Why am I getting AdbCommandRejectedException getting properties for device ?????
13
Posted at 3/7/2015 11:41:42        Only Author  1#
Hello:
I'm attempting to install a simple test app on the RK3288, thus far without success.
When attempting to debug the app Android Studio, a line is displayed in the AS console window stating it is "waiting on device."
In the terminal window used to start adb server, the following line is displayed multiple times:
AdbCommandRejectedException getting properties for device ????????????
From the same terminal window, "adb devices" returns this:
List of devices attached
????????????        no permissions
Can someone help me understand why this is happening?
Fwiw, my environment is Ubuntu 14.04.2 64-bit, Android Studio 1.1.0
Thank you.
Posted at 3/7/2015 15:45:26        Only Author  2#
Re: Why am I getting AdbCommandRejectedException getting properties for device ?
you need to add udev rules or a usb.ini file from lsusb
Posted at 3/9/2015 03:11:55        Only Author  3#
Thank you for the response.
Itwas my understanding that udev rules had been set up already according to the instructions on the wiki page "ADB Usage" -> "ADB Installation under Ubuntu":
http://wiki.t-firefly.com/index.php/Fir ... der_Ubuntu
Find below what I did according to that page. Are you saying that I need to do something different? Are these instructions for the RK3288 under Ubuntu incorrect or missing something?
Add device identity:
mkdir -p ~/.android
vi ~/.android/adb_usb.ini
# append following line
0x2207
Add udev rule:
sudo vi /etc/udev/rules.d/51-android.rules
# append following line:
SUBSYSTEM=="usb", ATTR{idVendor}=="2207", MODE="0666"
plug the USB OTG cable out, then plug in, or run the following
commands, to make udev rule take effect:
sudo udevadm control --reload-rules
sudo udevadm trigger
Posted at 3/9/2015 10:37:04        Only Author  4#
So copy the adb to /usr/bin for convenience.
Do:
sudo adb kill-server
sudo adb shell
To see if you can get a shell of the device.
This is to confirm if permission is the root cause of your problem.
Posted at 3/13/2015 05:02:56        Only Author  5#
busybee:
I did as you suggested above, am still running into the same problem attempting to connect to adb over usb.
However,  I can connect to adb over ethernet.  So...I have serial-over-usb debug console, usb OTG  for flashing, and ethernet for adb - with that combination everything is working to the extent needed.
Will update this thread when (or if) I finally resolve the adb-over-usb problem.
