Poor WiFi Performance
175
Posted at 2/5/2015 16:09:04        Only Author  1#
I'm currently running Ubuntu 14.04 and have Firefly connected to my home network via 802.11n (2.4Ghz).
With "Firefly-RK3288_Server_Ubuntu14.04_201501271052" I'm seeing 300 kB/s - 1 MB/s.
Other devices in the same room get fairly good bandwidth and reception whereas I'm seeing about 1 MB/s with Firefly. I've also noticed poor WiFi performance in Android as well with the "Firefly-RK3288_Android4.4_201501271047.img".
Here's iwconfig. I turned off power management and the signal seems strong.
  1. wlan0     IEEE 802.11  ESSID:"ESSID"
  2.           Mode:Master  Frequency:2.437 GHz  Access Point: XX:XX:XX:XX:XX:XX
  3.           Bit Rate:39 Mb/s   Tx-Power:32 dBm
  4.           Retry min limit:7   RTS thr:off   Fragment thr:off
  5.           Encryption key:off
  6.           Power Managementmode:off
  7.           Link Quality=4/5  Signal level=-67 dBm  Noise level=-92 dBm
  8.           Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
  9.           Tx excessive retries:0  Invalid misc:0   Missed beacon:0
Copy the code
Using the "Firefly-RK3288_Ubuntu14.04_201501271612.img" image:
  2.           Mode:Master  Frequency:2.437 GHz  Access Point: XX:XX:XXX:XX:XX:XX
  3.           Bit Rate:72 Mb/s   Tx-Power:32 dBm
  6.           Power Management:off
  7.           Link Quality=5/5  Signal level=-57 dBm  Noise level=-91 dBm
Copy the code
Speed test:
On a Macbook Pro in the same room:
I will test with the latest Android image and update again.
Posted at 1/14/2026 20:28:22        Only Author  2#
I feel much more knowledgeable after reading it. The H11-861_V4.0 detailed study dumps resources are free and very helpful.
Posted at 1/17/2026 01:18:24        Only Author  3#
What a powerful piece, thank you for sharing this inspiring article! Free New C_SEC_2405 exam tutorial test papers for everyone—promotions and salary raises await!
