Posted at 12/18/2018 20:21:24
Hello,
ok I fixed the problem it works with windows10, I decompressed the AndroidTool archive and made it directly start from the usb key on windows10 (64bits). Android tool works but whatever I do it is impossible to access the "chip" I still have the error. As you can see on my screenshots, nothing works. I have no choice but to switch to maskrom but I can not do it, your tutorial on the wiki to go in MaskRom is very basic, I have a hard time doing it.
Yes, it works well, you do not see the extension config.ini because I have hidden the extentions for windows10 by default to erase them by mistake. For my problem, there is only one solution in my opinion enter MaskRom mode but as I said I can not do it, with the wiki I'm not doing it for this operation with a small iron tip.
(97.52 KB, Down times: 87)
(100.06 KB, Down times: 87)
(103.08 KB, Down times: 89)
(106.04 KB, Down times: 92)
(128.3 KB, Down times: 87)
