Posted at 11/14/2020 14:18:38
Hi I'm building an SD card image for the Firefly RK3288 board using buildroot. Here are the steps I've followed to build the image.
- mkdir <work area>; cd <work area>
- git clone <a href="https://github.com/FireflyTeam/buildroot.git" target="_blank">https://github.com/FireflyTeam/buildroot.git</a>
- cd buildroot
- git branch
- < output indicated on branch "2016.08.x" >
- make firefly_rk3288_defconfig
- make menuconfig
- <save .config in menus then exit>
- make
Copy the code ... lots of compiling ...when finally finished, then write .../output/images/sdcard.img to high quality SanDisk class 10 uSD card
Preparation on the Firefly board were to image the board with the Firefly-RK3288-Reload_Ubuntu14.04_201803201147.img image and boot the board. Next I cleared the EMMC part so the board will boot from the uSD per the thread (https://bbs.t-firefly.com/forum.php?mod=viewthread&tid=1777&extra=&page=2) instructions with:
- dd if=/dev/zero of=/dev/mmcblk0 bs=1M count=4
Copy the code
I then insert the uSD card into the board and reset the board. It properly boots uBoot and then the Linux kernel, but the kernel can't ever get the root filesystem loaded due to what look like MMC errors reading the uSD card's filesytem.
I know the uSD card is good as I have tried several cards, all with the same results. I also have tried reading / writing the cards on the Firefly board when it is using the Factory Ubuntu image and that works as well.
Here is the boot output from the Firefly showing the failures in trying to mount the filesystem:
- U-Boot SPL 2016.01 (Nov 13 2020 - 22:19:14)
- Trying to boot from MMC
- U-Boot 2016.01 (Nov 13 2020 - 22:19:14 -0700)
- Model: Firefly-RK3288
- DRAM: 2 GiB
- MMC: dwmmc@ff0c0000: 0, dwmmc@ff0f0000: 1
- *** Warning - bad CRC, using default environment
- In: serial@ff690000
- Out: serial@ff690000
- Err: serial@ff690000
- Net: Net Initialization Skipped
- No ethernet found.
- Hit any key to stop autoboot: 0
- switch to partitions #0, OK
- mmc0 is current device
- Scanning mmc 0:1...
- Found /boot/extlinux/extlinux.conf
- Retrieving file: /boot/extlinux/extlinux.conf
- 160 bytes read in 26 ms (5.9 KiB/s)
- 1: firefly-rk3288
- Retrieving file: /boot/uImage
- 5504568 bytes read in 1033 ms (5.1 MiB/s)
- append: console=ttyS2,115200n8 root=/dev/mmcblk0p1 rootwait
- Retrieving file: /boot/rk3288-firefly.dtb
- 35785 bytes read in 33 ms (1 MiB/s)
- ## Booting kernel from Legacy Image at 02000000 ...
- Image Name: Linux-4.4.0-rc5
- Image Type: ARM Linux Kernel Image (uncompressed)
- Data Size: 5504504 Bytes = 5.2 MiB
- Load Address: 02000000
- Entry Point: 02000000
- Verifying Checksum ... OK
- ## Flattened Device Tree blob at 01f00000
- Booting using the fdt blob at 0x1f00000
- Loading Kernel Image ... OK
- Loading Device Tree to 1fff4000, end 1ffffbc8 ... OK
- Starting kernel ...
- [ 0.000000] Booting Linux on physical CPU 0x500
- [ 0.000000] Initializing cgroup subsys cpuset
- [ 0.000000] Initializing cgroup subsys cpuacct
- [ 0.000000] Linux version 4.4.0-rc5 (brianm@vbox-ubuntu14) (gcc version 5.4.0 (Buildroot 2016.08.1-g5c 2cd404aa) ) #1 SMP Fri Nov 13 22:22:28 MST 2020
- [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
- [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- [ 0.000000] Machine model: Firefly-RK3288
- [ 0.000000] Memory policy: Data cache writealloc
- [ 0.000000] PERCPU: Embedded 14 pages/cpu @eed80000 s25216 r8192 d23936 u57344
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522560
- [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk0p1 rootwait
- [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
- [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
- [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
- [ 0.000000] Memory: 2056732K/2097152K available (8164K kernel code, 586K rwdata, 2620K rodata, 556K in it, 8701K bss, 40420K reserved, 0K cma-reserved, 1310720K highmem)
- [ 0.000000] Virtual kernel memory layout:
- [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
- [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
- [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
- [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
- [ 0.000000] .text : 0xc0008000 - 0xc0a90444 (10786 kB)
- [ 0.000000] .init : 0xc0a91000 - 0xc0b1c000 ( 556 kB)
- [ 0.000000] .data : 0xc0b1c000 - 0xc0bae968 ( 587 kB)
- [ 0.000000] .bss : 0xc0bb1000 - 0xc14307c8 (8702 kB)
- [ 0.000000] Running RCU self tests
- [ 0.000000] Hierarchical RCU implementation.
- [ 0.000000] RCU lockdep checking is enabled.
- [ 0.000000] Build-time adjustment of leaf fanout to 32.
- [ 0.000000] NR_IRQS:16 nr_irqs:16 16
- [ 0.000000] L2C: failed to init: -19
- [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
- [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns : 440795202592 ns
- [ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
- [ 0.000035] Switching to timer-based delay loop, resolution 41ns
- [ 0.004096] Console: colour dummy device 80x30
- [ 0.004210] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
- [ 0.004227] ... MAX_LOCKDEP_SUBCLASSES: 8
- [ 0.004241] ... MAX_LOCK_DEPTH: 48
- [ 0.004255] ... MAX_LOCKDEP_KEYS: 8191
- [ 0.004268] ... CLASSHASH_SIZE: 4096
- [ 0.004281] ... MAX_LOCKDEP_ENTRIES: 32768
- [ 0.004295] ... MAX_LOCKDEP_CHAINS: 65536
- [ 0.004308] ... CHAINHASH_SIZE: 32768
- [ 0.004321] memory used by lock dependency info: 5167 kB
- [ 0.004335] per task-struct memory footprint: 1536 bytes
- [ 0.004383] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
- [ 0.004412] pid_max: default: 32768 minimum: 301
- [ 0.005182] Security Framework initialized
- [ 0.005205] Yama: becoming mindful.
- [ 0.005817] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
- [ 0.005849] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
- [ 0.013936] Initializing cgroup subsys io
- [ 0.014155] Initializing cgroup subsys memory
- [ 0.014268] Initializing cgroup subsys devices
- [ 0.014479] Initializing cgroup subsys freezer
- [ 0.014808] Initializing cgroup subsys perf_event
- [ 0.014861] Initializing cgroup subsys pids
- [ 0.014961] CPU: Testing write buffer coherency: ok
- [ 0.015119] ftrace: allocating 26468 entries in 78 pages
- [ 0.091452] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
- [ 0.092114] Setting up static identity map for 0x8280 - 0x82d8
- [ 0.111070] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
- [ 0.116301] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
- [ 0.121087] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
- [ 0.121528] Brought up 4 CPUs
- [ 0.121562] SMP: Total of 4 processors activated (192.00 BogoMIPS).
- [ 0.121574] CPU: All CPU(s) started in SVC mode.
- [ 0.127812] devtmpfs: initialized
- [ 0.198981] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
- [ 0.200759] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750 000 ns
- [ 0.202557] pinctrl core: initialized pinctrl subsystem
- [ 0.212557] NET: Registered protocol family 16
- [ 0.213811] DMA: preallocated 256 KiB pool for atomic coherent allocations
- [ 0.239763] cpuidle: using governor ladder
- [ 0.269684] cpuidle: using governor menu
- [ 0.362620] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
- [ 0.362639] hw-breakpoint: maximum watchpoint size is 4 bytes.
- [ 0.514144] iommu: Adding device ff930000.vop to group 0
- [ 0.514481] iommu: Adding device ff940000.vop to group 1
- [ 0.518839] SCSI subsystem initialized
- [ 0.520126] usbcore: registered new interface driver usbfs
- [ 0.520428] usbcore: registered new interface driver hub
- [ 0.520985] usbcore: registered new device driver usb
- [ 0.522580] pps_core: LinuxPPS API ver. 1 registered
- [ 0.522598] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <<a href="mailto:giometti@linux.it">giometti@linux.it</a>>
- [ 0.522699] PTP clock support registered
- [ 0.525028] Advanced Linux Sound Architecture Driver Initialized.
- [ 0.536772] clocksource: Switched to clocksource arch_sys_counter
- [ 0.829307] NET: Registered protocol family 2
- [ 0.833214] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
- [ 0.833439] TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
- [ 0.837517] TCP: Hash tables configured (established 8192 bind 8192)
- [ 0.837883] UDP hash table entries: 512 (order: 3, 40960 bytes)
- [ 0.838428] UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
- [ 0.840476] NET: Registered protocol family 1
- [ 0.843173] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
- [ 0.850698] futex hash table entries: 1024 (order: 4, 65536 bytes)
- [ 0.861696] squashfs: version 4.0 (2009/01/31) Phillip Lougher
- [ 0.870904] bounce: pool size: 64 pages
- [ 0.871121] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
- [ 0.871290] io scheduler noop registered
- [ 0.871326] io scheduler deadline registered (default)
- [ 0.895444] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
- [ 0.895472] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Even ts-16
- [ 0.901094] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
- [ 0.901120] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events -10
- [ 0.903488] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
- [ 0.928023] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
- [ 0.932981] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
- [ 0.937546] console [ttyS2] disabled
- [ 0.938531] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 39, base_baud = 1500000) is a 16550A
- [ 1.611369] console [ttyS2] enabled
- [ 1.619470] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 40, base_baud = 1500000) is a 16550A
- [ 1.632634] [drm] Initialized drm 1.1.0 20060810
- [ 1.653831] rockchip-drm display-subsystem: bound ff940000.vop (ops vop_component_ops)
- [ 1.663319] rockchip-drm display-subsystem: bound ff930000.vop (ops vop_component_ops)
- [ 1.671737] rockchip-drm display-subsystem: failed to bind ff980000.hdmi (ops dw_hdmi_rockchip_ops): - 517
- [ 1.688953] rockchip-drm display-subsystem: master bind failed: -517
- [ 1.707046] brd: module loaded
- [ 1.753742] loop: module loaded
- [ 1.768106] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
- [ 1.779346] ff540000.usb supply vusb_d not found, using dummy regulator
- [ 1.786985] ff540000.usb supply vusb_a not found, using dummy regulator
- [ 2.647646] dwc2 ff540000.usb: DWC OTG Controller
- [ 2.653530] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
- [ 2.660936] dwc2 ff540000.usb: irq 43, io mem 0x00000000
- [ 2.668864] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
- [ 2.675662] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 2.682929] usb usb1: Product: DWC OTG Controller
- [ 2.687669] usb usb1: Manufacturer: Linux 4.4.0-rc5 dwc2_hsotg
- [ 2.693506] usb usb1: SerialNumber: ff540000.usb
- [ 2.704939] hub 1-0:1.0: USB hub found
- [ 2.709036] hub 1-0:1.0: 1 port detected
- [ 2.719814] dwc2 ff580000.usb: Configuration mismatch. Forcing host mode
- [ 2.726824] ff580000.usb supply vusb_d not found, using dummy regulator
- [ 2.733862] ff580000.usb supply vusb_a not found, using dummy regulator
- [ 3.106832] usb 1-1: new high-speed USB device number 2 using dwc2
- [ 3.317786] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
- [ 3.324498] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
- [ 3.331701] usb 1-1: Product: USB 2.0 Hub [MTT]
- [ 3.340555] hub 1-1:1.0: USB hub found
- [ 3.344525] hub 1-1:1.0: 4 ports detected
- [ 3.597357] dwc2 ff580000.usb: DWC OTG Controller
- [ 3.602194] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
- [ 3.609394] dwc2 ff580000.usb: irq 44, io mem 0x00000000
- [ 3.615769] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
- [ 3.622607] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
- [ 3.629865] usb usb2: Product: DWC OTG Controller
- [ 3.634577] usb usb2: Manufacturer: Linux 4.4.0-rc5 dwc2_hsotg
- [ 3.640441] usb usb2: SerialNumber: ff580000.usb
- [ 3.649088] hub 2-0:1.0: USB hub found
- [ 3.653030] hub 2-0:1.0: 1 port detected
- [ 3.664939] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- [ 3.671610] ehci-platform: EHCI generic platform driver
- [ 3.678102] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- [ 3.684685] usbcore: registered new interface driver cdc_acm
- [ 3.690402] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
- [ 3.698858] usbcore: registered new interface driver usb-storage
- [ 3.705378] usbcore: registered new interface driver usbserial
- [ 3.711444] usbcore: registered new interface driver usbserial_generic
- [ 3.718696] usbserial: USB Serial support registered for generic
- [ 3.731047] rk3x-i2c ff140000.i2c: using default SCL frequency: 100000
- [ 3.739461] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f08d2000
- [ 3.746899] rk3x-i2c ff160000.i2c: using default SCL frequency: 100000
- [ 3.754817] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f08d4000
- [ 3.762976] rk3x-i2c ff170000.i2c: using default SCL frequency: 100000
- [ 3.770925] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f08d6000
- [ 3.783097] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
- [ 3.795810] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
- [ 3.813076] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
- [ 3.849502] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f08d8000
- [ 3.856912] rk3x-i2c ff660000.i2c: using default SCL frequency: 100000
- [ 3.864808] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f08da000
- [ 3.874257] vcc_io: supplied by vcc_sys
- [ 3.880245] vcc28_dvp: supplied by vcc_io
- [ 3.884804] dovdd_1v8: supplied by vcc28_dvp
- [ 3.890313] vcc_flash: supplied by vcc_io
- [ 3.895434] vcc_lan: supplied by vcc_sys
- [ 3.900804] vcc_20: supplied by vcc_sys
- [ 3.905177] vcc_18: supplied by vcc_20
- [ 3.911853] vcca_33: supplied by vcc_sys
- [ 3.917172] vccio_sd: supplied by vcc_sys
- [ 3.926948] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: <a href="mailto:dm-devel@redhat.com">dm-devel@redhat.com</a>
- [ 3.936874] vdd_cpu: supplied by vcc_sys
- [ 3.948075] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 500000 KHz
- [ 3.958236] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 600000 KHz
- [ 3.972744] sdhci: Secure Digital Host Controller Interface driver
- [ 3.978970] sdhci: Copyright(c) Pierre Ossman
- [ 3.983344] Synopsys Designware Multimedia Card Interface Driver
- [ 3.991212] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
- [ 3.998518] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
- [ 4.005312] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
- [ 4.011288] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
- [ 4.021406] vcc_sd: supplied by vcc_io
- [ 4.156832] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 4.177284] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
- [ 4.184356] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
- [ 4.195324] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
- [ 4.202758] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
- [ 4.209609] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
- [ 4.215618] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
- [ 4.226731] dwmmc_rockchip ff0d0000.dwmmc: Failed getting OCR mask: 0
- [ 4.237774] dwmmc_rockchip ff0d0000.dwmmc: could not set regulator OCR (-22)
- [ 4.244869] dwmmc_rockchip ff0d0000.dwmmc: failed to enable vmmc regulator
- [ 4.266961] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 4.287170] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
- [ 4.294345] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
- [ 4.301768] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
- [ 4.308637] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
- [ 4.314650] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
- [ 4.346859] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 4.367052] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
- [ 4.373312] sdhci-pltfm: SDHCI platform and OF driver helper
- [ 4.382696] hidraw: raw HID events driver (C) Jiri Kosina
- [ 4.390128] usbcore: registered new interface driver usbhid
- [ 4.395701] usbhid: USB HID core driver
- [ 4.400360] usbcore: registered new interface driver r8188eu
- [ 4.406411] usbcore: registered new interface driver rtl8723au
- [ 4.417121] Netfilter messages via NETLINK v0.30.
- [ 4.422770] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
- [ 4.430024] ctnetlink v0.93: registering with nfnetlink.
- [ 4.439861] ip_tables: (C) 2000-2006 Netfilter Core Team
- [ 4.446637] NET: Registered protocol family 10
- [ 4.454471] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 4.464492] mmc0: new high speed SDHC card at address aaaa
- [ 4.465600] NET: Registered protocol family 17
- [ 4.465803] ThumbEE CPU extension supported.
- [ 4.465845] Registering SWP/SWPB emulation handler
- [ 4.485174] rockchip-drm display-subsystem: bound ff940000.vop (ops vop_component_ops)
- [ 4.494664] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
- [ 4.494735] rockchip-drm display-subsystem: bound ff930000.vop (ops vop_component_ops)
- [ 4.495260] dwhdmi-rockchip ff980000.hdmi: Detected HDMI controller 0x20:0xa:0xa0:0xc1
- [ 4.496896] rockchip-drm display-subsystem: bound ff980000.hdmi (ops dw_hdmi_rockchip_ops)
- [ 4.497899] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
- [ 4.497904] [drm] No driver support for vblank timestamp query.
- [ 4.498550] rockchip-drm display-subsystem: No connectors reported connected with modes
- [ 4.498881] [drm] Cannot find any crtc or sizes - going 1024x768
- [ 4.558954] mmcblk0: p1
- [ 4.563701] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
- [ 4.570232] Console: switching to colour frame buffer device 128x48
- [ 4.578895] mmc2: mmc_rescan_try_freq: trying to init card at 400000 Hz
- [ 4.607746] rockchip-drm display-subsystem: fb0: frame buffer device
- [ 4.620020] mmc2: MAN_BKOPS_EN bit is not set
- [ 4.626145] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
- [ 4.636559] mmc2: new high speed MMC card at address 0001
- [ 4.644561] mmcblk1: mmc2:0001 BGND3R 29.1 GiB
- [ 4.650303] mmcblk1boot0: mmc2:0001 BGND3R partition 1 4.00 MiB
- [ 4.657544] mmcblk1boot1: mmc2:0001 BGND3R partition 2 4.00 MiB
- [ 4.658085] vdd_gpu: supplied by vcc_sys
- [ 4.668437] mali ffa30000.gpu: Continuing without Mali clock control
- [ 4.674945] mali ffa30000.gpu: Old backward DVFS table; converting
- [ 4.681177] mali ffa30000.gpu: freq:100000000 Hz volt:950000 uV
- [ 4.687125] mali ffa30000.gpu: freq:200000000 Hz volt:950000 uV
- [ 4.693046] mali ffa30000.gpu: freq:300000000 Hz volt:1000000 uV
- [ 4.699074] mali ffa30000.gpu: freq:400000000 Hz volt:1100000 uV
- [ 4.705081] mali ffa30000.gpu: freq:600000000 Hz volt:1250000 uV
- [ 4.712924] vdd_gpu: ramp_delay not set
- [ 4.716869] mali ffa30000.gpu: initial freq = 100000000
- [ 4.723102] hrtimer: interrupt took 674041 ns
- [ 4.730355] vdd_gpu: ramp_delay not set
- [ 4.736437] vdd_gpu: ramp_delay not set
- [ 4.744410] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
- [ 4.752343] vdd_gpu: ramp_delay not set
- [ 4.763461] mali ffa30000.gpu: Couldn't initialize devfreq
- [ 4.771633] mali ffa30000.gpu: Probed as mali0
- [ 4.779116] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
- [ 4.786173] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
- [ 4.791871] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
- [ 4.797581] rk_gmac-dwmac ff290000.ethernet: init for RGMII
- [ 4.803453] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
- [ 4.815082] stmmac - user ID: 0x10, Synopsys ID: 0x35
- [ 4.820166] Ring mode enabled
- [ 4.823224] DMA HW capability register supported
- [ 4.827771] Normal descriptors
- [ 4.831099] RX Checksum Offload Engine supported (type 2)
- [ 4.836581] TX Checksum insertion supported
- [ 4.840866] Wake-Up On Lan supported
- [ 4.844783] Enable RX Mitigation via HW Watchdog Timer
- [ 5.898105] libphy: stmmac: probed
- [ 5.901559] eth0: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
- [ 5.908013] eth0: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
- [ 5.922299] input: gpio-keys as /devices/platform/gpio-keys/input/input0
- [ 5.940266] rtc-hym8563 0-0051: setting system clock to 2017-01-01 15:20:18 UTC (1483284018)
- [ 6.215237] dovdd_1v8: disabling
- [ 6.223344] ALSA device list:
- [ 6.226349] No soundcards found.
- [ 6.237683] ttyS2 - failed to request DMA
- <font color="Red">[ 6.255608] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
- [ 6.278691] mmcblk0: error -84 transferring data, sector 809, nr 14, cmd response 0x900, card status 0 xb00
- [ 6.417007] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 6.505225] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 6.515506] mmc0: tried to reset card
- [ 6.522771] mmcblk0: error -84 transferring data, sector 809, nr 14, cmd response 0x900, card status 0 xb00
- [ 6.532508] mmcblk0: retrying using single block read
- [ 6.541976] mmcblk0: error -84 transferring data, sector 813, nr 10, cmd response 0x900, card status 0 x0
- [ 6.677120] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 6.765618] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 6.775899] mmc0: tried to reset card
- [ 6.782958] mmcblk0: error -84 transferring data, sector 813, nr 10, cmd response 0x900, card status 0 x0
- [ 6.792725] blk_update_request: I/O error, dev mmcblk0, sector 813
- [ 6.805702] mmcblk0: error -84 transferring data, sector 823, nr 12, cmd response 0x900, card status 0 xb00
- [ 6.946998] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 7.035339] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 7.045625] mmc0: tried to reset card
- [ 7.052802] mmcblk0: error -84 transferring data, sector 823, nr 12, cmd response 0x900, card status 0 xb00
- [ 7.062552] mmcblk0: retrying using single block read
- [ 7.070198] mmcblk0: error -84 transferring data, sector 823, nr 12, cmd response 0x900, card status 0 x0
- [ 7.079788] blk_update_request: I/O error, dev mmcblk0, sector 823
- [ 7.091375] mmcblk0: error -84 transferring data, sector 830, nr 5, cmd response 0x900, card status 0x 0
- [ 7.226995] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 7.315924] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 7.326465] mmc0: tried to reset card
- [ 7.333805] mmcblk0: error -84 transferring data, sector 830, nr 5, cmd response 0x900, card status 0x 0
- [ 7.343359] blk_update_request: I/O error, dev mmcblk0, sector 830
- [ 7.374709] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
- [ 7.383361] VFS: Mounted root (ext4 filesystem) readonly on device 179:1.
- [ 7.398235] devtmpfs: mounted
- [ 7.404599] Freeing unused kernel memory: 556K (c0a91000 - c0b1c000)
- [ 7.416549] mmcblk0: error -84 transferring data, sector 23269, nr 4, cmd response 0x900, card status 0x0
- [ 7.557379] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 7.656078] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 7.666607] mmc0: tried to reset card
- [ 7.674191] mmcblk0: error -84 transferring data, sector 23269, nr 4, cmd response 0x900, card status 0xb00
- [ 7.684198] mmcblk0: retrying using single block read
- [ 7.694753] mmcblk0: error -84 transferring data, sector 23271, nr 2, cmd response 0x900, card status 0x0
- [ 7.837465] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 7.937918] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 7.949031] mmc0: tried to reset card
- [ 7.957603] mmcblk0: error -84 transferring data, sector 23271, nr 2, cmd response 0x900, card status 0x0
- [ 7.967486] blk_update_request: I/O error, dev mmcblk0, sector 23271
- [ 7.978856] mmcblk0: error -84 transferring data, sector 23273, nr 42, cmd response 0x900, card status 0xb00
- [ 8.117691] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 8.217919] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 8.229027] mmc0: tried to reset card
- [ 8.237702] mmcblk0: error -84 transferring data, sector 23273, nr 42, cmd response 0x900, card status 0xb00
- [ 8.247812] mmcblk0: retrying using single block read
- [ 8.259448] mmcblk0: error -84 transferring data, sector 23276, nr 39, cmd response 0x900, card status 0x0
- [ 8.397478] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 8.498125] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 8.509224] mmc0: tried to reset card
- [ 8.524707] mmcblk0: error -84 transferring data, sector 23284, nr 31, cmd response 0x900, card status 0x0
- [ 8.667481] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 8.768192] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 8.779295] mmc0: tried to reset card
- [ 8.792103] mmcblk0: error -84 transferring data, sector 23289, nr 26, cmd response 0x900, card status 0x0
- [ 8.927471] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 9.027850] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 9.038952] mmc0: tried to reset card
- [ 9.047065] mmcblk0: error -84 transferring data, sector 23289, nr 26, cmd response 0x900, card status 0x0
- [ 9.057058] blk_update_request: I/O error, dev mmcblk0, sector 23289
- [ 9.073796] mmcblk0: error -84 transferring data, sector 23297, nr 18, cmd response 0x900, card status 0x0
- [ 9.207470] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 9.308071] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 9.319174] mmc0: tried to reset card
- [ 9.327319] mmcblk0: error -84 transferring data, sector 23297, nr 18, cmd response 0x900, card status 0x0
- [ 9.337217] blk_update_request: I/O error, dev mmcblk0, sector 23297
- [ 9.347248] mmcblk0: error -84 transferring data, sector 23298, nr 17, cmd response 0x900, card status 0x0
- [ 9.357229] blk_update_request: I/O error, dev mmcblk0, sector 23298
- [ 9.395864] mmcblk0: error -84 transferring data, sector 12063, nr 12, cmd response 0x900, card status 0x0
- [ 9.537478] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 9.637924] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 9.649035] mmc0: tried to reset card
- [ 9.657400] mmcblk0: error -84 transferring data, sector 12063, nr 12, cmd response 0x900, card status 0xb00
- [ 9.667454] mmcblk0: retrying using single block read
- [ 9.677339] mmcblk0: error -84 transferring data, sector 12064, nr 11, cmd response 0x900, card status 0x0
- [ 9.817477] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 9.917851] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 9.928987] mmc0: tried to reset card
- [ 9.938108] mmcblk0: error -84 transferring data, sector 12065, nr 10, cmd response 0x900, card status 0x0
- [ 10.077965] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 10.178054] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 10.189168] mmc0: tried to reset card
- [ 10.230564] mmcblk0: error -84 transferring data, sector 8583, nr 24, cmd response 0x900, card status 0xb00
- [ 10.367505] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 10.467922] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 10.479076] mmc0: tried to reset card
- [ 10.487672] mmcblk0: error -84 transferring data, sector 8583, nr 24, cmd response 0x900, card status 0xb00
- [ 10.497667] mmcblk0: retrying using single block read
- [ 10.507257] mmcblk0: error -84 transferring data, sector 8584, nr 23, cmd response 0x900, card status 0x0
- [ 10.647482] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 10.747804] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 10.758954] mmc0: tried to reset card
- [ 10.769823] mmcblk0: error -84 transferring data, sector 8587, nr 20, cmd response 0x900, card status 0x0
- [ 10.907476] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 11.008040] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 11.019139] mmc0: tried to reset card
- [ 11.027237] mmcblk0: error -84 transferring data, sector 8587, nr 20, cmd response 0x900, card status 0x0
- [ 11.037072] blk_update_request: I/O error, dev mmcblk0, sector 8587
- [ 11.055236] mmcblk0: error -84 transferring data, sector 8596, nr 11, cmd response 0x900, card status 0x0
- [ 11.197650] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 11.298083] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 11.308892] mmc0: tried to reset card
- [ 11.317226] mmcblk0: error -84 transferring data, sector 8596, nr 11, cmd response 0x900, card status 0x0
- [ 11.327058] blk_update_request: I/O error, dev mmcblk0, sector 8596
- [ 11.337508] mmcblk0: error -84 transferring data, sector 8597, nr 10, cmd response 0x900, card status 0x0
- [ 11.347360] blk_update_request: I/O error, dev mmcblk0, sector 8597
- [ 11.361065] mmcblk0: error -84 transferring data, sector 8602, nr 5, cmd response 0x900, card status 0 x0
- [ 11.497500] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 11.597845] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 11.608970] mmc0: tried to reset card
- [ 11.623541] mmcblk0: error -84 transferring data, sector 8583, nr 8, cmd response 0x900, card status 0 x0
- [ 11.757452] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 11.858055] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 11.869161] mmc0: tried to reset card
- [ 11.877996] mmcblk0: error -84 transferring data, sector 8583, nr 8, cmd response 0x900, card status 0 xb00
- [ 11.887867] mmcblk0: retrying using single block read
- [ 11.900223] mmcblk0: error -84 transferring data, sector 8587, nr 4, cmd response 0x900, card status 0 x0
- [ 12.037474] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 12.147911] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 12.159029] mmc0: tried to reset card
- [ 12.167228] mmcblk0: error -84 transferring data, sector 8587, nr 4, cmd response 0x900, card status 0 x0
- [ 12.177062] blk_update_request: I/O error, dev mmcblk0, sector 8587
- [ 12.187069] mmcblk0: error -84 transferring data, sector 8588, nr 3, cmd response 0x900, card status 0 x0
- [ 12.196657] blk_update_request: I/O error, dev mmcblk0, sector 8588
- [ 12.207784] Starting init: /sbin/init exists but couldn't execute it (error -5)
- [ 12.228465] mmcblk0: error -84 transferring data, sector 8583, nr 8, cmd response 0x900, card status 0 x0
- [ 12.367485] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 12.467854] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 12.479196] mmc0: tried to reset card
- [ 12.487780] mmcblk0: error -84 transferring data, sector 8583, nr 8, cmd response 0x900, card status 0 xb00
- [ 12.497645] mmcblk0: retrying using single block read
- [ 12.507230] mmcblk0: error -84 transferring data, sector 8584, nr 7, cmd response 0x900, card status 0 x0
- [ 12.647467] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 12.748055] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 12.759152] mmc0: tried to reset card
- [ 12.767390] mmcblk0: error -84 transferring data, sector 8584, nr 7, cmd response 0x900, card status 0 x0
- [ 12.777111] blk_update_request: I/O error, dev mmcblk0, sector 8584
- [ 12.788998] mmcblk0: error -84 transferring data, sector 8587, nr 4, cmd response 0x900, card status 0 x0
- [ 12.927474] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
- [ 13.027920] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
- [ 13.039021] mmc0: tried to reset card
- [ 13.047314] mmcblk0: error -84 transferring data, sector 8587, nr 4, cmd response 0x900, card status 0 x0
- [ 13.057057] blk_update_request: I/O error, dev mmcblk0, sector 8587
- [ 13.068864] Starting init: /bin/sh exists but couldn't execute it (error -5)
- [ 13.076427] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. Se e Linux Documentation/init.txt for guidance.
- [ 13.089623] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.4.0-rc5 #1
- [ 13.095849] Hardware name: Rockchip (Device Tree)
- [ 13.100683] [<c0019854>] (unwind_backtrace) from [<c0014b0c>] (show_stack+0x20/0x24)
- [ 13.108525] [<c0014b0c>] (show_stack) from [<c02c4104>] (dump_stack+0x84/0xb8)
- [ 13.115851] [<c02c4104>] (dump_stack) from [<c0115258>] (panic+0x9c/0x210)
- [ 13.122829] [<c0115258>] (panic) from [<c075efd4>] (kernel_init+0xc8/0xf4)
- [ 13.129799] [<c075efd4>] (kernel_init) from [<c000ff50>] (ret_from_fork+0x14/0x24)
- [ 13.138154] CPU2: stopping
- [ 13.140961] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.0-rc5 #1
- [ 13.147185] Hardware name: Rockchip (Device Tree)
- [ 13.152005] [<c0019854>] (unwind_backtrace) from [<c0014b0c>] (show_stack+0x20/0x24)
- [ 13.159841] [<c0014b0c>] (show_stack) from [<c02c4104>] (dump_stack+0x84/0xb8)
- [ 13.167159] [<c02c4104>] (dump_stack) from [<c0017688>] (handle_IPI+0x150/0x318)
- [ 13.174641] [<c0017688>] (handle_IPI) from [<c0009538>] (gic_handle_irq+0x78/0x80)
- [ 13.182283] [<c0009538>] (gic_handle_irq) from [<c0015638>] (__irq_svc+0x58/0x78)
- [ 13.189808] Exception stack(0xee935f58 to 0xee935fa0)
- [ 13.194915] 5f40: 00000001 2e287000
- [ 13.203166] 5f60: 00000000 ee92e180 00000000 00000000 c0b15424 c0bb1328 0000406a 410fc0d1
- [ 13.211414] 5f80: 00000000 ee935fb4 ee935f78 ee935fa8 c007ba80 c0010a28 20000013 ffffffff
- [ 13.219675] [<c0015638>] (__irq_svc) from [<c0010a28>] (arch_cpu_idle+0x40/0x4c)
- [ 13.227162] [<c0010a28>] (arch_cpu_idle) from [<c0072ab0>] (default_idle_call+0x3c/0x40)
- [ 13.235334] [<c0072ab0>] (default_idle_call) from [<c0072d80>] (cpu_startup_entry+0x26c/0x3f4)
- [ 13.244025] [<c0072d80>] (cpu_startup_entry) from [<c00172c4>] (secondary_start_kernel+0x150/0x174)
- [ 13.253138] [<c00172c4>] (secondary_start_kernel) from [<000095cc>] (0x95cc)
- [ 13.260244] CPU0: stopping
- [ 13.263049] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.0-rc5 #1
- [ 13.269277] Hardware name: Rockchip (Device Tree)
- [ 13.274101] [<c0019854>] (unwind_backtrace) from [<c0014b0c>] (show_stack+0x20/0x24)
- [ 13.281937] [<c0014b0c>] (show_stack) from [<c02c4104>] (dump_stack+0x84/0xb8)
- [ 13.289252] [<c02c4104>] (dump_stack) from [<c0017688>] (handle_IPI+0x150/0x318)
- [ 13.296732] [<c0017688>] (handle_IPI) from [<c0009538>] (gic_handle_irq+0x78/0x80)
- [ 13.304372] [<c0009538>] (gic_handle_irq) from [<c0015638>] (__irq_svc+0x58/0x78)
- [ 13.311895] Exception stack(0xc0b1df08 to 0xc0b1df50)
- [ 13.317018] df00: 00000001 2e26b000 00000000 c0b235f8 00000000 00000000
- [ 13.325270] df20: c0b15424 c0b1e580 eedbacc0 c0adea48 00000000 c0b1df64 c0b1df28 c0b1df58
- [ 13.333501] df40: c007ba80 c0010a28 20000013 ffffffff
- [ 13.338640] [<c0015638>] (__irq_svc) from [<c0010a28>] (arch_cpu_idle+0x40/0x4c)
- [ 13.346125] [<c0010a28>] (arch_cpu_idle) from [<c0072ab0>] (default_idle_call+0x3c/0x40)
- [ 13.354300] [<c0072ab0>] (default_idle_call) from [<c0072d80>] (cpu_startup_entry+0x26c/0x3f4)
- [ 13.362996] [<c0072d80>] (cpu_startup_entry) from [<c075eed4>] (rest_init+0x164/0x19c)
- [ 13.371001] [<c075eed4>] (rest_init) from [<c0a91d08>] (start_kernel+0x39c/0x40c)
- [ 13.378545] CPU1: stopping
- [ 13.381353] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.0-rc5 #1
- [ 13.387580] Hardware name: Rockchip (Device Tree)
- [ 13.392406] [<c0019854>] (unwind_backtrace) from [<c0014b0c>] (show_stack+0x20/0x24)
- [ 13.400244] [<c0014b0c>] (show_stack) from [<c02c4104>] (dump_stack+0x84/0xb8)
- [ 13.407561] [<c02c4104>] (dump_stack) from [<c0017688>] (handle_IPI+0x150/0x318)
- [ 13.415041] [<c0017688>] (handle_IPI) from [<c0009538>] (gic_handle_irq+0x78/0x80)
- [ 13.422685] [<c0009538>] (gic_handle_irq) from [<c0015638>] (__irq_svc+0x58/0x78)
- [ 13.430212] Exception stack(0xee931f58 to 0xee931fa0)
- [ 13.435324] 1f40: 00000001 2e279000
- [ 13.443576] 1f60: 00000000 ee92ee80 00000000 00000000 c0b15424 c0bb1328 0000406a 410fc0d1
- [ 13.451827] 1f80: 00000000 ee931fb4 ee931f78 ee931fa8 c007ba80 c0010a28 20000013 ffffffff
- [ 13.460088] [<c0015638>] (__irq_svc) from [<c0010a28>] (arch_cpu_idle+0x40/0x4c)
- [ 13.467574] [<c0010a28>] (arch_cpu_idle) from [<c0072ab0>] (default_idle_call+0x3c/0x40)
- [ 13.475752] [<c0072ab0>] (default_idle_call) from [<c0072d80>] (cpu_startup_entry+0x26c/0x3f4)
- [ 13.484447] [<c0072d80>] (cpu_startup_entry) from [<c00172c4>] (secondary_start_kernel+0x150/0x174)
- [ 13.493565] [<c00172c4>] (secondary_start_kernel) from [<000095cc>] (0x95cc)
- [ 13.500963] ---[ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.</font>
Copy the code
Any suggestions on what might be wrong here? I've tried several things, but can't seem to get a working image to boot with.
Thanks in advance for any help!!
