[Fireprime] s5k4ec AF function has some error!!
Posted at 6/12/2018 13:05:50
Hi,
I have a problem using the s5k4ec module that you made.
I modified your /media/video/s5k4ec.c to use Auto Focus as follows:
static unsigned int SensorConfiguration = (CFG_WhiteBalance|CFG_Effect
|CFG_Scene|CFG_Focus
|CFG_FocusZone);
//below is original code.
//static unsigned int SensorConfiguration = (CFG_WhiteBalance|CFG_Effect
// |CFG_Scene
// |CFG_FocusZone);
Without the AF function, the captured image is too burred, that is, it is not clean.
If I use AF, the image is better than no AF.
But it is still burr.
So, I debugged the code, and then I found some error in your code
the debugging message as follows:
== error log ->why this log is happening?
[ 72.292728] s5k4ec[8452] [jaym ################ single focus mode set !
[ 74.265015] s5k4ec(8479): s5k4ec[8479] [jaym ######]focus state(0x4718) is error!
== source code s5k4ec.c
static int sensor_focus_af_single_usr_cb(struct i2c_client *client)
int ret = 0;
char cnt;
u16 state;
struct af_cmdinfo cmdinfo;
//char s_zone[5],i;
cmdinfo.cmd_tag = 0x01;
cmdinfo.validate_bit = 0x80;
printk("%s[%d] [jaym ################ single focus mode set !\n",SENSOR_NAME_STRING(),__LINE__);
sensor_write(client,0xFCFC, 0xD000),
sensor_write(client,0x0028, 0x7000),
sensor_write(client,0x002A, 0x028E),
sensor_write(client,0x0F12, 0x0000),
sensor_write(client,0x002A, 0x028C),
sensor_write(client,0x0F12, 0x0005),
//sensor_write(client,0xffff, 150), // delay 150ms
cnt = 0;
state=0x0000;
do
if (cnt != 0) {
msleep(1);
cnt++;
sensor_write(client,0x002E, 0x2EEE),
ret = sensor_read(client, 0x0f12, &state);
//printk("[jaym ] printk ######### \n");
}while((state != 0x0002) && (cnt<100));
if (state != 0x0002) {
SENSOR_TR("%s[%d] [jaym ######]focus state(0x%x) is error!\n",SENSOR_NAME_STRING(),__LINE__,state);
ret = -1;
goto sensor_af_single_end;
} else {
SENSOR_DG("%s[%d] single focus mode set success!\n",SENSOR_NAME_STRING(),__LINE__);
sensor_af_single_end:
return ret;
Can you help me why this is happening?
thank you
