【Linux】
SD card not readable after SW reset from Linux
Posted at 5/17/2019 16:01:20
Hi all,
after sw reset from Linux u-boot can't read SD card partition.
- root@linaro-alip:~# reboot
- Stopping User Manager for UID 0...
- [ OK ] Stopped target Alcoma RRL.
- [ OK ] Stopped target Timers.
- Stopping Session c1 of user root.
- [ OK ] Stopped target Sound Card.
- [ OK ] Stopped target Multi-User System.
- Stopping Network Name Resolution...
- Stopping LSB: Advanced IEEE 802.11 management daemon...
- Stopping ACPI event daemon...
- Stopping LSB: set CPUFreq kernel parameters...
- [ OK ] Stopped target Login Prompts.
- Stopping Getty on tty1...
- Stopping Serial Getty on ttyFIQ0...
- [ OK ] Stopped Daily apt upgrade and clean activities.
- [ OK ] Stopped Trigger anacron every hour.
- [ OK ] Stopped Daily Cleanup of Temporary Directories.
- [ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
- Stopping Save/Restore Sound Card State...
- [ OK ] Stopped Daily apt download activities.
- [ OK ] Stopped target System Time Synchronized.
- Stopping System Logging Service...
- [ OK ] Stopped ACPI event daemon.
- [ OK ] Stopped System Logging Service.
- [ OK ] Stopped Network Name Resolution.
- [ OK ] Stopped Getty on tty1.
- [ 680.438935] tty_port_close_start: tty->count = 1 port count = 2.
- [ OK ] Stopped Serial Getty on ttyFIQ0.
- [ OK ] Stopped LSB: Advanced IEEE 802.11 management daemon.
- [ OK ] Stopped Session c1 of user root.
- [ OK ] Stopped User Manager for UID 0.
- [ OK ] Stopped Save/Restore Sound Card State.
- [ OK ] Stopped LSB: set CPUFreq kernel parameters.
- Stopping LSB: Load kernel modules needed to enable cpufreq scaling...
- [ OK ] Removed slice User Slice of root.
- Stopping Login Service...
- [ OK ] Removed slice system-serial\x2dgetty.slice.
- [ OK ] Removed slice system-getty.slice.
- Stopping Permit User Sessions...
- [ OK ] Stopped /etc/rc.local Compatibility.
- [ OK ] Stopped target Network is Online.
- [ OK ] Stopped Login Service.
- [ OK ] Stopped Permit User Sessions.
- [ OK ] Stopped target Network.
- Stopping WPA supplicant...
- Stopping Network Service...
- Stopping Raise network interfaces...
- [ OK ] Stopped WPA supplicant.
- [ OK ] Stopped LSB: Load kernel modules needed to enable cpufreq scaling.
- [ OK ] Stopped target Remote File Systems.
- Stopping D-Bus System Message Bus...
- [ OK ] Stopped Network Service.
- [ OK ] Stopped D-Bus System Message Bus.
- [ OK ] Stopped target Basic System.
- [ OK ] Stopped target Slices.
- [ OK ] Removed slice User and Session Slice.
- [ OK ] Stopped target Paths.
- [ OK ] Stopped ACPI Events Check.
- [ OK ] Stopped target Sockets.
- [ OK ] Closed Syslog Socket.
- [ OK ] Closed ACPID Listen Socket.
- [ OK ] Closed OpenBSD Secure Shell server socket.
- [ OK ] Closed D-Bus System Message Bus Socket.
- [ OK ] Stopped target System Initialization.
- Stopping Update UTMP about System Boot/Shutdown...
- Stopping Load/Save Random Seed...
- Stopping Network Time Synchronization...
- [ OK ] Stopped target Swap.
- [ OK ] Stopped target Encrypted Volumes.
- [ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
- [ OK ] Stopped Forward Password Requests to Wall Directory Watch.
- Stopping Load/Save Screen Backlight…ightness of backlight:backlight...
- [ OK ] Stopped Network Time Synchronization.
- [ OK ] Stopped Load/Save Screen Backlight Brightness of backlight:backlight.
- [ OK ] Stopped Update UTMP about System Boot/Shutdown.
- [ OK ] Stopped Load/Save Random Seed.
- [ OK ] Stopped Create Volatile Files and Directories.
- [ OK ] Removed slice system-systemd\x2dbacklight.slice.
- [ OK ] Stopped Raise network interfaces.
- [ OK ] Stopped Apply Kernel Variables.
- [ OK ] Stopped Load Kernel Modules.
- [ OK ] Stopped target Local File Systems.
- Unmounting /run/user/0...
- Unmounting /var/ram...
- Unmounting /boot...
- [ OK ] Unmounted /var/ram.
- [ OK ] Unmounted /run/user/0.
- [ OK ] Unmounted /boot.
- [ OK ] Reached target Unmount All Filesystems.
- [ OK ] Stopped target Local File Systems (Pre).
- [ OK ] Stopped Create Static Device Nodes in /dev.
- [ OK ] Stopped Remount Root and Kernel File Systems.
- [ OK ] Reached target Shutdown.
- [ 680.819156] dw_wdt: unexpected close, system will reboot soon
- [ 680.898628] systemd-journald[172]: Received SIGTERM from PID 1 (systemd-shutdow).
- [ 680.951241] EXT4-fs (mmcblk0p5): re-mounted. Opts: data=ordered
- [ 680.956409] EXT4-fs (mmcblk0p5): re-mounted. Opts: data=ordered
- Failed to read reboot parameter file: No such file or directory
- [ 680.967925] cpu4 limit freq=816000 min=816000 max=816000
- [ 680.971211] cpu0 limit freq=816000 min=816000 max=816000
- [ 680.974836] I : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 273; [Func] : kbase_platform_rk_shutdown(); to make vdd_gpu enabled for turning off pd_gpu in pm_framework.
- [ 680.976614] rk-vcodec ff660000.rkvdec: shutdown
- [ 680.977099] rk-vcodec ff650000.vpu_service: shutdown
- [ 680.978071] reboot: Restarting system
- DDR Version 1.22 20190506
- In
- soft reset
- SRX
- channel 0
- CS = 0
- MR0=0x18
- MR4=0x1
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- CS = 1
- MR0=0x18
- MR4=0x2
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- channel 1
- CS = 0
- MR0=0x18
- MR4=0x2
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- CS = 1
- MR0=0x18
- MR4=0x2
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- channel 0 training pass!
- channel 1 training pass!
- change freq to 416MHz 0,1
- Channel 0: LPDDR4,416MHz
- Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
- Channel 1: LPDDR4,416MHz
- 256B stride
- channel 0
- CS = 0
- MR0=0x18
- MR4=0x1
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- CS = 1
- MR0=0x18
- MR4=0x2
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- channel 1
- CS = 0
- MR0=0x18
- MR4=0x2
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- CS = 1
- MR0=0x18
- MR4=0x2
- MR5=0x6
- MR8=0x8
- MR12=0x72
- MR14=0x72
- MR18=0x0
- MR19=0x0
- MR24=0x8
- MR25=0xFC
- channel 0, cs 0, advanced training done
- channel 0, cs 1, advanced training done
- channel 1, cs 0, advanced training done
- channel 1, cs 1, advanced training done
- change freq to 856MHz 1,0
- ch 0 ddrconfig = 0x101, ddrsize = 0x2020
- ch 1 ddrconfig = 0x101, ddrsize = 0x2020
- pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
- OUT
- Boot1: 2019-03-14, version: 1.19
- CPUId = 0x0
- ChipType = 0x10, 325
- mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
- mmc: ERROR: Card did not respond to voltage select!
- emmc reinit
- emmc reinit
- SdmmcInit=2 1
- mmc0:cmd5,20
- SdmmcInit=0 0
- BootCapSize=0
- UserCapSize=15193MB
- FwPartOffset=2000 , 0
- StorageInit ok = 58566
- SecureMode = 0
- SecureInit read PBA: 0x4
- SecureInit read PBA: 0x404
- SecureInit read PBA: 0x804
- SecureInit read PBA: 0xc04
- SecureInit read PBA: 0x1004
- SecureInit read PBA: 0x1404
- SecureInit read PBA: 0x1804
- SecureInit read PBA: 0x1c04
- SecureInit ret = 0, SecureMode = 0
- atags_set_bootdev: ret:(0)
- GPT part: 0, name: loader1, start:0x40, size:0x1f40
- GPT part: 1, name: loader2, start:0x4000, size:0x2000
- GPT part: 2, name: trust, start:0x6000, size:0x2000
- GPT part: 3, name: boot, start:0x8000, size:0x38000
- GPT part: 4, name: rootfs, start:0x40000, size:0x4e9fdf
- no find partition:uboot.
- LoadTrust Addr:0x4000
- No find bl30.bin
- Load uboot, ReadLba = 2000
- hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- Load OK, addr=0x200000, size=0x9c558
- RunBL31 0x10000
- NOTICE: BL31: v1.3(debug):d98d16e
- NOTICE: BL31: Built : 15:03:07, May 10 2018
- NOTICE: BL31: Rockchip release version: v1.1
- INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
- INFO: Using opteed sec cpu_context!
- INFO: boot cpu mask: 0
- INFO: plat_rockchip_pmu_init(1151): pd status 3e
- INFO: BL31: Initializing runtime services
- INFO: BL31: Initializing BL32
- INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-96-g3fbe315-dev #4 Fri Jun 30 00:35:17 UTC 2017 aarch64)
- INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
- INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
- INFO: BL31: Preparing for EL3 exit to normal world
- INFO: Entry point address = 0x200000
- INFO: SPSR = 0x3c9
- U-Boot 2017.09-gc58a8168bd-dirty (May 15 2019 - 10:28:42 +0200)
- Model: Firefly-RK3399 Board
- DRAM: 3.9 GiB
- MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
- Card did not respond to voltage select!
- mmc_init: -95, time 20
- *** Warning - No block device, using default environment
- In: serial@ff1a0000
- Out: serial@ff1a0000
- Err: serial@ff1a0000
- normal boot
- Net: eth0: ethernet@fe300000
- Hit any key to stop autoboot: 0
- mmc_init: -95, time 19
- switch to partitions #0, OK
- mmc1 is current device
- *** ERROR: Can't read GPT Entries ***
- GPT: Failed to allocate memory for PTE
- part_get_info_efi: *** ERROR: Invalid GPT ***
- *** ERROR: Can't read GPT header ***
- part_get_info_efi: *** ERROR: Invalid Backup GPT ***
- ** Invalid partition 4 **
- starting USB...
- USB0: ERROR: failed to enable clock 0
- at drivers/usb/host/ehci-generic.c:54/ehci_usb_probe()
- probe failed, error -38
- USB1: ERROR: failed to enable clock 0
- USB error: all controllers failed lowlevel init
- USB is stopped. Please issue 'usb start' first.
- starting USB...
- ethernet@fe300000 Waiting for PHY auto negotiation to complete... done
- Speed: 1000, full duplex
- BOOTP broadcast 1
- BOOTP broadcast 2
- BOOTP broadcast 3
- BOOTP broadcast 4
- BOOTP broadcast 5
- BOOTP broadcast 6
- BOOTP broadcast 7
- BOOTP broadcast 8
- BOOTP broadcast 9
- BOOTP broadcast 10
- BOOTP broadcast 11
- BOOTP broadcast 12
- BOOTP broadcast 13
- BOOTP broadcast 14
- BOOTP broadcast 15
- BOOTP broadcast 16
- BOOTP broadcast 17
- Retry time exceeded; starting again
- missing environment variable: pxeuuid
- missing environment variable: bootfile
- Retrieving file: pxelinux.cfg/01-92-10-db-6a-67-ee
- *** ERROR: `serverip' not set
- Retrieving file: pxelinux.cfg/00000000
- Retrieving file: pxelinux.cfg/default-arm-rockchip
- Config file not found
- starting USB...
- BOOTP broadcast 1
- BOOTP broadcast 2
- BOOTP broadcast 3
- BOOTP broadcast 4
- BOOTP broadcast 5
- BOOTP broadcast 6
- BOOTP broadcast 7
- BOOTP broadcast 8
- BOOTP broadcast 9
- BOOTP broadcast 1
- BOOTP broadcast 2
- BOOTP broadcast 3
- BOOTP broadcast 4
- BOOTP broadcast 5
- BOOTP broadcast 6
- BOOTP broadcast 7
- BOOTP broadcast 8
- BOOTP broadcast 9
- => mmc part
- Partition Map for MMC device 1 -- Partition Type: EFI
- part_print_efi: *** ERROR: Invalid GPT ***
- part_print_efi: *** ERROR: Invalid Backup GPT ***
Copy the code
Any idea?
Thanks. |
