[Android] How to install Google App for rk3399
28
【Android】 How to install Google App for rk3399
Posted at 1/12/2021 02:17:56      View:4320 | Replies:3        Print      Only Author   [Copy Link] 1#
Hello
How to install Google App for rk3399?
Posted at 1/12/2021 02:31:10        Only Author  2#
android 7.12
Posted at 2/21/2021 17:41:14        Only Author  3#
Install Google Play Store on Android 8.1.0
After trying all sorts of methods to get google play store on ROC-RK3399-PC, I finally found a method that works!
Required: Working ADB
Download playstore files for Android 8.1.0 and Device_ID.apk from here: https://mega.nz/#F!AQFWHQRb!CtZaS3cU0PCzTELrHZRrUg
Tested on this image: sd_ROC-RK3399-PC_Android8.1.0_DEFAULT_181025.img
On ROC-RK3399-PC, launch Settings -> System -> About tablet
Tab on Build number 7 times to activate Developer mode
Settings -> System -> Developer options
Turn on Root access for ADB
Turn on USB debugging
Turn on ADB over network (Note the IP)
On your PC with working ADB, extract the contents of the playstore_files.zip into a directory
Save Device_ID.apk into the same directory
Open a shell with root/admin privileges
adb connect <IP of the device from Debugging section earlier>
adb root
adb remount
adb push playstore.apk /system/priv-app/
adb push playservices.apk /system/priv-app/
adb push gsf.apk /system/priv-app/
adb install -r gsf.apk
adb install -r playservices.apk
adb install -r playstore.apk
adb install Device_ID.apk
adb push libAppDataSearch.so /system/lib/
adb push libconscrypt_gmscore_jni.so /system/lib/
adb push libgcastv2_base.so /system/lib/
adb push libgcastv2_support.so /system/lib/
adb push libgmscore.so /system/lib/
adb push libgoogle-ocrclient-v3.so /system/lib/
adb push libjgcastservice.so /system/lib/
adb push libjingle_peerconnection_so.so /system/lib/
adb push libleveldbjni.so /system/lib/
adb push libnative.so /system/lib/
adb push libsslwrapper_jni.so /system/lib/
adb push libvcdiffjni.so /system/lib/
adb push libwearable-selector.so /system/lib/
adb push libWhisper.so /system/lib/
Reboot ROC-RK3399-PC
Launch Settings -> Apps and give all the permissions to the 3 apks we installed
Reconnect via ADB again and enter the commands below to prevent occasional Google Play Services errors:
adb shell
pm grant com.google.android.gms android.permission.ACCESS_COARSE_LOCATION
pm grant com.google.android.gms android.permission.ACCESS_FINE_LOCATION
Reboot ROC-RK3399-PC again
Launch Device ID and note the GSF ID
Log into https://www.google.com/android/uncertified/ and register the GSF ID to your account
Turn off Root access for ADB
Turn off ADB over network
Turn off USB debugging
It is not perfect... some apps will launch sideways and I still get pesky uncertified warnings even after I registered the GSF ID. Also GSF ID changes every time you flash and reinstall again so be sure to register every time. At least I could log into Play Store and download purchased apps. Hope this helps!
Checked on Firefly-RK3399 and ROC-RK3399-PC.
Posted at 3/1/2021 21:32:40        Only Author  4#
You could also consider the alternative : microg.org
