Firefly-RK3288 Slackware Arm
1175
vip
Rank: 6Rank: 6
Posted at 5/1/2016 03:07:52        Only Author  51#
donation   slarm64
Posted at 5/1/2016 10:50:42        Only Author  52#
I'll post some results once I've installed the dependencies for glmark2
vip
Rank: 6Rank: 6
Posted at 5/1/2016 18:56:18        Only Author  53#
test glmark2 [   574.822] (II) FBDEV: driver for framebuffer: fbdev
http://p.fail.pp.ua/Wo5SWr6Y
very bad performance
using armsoc performance worse
donation   slarm64
Posted at 5/17/2016 04:10:04        Only Author  54#
hi mara,
are you using opengl for mali-t760 from arm?
  1.     OpenGL Information
  2.     GL_VENDOR:     ARM
  3.     GL_RENDERER:   Mali-T760
  4.     GL_VERSION:    OpenGL ES 3.1 v1.r6p0-02rel0.4b8779afaaaf01b0c5ec7bfb4419c6ab
Copy the code
i've got same kernel with ubuntu 16.04 using armsoc and get score 9 for glmark2-es. so about 10 fps...
still way too slow especially as it is only a window and not full-screen/1080p...
see my results: http://p.fail.pp.ua/Xf7AVg5I
vip
Rank: 6Rank: 6
Posted at 5/18/2016 04:24:44        Only Author  55#
hi mac-l1,
yes I have enabled library Mesa, but the results will not differ think.
later again to do the test.
donation   slarm64
Posted at 6/12/2016 04:22:30        Only Author  56#
i have a firefly rk3288 reloaded, and wanted to use your "next" type of images (the main line kernel)
first i tried flashing it to SD card, but the board did not boot at all
then i also tried flashing it directly to the board, but it always failed to flash the bootloader, leaving my board half-bricked... :-/
  1. ./flash.sh -r
  2. ------ unpack tools
  3. ------ flash boot loader
  4. Loading loader...
  5. Loading loader failed!
  6. ------ flash parameters
  7. rkflashtool: info: rkflashtool v5.2
  8. rkflashtool: info: Detected RK3288...
  9. rkflashtool: info: interface claimed
  10. rkflashtool: info: writing flash memory at offset 0x00001c00... Done!
  11. ------ flash kernel
  12. rkflashtool: info: rkflashtool v5.2
  13. rkflashtool: info: Detected RK3288...
  14. rkflashtool: info: interface claimed
  15. rkflashtool: info: working with partition: kernel
  16. rkflashtool: info: found offset: 0x00002000
  17. rkflashtool: info: found size: 0x00008000
  18. rkflashtool: info: writing flash memory at offset 0x000060a0... Done!
  19. rkflashtool: info: premature end-of-file reached.
  20. ------ flash boot
  21. rkflashtool: info: rkflashtool v5.2
  22. rkflashtool: info: Detected RK3288...
  23. rkflashtool: info: interface claimed
  24. rkflashtool: info: working with partition: boot
  25. rkflashtool: info: found offset: 0x0000a000
  26. rkflashtool: info: found size: 0x00008000
  27. rkflashtool: info: writing flash memory at offset 0x0000a720... Done!
  28. rkflashtool: info: premature end-of-file reached.
  29. ------ flash linuxroot slack-current-miniroot_07Apr16-4.6.0-rc1-firefly-build-20160502.img
  30. rkflashtool: info: rkflashtool v5.2
  31. rkflashtool: info: Detected RK3288...
  32. rkflashtool: info: interface claimed
  33. rkflashtool: info: working with partition: linuxroot
  34. rkflashtool: info: found offset: 0x00012000
  35. rkflashtool: info: partition extends up to the end of NAND (size: 0x01d0d000).
  36. rkflashtool: info: writing flash memory at offset 0x0013c800... Done!
  37. rkflashtool: info: premature end-of-file reached.
  38. ------ reboot device
  39. rkflashtool: info: rkflashtool v5.2
  40. rkflashtool: info: Detected RK3288...
  41. rkflashtool: info: interface claimed
  42. rkflashtool: info: rebooting device...
Copy the code
is it because the bootloader differs for the reloaded and the simple rk3288?
vip
Rank: 6Rank: 6
Posted at 6/13/2016 00:20:19        Only Author  57#
for unbrick to fleshing the official firmware and bootloader
this firmware is working properly with the sd card to record eMMC after loading has migration script on eMMC
bootloader can not fleshing on eMMC
ideas for these two boards are not very different and must be loaded on both
donation   slarm64
vip
Rank: 6Rank: 6
Posted at 6/19/2016 15:59:51        Only Author  58#
hi mac-l1
bad news,
in slackware You can not use the binary driver, the reason is that they are collected as a hard float. slackware collected as a soft float, for drivers need to add multilib packages
donation   slarm64
vip
Rank: 6Rank: 6
Posted at 9/10/2016 18:58:53        Only Author  59#
Slackware ARM -current and onwards is now a hard float OS!
add support legacy kernel 3.14
info:
http://fail.pp.ua/board/2
donation   slarm64
super moderator
Rank: 8Rank: 8
Posted at 9/12/2016 10:14:09        Only Author  60#
nice work ,great!
