can not power up SDA7123
67
Posted at 4/25/2015 16:11:09      View:3442 | Replies:2        Print      Only Author   [Copy Link] 1#
I  want to work VGA output.
HSYNC/VSYNC is working.
But Color-Signal not working.
I check SDA7123(LCD to VGA).
PSAVE signal is 1.1V. (not 3.3V)
I tryed.
PMUGPIO0_c1 is enabled.
GOIO0_C1 set to '1'.
How do I ?
Posted at 4/25/2015 21:58:10        Only Author  2#
Additional,
I was done following.
CRU_CLKSEL27_CON  <= 0xff008000   /* LCDC clock prescale */
/* following is written on VOP manual(IO_MUX setting). */
GRF_GPIO1D_IOMUX  <= 0x00550055
GRF_GPIO1H_SR     <= 0x0f000f00
GRF_GPIO1D_E      <= 0x00ff00ff
GRF_SOC_CON6      <= 0x00080000
GRF_SOC_CON7      <= 0x1fff1840
/* for LVDS (for LCDC) */
lvds+0x00*4       <= 0x7f
lvds+0x01*4       <= 0x40
lvds+0x02*4       <= 0x00
lvds+0x03*4       <= 0x46
lvds+0x04*4       <= 0x3f
lvds+0x05*4       <= 0x3f
lvds+0x0d*4       <= 0x0a
lvds+0x40*4       <= 0x7f
lvds+0x41*4       <= 0x40
lvds+0x42*4       <= 0x00
lvds+0x43*4       <= 0x46
lvds+0x44*4       <= 0x3f
lvds+0x45*4       <= 0x3f
lvds+0x4d*4       <= 0x0a
/* this is setting for SDA7123 PSAVE pin */
PMU_GPIO0_C_PULL  <= 0x3ff
PMU_GPIO0_C_DRV   <= 0x3f
PMU_GPIO0_C_IOMUX <= 0x00000000
/* following is VOP manual (RGBsetting) */
VOP_SYS_CTRL      <= VOP_SYS_CTRL | (0x01u<<21)  /* VOP DMA on */
/* following is default setting (may be MCGA) */
VOP_DSP_HTOTAL_HS_END
VOP_DSP_HACT_ST_END
VOP_DSP_VTOTAL_HS_END
VOP_DSP_VACT_ST_END
VOP_DSP_VS_ST_END_F1
VOP_DSP_VACT_ST_END_F1
VOP_DSP_BG<= (0xff<<20)|(0x3f<<10)|(0xf)  /* background color */
VOP_REG_CFG_DONE<= 0x01 /* DONE!! */
Posted at 4/26/2015 16:32:18        Only Author  3#
I was resolved myself.
I did not set GPIO direction and GPIO output.
I did miss-coding.
(And little mistake)
I was modified my-code,  VGA-output OK!!
