Google Widevine DRM on Android
543
Posted at 3/9/2015 12:01:59
In SDK I change device/rockchip/rksdk/BoardConfig.mk BUILD_WITH_DRMSERVICE :=true
Then build new firmware.
Then it says edit out/target/product/rk30sdk/system/build.prop  ro.product.manufacturer & ro.product.model but not sure what to change it to.
Then you have to build update.img with kernel inside boot.
Then I use Rockchip Secure Boot Tool to generate private & public key and check 'Sign check key'
Then I click 'sign firmware' and it generates a new update.img
I then flash the new update.img.
https://bitbucket.org/T-Firefly/firefly ... ol/?at=pad
Then I use 'UpgradeDllTool_Release_v1.3' to lock device with setting at the bottom. But don't think it locked correctly.
But I still can't play Google Widevine DRM streams.
Any help would be appreciated.
Posted at 8/27/2015 06:41:31
Did you rebuild uboot to enable SecureBootEn and SecureBootLock
In Serial Console:
U-Boot 2014.10-RK3288-02 (Jan 21 2015 - 17:07:53)
SecureBootEn = 0, SecureBootLock = 0
They should both be set to 1
