Dual Camera Color
198
Dual Camera Color
Posted at 3/7/2019 08:08:13      View:4542 | Replies:1        Print      Only Author   [Copy Link] 1#
I am testing dual camera with ROC-RK3399-PC
But the Color is not good. green color is too strong.
where can I fix?
Posted at 8/30/2019 05:52:22        Only Author  2#
Did you find a way to fix this? What's the max resolution of each camera stream that you can get?
Also: Is this a ROC-RK3399-PC that you're using? How did you connect the 30 pin camera to the 24 pin connector?
