.366591] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 1.367103] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.367616] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.367939] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.372123] mali ff9a0000.gpu: Failed to get regulator
[ 1.372140] mali ff9a0000.gpu: Power control initialization failed
[ 1.372374] Unable to detect cache hierarchy from DT for CPU 0
[ 1.413303] brd: module loaded
[ 1.437160] loop: module loaded
[ 1.446527] zram: Added device: zram0
[ 1.447061] SCSI Media Changer driver v0.25
[ 1.447559] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 1.447580] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 1.447597] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 1.447614] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 1.447747] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.447762] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.449832] tun: Universal TUN/TAP device driver, 1.6
[ 1.449844] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.450767] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.450786] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.450800] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.450832] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.451004] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.456024] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.456094] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.456105] Ring mode enabled
[ 1.456126] DMA HW capability register supported
[ 1.456136] Normal descriptors
[ 1.456147] RX Checksum Offload Engine supported (type 2)
[ 1.456158] TX Checksum insertion supported
[ 1.456167] Wake-Up On Lan supported
[ 1.456210] Enable RX Mitigation via HW Watchdog Timer
[ 1.523685] libphy: stmmac: probed
[ 1.523700] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.523714] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.524414] PPP generic driver version 2.4.2
[ 1.524567] PPP BSD Compression module registered
[ 1.524584] PPP Deflate Compression module registered
[ 1.524616] PPP MPPE Compression module registered
[ 1.524639] NET: Registered protocol family 24
[ 1.524689] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.524703] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.524726] Rockchip WiFi SYS interface (V1.00) ...
[ 1.524810] usbcore: registered new interface driver catc
[ 1.524856] usbcore: registered new interface driver kaweth
[ 1.524874] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.524911] usbcore: registered new interface driver pegasus
[ 1.524956] usbcore: registered new interface driver rtl8150
[ 1.525000] usbcore: registered new interface driver r8152
[ 1.525018] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.525079] usbcore: registered new interface driver hso
[ 1.525131] usbcore: registered new interface driver asix
[ 1.525175] usbcore: registered new interface driver ax88179_178a
[ 1.525220] usbcore: registered new interface driver cdc_ether
[ 1.525264] usbcore: registered new interface driver cdc_eem
[ 1.525311] usbcore: registered new interface driver dm9601
[ 1.525365] usbcore: registered new interface driver smsc75xx
[ 1.525419] usbcore: registered new interface driver smsc95xx
[ 1.525462] usbcore: registered new interface driver gl620a
[ 1.525506] usbcore: registered new interface driver net1080
[ 1.525552] usbcore: registered new interface driver plusb
[ 1.525597] usbcore: registered new interface driver rndis_host
[ 1.525642] usbcore: registered new interface driver cdc_subset
[ 1.525686] usbcore: registered new interface driver zaurus
[ 1.525733] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.525796] usbcore: registered new interface driver int51x1
[ 1.525841] usbcore: registered new interface driver kalmia
[ 1.525885] usbcore: registered new interface driver ipheth
[ 1.525932] usbcore: registered new interface driver sierra_net
[ 1.525977] usbcore: registered new interface driver cx82310_eth
[ 1.526034] usbcore: registered new interface driver cdc_ncm
[ 1.526078] usbcore: registered new interface driver qmi_wwan
[ 1.526154] usbcore: registered new interface driver cdc_mbim
[ 1.527289] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.530268] rockchip-typec-phy ff800000.phy: mode = 0, id = 0
[ 1.530286] rockchip-typec-phy ff800000.phy: new_mode = 2
[ 1.530300] rockchip-typec-phy ff800000.phy: tcphy->mode = 0, new_mode = 2
[ 1.532649] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.533252] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.533273] ehci-pci: EHCI PCI platform driver
[ 1.533331] ehci-platform: EHCI generic platform driver
[ 1.537127] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.537157] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.537301] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.546144] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.546280] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.546297] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.546311] usb usb1: Product: EHCI Host Controller
[ 1.546324] usb usb1: Manufacturer: Linux 4.4.83 ehci_hcd
[ 1.546335] usb usb1: SerialNumber: fe3c0000.usb
[ 1.546769] hub 1-0:1.0: USB hub found
[ 1.546802] hub 1-0:1.0: 1 port detected
[ 1.547276] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.547307] ohci-platform: OHCI generic platform driver
[ 1.547751] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.547782] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.547889] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.603606] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.603623] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.603638] usb usb2: Product: Generic Platform OHCI controller
[ 1.603651] usb usb2: Manufacturer: Linux 4.4.83 ohci_hcd
[ 1.603663] usb usb2: SerialNumber: fe3e0000.usb
[ 1.604062] hub 2-0:1.0: USB hub found
[ 1.604096] hub 2-0:1.0: 1 port detected
[ 1.604855] usbcore: registered new interface driver cdc_acm
[ 1.604869] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.604931] usbcore: registered new interface driver usblp
[ 1.604977] usbcore: registered new interface driver cdc_wdm
[ 1.605021] usbcore: registered new interface driver uas
[ 1.605092] usbcore: registered new interface driver usb-storage
[ 1.605133] usbcore: registered new interface driver ums-alauda
[ 1.605174] usbcore: registered new interface driver ums-cypress
[ 1.605214] usbcore: registered new interface driver ums-datafab
[ 1.605254] usbcore: registered new interface driver ums_eneub6250
[ 1.605295] usbcore: registered new interface driver ums-freecom
[ 1.605335] usbcore: registered new interface driver ums-isd200
[ 1.605375] usbcore: registered new interface driver ums-jumpshot
[ 1.605413] usbcore: registered new interface driver ums-karma
[ 1.605456] usbcore: registered new interface driver ums-onetouch
[ 1.605497] usbcore: registered new interface driver ums-sddr09
[ 1.605537] usbcore: registered new interface driver ums-sddr55
[ 1.605576] usbcore: registered new interface driver ums-usbat
[ 1.605656] usbcore: registered new interface driver usbserial
[ 1.605695] usbcore: registered new interface driver usbserial_generic
[ 1.605726] usbserial: USB Serial support registered for generic
[ 1.605772] usbcore: registered new interface driver option
[ 1.605802] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.605898] usbcore: registered new interface driver trancevibrator
[ 1.605914] usb20_otg: version 3.10a 21-DEC-2012
[ 1.606069] usb20_host: version 3.10a 21-DEC-2012
[ 1.609846] usbcore: registered new interface driver xpad
[ 1.609895] usbcore: registered new interface driver usb_acecad
[ 1.609941] usbcore: registered new interface driver aiptek
[ 1.609986] usbcore: registered new interface driver gtco
[ 1.610031] usbcore: registered new interface driver hanwang
[ 1.610077] usbcore: registered new interface driver kbtab
[ 1.610113] Successfully added driver ft5x0x_ts
[ 1.610393] .. rk pwm remotectl v1.1 init
[ 1.610611] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.610859] remotectl-pwm ff420030.pwm: Missing psci property in the DT.
[ 1.610967] sensor_register_slave:mma8452,id=17
[ 1.610983] sensor_register_slave:lis3dh,id=7
[ 1.610997] sensor_register_slave:mma7660,id=18
[ 1.611011] sensor_register_slave:lsm303d,id=22
[ 1.611025] sensor_register_slave:gs_mc3230,id=23
[ 1.611035] [Gsensor] gsensor_init
[ 1.611048] sensor_register_slave:mpu6880_acc,id=24
[ 1.611063] sensor_register_slave:mpu6500_acc,id=25
[ 1.611077] sensor_register_slave:lsm330_acc,id=26
[ 1.611092] sensor_register_slave:akm8975,id=28
[ 1.611105] sensor_register_slave:akm8963,id=29
[ 1.611120] sensor_register_slave:l3g4200d,id=43
[ 1.611133] sensor_register_slave:l3g20d,id=44
[ 1.611147] sensor_register_slave:ewtsa,id=45
[ 1.611161] sensor_register_slave:lsm330_gyro,id=48
[ 1.611175] sensor_register_slave:cm3217,id=50
[ 1.611189] sensor_register_slave:cm3218,id=51
[ 1.611788] i2c /dev entries driver
[ 1.612875] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.612936] fan53555-reg: supplied by vcc5v0_sys
[ 1.614928] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.614977] fan53555-reg: supplied by vcc5v0_sys
[ 1.617036] rk808 0-001b: Pmic Chip id: 0x0
[ 1.619697] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.619750] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.619831] DCDC_REG1: supplied by vcc3v3_sys
[ 1.620485] DCDC_REG2: supplied by vcc3v3_sys
[ 1.620977] DCDC_REG3: supplied by vcc3v3_sys
[ 1.621180] DCDC_REG4: supplied by vcc3v3_sys
[ 1.621541] LDO_REG1: supplied by vcc3v3_sys
[ 1.622582] LDO_REG2: supplied by vcc3v3_sys
[ 1.623460] LDO_REG3: supplied by vcc3v3_sys
[ 1.624341] LDO_REG4: supplied by vcc3v3_sys
[ 1.625234] LDO_REG5: supplied by vcc3v3_sys
[ 1.626109] LDO_REG6: supplied by vcc3v3_sys
[ 1.627019] LDO_REG7: supplied by vcc3v3_sys
[ 1.627902] LDO_REG8: supplied by vcc3v3_sys
[ 1.628797] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.629002] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.632214] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.632630] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096fc000
[ 1.632732] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.632751] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.632766] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.632822] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.633183] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80096fe000
[ 1.646374] fusb302 4-0022: port 0 probe success
[ 1.646510] ft5x0x_ts############################
[ 1.646522] ft5x0x_ts_probe-373
[ 1.712510] fusb302 4-0022: CC connected in 0 as UFP
[ 1.852812] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.856589] input: ft5x0x_ts as /devices/virtual/input/input1
[ 1.976726] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.976745] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.976761] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.977216] hub 1-1:1.0: USB hub found
[ 1.977349] hub 1-1:1.0: 7 ports detected
[ 2.009643] ft5x0x_ts 4-0038: fft5x0x_i2c_Read: i2c read error.
[ 2.009658] [FTS]####### Firmware version = 0x8b
[ 2.009830] ft5x0x_ts 4-0038: fft5x0x_i2c_Read: i2c read error.
[ 2.009843] [FTS]####### report rate is 1390Hz.
[ 2.010014] ft5x0x_ts 4-0038: fft5x0x_i2c_Read: i2c read error.
[ 2.010029] #######ft5x0x_ts_probe ok !!!!483
[ 2.010056] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009742000
[ 2.010963] IR NEC protocol handler initialized
[ 2.010980] IR RC5(x/sz) protocol handler initialized
[ 2.010997] IR RC6 protocol handler initialized
[ 2.011013] IR JVC protocol handler initialized
[ 2.011029] IR Sony protocol handler initialized
[ 2.011045] IR SANYO protocol handler initialized
[ 2.011061] IR Sharp protocol handler initialized
[ 2.011077] IR MCE Keyboard/mouse protocol handler initialized
[ 2.011094] IR XMP protocol handler initialized
[ 2.011178] usbcore: registered new interface driver uvcvideo
[ 2.011189] USB Video Class driver (1.1.1)
[ 2.011208] CamSys driver version: v0.34.5, CamSys head file version: v0.13.0
[ 2.015228] __power_supply_register: Expected proper parent device for 'test_ac'
[ 2.015353] __power_supply_register: Expected proper parent device for 'test_battery'
[ 2.015587] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.015688] __power_supply_register: Expected proper parent device for 'test_usb'
[ 2.017781] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.018343] device-mapper: uevent: version 1.0.3
[ 2.018606] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.022086] Bluetooth: HCI UART driver ver 2.3
[ 2.022101] Bluetooth: HCI UART protocol H4 registered
[ 2.022112] Bluetooth: HCI UART protocol LL registered
[ 2.022126] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.022137] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.022149] rtk_btusb: Register usb char device interface for BT driver
[ 2.022394] usbcore: registered new interface driver rtk_btusb
[ 2.025439] sdhci: Secure Digital Host Controller Interface driver
[ 2.025453] sdhci: Copyright(c) Pierre Ossman
[ 2.025464] Synopsys Designware Multimedia Card Interface Driver
[ 2.026105] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.026238] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.026257] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.026297] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.026329] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.026370] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.026380] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.026977] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.027015] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.027032] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.027065] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.027084] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.027161] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.027356] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.027371] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 2.039567] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.053912] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.054119] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.055676] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.055688] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.082867] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.083539] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.085530] usbcore: registered new interface driver usbhid
[ 2.085541] usbhid: USB HID core driver
[ 2.085648] inv_mpu_iio: inv_mpu_init:746
[ 2.087064] ashmem: initialized
[ 2.089280] ff100000.saradc supply vref not found, using dummy regulator
[ 2.096685] rknandbase v1.1 2016-11-08
[ 2.097125] usbcore: registered new interface driver snd-usb-audio
[ 2.101793] u32 classifier
[ 2.101806] Actions configured
[ 2.101843] Netfilter messages via NETLINK v0.30.
[ 2.101897] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.102213] ctnetlink v0.93: registering with nfnetlink.
[ 2.102872] xt_time: kernel timezone is -0000
[ 2.104470] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.104730] arp_tables: (C) 2002 David S. Miller
[ 2.105165] Initializing XFRM netlink socket
[ 2.105540] NET: Registered protocol family 10
[ 2.106284] mip6: Mobile IPv6
[ 2.106310] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.108206] sit: IPv6 over IPv4 tunneling driver
[ 2.108590] NET: Registered protocol family 17
[ 2.108614] NET: Registered protocol family 15
[ 2.108646] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.109311] Bridge firewalling registered
[ 2.109324] Ebtables v2.0 registered
[ 2.109522] Bluetooth: RFCOMM TTY layer initialized
[ 2.109540] Bluetooth: RFCOMM socket layer initialized
[ 2.109563] Bluetooth: RFCOMM ver 1.11
[ 2.109582] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.109591] Bluetooth: BNEP filters: protocol multicast
[ 2.109604] Bluetooth: BNEP socket layer initialized
[ 2.109617] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.109629] Bluetooth: HIDP socket layer initialized
[ 2.109667] l2tp_core: L2TP core driver, V2.0
[ 2.109685] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.109698] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.109931] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.109982] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 2.109993] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.110003] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.110054] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 1003, flags = 0.
[ 2.110065] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.110076] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.110120] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.110384] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 1083.
[ 2.110419] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 1009.
[ 2.110446] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 1090.
[ 2.110472] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 1004.
[ 2.110693] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.110739] [BT_RFKILL]: ** disable irq
[ 2.110845] [BT_RFKILL]: bt_default device registered.
[ 2.111045] sensor_register_slave:mpu6880_gyro,id=47
[ 2.111434] Registered cp15_barrier emulation handler
[ 2.111528] Registered setend emulation handler
[ 2.112111] registered taskstats version 1
[ 2.112635] rockchip ion idev is NULL
[ 2.112648] rga2 ff680000.rga: rga ion client create success!
[ 2.112883] rga: Driver loaded successfully ver:3.02
[ 2.113010] pvtm list NULL
[ 2.113695] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 2.114957] rockchip-vop ff900000.vop: failed to get vop register byname
[ 2.114991] rockchip-vop ff900000.vop: invalid resource
[ 2.115002] rockchip-vop ff900000.vop: failed to get vop lut registers
[ 2.115013] rockchip-vop ff900000.vop: invalid resource
[ 2.115022] rockchip-vop ff900000.vop: failed to get vop cabc lut registers
[ 2.115179] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 2.115204] rockchip-vop ff8f0000.vop: failed to get vop register byname
[ 2.115227] rockchip-vop ff8f0000.vop: invalid resource
[ 2.115237] rockchip-vop ff8f0000.vop: failed to get vop lut registers
[ 2.115247] rockchip-vop ff8f0000.vop: invalid resource
[ 2.115256] rockchip-vop ff8f0000.vop: failed to get vop cabc lut registers
[ 2.115373] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 2.115755] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.115780] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.115840] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.120295] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 2.120713] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 2.120729] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.120741] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 2.121128] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.128625] mmc1: MAN_BKOPS_EN bit is not set
[ 2.141335] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.145227] mmcblk1: mmc1:0001 BJNB4R 29.1 GiB
[ 2.145432] mmcblk1boot0: mmc1:0001 BJNB4R partition 1 4.00 MiB
[ 2.148993] mmcblk1boot1: mmc1:0001 BJNB4R partition 2 4.00 MiB
[ 2.149298] mmcblk1rpmb: mmc1:0001 BJNB4R partition 3 4.00 MiB
[ 2.149779] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 2.149794] trust: 0x000800000 -- 0x000c00000 (4 MB)
[ 2.149805] misc: 0x000c00000 -- 0x001000000 (4 MB)
[ 2.149815] resource: 0x001000000 -- 0x002000000 (16 MB)
[ 2.149825] kernel: 0x002000000 -- 0x003800000 (24 MB)
[ 2.149835] boot: 0x003800000 -- 0x005800000 (32 MB)
[ 2.149844] recovery: 0x005800000 -- 0x007800000 (32 MB)
[ 2.149854] backup: 0x007800000 -- 0x00e800000 (112 MB)
[ 2.149864] cache: 0x00e800000 -- 0x016800000 (128 MB)
[ 2.149873] system: 0x016800000 -- 0x0bf400000 (2700 MB)
[ 2.149883] metadata: 0x0bf400000 -- 0x0c0400000 (16 MB)
[ 2.149892] baseparamer: 0x0c0400000 -- 0x0c0800000 (4 MB)
[ 2.149902] userdata: 0x0c0800000 -- 0x747800000 (26736 MB)
[ 2.149941] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 2.259477] usb 1-1.1: new low-speed USB device number 3 using ehci-platform
[ 2.360152] usb 1-1.1: New USB device found, idVendor=04f3, idProduct=0235
[ 2.360171] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.360184] usb 1-1.1: Product: OM
[ 2.363872] input: OM as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:04F3:0235.0001/input/input2
[ 2.364332] hid-generic 0003:04F3:0235.0001: input,hidraw0: USB HID v1.11 Mouse [OM] on usb-fe3c0000.usb-1.1/input0
[ 2.583241] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.601598] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.602684] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.606896] mali ff9a0000.gpu: Probed as mali0
[ 2.610669] rockchip-typec-phy ff7c0000.phy: ufp = 1, dfp = 0, dp = 0
[ 2.610695] rockchip-typec-phy ff7c0000.phy: new_mode = 1
[ 2.610709] rockchip-typec-phy ff7c0000.phy: tcphy->mode = 0, new_mode = 1
[ 2.615065] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.615131] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 2.615501] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 2.615593] xhci-hcd xhci-hcd.10.auto: irq 232, io mem 0xfe800000
[ 2.615819] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.615836] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.615872] usb usb3: Product: xHCI Host Controller
[ 2.615889] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.615901] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 2.616774] hub 3-0:1.0: USB hub found
[ 2.616834] hub 3-0:1.0: 1 port detected
[ 2.617299] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.617324] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.617422] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.617606] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.617628] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.617642] usb usb4: Product: xHCI Host Controller
[ 2.617655] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.617667] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.618418] hub 4-0:1.0: USB hub found
[ 2.618478] hub 4-0:1.0: 1 port detected
[ 2.619182] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.619230] usb usb4: USB disconnect, device number 1
[ 2.620067] xhci-hcd xhci-hcd.10.auto: USB bus 4 deregistered
[ 2.620091] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 2.620113] usb usb3: USB disconnect, device number 1
[ 2.620868] xhci-hcd xhci-hcd.10.auto: USB bus 3 deregistered
[ 2.621246] rockchip-dwc3 usb@fe800000: USB peripheral not support!
[ 2.625369] rockchip-typec-phy ff800000.phy: mode = 0, id = 0
[ 2.625390] rockchip-typec-phy ff800000.phy: new_mode = 2
[ 2.625405] rockchip-typec-phy ff800000.phy: tcphy->mode = 0, new_mode = 2
[ 2.627859] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.627909] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.628278] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 2.628344] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe900000
[ 2.628626] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.628658] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.628676] usb usb3: Product: xHCI Host Controller
[ 2.628689] usb usb3: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.628703] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.629616] hub 3-0:1.0: USB hub found
[ 2.629696] hub 3-0:1.0: 1 port detected
[ 2.630194] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.630223] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.630341] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.630522] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.630555] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.630574] usb usb4: Product: xHCI Host Controller
[ 2.630587] usb usb4: Manufacturer: Linux 4.4.83 xhci-hcd
[ 2.630599] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 2.631415] hub 4-0:1.0: USB hub found
[ 2.631459] hub 4-0:1.0: 1 port detected
[ 2.632313] vendor storage:20160801 ret = 0
[ 2.636166] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.636200] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 2.636488] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.646166] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.646346] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.646363] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.646378] usb usb5: Product: EHCI Host Controller
[ 2.646391] usb usb5: Manufacturer: Linux 4.4.83 ehci_hcd
[ 2.646404] usb usb5: SerialNumber: fe380000.usb
[ 2.647013] hub 5-0:1.0: USB hub found
[ 2.647056] hub 5-0:1.0: 1 port detected
[ 2.647977] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.648008] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 2.648184] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.703713] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.703732] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.703747] usb usb6: Product: Generic Platform OHCI controller
[ 2.703761] usb usb6: Manufacturer: Linux 4.4.83 ohci_hcd
[ 2.703774] usb usb6: SerialNumber: fe3a0000.usb
[ 2.704781] hub 6-0:1.0: USB hub found
[ 2.704836] hub 6-0:1.0: 1 port detected
[ 2.706455] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.706568] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.706589] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.706629] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.706657] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.706717] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.706731] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.707103] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.719639] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.733029] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.738119] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[ 2.741754] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 2.741783] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to add ELD: -16
[ 2.742435] rk-hdmi-dp-sound hdmi-dp-sound: multicodec <-> ff8a0000.i2s mapping ok
[ 2.742530] hdmi-audio-codec hdmi-audio-codec.9.auto: ASoC: Failed to create Playback debugfs file
[ 2.744302]
[ 2.744313] =======================================================
[ 2.744322] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.744332] =======================================================
[ 2.744341] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 2.744353] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.744363] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.744371] RTL871X: module init start
[ 2.744379] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 2.744486] usbcore: registered new interface driver rtl8188eu
[ 2.744496] RTL871X: module init ret=0
[ 2.744512] otg_wakelock_init: No USB transceiver found
[ 2.744586] sensor_init: Probe name sensors
[ 2.744597] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.744637] dhd_module_init: in Dongle Host Driver, version 1.363.59.144.10 (r)
[ 2.744648] ======== dhd_wlan_init_plat_data ========
[ 2.744658] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 2.744666] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 2.744675] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.744686] dhd_wlan_init_gpio: host_oob_irq: 73
[ 2.744694] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 2.744702] dhd_wifi_platform_load: Enter
[ 2.744723] Power-up adapter 'DHD generic adapter'
[ 2.744772] wifi_platform_set_power = 1
[ 2.744781] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.744790] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.744798] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.745398] rk808-rtc rk808-rtc: setting system clock to 2018-05-24 07:39:25 UTC (1527147565)
[ 2.745986] It doesn't contain Rogue gpu
[ 2.756844] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-8fefd62', rk_ko_ver is '5', built at '14:47:26', on 'May 24 2018'.
[ 2.757037] Mali: Mali device driver loaded
[ 2.757428] input: rk29-keypad as /devices/platform/rockchip-key/input/input3
[ 2.758057] ALSA device list:
[ 2.758067] #0: ROCKCHIP,SPDIF
[ 2.758075] #1: rk-hdmi-dp-sound
[ 2.758555] Freeing unused kernel memory: 832K
[ 2.762330] init: init first stage started!
[ 2.763348] init: init second stage started!
[ 2.765285] init: Setting ro.rk.soc=rk3399
[ 2.765358] init: OK,EMMC DRIVERS INIT OK
[ 2.765383] init: property_set("ro.boot.mode", "emmc") failed
[ 2.765445] init: property_set("ro.hardware", "rk30board") failed
[ 2.765493] init: Running restorecon...
[ 2.765587] init: waitpid failed: No child processes
[ 2.765861] init: (Loading properties from /default.prop took 0.00s.)
[ 2.767279] init: /init.rc: 592: invalid keyword 'echo'
[ 2.767651] init: (Parsing /init.environ.rc took 0.00s.)
[ 2.768022] init: (Parsing /init.usb.rc took 0.00s.)
[ 2.768796] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 2.769490] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 2.769546] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 2.769623] init: could not import file '/init.stt_trace.rc' from '/init.debug.rc': No such file or directory
[ 2.769660] init: could not import file '/init.logs.rc' from '/init.debug.rc': No such file or directory
[ 2.769694] init: could not import file '/init.crashlogd.rc' from '/init.debug.rc': No such file or directory
[ 2.769729] init: could not import file '/init.coredump.rc' from '/init.debug.rc': No such file or directory
[ 2.769766] init: could not import file '/init.log-watch.rc' from '/init.debug.rc': No such file or directory
[ 2.769828] init: (Parsing /init.kernel.rc took 0.00s.)
[ 2.769931] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 2.769951] init: (Parsing /init.debug.rc took 0.00s.)
[ 2.769968] init: (Parsing init.rockchip.rc took 0.00s.)
[ 2.770353] init: (Parsing init.connectivity.rc took 0.00s.)
[ 2.770390] init: could not import file 'init.box.samba.rc' from '/init.rk30board.rc': No such file or directory
[ 2.770493] init: (Parsing init.rk3399.rc took 0.00s.)
[ 2.770610] init: ignored duplicate definition of service 'serio'init: (Parsing init.tablet.rc took 0.00s.)
[ 2.770663] init: could not import file 'init.car.rc' from '/init.rk30board.rc': No such file or directory
[ 2.770697] init: could not import file 'init.optee.rc' from '/init.rk30board.rc': No such file or directory
[ 2.770718] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 2.771324] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 2.771422] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 2.771441] init: (Parsing /init.rc took 0.01s.)
[ 2.771692] init: Starting service 'ueventd'...
[ 2.774609] ueventd: ueventd started!
[ 2.774797] init: write_file: Unable to open '/proc/sys/kernel/panic_on_stackoverflow': No such file or directory
[ 2.774835] init: Waiting for /dev/.coldboot_done...
[ 2.775688] ueventd: invalid gid 'trace'
[ 2.777407] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.778988] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.780568] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.783400] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.839044] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 2.903719] ueventd: Coldboot took 0.13s.
[ 2.907028] init: Waiting for /dev/.coldboot_done took 0.13s.
[ 2.907166] init: /dev/hw_random not found
[ 2.908163] keychord: using input dev ff420030.pwm for fevent
[ 2.908201] keychord: using input dev rk29-keypad for fevent
[ 2.912557] init: write_file: Unable to open '/proc/cpu/alignment': No such file or directory
[ 2.922363] Registered swp emulation handler
[ 2.922622] init: write_file: Unable to open '/sys/module/rockchip_pm/parameters/policy': No such file or directory
[ 2.923647] fs_mgr: Warning: unknown flag resize
[ 2.923830] init: /dev/hw_random not found
[ 2.924008] init: write_file: Unable to open '/sys/block/mmcblk0/bdi/read_ahead_kb': No such file or directory
[ 2.924804] fs_mgr: Warning: unknown flag resize
[ 2.929253] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.929316] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 2.930600] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 2.931352] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 2.938470] random: e2fsck: uninitialized urandom read (40 bytes read, 41 bits of entropy available)
[ 2.939602] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 250
[ 2.943185] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.943229] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.946140] wifi_platform_bus_enumerate device present 1
[ 2.946155] ======== Card detection to detect SDIO card! ========
[ 2.946166] mmc2:mmc host rescan start!
[ 2.962268] bcmsdh_register: register client driver
[ 2.962426] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.962550] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.962561] bus num (host idx)=2, slot num (rca)=1
[ 2.962571] found adapter info 'DHD generic adapter'
[ 2.962642] sdioh_attach: set sd_f2_blocksize 256
[ 2.963187] F1 signature read @0x18000000=0x17224356
[ 2.968664] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 2.969511] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.969618] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 2.970614] wl_create_event_handler(): thread:wl_event_handler:b8 started
[ 2.970874] tsk Enter, tsk = 0xffffffc0f0a81a90
[ 2.970897] dhd_attach(): thread:dhd_watchdog_thread:b9 started
[ 2.970972] dhd_attach(): thread:dhd_dpc:ba started
[ 2.971039] dhd_attach(): thread:dhd_rxf:bb started
[ 2.971054] dhd_deferred_work_init: work queue initialized
[ 2.981471] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.981471]
[ 2.981510] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 38/8192 files, 1753/32768 blocks
[ 2.981510]
[ 2.986402] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.986516] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 2.987664] EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
[ 2.988939] Dongle Host Driver, version 1.363.59.144.10 (r)
[ 2.989108] EXT4-fs (mmcblk1p11): warning: maximal mount count reached, running e2fsck is recommended
[ 2.989703] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.989777] Register interface [wlan0] MAC: ac:83:f3:9e:4d:5e
[ 2.989777]
[ 2.989786] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 2.989822] wl_event_handler: was terminated
[ 2.989860] wl_destroy_event_handler(): thread:wl_event_handler:b8 terminated OK
[ 2.989879] dhd_wl_ioctl: returning as busstate=0
[ 2.989945] bcmsdh_oob_intr_unregister: Enter
[ 2.989956] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.989976] dhd_txglom_enable: enable 0
[ 2.989988] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0, txglom_bucket_size=0
[ 2.990000] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 2.990013] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[ 2.990024] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=0
[ 2.990035] sdioh_set_mode: set txglom_mode to copy
[ 2.990044] dhd_bus_devreset: WLAN OFF DONE
[ 2.990108] wifi_platform_set_power = 0
[ 2.990119] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.990129] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.990153] [WLAN_RFKILL]: wifi shut off power.
[ 2.990245] dhd_module_init: Exit err=0
[ 3.014637] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 3.014696] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 3.016181] random: e2fsck: uninitialized urandom read (40 bytes read, 58 bits of entropy available)
[ 3.032429] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 3.032429]
[ 3.032483] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata has been mounted 11 times without being checked, check forced.
[ 3.032483]
[ 3.032510] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 3.032510]
[ 3.032532] e2fsck: Pass 2: Checking directory structure
[ 3.032532]
[ 3.032554] e2fsck: Pass 3: Checking directory connectivity
[ 3.032554]
[ 3.032576] e2fsck: Pass 4: Checking reference counts
[ 3.032576]
[ 3.032598] e2fsck: Pass 5: Checking group summary information
[ 3.032598]
[ 3.032620] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: 11/1024 files (0.0% non-contiguous), 1102/4096 blocks
[ 3.032620]
[ 3.035306] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.035380] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 3.035470] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 3.037467] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 3.037467]
[ 3.037528] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 3.037528]
[ 3.079722] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[ 3.083592] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 3.083955] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 3.084248] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 3.084640] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 3.084937] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 3.085195] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 3.085450] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 3.085722] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 3.086180] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 3.086449] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 3.086753] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 3.087012] init: (Parsing /system/etc/init/inputflinger.rc took 0.00s.)
[ 3.087277] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 3.087557] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 3.087858] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 3.088457] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 3.088787] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 3.089077] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 3.089363] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 3.089648] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 3.089932] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 3.090223] init: ignored duplicate definition of service 'media'init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 3.090527] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 3.090861] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 3.091144] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 3.091417] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 3.091704] init: ignored duplicate definition of service 'ril-daemon'init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 3.092048] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 3.092327] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 3.092645] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 3.092957] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 3.093284] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 3.094319] init: property_set("ro.board.platform", "rk3399") failed
[ 3.094796] init: property_set("ro.factory.hasGPS", "false") failed
[ 3.095047] init: property_set("ro.boot.noril", "true") failed
[ 3.095290] init: property_set("ro.rk.screenshot_enable", "true") failed
[ 3.095442] init: (Loading properties from /system/build.prop took 0.00s.)
[ 3.095514] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 3.095563] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 3.095700] fs_mgr: Warning: unknown flag resize
[ 3.095835] init: /recovery not specified in fstab
[ 3.095974] init: Starting service 'healthd'...
[ 3.096515] init: cannot find '/system/bin/displayd' (No such file or directory), disabling 'displayd'
[ 3.096650] init: Starting service 'lmkd'...
[ 3.097097] init: Starting service 'servicemanager'...
[ 3.097452] init: setsockcreatecon("") failed: Invalid argument
[ 3.097786] init: Starting service 'surfaceflinger'...
[ 3.098379] init: Starting service 'vold'...
[ 3.098441] binder: 198:198 transaction failed 29189/0, size 0-0 line 2868
[ 3.099313] init: setsockcreatecon("") failed: Invalid argument
[ 3.099404] init: setsockcreatecon("") failed: Invalid argument
[ 3.101074] random: surfaceflinger: uninitialized urandom read (40 bytes read, 62 bits of entropy available)
[ 3.101080] random: lmkd: uninitialized urandom read (40 bytes read, 62 bits of entropy available)
[ 3.103665] random: servicemanager: uninitialized urandom read (40 bytes read, 62 bits of entropy available)
[ 3.104011] init: insmod: open("/system/lib/modules/ump.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali_kbase.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/rk30_mirroring.ko") failed: No such file or directoryinit: finit_module for "/system/lib/modules/rk29-ipp.ko" failed: Exec format errorinit: insmod: open("/system/lib/modules/pvrsrvkm.ko") failed: No such file or directoryinit: finit_module for "/drmboot.ko" failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 3.105643] random: vold: uninitialized urandom read (40 bytes read, 62 bits of entropy available)
[ 3.107101] zram0: detected capacity change from 0 to 533413888
[ 3.111836] random: mkswap: uninitialized urandom read (40 bytes read, 63 bits of entropy available)
[ 3.145285] random: mkswap: uninitialized urandom read (16 bytes read, 65 bits of entropy available)
[ 3.147553] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.150512] init: Starting service 'debuggerd'...
[ 3.151451] init: Starting service 'debuggerd64'...
[ 3.153200] init: Not bootcharting.
[ 3.158658] random: debuggerd64: uninitialized urandom read (40 bytes read, 66 bits of entropy available)
[ 3.160941] random: vdc: uninitialized urandom read (40 bytes read, 66 bits of entropy available)
[ 3.170723] random: debuggerd: uninitialized urandom read (40 bytes read, 67 bits of entropy available)
[ 3.380745] fs_mgr: Warning: unknown flag resize
[ 3.381592] ueventd[178]: unhandled level 2 translation fault (11) at 0x00000000, esr 0x92000006
[ 3.381610] pgd = ffffffc0f090a000
[ 3.381619] [00000000] *pgd=00000000f090d003, *pud=00000000f090d003, *pmd=0000000000000000
[ 3.381640]
[ 3.381651] CPU: 4 PID: 178 Comm: ueventd Not tainted 4.4.83 #2
[ 3.381660] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
[ 3.381670] task: ffffffc0f0f56800 task.stack: ffffffc0f08e8000
[ 3.381681] PC is at 0x4c5580
[ 3.381688] LR is at 0x4c3274
[ 3.381696] pc : [<00000000004c5580>] lr : [<00000000004c3274>] pstate: 40000000
[ 3.381705] sp : 0000007ffd7a8120
[ 3.381712] x29: 0000007ffd7a8130 x28: 0000000000533018
[ 3.381727] x27: 02fea1d0d680962a x26: 0000000000000000
[ 3.381742] x25: 0000000000000000 x24: 0000000000006180
[ 3.381756] x23: 0000000000000100 x22: 000000000053a728
[ 3.381770] x21: 0000007ffd7a82ed x20: 0000007ffd7a8ac8
[ 3.381784] x19: ffffffffffffffff x18: 0000000000000000
[ 3.381797] x17: 0000007ffd7a79b0 x16: 000000000050c0e4
[ 3.381811] x15: 08030e0000000000 x14: 000000008000002f
[ 3.381824] x13: 0000000000000000 x12: 000000000000002c
[ 3.381838] x11: 0101010101010101 x10: 0000000000006000
[ 3.381851] x9 : 000000000053a728 x8 : 0000000000000011
[ 3.381865] x7 : 0000000000000000 x6 : 00000000000c1903
[ 3.381879] x5 : 03190c0000000000 x4 : 0000000000000000
[ 3.381892] x3 : 0000000000000100 x2 : 0000000000006180
[ 3.381906] x1 : 0000000000000000 x0 : 0000000000000000
[ 3.381919]
[ 4.099839] healthd: BatteryCurrentNowPath not found
[ 4.099861] healthd: BatteryCycleCountPath not found
[ 4.100354] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.100810] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.101244] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.101681] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 4.618007] fusb302 4-0022: PD disabled
[ 5.359576] iep dpi mode inactivity
[ 5.752849] I'am in gsl_ts_resume() start
[ 8.523021] random: nonblocking pool is initialized |
