New Topic
How to change the boot logo
175
Posted at 2/9/2015 03:20:01        Only Author  1#
Hello,
Is there a way to change the first screen logo ? I mean when I switch the card on the Firefly logo is displayed. I want to change that.
Please let me know if it is possible and how to change it ?
Regards
Posted at 2/9/2015 03:37:33        Only Author  2#
Re: How to change the boot logo
You have to compile your own kernel with a different logo or without to skip the logo.
Posted at 2/9/2015 05:34:40        Only Author  3#
Thank you for the reply, do you know where I can find the steps? my only change will be the logo and nothing else.
Posted at 2/9/2015 10:41:54        Only Author  4#
i am not sure which logo you really want to change , i guess change "logo_linux_clut224.ppm" this file may be your choice .
kernel/drivers/video/logo/logo_linux_clut224.ppm
Posted at 2/9/2015 17:13:38        Only Author  5#
I wish to change the Firefly screen that appears upon switching on the board.
Posted at 2/9/2015 23:31:40        Only Author  6#
Answer is above.
Make sure in kernel menuconfig that logo file mentioned is used.
Can use most Linux picture editors to make your own ppm file logo.
http://wiki.t-firefly.com/index.php/Fir ... _kernel/en
Posted at 2/10/2015 07:11:05        Only Author  7#
Thank you for the reply.
I am at the point where I need to mount the resource.img as the boot picture is supposed to be there according to the following link: http://wiki.t-firefly.com/index.php/Fir ... t_Firmware
Unfortunately I am getting an error when executing the following command : sudo mount -o loop resource.img /mnt/resource
Mount: wrong fs type, bad option, bad superblock on /dev/loop1, missing codepage or helper program, or other error.
The same command works fine should I do it for system.img
The question is what command should I use to mount the resource.img so that I can access it ?
Thank you
Posted at 2/10/2015 11:07:22        Only Author  8#
You can't mount resource.img, not possible.
You can only extract the dtb file from resource.img, but won't help you since it is also already in the firefly kernel's boot directory.
The logo is inside the kernel, have to compile a new kernel.
Posted at 2/11/2015 02:30:48        Only Author  9#
Got that, thank you. I followed the steps in that link. the only place I was able to see pictures is the rockchip-mkbootimg/firefly-rk3288-kernel/drivers/video/logo however I was not able to see the boot screen image of firefly. do I need to look somewhere else ?
Posted at 1/9/2026 05:40:32        Only Author  10#
認証を取得するのは給料を高める重要なものです。Data-Driven-Decision-Making試験に参加する人にとって、Data-Driven-Decision-Making試験を心配する必要がありません。最新の問題集を入手したら、Data-Driven-Decision-Making試験に順調に合格することができます。この問題集はPDF版、ソフト版とオンライン版を含めています。Data-Driven-Decision-Making試験のすべての領域を全面的に含めています。
Return to List
12
