AIO-3399J Compile Error
198
Posted at 8/30/2018 19:17:37      View:9557 | Replies:2        Print      Only Author   [Copy Link] 1#
my command is like below
make rk3399-firefly-aio-linux-lvds.img -j4
there are some errors at last
   LD      vmlinux
  SORTEX  vmlinux
  SYSMAP  System.map
  OBJCOPY arch/arm64/boot/Image
  Image:  kernel.img is ready
./scripts/resource_tool: 1: ./scripts/resource_tool: Syntax error: "(" unexpected
make: *** [rk3399-firefly-aio-linux-lvds.img] Error 2
Posted at 8/31/2018 13:11:11        Only Author  2#
I found solution. resource_tool is 64bit version
I used 32bit version ubuntu. I have to reinstall 64bit version
file kernel/scripts/resource_tool
kernel/scripts/resource_tool: ELF 64-bit LSB  executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, BuildID[sha1]=49650dd94618f4805ddc8bd9fe3632df7f5b901d, stripped
Posted at 7/1/2020 01:28:21        Only Author  3#
Which kernel version are you using? my make fails for vmlinux
