New Topic
Mali kernel driver TX011-SW-99002-r5p1-00rel0 for firefly
38
Posted at 3/3/2015 18:02:07        Only Author  11#
Re: Mali kernel driver TX011-SW-99002-r5p1-00rel0 for firefly
  >>Error: eglGetError(): 12289 (0x3001)
  >>Error: Failed to initialize EGL at ../../../../samples/opengles_30/skybox/EGLRuntime.cpp:243
try execute this command:
  1. sudo chmod 777 /dev/mali0
Copy the code
Posted at 3/3/2015 18:03:20        Only Author  12#
Getting some errors:
You should run the demo with 32 bits framebuffer. And as Ava mentions, make sure you have permission on /dev/mali and /dev/fb0.
Try to run the demo in root user.
Posted at 3/4/2015 05:53:14        Only Author  13#
thanks, right now there is no /dev/mali
mali_kbase is loaded and the fbdev drivers are present in /usr/lib/fbdev/
how can I debug this?
Posted at 3/4/2015 09:37:01        Only Author  14#
Posted at 3/4/2015 10:54:17        Only Author  15#
        Can anyone here serve with ready-to go images so I don't need to rebuild that stuff?
        And did anyone try the result with the Mali Opencl Sdk?
Posted at 3/4/2015 14:17:43        Only Author  16#
I want to share the img to you ,but i don't know how to pack my system for img.
I have look the wiki page:
http://wiki.t-firefly.com/index.php/Fir ... irmware/en
but it only metion how to mount a rootfs and modify some files, then pack the img.
the actuality is i should install some software  in rootfs .if you can share some method for package i'll share my rootfs.
or in another method ,i share my kernel.img and you could update the kernel ,then you should only do :
download: http://pan.baidu.com/s/1kT1MQpD
0.update the boot.img and resource.img
1.copy the mali user space driver *.so in /usr/lib
2.copy the example sdk application in rootfs
3.set the 32bit framebuffer
then you could test the framebuffer mali gpu test .
Posted at 3/4/2015 18:20:04        Only Author  17#
Do:
# lsmod
mali_kbase module should be listed.
And
# ls /dev/mali0
mali0 should be presented. If not, check the kernel log by:
# dmesg
Posted at 3/4/2015 18:21:15        Only Author  18#
Examples in Opencl sdk have been tested. All are running fine.
Posted at 3/4/2015 18:30:28        Only Author  19#
its all working here now. Not tried the OpenCL demos yet.
Posted at 3/4/2015 23:53:50        Only Author  20#
The Mali SDK demos are working well here.
I guess the next step is to get xf86-video-fbturbo working
Return to List
12345
