[Linux] Unable to Compile Ubuntu Firmware into ROC-RK3399-PC
89
【Linux】 Unable to Compile Ubuntu Firmware into ROC-RK3399-PC
Posted at 8/2/2019 14:42:54      View:2823 | Replies:2        Print      Only Author   [Copy Link] 1#
I have recently bought RK3399-PC and tring to boot ubuntu. But after flashing the ubuntu into the SD card, I am not able to follow the steps given in the link http://wiki.t-firefly.com/en/ROC-RK3399-PC/linux_sdk.html#. When I try to compile Environment from the following link http://wiki.t-firefly.com/en/ROC ... compile-environment it diplays error "aarch64 file is obsoelte or command not found".
I have included Expansion board to the development board and has flashed ubuntu from the following link https://drive.google.com/drive/f ... LY0DG_BLx94eAeArvwI Are there any additional libraries that I need to install before compiling ubuntu firmware? Could you guide me in completing the bootup?
vip
Rank: 6Rank: 6
Posted at 8/3/2019 10:31:31        Only Author  2#
Hi, welcome to the forum.
The "sudo apt-get ..." command is meant to run as a big long line.
But copy and paste will result in multiple lines.
We'll fix the doc.
vip
Rank: 6Rank: 6
Posted at 8/3/2019 12:03:10        Only Author  3#
Doc fixed at http://wiki.t-firefly.com/en/ROC ... compile-environment
Thanks for reporting this to us.
