[Linux] RK3308 upgrade_tool linux error
17
【Linux】 RK3308 upgrade_tool linux error
Posted at 11/18/2020 15:56:34      View:4306 | Replies:1        Print      Only Author   [Copy Link] 1#
Hello ,
I am using ubuntu OS.
I  downloaded the upgrade_tool for linux.
When I run "sudo: upgrade_tool: command not found" this command , system give the error that "command not found"
Posted at 11/19/2020 19:14:08        Only Author  2#
Hi,UmutBayut
1.What is the version of your Ubuntu OS
2.Have you changed environment variables? such as PATH, and could this command show anything in your Ubuntu OS
  1. zyk@zyk-pc:~/work/linux-upgrade/Linux_Upgrade_Tool$ /usr/local/bin/upgrade_tool -v
  2. Program Data in /home/zyk/.config/upgrade_tool
  3. Upgrade Tool v1.38
  4. zyk@zyk-pc:~/work/linux-upgrade/Linux_Upgrade_Tool$
  5. zyk@zyk-pc:~/work/linux-upgrade/Linux_Upgrade_Tool$ echo $PATH
  6. /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Copy the code
