[Firefly-RK3399] system is stuck at logo(blur image) not booting up
Posted at 6/18/2020 19:48:49
Hi,
I have flashed Android 7 image on to the Firefly-RK3399 board. System once booted up normally. But after few boot cycles, system is stuck and not booting up.
Please refer the serial console logs attached below.
U-Boot 2017.02-RK3399-06 (Jun 16 2020 - 15:11:29)
CPU: rk3399
cpu version = 0
CPU's clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
cpll = 800000000HZ
dpll = 666000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Board: Rockchip platform Board
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(000000007fe00000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01e00000
128 MiB
SdmmcInit = 0 20
storage init OK!
Using default environment
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
usb bc: can find node by path: /dwc-control-usb/usb_bc
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=900000,pwm_value=16
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 666000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2020-06-16#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
failed to find panel driver
read logo on state from dts [1]
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 16
rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 0, div = 1
rockchip_panel_prepare: failed to find panel prepare funcs
hdmi_dev_config_video vic 16 color_output 3 color_output_depth 8
pixel clk is 148500000 tmds clk is 148500000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=1
rockchip_panel_enable: failed to find panel prepare funcs
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
failed to display kernel logo
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x01238008)
ramdisk @ 0x04bf0000 (0x007b21c4)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000004600000, end 0000000004615675 ... OK
Add bank:0000000000200000, 0000000008200000
Add bank:000000000a200000, 0000000075e00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Initializing cgroup subsys schedtune
[ 0.000000] Linux version 4.4.103 (kannan@kannan) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Jun 16 15:17:36 IST 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] hdmi init vic is -1
[ 0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eefe000 s45504 r8192 d32320 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 507912
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00010000@0x00010000(kernel),0x00010000@0x00020000(boot),0x00010000@0x00030000(recovery),0x00038000@0x00040000(backup),0x00040000@0x00078000(cache),0x00400000@0x000B8000(system),0x00008000@0x004B8000(metadata),0x00002000@0x004C0000(baseparamer),-@0x004C2000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2020-06-16_15:11:29 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] software IO TLB [mem 0x7eeb5000-0x7eef5000] (0MB) mapped at [ffffffc07eeb5000-ffffffc07eef4fff]
[ 0.000000] Memory: 1981276K/2064384K available (10878K kernel code, 1632K rwdata, 5272K rodata, 832K init, 1075K bss, 66724K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009120000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b20000 ( 10880 KB)
[ 0.000000] .rodata : 0xffffff8008b20000 - 0xffffff8009050000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009120000 - 0xffffff80092b8008 ( 1633 KB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual)
[ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[ 0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x000000000a280000
[ 0.000000] ITS: Allocated 1792 chunks for LPIs
[ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x000000000a290000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.009976] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.021258] pid_max: default: 32768 minimum: 301
[ 0.026417] Security Framework initialized
[ 0.030922] SELinux: Initializing.
[ 0.034836] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.042203] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.050814] Initializing cgroup subsys freezer
[ 0.055712] Initializing cgroup subsys debug
[ 0.061329] sched-energy: Sched-energy-costs installed from DT
[ 0.067753] CPU0: update cpu_capacity 401
[ 0.072211] ASID allocator initialised with 65536 entries
[ 0.095019] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.105122] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 1.130008] CPU1: failed to come online
[ 1.134234] CPU1: failed in unknown state : 0x0
[ 1.149371] Detected VIPT I-cache on CPU2
[ 1.149404] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 1.149439] CPU2: using LPI pending table @0x000000007c010000
[ 1.149483] CPU2: update cpu_capacity 401
[ 1.149486] CPU2: Booted secondary processor [410fd034]
[ 1.159394] Detected VIPT I-cache on CPU3
[ 1.159413] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 1.159445] CPU3: using LPI pending table @0x000000007c050000
[ 1.159473] CPU3: update cpu_capacity 401
[ 1.159476] CPU3: Booted secondary processor [410fd034]
[ 1.169438] Detected PIPT I-cache on CPU4
[ 1.169465] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 1.169506] CPU4: using LPI pending table @0x000000007c090000
[ 1.169547] CPU4: update cpu_capacity 1024
[ 1.169551] CPU4: Booted secondary processor [410fd082]
[ 1.179459] Detected PIPT I-cache on CPU5
[ 1.179477] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 1.179514] CPU5: using LPI pending table @0x000000007c0d0000
[ 1.179542] CPU5: update cpu_capacity 1024
[ 1.179545] CPU5: Booted secondary processor [410fd082]
[ 1.179629] Brought up 5 CPUs
[ 1.294359] SMP: Total of 5 processors activated.
[ 1.299529] CPU features: detected feature: GIC system register CPU interface
[ 1.307372] CPU: All CPU(s) started at EL2
[ 1.311905] alternatives: patching kernel code
[ 1.319217] devtmpfs: initialized
[ 1.336655] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 1.347397] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 1.354996] pinctrl core: initialized pinctrl subsystem
[ 1.362258] Failed to find legacy iommu devices
[ 1.367623] NET: Registered protocol family 16
[ 1.372870] schedtune: init normalization constants...
[ 1.378530] schedtune: CLUSTER[0,2-3] min_pwr: 56 max_pwr: 222
[ 1.385714] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 1.392896] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 1.400075] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 1.407255] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 1.414436] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 1.421616] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 1.428795] schedtune: SYSTEM min_pwr: 121 max_pwr: 4212
[ 1.435975] schedtune: using normalization constants mul: 5249288 sh1: 1 sh2: 11
[ 1.444107] schedtune: verify normalization constants...
[ 1.449954] schedtune: max_pwr/2^0: 4091 => norm_pwr: 1024
[ 1.456081] schedtune: max_pwr/2^1: 2045 => norm_pwr: 511
[ 1.462211] schedtune: max_pwr/2^2: 1022 => norm_pwr: 255
[ 1.468339] schedtune: max_pwr/2^3: 511 => norm_pwr: 127
[ 1.474467] schedtune: max_pwr/2^4: 255 => norm_pwr: 63
[ 1.480595] schedtune: max_pwr/2^5: 127 => norm_pwr: 31
[ 1.486722] schedtune: configured to support 5 boost groups
[ 1.512891] cpuidle: using governor ladder
[ 1.540773] cpuidle: using governor menu
[ 1.545113] Registered FIQ tty driver
[ 1.549467] vdso: 2 pages (1 code @ ffffff8008b26000, 1 data @ ffffff8009124000)
[ 1.557642] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.565819] DMA: preallocated 256 KiB pool for atomic allocations
[ 1.591494] console [pstore0] enabled
[ 1.595697] pstore: Registered ramoops as persistent store backend
[ 1.602503] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[[ 1.610824] console [ttyFIQ0] enabled
[[ 1.618513] bootconsole [uart0] disabled
[ 1.626899] Registered fiq debugger ttyFIQ0
[ 1.664583] Rockchip hdmi driver version 2.0
[ 1.665849] vcc3v3_sys: supplied by vcc_sys
[ 1.666533] iommu: Adding device ff650000.vpu_service to group 0
[ 1.666603] iommu: Adding device ff660000.rkvdec to group 1
[ 1.666669] iommu: Adding device ff670000.iep to group 2
[ 1.666759] iommu: Adding device ff8f0000.vop to group 3
[ 1.666892] iommu: Adding device ff900000.vop to group 4
[ 1.666995] iommu: Adding device ff910000.isp to group 5
[ 1.667069] iommu: Adding device ff920000.isp to group 6
[ 1.667733] rk_iommu ff670800.iommu: can't get aclk
[ 1.667749] rk_iommu ff670800.iommu: can't get hclk
[ 1.668581] SCSI subsystem initialized
[ 1.668750] usbcore: registered new interface driver usbfs
[ 1.668795] usbcore: registered new interface driver hub
[ 1.668877] usbcore: registered new device driver usb
[ 1.669216] media: Linux media interface: v0.10
[ 1.669264] Linux video capture interface: v2.00
[ 1.669394] pps_core: LinuxPPS API ver. 1 registered
[ 1.669404] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.669429] PTP clock support registered
[ 1.670871] Advanced Linux Sound Architecture Driver Initialized.
[ 1.671352] Bluetooth: Core ver 2.21
[ 1.671386] NET: Registered protocol family 31
[ 1.671397] Bluetooth: HCI device and connection manager initialized
[ 1.671414] Bluetooth: HCI socket layer initialized
[ 1.671428] Bluetooth: L2CAP socket layer initialized
[ 1.671459] Bluetooth: SCO socket layer initialized
[ 1.672475] rockchip-cpuinfo cpuinfo: Serial : 22f277de3415e9ca
[ 1.672936] clocksource: Switched to clocksource arch_sys_counter
[ 1.715586] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 1.715821] NET: Registered protocol family 2
[ 1.716235] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.716356] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 1.716481] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.716560] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.716589] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 1.716744] NET: Registered protocol family 1
[ 1.717223] Trying to unpack rootfs image as initramfs...
[ 2.057228] Freeing initrd memory: 7880K
[ 2.057754] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 2.057847] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 2.060540] audit: initializing netlink subsys (disabled)
[ 2.060598] audit: type=2000 audit(1.943:1): initialized
[ 2.065689] VFS: Disk quotas dquot_6.6.0
[ 2.065813] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.066851] Registering sdcardfs 0.1
[ 2.067441] fuse init (API version 7.23)
[ 2.068515]
[ 2.068515] TEE Core Framework initialization (ver 1:0.1)
[ 2.068543] TEE armv7 Driver initialization
[ 2.068879] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 2.068894] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 2.069057] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[ 2.073197] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.073217] io scheduler noop registered
[ 2.073388] io scheduler cfq registered (default)
[ 2.074578] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 2.078583] iep: failed to find iep power down clock source.
[ 2.078930] IEP Power ON
[ 2.079088] IEP Power OFF
[ 2.079156] IEP Driver loaded succesfully
[ 2.079265] Module initialized.
[ 2.079684] rk-vcodec ff650000.vpu_service: probe device
[ 2.079724] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c2b9810
[ 2.079858] rk-vcodec ff650000.vpu_service: allocator is drm
[ 2.079912] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 2.080327] rk-vcodec ff650000.vpu_service: init success
[ 2.080886] rk-vcodec ff660000.rkvdec: probe device
[ 2.080926] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c2ba010
[ 2.081055] rk-vcodec ff660000.rkvdec: allocator is drm
[ 2.081111] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 2.081398] rk-vcodec ff660000.rkvdec: init success
[ 2.082750] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.082769] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 2.084121] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.084140] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.085728] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.087189] console [ttyS0] disabled
[ 2.087235] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 34, base_baud = 1500000) is a 16550A
[ 2.087747] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 35, base_baud = 1500000) is a 16550A
[ 2.088128] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 2.092739] mali ff9a0000.gpu: Failed to get regulator
[ 2.092757] mali ff9a0000.gpu: Power control initialization failed
[ 2.093055] Unable to detect cache hierarchy from DT for CPU 0
[ 2.100675] brd: module loaded
[ 2.105173] loop: module loaded
[ 2.105668] zram: Added device: zram0
[ 2.106208] SCSI Media Changer driver v0.25
[ 2.107002] tun: Universal TUN/TAP device driver, 1.6
[ 2.107014] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.108056] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 2.108075] rk_gmac-dwmac fe300000.ethernet: TX delay(0x27).
[ 2.108089] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1c).
[ 2.108116] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 2.108279] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 2.113298] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 2.113425] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.113436] Ring mode enabled
[ 2.113444] DMA HW capability register supported
[ 2.113453] Normal descriptors
[ 2.113464] RX Checksum Offload Engine supported (type 2)
[ 2.113473] TX Checksum insertion supported
[ 2.113481] Wake-Up On Lan supported
[ 2.113524] Enable RX Mitigation via HW Watchdog Timer
[ 2.182369] libphy: stmmac: probed
[ 2.182384] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 2.182396] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 2.183241] PPP generic driver version 2.4.2
[ 2.183399] PPP BSD Compression module registered
[ 2.183414] PPP Deflate Compression module registered
[ 2.183442] PPP MPPE Compression module registered
[ 2.183461] NET: Registered protocol family 24
[ 2.183500] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 2.183513] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.183534] Rockchip WiFi SYS interface (V1.00) ...
[ 2.183618] usbcore: registered new interface driver catc
[ 2.183661] usbcore: registered new interface driver kaweth
[ 2.183677] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.183715] usbcore: registered new interface driver pegasus
[ 2.183757] usbcore: registered new interface driver rtl8150
[ 2.183798] usbcore: registered new interface driver r8152
[ 2.183813] hso: drivers/net/usb/hso.c: Option Wireless
[ 2.183873] usbcore: registered new interface driver hso
[ 2.183921] usbcore: registered new interface driver asix
[ 2.183963] usbcore: registered new interface driver ax88179_178a
[ 2.184004] usbcore: registered new interface driver cdc_ether
[ 2.184048] usbcore: registered new interface driver cdc_eem
[ 2.184090] usbcore: registered new interface driver dm9601
[ 2.184141] usbcore: registered new interface driver smsc75xx
[ 2.184193] usbcore: registered new interface driver smsc95xx
[ 2.184234] usbcore: registered new interface driver gl620a
[ 2.184278] usbcore: registered new interface driver net1080
[ 2.184319] usbcore: registered new interface driver plusb
[ 2.184361] usbcore: registered new interface driver rndis_host
[ 2.184404] usbcore: registered new interface driver cdc_subset
[ 2.184446] usbcore: registered new interface driver zaurus
[ 2.184489] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.184549] usbcore: registered new interface driver int51x1
[ 2.184591] usbcore: registered new interface driver kalmia
[ 2.184633] usbcore: registered new interface driver ipheth
[ 2.184677] usbcore: registered new interface driver sierra_net
[ 2.184719] usbcore: registered new interface driver cx82310_eth
[ 2.184778] usbcore: registered new interface driver cdc_ncm
[ 2.184822] usbcore: registered new interface driver qmi_wwan
[ 2.184866] usbcore: registered new interface driver cdc_mbim
[ 2.186025] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 2.191521] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 2.192391] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.192409] ehci-pci: EHCI PCI platform driver
[ 2.192469] ehci-platform: EHCI generic platform driver
[ 2.196291] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.196326] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 2.196459] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.206281] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.206412] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.206428] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.206441] usb usb1: Product: EHCI Host Controller
[ 2.206453] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 2.206464] usb usb1: SerialNumber: fe3c0000.usb
[ 2.206940] hub 1-0:1.0: USB hub found
[ 2.206973] hub 1-0:1.0: 1 port detected
[ 2.207459] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.207489] ohci-platform: OHCI generic platform driver
[ 2.207929] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.207956] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 2.208071] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.263754] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.263771] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.263784] usb usb2: Product: Generic Platform OHCI controller
[ 2.263796] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[ 2.263807] usb usb2: SerialNumber: fe3e0000.usb
[ 2.264220] hub 2-0:1.0: USB hub found
[ 2.264253] hub 2-0:1.0: 1 port detected
[ 2.265042] usbcore: registered new interface driver cdc_acm
[ 2.265055] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.265115] usbcore: registered new interface driver usblp
[ 2.265162] usbcore: registered new interface driver cdc_wdm
[ 2.265209] usbcore: registered new interface driver uas
[ 2.265284] usbcore: registered new interface driver usb-storage
[ 2.265327] usbcore: registered new interface driver ums-alauda
[ 2.265369] usbcore: registered new interface driver ums-cypress
[ 2.265411] usbcore: registered new interface driver ums-datafab
[ 2.265453] usbcore: registered new interface driver ums_eneub6250
[ 2.265496] usbcore: registered new interface driver ums-freecom
[ 2.265538] usbcore: registered new interface driver ums-isd200
[ 2.265583] usbcore: registered new interface driver ums-jumpshot
[ 2.265625] usbcore: registered new interface driver ums-karma
[ 2.265667] usbcore: registered new interface driver ums-onetouch
[ 2.265710] usbcore: registered new interface driver ums-sddr09
[ 2.265752] usbcore: registered new interface driver ums-sddr55
[ 2.265794] usbcore: registered new interface driver ums-usbat
[ 2.265875] usbcore: registered new interface driver usbserial
[ 2.265917] usbcore: registered new interface driver usbserial_generic
[ 2.265948] usbserial: USB Serial support registered for generic
[ 2.265992] usbcore: registered new interface driver option
[ 2.266022] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.266125] usbcore: registered new interface driver trancevibrator
[ 2.266141] usb20_otg: version 3.10a 21-DEC-2012
[ 2.266354] usb20_host: version 3.10a 21-DEC-2012
[ 2.266750] usbcore: registered new interface driver xpad
[ 2.266801] usbcore: registered new interface driver usb_acecad
[ 2.266848] usbcore: registered new interface driver aiptek
[ 2.266895] usbcore: registered new interface driver gtco
[ 2.266945] usbcore: registered new interface driver hanwang
[ 2.266992] usbcore: registered new interface driver kbtab
[ 2.267415] .. rk pwm remotectl v1.1 init
[ 2.267655] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 2.268034] sensor_register_slave:mma8452,id=17
[ 2.268054] sensor_register_slave:lis3dh,id=7
[ 2.268071] sensor_register_slave:mma7660,id=18
[ 2.268086] sensor_register_slave:lsm303d,id=22
[ 2.268102] sensor_register_slave:gs_mc3230,id=23
[ 2.268112] [Gsensor] gsensor_init
[ 2.268127] sensor_register_slave:mpu6880_acc,id=24
[ 2.268143] sensor_register_slave:mpu6500_acc,id=25
[ 2.268159] sensor_register_slave:lsm330_acc,id=26
[ 2.268174] sensor_register_slave:bma2xx_acc,id=27
[ 2.268190] sensor_register_slave:akm8975,id=29
[ 2.268206] sensor_register_slave:akm8963,id=30
[ 2.268221] sensor_register_slave:l3g4200d,id=44
[ 2.268237] sensor_register_slave:l3g20d,id=45
[ 2.268253] sensor_register_slave:ewtsa,id=46
[ 2.268268] sensor_register_slave:lsm330_gyro,id=50
[ 2.268284] sensor_register_slave:cm3217,id=52
[ 2.268299] sensor_register_slave:cm3218,id=53
[ 2.268315] sensor_register_slave:ls_stk3410,id=61
[ 2.268331] sensor_register_slave:ps_stk3410,id=66
[ 2.268959] i2c /dev entries driver
[ 2.269618] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80095de000
[ 2.280146] fusb302 4-0022: port 0 probe success
[ 2.280176] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fa000
[ 2.281164] fan53555-regulator 8-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.281228] fan53555-reg: supplied by vcc_sys
[ 2.283509] fan53555-regulator 8-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.283557] fan53555-reg: supplied by vcc_sys
[ 2.285996] rk808 8-001b: Pmic Chip id: 0x0
[ 2.289129] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 2.289191] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 2.289267] DCDC_REG1: supplied by vcc_sys
[ 2.289941] DCDC_REG2: supplied by vcc_sys
[ 2.290446] DCDC_REG3: supplied by vcc_sys
[ 2.290654] DCDC_REG4: supplied by vcc_sys
[ 2.291026] LDO_REG1: supplied by vcc_sys
[ 2.292072] LDO_REG2: supplied by vcc_sys
[ 2.293003] LDO_REG3: supplied by vcc_sys
[ 2.293894] LDO_REG4: supplied by vcc_sys
[ 2.294800] LDO_REG5: supplied by vcc_sys
[ 2.295692] LDO_REG6: supplied by vcc_sys
[ 2.296586] LDO_REG7: supplied by vcc_sys
[ 2.297491] LDO_REG8: supplied by vcc_sys
[ 2.298386] SWITCH_REG1: supplied by vcc3v3_sys
[ 2.298621] SWITCH_REG2: supplied by vcc3v3_sys
[ 2.301960] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 2.302388] rk3x-i2c ff3e0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fc000
[ 2.303203] IR NEC protocol handler initialized
[ 2.303219] IR RC5(x/sz) protocol handler initialized
[ 2.303234] IR RC6 protocol handler initialized
[ 2.303247] IR JVC protocol handler initialized
[ 2.303261] IR Sony protocol handler initialized
[ 2.303275] IR SANYO protocol handler initialized
[ 2.303289] IR Sharp protocol handler initialized
[ 2.303303] IR MCE Keyboard/mouse protocol handler initialized
[ 2.303317] IR XMP protocol handler initialized
[ 2.303513] usbcore: registered new interface driver uvcvideo
[ 2.303524] USB Video Class driver (1.1.1)
[ 2.303541] CamSys driver version: v0.34.8, CamSys head file version: v0.14.0
[ 2.307533] __power_supply_register: Expected proper parent device for 'test_ac'
[ 2.307669] __power_supply_register: Expected proper parent device for 'test_battery'
[ 2.307910] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.308008] __power_supply_register: Expected proper parent device for 'test_usb'
[ 2.310244] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.310794] device-mapper: uevent: version 1.0.3
[ 2.311066] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.311206] Bluetooth: HCI UART driver ver 2.3
[ 2.311219] Bluetooth: HCI UART protocol H4 registered
[ 2.311230] Bluetooth: HCI UART protocol LL registered
[ 2.311246] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 2.311257] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 2.311267] rtk_btusb: Register usb char device interface for BT driver
[ 2.311455] usbcore: registered new interface driver rtk_btusb
[ 2.311846] cpu cpu0: leakage=24
[ 2.328180] cpu cpu0: temp=51111, pvtm=147428 (146768 + 660)
[ 2.328404] cpu cpu0: pvtm-sel=1
[ 2.328707] cpu cpu4: leakage=40
[ 2.340602] cpu cpu4: temp=51111, pvtm=155050 (154700 + 350)
[ 2.340743] cpu cpu4: pvtm-sel=2
[ 2.344745] sdhci: Secure Digital Host Controller Interface driver
[ 2.344763] sdhci: Copyright(c) Pierre Ossman
[ 2.344780] Synopsys Designware Multimedia Card Interface Driver
[ 2.345580] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.345659] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.345680] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.345735] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.345768] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.345812] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.345824] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.346627] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.346678] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.346696] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.346736] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 2.346758] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.346864] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.347116] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 2.347140] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.347155] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.359736] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.374109] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.374383] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.376076] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.376089] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.403042] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.404413] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.407969] usbcore: registered new interface driver usbhid
[ 2.407983] usbhid: USB HID core driver
[ 2.408145] inv_mpu_iio: inv_mpu_init:746
[ 2.409148] ashmem: initialized
[ 2.415953] rknandbase v1.1 2016-11-08
[ 2.416457] usbcore: registered new interface driver snd-usb-audio
[ 2.417414] es8316 1-0010: Can not read property hp_det_gpio
[ 2.420560] u32 classifier
[ 2.420575] Actions configured
[ 2.420629] Netfilter messages via NETLINK v0.30.
[ 2.420687] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.421045] ctnetlink v0.93: registering with nfnetlink.
[ 2.421641] xt_time: kernel timezone is -0000
[ 29.229594] NMI watchdog: BUG: soft lockup - CPU#4 stuck for 23s! [swapper/0:1]
[ 29.229636] Modules linked in:
[ 29.229648]
[ 29.229662] CPU: 4 PID: 1 Comm: swapper/0 Not tainted 4.4.103 #1
[ 29.229672] Hardware name: Rockchip RK3399 Board rev2 (BOX) (DT)
[ 29.229685] task: ffffffc00a350000 task.stack: ffffffc00a358000
[ 29.229704] PC is at smp_call_function_many+0x258/0x288
[ 29.229717] LR is at smp_call_function_many+0x238/0x288
[ 29.229729] pc : [<ffffff800811a0e0>] lr : [<ffffff800811a0c0>] pstate: 80400045
[ 29.229741] sp : ffffffc00a35bab0
[ 29.229750] x29: ffffffc00a35bab0 x28: ffffff80090feec0
[ 29.229769] x27: ffffff8009128000 x26: ffffff8009127bd0
[ 29.229786] x25: ffffff8009128000 x24: 0000000000000000
[ 29.229802] x23: ffffff8009128000 x22: ffffffc07ef0be60
[ 29.229818] x21: ffffffc07ef5cf08 x20: ffffff8009127bd0
[ 29.229833] x19: ffffffc07ef5cf00 x18: 0000000000001400
[ 29.229850] x17: 0000000000000003 x16: 0000000000000010
[ 29.229865] x15: 2d736f691200031a x14: 0000000000000000
[ 29.229881] x13: ffffff0000000000 x12: 0000000000000000
[ 29.229896] x11: ffffffffffffffff x10: 0000000000000001
[ 29.229912] x9 : 0000000000000003 x8 : 0000000000000002
[ 29.229928] x7 : ffffff8009369da8 x6 : ffffffbffe7feffc
[ 29.229944] x5 : 000000000000002d x4 : 0000000000000000
[ 29.229959] x3 : 0000000000000000 x2 : 0000000000000000
[ 29.229974] x1 : ffffff8009128310 x0 : 0000000000000003
[ 29.229991]
[ 29.229991] PC: 0xffffff800811a060:
[ 29.230002] a060 b9401801 321f0021 b9001801 910c4361 f9000417 f9000818 f90037a4 f863d822
[ 29.230051] a080 aa0003e1 8b020382 940a0302 f94037a4 17ffffdc aa1503e0 97fdd3da 12800002
[ 29.230097] a0a0 340002b6 912f4294 d0008077 11000442 d2800101 aa1503e0 93407c42 940a02c7
[ 29.230143] a0c0 2a0003e2 b9400281 6b01001f 5400014a 910c42e1 f9400276 f860d820 8b0002d6
[ 29.230188] a0e0 910062c0 88dffc00 3607fe20 d503203f 17fffffc a94153f3 a9425bf5 a94363f7
[ 29.230234] a100 a9446bf9 a94573fb a8c77bfd d65f03c0 a9be7bfd aa0003e4 aa0103e3 910003fd
[ 29.230280] a120 f9000bf3 d5384113 b9401a60 11000400 b9001a60 b0005060 6b1f005f aa0403e1
[ 29.230326] a140 aa0303e2 1a9f07e3 f944e400 97ffff4f b9401a60 51000400 b9001a60 35000080
[ 29.230372]
[ 29.230372] LR: 0xffffff800811a040:
[ 29.230383] a040 36000061 d503203f 17fffffc b9401801 32000021 b9001801 d5033abf 34000096
[ 29.230429] a060 b9401801 321f0021 b9001801 910c4361 f9000417 f9000818 f90037a4 f863d822
[ 29.230475] a080 aa0003e1 8b020382 940a0302 f94037a4 17ffffdc aa1503e0 97fdd3da 12800002
[ 29.230520] a0a0 340002b6 912f4294 d0008077 11000442 d2800101 aa1503e0 93407c42 940a02c7
[ 29.230566] a0c0 2a0003e2 b9400281 6b01001f 5400014a 910c42e1 f9400276 f860d820 8b0002d6
[ 29.230611] a0e0 910062c0 88dffc00 3607fe20 d503203f 17fffffc a94153f3 a9425bf5 a94363f7
[ 29.230657] a100 a9446bf9 a94573fb a8c77bfd d65f03c0 a9be7bfd aa0003e4 aa0103e3 910003fd
[ 29.230702] a120 f9000bf3 d5384113 b9401a60 11000400 b9001a60 b0005060 6b1f005f aa0403e1
[ 29.230749]
[ 29.230749] SP: 0xffffffc00a35ba30:
[ 29.230758] ba30 7ef0be60 ffffffc0 09128000 ffffff80 00000000 00000000 09128000 ffffff80
[ 29.230804] ba50 09127bd0 ffffff80 09128000 ffffff80 090feec0 ffffff80 0a35bab0 ffffffc0
[ 29.230849] ba70 0811a0c0 ffffff80 0a35bab0 ffffffc0 0811a0e0 ffffff80 80400045 00000000
[ 29.230895] ba90 7ef5cf08 ffffffc0 00000001 00000000 ffffffff ffffffff 0811a0c0 ffffff80
[ 29.230940] bab0 0a35bb20 ffffffc0 0811a150 ffffff80 0a350000 ffffffc0 0a35bbd0 ffffffc0
[ 29.230985] bad0 0a35bbcc ffffffc0 1400001c 00000000 04e73a80 ffffffc0 00000000 00000000
[ 29.231031] baf0 091318f0 ffffff80 090504a0 ffffff80 090b2e30 ffffff80 092bc000 ffffff80
[ 29.231076] bb10 0a35bbcc ffffffc0 00000005 00000000 0a35bb40 ffffffc0 0811a218 ffffff80
[ 29.231124]
[ 29.231124] X1: 0xffffff8009128290:
[ 29.231134] 8290 00000001 00000000 00000001 00000000 0000012c 00000000 7ef7c0c0 ffffffc0
[ 29.231179] 82b0 00000015 00000000 7ef7c080 ffffffc0 00000001 00000000 00000060 00000000
[ 29.231225] 82d0 00015000 00000000 7ef7c140 ffffffc0 7ef7c100 ffffffc0 00000001 00001000
[ 29.231270] 82f0 00000006 00000000 00000005 00000010 7eefdf00 ffffffc0 7eefe000 ffffffc0
[ 29.231316] 8310 75e0a000 00000040 75e1f000 00000040 75e34000 00000040 75e49000 00000040
[ 29.231361] 8330 75e5e000 00000040 75e73000 00000040 00000000 00000000 00000000 00000000
[ 29.231406] 8350 00000001 00000000 00000001 00000000 000014bb 00000000 00010000 00000000
[ 29.231451] 8370 0007ffff 00000000 0000f2fc 00000000 00002000 00000000 00000000 0000fffa
[ 29.231499]
[ 29.231499] X6: 0xffffffbffe7fef7c:
[ 29.231509] ef7c ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231563] ef9c ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231611] efbc ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231660] efdc ******** ******** ******** ******** ******** ******** ******** ********
[ 29.231708] effc ******** 00000000 00000001 000000c1 00000003 00000000 00000000 00000000
[ 29.231756] f01c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.231804] f03c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.231853] f05c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.231902]
[ 29.231902] X7: 0xffffff8009369d28:
[ 29.231912] 9d28 08000000 ffffff80 bff72000 ffffffbd 00000000 00000000 00000000 00000000
[ 29.231958] 9d48 000002df 00000000 00001000 00000000 00002000 00000000 00080000 00000000
[ 29.232003] 9d68 00080000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232048] 9d88 00000001 00000000 00200000 00000000 08200000 00000000 00000000 00000000
[ 29.232093] 9da8 0a200000 00000000 75e00000 00000000 00000000 00000000 0a200000 00000000
[ 29.232138] 9dc8 75e00000 00000000 00000000 00000000 0a200000 00000000 75e00000 00000000
[ 29.232184] 9de8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232229] 9e08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232279]
[ 29.232279] X19: 0xffffffc07ef5ce80:
[ 29.232289] ce80 00000000 00000000 00000001 00000000 7ef5ce90 ffffffc0 7ef5ce90 ffffffc0
[ 29.232335] cea0 00000000 00000000 00000000 00000000 00000000 00000004 09144c40 ffffff80
[ 29.232380] cec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232425] cee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232470] cf00 09101e60 ffffff80 0000002d 00000000 00000000 00000000 00000000 00000000
[ 29.232516] cf20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232560] cf40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232605] cf60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232651]
[ 29.232651] X20: 0xffffff8009127b50:
[ 29.232661] 7b50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232706] 7b70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232751] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.232796] 7bb0 7c280000 ffffffc0 00000800 00000000 00000001 00000000 00000000 00000000
[ 29.232842] 7bd0 00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
[ 29.232887] 7bf0 00000000 00000000 00000000 00000000 00000000 00000000 092ae1c0 ffffff80
[ 29.232932] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 092ae208 ffffff80
[ 29.232978] 7c30 00000000 00000000 00000000 00000000 0000000a 00000000 00400000 0000000a
[ 29.233024]
[ 29.233024] X21: 0xffffffc07ef5ce88:
[ 29.233034] ce88 00000001 00000000 7ef5ce90 ffffffc0 7ef5ce90 ffffffc0 00000000 00000000
[ 29.233080] cea8 00000000 00000000 00000000 00000004 09144c40 ffffff80 00000000 00000000
[ 29.233127] cec8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233172] cee8 00000000 00000000 00000000 00000000 00000000 00000000 09101e60 ffffff80
[ 29.233217] cf08 0000002d 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233262] cf28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233307] cf48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233353] cf68 00000000 00000000 00000000 00000000 00000000 00000000 7ef5cf80 ffffffc0
[ 29.233400]
[ 29.233400] X22: 0xffffffc07ef0bde0:
[ 29.233409] bde0 00000000 00000000 00000001 00000000 00000000 00000000 00000000 00000000
[ 29.233455] be00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233500] be20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233545] be40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233590] be60 00000000 00000000 081197e4 ffffff80 00000000 00000000 00000003 00000000
[ 29.233636] be80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233682] bea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233727] bec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.233773]
[ 29.233773] X23: 0xffffff8009127f80:
[ 29.233782] 7f80 092952c8 ffffff80 09295360 ffffff80 092953f8 ffffff80 09295490 ffffff80
[ 29.233828] 7fa0 09295528 ffffff80 092955c0 ffffff80 09295658 ffffff80 092956f0 ffffff80
[ 29.233874] 7fc0 09295788 ffffff80 09295820 ffffff80 092958b8 ffffff80 09295950 ffffff80
[ 29.233920] 7fe0 092959e8 ffffff80 09295a80 ffffff80 0928e0a8 ffffff80 0928e140 ffffff80
[ 29.233965] 8000 0928e1d8 ffffff80 0928e270 ffffff80 0928e308 ffffff80 0928e3a0 ffffff80
[ 29.234011] 8020 0928e438 ffffff80 0928e4d0 ffffff80 0928e568 ffffff80 0928e600 ffffff80
[ 29.234057] 8040 0928e698 ffffff80 0928e730 ffffff80 0928e7c8 ffffff80 0928e860 ffffff80
[ 29.234102] 8060 0928e8f8 ffffff80 0928e990 ffffff80 09291898 ffffff80 09291930 ffffff80
[ 29.234149]
[ 29.234149] X25: 0xffffff8009127f80:
[ 29.234159] 7f80 092952c8 ffffff80 09295360 ffffff80 092953f8 ffffff80 09295490 ffffff80
[ 29.234205] 7fa0 09295528 ffffff80 092955c0 ffffff80 09295658 ffffff80 092956f0 ffffff80
[ 29.234251] 7fc0 09295788 ffffff80 09295820 ffffff80 092958b8 ffffff80 09295950 ffffff80
[ 29.234296] 7fe0 092959e8 ffffff80 09295a80 ffffff80 0928e0a8 ffffff80 0928e140 ffffff80
[ 29.234342] 8000 0928e1d8 ffffff80 0928e270 ffffff80 0928e308 ffffff80 0928e3a0 ffffff80
[ 29.234388] 8020 0928e438 ffffff80 0928e4d0 ffffff80 0928e568 ffffff80 0928e600 ffffff80
[ 29.234434] 8040 0928e698 ffffff80 0928e730 ffffff80 0928e7c8 ffffff80 0928e860 ffffff80
[ 29.234480] 8060 0928e8f8 ffffff80 0928e990 ffffff80 09291898 ffffff80 09291930 ffffff80
[ 29.234526]
[ 29.234526] X26: 0xffffff8009127b50:
[ 29.234536] 7b50 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.234581] 7b70 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.234627] 7b90 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.234672] 7bb0 7c280000 ffffffc0 00000800 00000000 00000001 00000000 00000000 00000000
[ 29.234717] 7bd0 00000006 00000000 00000013 00000000 00000000 00000000 00000000 00000000
[ 29.234762] 7bf0 00000000 00000000 00000000 00000000 00000000 00000000 092ae1c0 ffffff80
[ 29.234808] 7c10 00000000 00000000 00000000 00000000 00000000 00000000 092ae208 ffffff80
[ 29.234854] 7c30 00000000 00000000 00000000 00000000 0000000a 00000000 00400000 0000000a
[ 29.234900]
[ 29.234900] X27: 0xffffff8009127f80:
[ 29.234910] 7f80 092952c8 ffffff80 09295360 ffffff80 092953f8 ffffff80 09295490 ffffff80
[ 29.234956] 7fa0 09295528 ffffff80 092955c0 ffffff80 09295658 ffffff80 092956f0 ffffff80
[ 29.235001] 7fc0 09295788 ffffff80 09295820 ffffff80 092958b8 ffffff80 09295950 ffffff80
[ 29.235047] 7fe0 092959e8 ffffff80 09295a80 ffffff80 0928e0a8 ffffff80 0928e140 ffffff80
[ 29.235093] 8000 0928e1d8 ffffff80 0928e270 ffffff80 0928e308 ffffff80 0928e3a0 ffffff80
[ 29.235139] 8020 0928e438 ffffff80 0928e4d0 ffffff80 0928e568 ffffff80 0928e600 ffffff80
[ 29.235185] 8040 0928e698 ffffff80 0928e730 ffffff80 0928e7c8 ffffff80 0928e860 ffffff80
[ 29.235231] 8060 0928e8f8 ffffff80 0928e990 ffffff80 09291898 ffffff80 09291930 ffffff80
[ 29.235278]
[ 29.235278] X28: 0xffffff80090fee40:
[ 29.235287] ee40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235333] ee60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235377] ee80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235423] eea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235468] eec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235513] eee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235558] ef00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235603] ef20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 29.235650]
[ 29.235650] X29: 0xffffffc00a35ba30:
[ 29.235659] ba30 7ef0be60 ffffffc0 09128000 ffffff80 00000000 00000000 09128000 ffffff80
[ 29.235705] ba50 09127bd0 ffffff80 09128000 ffffff80 090feec0 ffffff80 0a35bab0 ffffffc0
[ 29.235750] ba70 0811a0c0 ffffff80 0a35bab0 ffffffc0 0811a0e0 ffffff80 80400045 00000000
[ 29.235796] ba90 7ef5cf08 ffffffc0 00000001 00000000 ffffffff ffffffff 0811a0c0 ffffff80
[ 29.235841] bab0 0a35bb20 ffffffc0 0811a150 ffffff80 0a350000 ffffffc0 0a35bbd0 ffffffc0
[ 29.235887] bad0 0a35bbcc ffffffc0 1400001c 00000000 04e73a80 ffffffc0 00000000 00000000
[ 29.235932] baf0 091318f0 ffffff80 090504a0 ffffff80 090b2e30 ffffff80 092bc000 ffffff80
[ 29.235978] bb10 0a35bbcc ffffffc0 00000005 00000000 0a35bb40 ffffffc0 0811a218 ffffff80
[ 29.236024]
Tried flashing some other factory images as well, but still system is not booting. Please let me know, if you people know any solution to resolve this issue.
