Posted at 8/9/2019 18:23:06
Hello,
I have tried to flash custom image to emmc (i used rkdeveloptool because there is not enough info about custom images on firefly wiki) but one of them was wrong and i had to enter maskrom mode using hardware method. After that i have following problem when trying to flash something (in both cases "rkdevelop db" step is already performed):
1) if i use
- rkdeveloptool gpt parameter.txt
Copy the code
it returns success but then does not show partition table. Partition table is shown if i reset device after this step or write partition table with
- rkdeveloptool prm parameter.txt
Copy the code
Anyway, if i flash any image after this step partition table is destroyed again
2) if i use upgrade_tool instead i can successfully flash parameter but when i flash any image after that i get the following error:
- Compare data failed in checking,exit download image!
Copy the code
Also, i used rs and rl commands to check data blocks defore and after writing image: parameter blocks are overriden. These commands also show some strange behaviour:
shows the same output for any start block.
So, could it be that i have broken emmc controller when entered maskrom mode? How could i then make device bootable? |
