need help with flashing Firefly 3399
Posted at 11/1/2018 04:41:23
Hi,
I was playing with different images and finally after I flashed FlintOS I was not able to return to Ubuntu - upgrade_tool hangs on Check Chip Start and AndriodTool in Windows gives a red Check Chip Fail (first tab shows only one green string with Loader), it can read FlashID, FlashInfo, ChipInfo and pass the TestDevice. ReadCapability also fail. Rockchip Batch Tool also does not pass Check Chip.
Then I noticed that FlintOS was flashed using wl key, that is direct write.
So I tried to do it same way with unpacked Ubuntu image according to parameter file, started fromfollowed with the rest of uboot, trust, resources, kernel and boot.
Unfortunately this didn't help and even pl key gave me Reading partition info from device failes!
I would appreciate if someone guide me how to flash Ubuntu image or simply give a full dump of clear Ubuntu system to make- upgrade_tool wl 0 full_ubuntu.img
Copy the code I have 4GB/16GB version of Firefly-RK3399
Regards
