The OV13850 and serial board for Firefly is available now
1597
administrator
Rank: 9Rank: 9Rank: 9
Posted at 1/22/2015 23:55:41        Only Author  1#
Good news for you! The OV13850 camera and serial board for Firefly-RK3288 are available on Aliexpressnow.
OV13850 color image sensor is a low voltage, high performance 1/3.06-inch 13.2 megapixel CMOS image sensor that provides the functionality of a single 13.2 megapixel (4224×3136) camera using OmniBSI+™ technology.
The serial board is used for debugging of Firefly-RK3288. Which is a bridge between the Firefly and your computer. You can receive the debug information through this board while connect to debug serial on Firefly-RK3288.
OV13850: http://www.aliexpress.com/item/Firefly- ... 01526.html
Serial board: http://www.aliexpress.com/item/Firefly- ... 76191.html
Posted at 1/25/2015 00:37:33        Only Author  2#
Re: The OV13850 and serial board for Firefly is available now
Is there a schematic for the camera board this board?
Posted at 1/26/2015 04:40:58        Only Author  3#
Can we encode the image from this camera using onboard 265 encoder?
super moderator
Rank: 8Rank: 8
Posted at 1/26/2015 16:36:23        Only Author  4#
there is only h265 decoder on this board.
encoder? em ,you can try H264 for it.
Posted at 2/3/2015 06:46:28        Only Author  5#
Hi,
is it possible to connect two cameras to the device?
Yours,
Jonas
